aleksey-ms
142
153
43
Ukraine
vc2.motorstate.com.ua
Iveco EASY (Electronic Advanced System): Dealer Diagnostics for Astra Trucks & Buses
AVAILABLE VERSIONS:
* 16.1
* 18.1
* 18.1 VMware
WHAT INSIDE:
* Installation files / VMware images for Iveco E.A.SY (Electronic Advanced SYstem)
* Coverage for Heavy Duty Astra trucks and Iveco Bus lineups
* Diagnostic protocols for engine, transmission, braking (ABS/EBS), and body modules
1. MAIN FUNCTIONS AND CONTENT
DEALER-LEVEL DIAGNOSTICS & PROGRAMMING
* Active ECU Diagnostics – read and clear diagnostic trouble codes (DTC), display live data parameters.
* ECU Parameter Programming – engine calibration, speed limit adjustments, key programming.
* Actuator & Engine Tests – cylinder cut-off tests, compression tests, VGT turbo calibration.
* Interactive Wiring Diagrams – view electrical schematics and connector pinouts organized by vehicle symptom.
MODEL COVERAGE
* Heavy Duty & Special Vehicles: Astra (HD7, HD8, HD9, HHD series).
* Trucks: Daily, EuroCargo, Stralis (Hi-Way, X-Way), S-Way, T-Way, Trakker, EuroStar, EuroTech.
* Buses & Coaches: Urbanway, Crossway, Crealis, Magelys, Evadys, Domino, Arway, Minibus series.
2. PACK FEATURES
HEAVY DUTY & BUS SPECIALIZATION
* Provides specialized access to Astra heavy construction trucks and Iveco passenger bus platforms.
* Guided troubleshooting by symptom to assist technicians in resolving complex faults.
Iveco E.A.SY (Electronic Advanced SYstem) is the official dealer diagnostic software designed to perform full troubleshooting, parameter programming, and component testing on Iveco trucks, Astra heavy vehicles, and buses using the ECI communication module.
  • Iveco_EASY_new.txt
