Doorman
Vip Member
Jul 13, 2021
90
85
Viet Nam
api.whatsapp.com
If you download this document, you will be lost 11950 Beer
Hino DX3 v1.23.7 (07.2023) [With Keygen]
1. Descriptions:
Hino Diagnostics Explorer DX III is a diagnostic software designed for Hino Trucks. It allows users to perform diagnostic tests and troubleshoot issues on Hino vehicles. The software is typically used by mechanics and technicians who work on Hino trucks.
2. Software Informations:
  • + Name: Hino DX3
  • + Size: 541 MB
  • + Version: v1.23.7 [07.2023]
  • + Language: English, Japanese, Chinese, Spanish, Thai, Russian, French, Indonesian, Vietnamese
  • + Available Regions: DEF, JPN, USA, CAN, AUS, CHN, ESP, NZL, COL, CHL, HKG, TWN, GBR, IRL, SGP, THA
3. Software Functions:
Troubleshoot:​
  • + Reading DTCs (Diagnostic Trouble Codes)
  • + Diagnostic and Troubleshooting workflow
  • + Check and Activation Tests for engine components
  • + Data Monitor function for recording engine/system operation
Customization​
  • + Configure user specific features such as
  • + Idle Shutdown
  • + PTO settings
  • + Vehicle/Cruise Speed settings
  • + Engine Protection settings
  • + Maintenance Intervals
  • + System Protection data reset
  • + Special Learning for new eng
  • + Etc…
Setting​
  • + Print setting
  • + Communication/Interface setting
  • + Language setting
  • + Unit setting
  • + View setting
Past Work Information​
  • + DTC reports
  • + Vehicle Information reports
  • + Diagnostic
4. System Requirements:
  • + Ram: 4 GB
  • + Free hard drive: 15 GB
  • + Windows® 7 32-bit and 64-bit
  • + Windows® 8.1 32-bit and 64-bit
  • + Windows® 10 32-bit and 64-bit
  • + Windows® 11 32-bit and 64-bit
5. Supported Hardwares:
  • + Nexiq USB link (Version 1 or 2)
  • + DPA5
  • + Noregon DLA
  • + And some other RP1210 devices
6. Replace
Ver.1.23.7
- Updated the database.
- Fixed some bugs.
- Implemented a function conforming to "Past work information" of Hino DXII.
Follow the steps below to check.
HOME screen - Special working - Past work information list
- Since the repro work after replacing the supply engine is different for the ECU direct engine and the non-direct engine, the explanation of each work content is described in the "Notes" column.
  • SoHiHiX160123.txt
