Mike Alex
25
6
3
Ho Chi Minh City, Vietnam
What happens do you change transmission fluid without change the filter?
1. What is a Transmission Filter?
A transmission filter is a screen that catches contaminants from the transmission fluid. The filter is located in the pan, or lower part of your car’s transmission.
You need to know how to change your transmission fluid without changing the filter because it could lead to problems with your vehicle and cause damage that might not be covered by the warranty.
Transmission filters are one of the most important parts of your car. They help keep your transmission clean and efficient by removing dirt, debris, and other contaminants from the fluid.
A transmission filter is a device on your vehicle that cleans the transmission fluid. It’s located in the transmission, and it works by filtering out dirt, debris, and other contaminants as reiterated earlier.
Transmission filters are usually made of either paper or synthetic materials, though some newer models use carbon fiber instead of paper. They play a big role in keeping your vehicle running in top condition.
This is because a transmission filter is designed to protect the gears, bearings, and housing from rust, dirt, and other debris that could cause damage if left unchecked.
The transmission filter should be replaced every two years or as needed based on how much driving your vehicle does.
The more you drive your car, the more mileage it has. So if you drive a lot, you should not wait till 2 years before changing the transmission filter.
It also helps to keep you safe because it catches small particles before they make their way into the engine and cause damage.
Transmission filters can be found under the hood of any vehicle with an engine. However, they’re not always visible when you look underneath your car or truck’s hood because they’re usually built into the transmission itself.
2. Can I Change My Transmission Fluid Without Changing the Filter?
Yes, you can change your vehicle’s transmission fluid without changing the filter, however, you have to be very careful while going through the process.
Before you change the transmission fluid of your vehicle, you should make sure that you have completely drained out the old transmission fluid from the transmission fluid pan.
After you have completely drained the transmission fluid from the pan, before refilling the transmission fluid pan with new transmission fluid, you should check the filter(if your car has one) for any damages.
While going through this process, the car should be in an elevated position so that you can have access to the transmission fluid pan to drain it.
3. What Happens if You Don’t Change the Transmission Filter?
The transmission filter cleans and removes dirt so when it gets clogged up with dirt and is not changed, it causes problems such as transmission problems.
When the transmission filter isn’t properly maintained, there’s a very high risk of transmission problems in your vehicle.
This is because the vehicle would be taking in all sorts of dirt and debris that’s supposed to be filtered by the transmission filter which puts it at risk.
This increased risk of transmission failure that’s caused by a dirty or clogged transmission filter can lead to reduced performance in the vehicle or even cause it to fail altogether.
Your vehicle will start experiencing a lack of smooth gear shifting.
You may notice that there is not as much control over your vehicle’s gear shifts as there was before because the fluid has lost its ability to lubricate the internal parts properly.
This means that they will wear out faster than usual or break down completely over time due to friction with other parts inside them (such as pistons).
This can also cause slippage between different gears making it difficult for drivers that are unfamiliar with this type of car and other new drivers trying out new roads without knowing how they work yet.
Filters don’t get clogged up in one day, it’s a result of the kind of fluid y have been using. If the fluid is clean and clear while you’re pouring it in, then you might have no issues with the filter for a very long period.
However, if the fluid you use is not clean and clear, you might have to check regularly and change the filter when it starts getting clogged up to avoid transmission problems.
