BMW i8 2015-2018 Owners Manual​
Brand: BMW
File Size: 12.4 MB
Manual Type: Owners Manual
Model: BMW i8
Date Model: 2015-2018
Number of Pages: 224 Pages
At a glance
Cockpit
Vehicle features and options
All around the steering wheel
All around the center console
All around the roofliner
iDrive
The concept
Control elements at a glance
Operating concept
Touchpad
Example: setting the clock
Status information
Split screen
Programmable memory buttons
Deleting personal in the vehicle
Entering letters and numbers
Voice activation system
The concept
Requirements
Using voice activation
Possible commands
One example: open the tone settings
Setting the voice dialog
Adjusting the volume
Hints on Emergency Requests
Environmental conditions
Integrated Owner's Manual in the vehicle
BMW eDRIVE
BMW eDRIVE
Safety of the high-voltage system
Controls
Opening and closing
Remote control/key
Personal Profile
LED in the driver's door
Using the remote control
Without remote control
Hood
Tailgate
Comfort Access
Adjusting
Alarm system
Power windows
Adjusting
Sitting safely
Seats
Safety belts
Front head restraints
Mirrors
Steering wheel
Transporting children safely
The right place for children
Installing child restraint systems
LATCH child restraint system
Driving
Start/Stop button, drive readiness
Drive readiness in detail
Electric driving: ePOWER
Driving with the combustion engine: POWER
Assistance for the combustion engine
Energy recovery: CHARGE
Parking brake
Turn signal, high beams, headlight flasher
Washer/wiper system
Washer fluid
Steptronic Sport transmission
Displays
Instrument cluster
Displays of the hybrid system
Check Control
Fuel gauge
Tachometer
Engine oil temperature
Coolant temperature
Odometer and trip odometer
External temperature
Time
Date
Range
Service requirements
Gear shift indicator
Speed limit detection
Selection lists in the instrument cluster
On-board computer
Speed warning
Settings on the Control Display
Head-up Display
Lights
Overview
Parking lights/low beams, headlight control
Variable light distribution
High-beam Assistant
Instrument lighting
Interior lights
Airbags
Tire Pressure Monitor TPM
Intelligent Safety
Front-end collision warning with City Braking function
Pedestrian warning with city braking function
Brake force display
Driving stability control systems
Antilock Brake System ABS
Brake assistant
DSC Dynamic Stability Control
DTC Dynamic Traction Control
Performance Control
Driving Dynamics Control
Drive-off assistant
Driving comfort
Cruise control
PDC Park Distance Control
Surround View
Rearview camera
Top View
Side View
Climate control
Automatic climate control
Ventilation
Stationary climate control
Interior equipment
Universal Integrated Remote Control
Sun visor
Connecting electrical devices
USB interface for data transfer
Cargo area
Storage compartments
Hints
Glove compartment
Between the front seats
Rear seat
Driving tips
Things to remember when driving
Breaking-in period
Using eDRIVE efficiently
General driving notes
Loading
Hints
Determining the load limit
Load
Stowing cargo
Increase range
General information
Remove unnecessary cargo
Remove attached parts following use
Closing the windows
Tires
Standing air conditioning
Look well ahead when driving
Use coasting
Switch off any functions that are not currently needed
Have maintenance carried out
ECO PRO
Mobility
Charging vehicle
The concept
General information
Hints
Charging cable
Manual release
Charging operation
Displays in the instrument cluster
Departure time
Climate control
Discharged high-voltage and vehicle battery
Refueling
Hints
Tank vent
Fuel lid
Observe the following when refueling
Fuel
Fuel recommendation
Wheels and tires
Tire inflation pressure
Tire identification marks
Tire tread
Tire damage
Changing wheels and tires
Mobility System
Snow chains
Engine oil
General information
Electronic oil measurement
Engine compartment access
Adding engine oil
Engine oil types to add
Engine oil change:
Coolant
Coolant level
Maintenance
BMW maintenance system
Note
Condition Based Service CBS
Service and Warranty Information Booklet for US models and Warranty and Service Guide Booklet for Canadian models
Socket for OBD Onboard Diagnosis
Replacing components
Wiper blade replacement
Lamp and bulb replacement
Changing wheels
Vehicle battery
Fuses
Breakdown assistance
Hazard warning flashers
Intelligent Emergency Request
Warning triangle
First aid kit
Jump-starting
Tow-starting and towing
What to do after an accident
Care
Car washes
Vehicle care
Reference
Technical data
Note
Dimensions
Weights
Capacities
Appendix
  • BMW i8 2015-2018 Owners Manual.txt
