aleksey-ms
171
161
43
Ukraine
vc2.motorstate.com.ua
Files inside:
BMW E-Sys 3.27
Premium Launcher
PSdZdata 63 Lite
Windows 7 x64 English VMware
1. BMW E-Sys 3.27
This is a stable "engineering" version of the software for BMW F, G, and I-series vehicles. It is used for:
- Function coding (activating hidden options);
- Editing trim levels (FA/VO);
- Programming (flashing) electronic control units.
2. E-Sys Launcher Premium (by TokenMaster)
E-Sys itself is closed for editing critical data.
The launcher performs two main tasks:
- Token generation (.EST): Allows the "FDL Coding" function
(changing individual parameters within the unit). Without this, you can only
change the entire trim level, not individual settings.
- Un-trimming (Mapping): In newer databases, BMW removes function names,
leaving periods or empty strings. The launcher replaces this data,
returning human-readable names (for example, instead of "3001 > .."
you see "3001 > Speed_Limit").
3. Differences in PSdZdata Databases
PSdZdata contains firmware and module descriptions that are "inserted"
into E-Sys for vehicle operation.
PSdZdata LITE:
- Purpose: Exclusively CODING (hidden functions, settings).
- SWFL files: None (cut to save space).
- Disk space: ~5-15 GB.
- Pros: Takes up little space, downloads and installs quickly.
PSdZdata FULL:
- Purpose: PROGRAMMING (firmware) + coding.
- SWFL files: Included in full.
- Disk space: ~150-350 GB.
- Pros: Allows you to fully update your vehicle's software and restore control units.
* SWFL (Software Files) are large firmware files required for updating control unit software.
4. Which one to choose?
- If you're a beginner and just want to activate functions (start-stop, logos, videos): download the LITE version.
- If you plan to update your vehicle's firmware or replace the hardware with used equipment: you need the FULL version.
