FORScan: Advanced Diagnostics and Coding for Ford, Mazda, Lincoln, Mercury
CURRENT VERSIONS:
* FORScan 2.3.62 for Windows
* FORScan 1.5.1 & 1.5.30 for Android
FORScan is a powerful software scanner designed specifically for Ford, Mazda, Lincoln, and Mercury vehicles. It works seamlessly with OBD2-RS232 adapters such as ELM327, OBDLink, ELS27, and devices compatible with J2534 Pass-Thru. Unlike standard OBD2 scanners, FORScan provides manufacturer-level access to all modules, allowing you to read/clear proprietary DTCs, run service tests, and perform module coding.
SUPPORTED VEHICLES:
* Ford (1996 - Current): Focus, Mondeo/Fusion, Fiesta, Kuga/Escape, Explorer, F-Series (F-150, F-250, etc.), Transit/Tourneo, Mustang, Ranger, Edge, EcoSport, Puma, S-MAX, Galaxy, Bronco, Expedition, C-MAX.
* Mazda (1996 - Current): Mazda 2, Mazda 3, Mazda 6, CX-3, CX-30, CX-5, CX-7, CX-9, MX-5 (Miata), RX-8, BT-50, Tribute.
* Lincoln (1996 - Current): Navigator, Aviator, Corsair, Nautilus, MKC, MKT, MKX, MKZ, Continental, Town Car, LS.
* Mercury (1996 - 2011): Grand Marquis, Mountaineer, Mariner, Milan, Sable, Cougar, Villager.
KEY FEATURES:
* Read and reset Diagnostic Trouble Codes (DTC) from all modules (Engine, ABS, Airbag, Climate, etc.)
* Display live data stream and sensor parameters in real-time
* Run diagnostic tests and service procedures (DPF regeneration, PATS programming, ABS bleeding, etc.)
* Module configuration, adaptations, and AS-BUILT data modification
LICENSE & ACTIVATION:
The package includes all necessary links from the official website + detailed instructions on how to make a 2-month trial Extended License Key for the Windows version.
Note: After the free trial period ends, you will need to purchase a license or register again using a different email address.
CURRENT VERSIONS:
SUPPORTED VEHICLES:
KEY FEATURES:
