Topdoor
Sweden
Hello ! Thanks for share
Please active for me Autocom 2020 . 23
System id
BxMJMIu0LRtG1hYu8wo0mh4FJF5Ns2MvUZpxoiUzNfo
a1pp4
Finland
Hello. Dear member!
Autocom Release 2020.23 Car & Truck is new version. It work best on Windows 7 Pro, Ultimate 32bit and 64 bit, Windows 10 Pro, Ultimate, Windows 11
A little about Autocom Release 2020.23:
The latest version 2020.23 fully working, without bugs, like original, , and support cars before 2021!!
For those who have not tested 2020.23 software, it's. It works only on new vci (6 digit serial like 100251 clones or any serial number)
The software comes with 1622 firmware (you will find in my thread link with firmwares till 3200), it's older firmware so that works on all clones, because many clones are 2 board/pcb and cannot use the latest 3200 firmware. older firmware does not work on newer cars (mostly 2015+ or bmw).
After you have successfully installed, please send me the System ID or FileActivation.xml. I will activate the ID for you
Guide active: Look at the picture!
Step 1: Save the file "fileActivation.xml" or copy System ID then sent on the post or send it to me via pm
Step 2: I will activate and sent for you activation code. Your job is to enter activation code in box 3 on the picture
Step 3: Click on box No. 4 (Activate)
Step 4: Wait for run software and check. Good luck!
Link:
Note: Only support maximum activation of 3 PC / 1 User Member!
Best regards !!!
Hey everyone! Cant download link? Would be possible to get download link please :)
Hamou21
France
Bonjour. Cher membre !
Autocom Release 2020.23 Car & Truck est une nouvelle version. Il fonctionne mieux sur Windows 7 Pro, Ultimate 32 bits et 64 bits, Windows 10 Pro, Ultimate, Windows 11
Un peu sur la version Autocom 2020.23 :
La dernière version 2020.23 fonctionne entièrement, sans bugs, comme l'original, et prend en charge les voitures avant 2021 !!
Pour ceux qui n’ont pas testé le logiciel 2020.23, c’est le cas. Cela fonctionne uniquement sur les nouveaux vci (série à 6 chiffres comme les clones 100251 ou n'importe quel numéro de série)
Le logiciel est livré avec le firmware 1622 (vous trouverez dans mon fil de discussion un lien avec les firmwares jusqu'à 3200), c'est un firmware plus ancien qui fonctionne donc sur tous les clones, car de nombreux clones sont à 2 cartes/pcb et ne peuvent pas utiliser le dernier firmware 3200. l'ancien firmware ne fonctionne pas sur les voitures plus récentes (principalement 2015+ ou BMW).
Une fois l'installation réussie, veuillez m'envoyer l'ID système ou FileActivation.xml. J'activerai l'identifiant pour vous
Guide actif : Regardez la photo !
Étape 1 : Enregistrez le fichier "fileActivation.xml" ou copiez l'ID système puis envoyé par la poste ou envoyez-le-moi via MP
Étape 2 : Je vais activer et vous envoyer le code d'activation. Votre travail consiste à saisir le code d'activation dans la case 3 sur l'image
Étape 3 : Cliquez sur la case n°4 (Activer)
Étape 4 : Attendez que le logiciel soit exécuté et vérifiez. Bonne chance!
Lien :
Remarque : ne prend en charge que l'activation maximale de 3 PC / 1 membre utilisateur !
Cordialement !!!
bonsoir et merci pour le partage.
andrea1130
spain
Hello. Dear member!
Link:
Best regards !!!
FvfVPg6Dk7MAhW2_e3HZsa_NneEp4i4lLTFff8T6vtw
lucas9874
Italia
Ehi,
grazie per i tuoi contributi
Questo è il mio ID di sistema, abilitalo
ID del sistema: 1urh1POV2o59ZjJWFKOwfhfMFrbutYZL3RbRmKZF-WI
