Volvo Skid Steer Loader MCT85C Service and Repair Manual​
Model: Volvo MCT85C Skid Steer Loader
Type of Machine: Skid Steer Loader
Type of Manual: Electrical and Hydraulic Diagrams, Service and Repair Manual
Number of Pages: 4026 Pages
1 Volvo MCT85C
Descriptions
Battery isolator
Description, complete machine
Drive motor, description
Electronic control unit (ECU), description
Fan reversing valve, description
Fault code list
Fault tracing on hydraulic system
Fuses
Gear pump, description
Hydraulic contamination
Hydraulic cylinders, description
Hydraulic service procedures
Main valve block, description
Multimeter
Operator's platform, lowering
Operator's platform, raising
Relays
Road lights, description
Rubber track, description 1
Self level valve, description
Service position 1
Throttle control
Windows, general'
Component list, Fuses 1
Component list, Relays 1
Component list, Sensors 1
Component list, Solenoid valves 1
Component list, Switches
Hydraulic diagram 1
Hydraulic diagram
Wiring diagram 1
Wiring diagram 1-1
Wiring diagram 2
Wiring diagram 2-1
Wiring diagram 3
Wiring diagram 3-1
Wiring diagram 4
Wiring diagram 4-1
Wiring diagram 5
Wiring diagram 5-1
Wiring diagram 6
Wiring diagram 6-1
Wiring diagram 7
Wiring diagram 7-1
Wiring diagram 8
Wiring diagram 9
Wiring diagram 9-1
Wiring diagram 10
Wiring diagram 10-1
Wiring diagram 11
Wiring diagram 12
Installation Instructions
A few simple safety rules
Air cleaner dust valve, changing 1
Air conditioning filters, changing 1
Alternator belt, checking
Alternator, installing
Alternator, removing
Alternator, testing
Battery isolator, checking
Battery, maintenance
Battery, replacing
Before operating
Before service, read
Boom suspension system accumulator, charging
Boom suspension system accumulator, discharging
Cab door, installing'
Cab door, removing
Charging batteries
Cleaning of the machine
Cleanliness
Compressor belt, checking
Coolant level, checking
Coolant, draining
Coolant, filling
Cooling package, installing
Cooling package, removing
Door handle, replacing
Drive chain case oil level, checking
Drive chain, installing
Drive chain, removing
Drive motor, installing
Drive motor, removing 1
Drive sprocket torque, checking
Drive sprocket, installing
Drive sprocket, removing
Engine air cleaner system integrity, checking
Engine oil filter, replacing 1
Engine oil level, checking
Engine oil, changing
Engine oil, draining
Engine oil, filling
Engine, installing 1
Engine, installing
Engine, removing 1
Front end accessory drive (FEAD) belt condition, checking
Front end accessory drive (FEAD) belt, adjusting
Front idler wheel, assembling
Front idler wheel, disassembling
Front idler wheel, installing
Front idler wheel, removing
Fuel filter element, changing
Fuel system, bleeding 1
Fuel system, bleeding 2
Fuel water separator, draining 1
Gear pump, installing
Gear pump, removing
Greasing, daily
Guide roller, assembling
Guide roller, disassembling
Guide roller, installing
Guide roller, removing
Hydraulic cylinders, checking
Hydraulic oil level, checking
Hydraulic oil tank, draining 1
Hydraulic oil tank, filling 1
Hydraulic oil tank, removing
Hydraulic oil, changing
Hydraulic pressure, testing
Hydraulic return filter, replacing
In-line fuel filter, changing
Loader arm lift cylinder, installing
Loader arm lift cylinder, removing
Loader arm, installing
Loader arm, removing
Main control valve, installing
Main control valve, removing
Rear door, installing
Rear door, removing
Rear idler wheel, assembling
Rear idler wheel, disassembling
Rear idler wheel, installing
Rear idler wheel, removing
Rubber track, inspecting
Rubber track, installing
Rubber track, removing
Rubber track, repairing
Self level valve, replacing
Service and Maintenance Introduction
Service position
Spark arrester, cleaning
Starter motor, installing
Starter motor, removing
Starter motor, testing
Stop pad, adjusting
Track frame, installing
Track frame, removing
Track tension, adjusting
Track tension, checking
Transmission pump, adjusting
Transmission pump, installing
Transmission pump, removing
Window pane, installation
Window pane, removal
yre, replacing
Bucket, not level
Cab door leak
Cab gas strut configuration
ECU trouble shooting
Improved Cab Door Sealing
Improved ignition switch
Improved lap bar
Improved top glass skylight seal
Left Hand Armrest Rotation
Loader Arm Shimming
New joystick stud with 25 angle
New Magnetic Flywheel Speed Sensor
New Skid Steer Loader models
Oil ejected from exhaust system
Optional precleaner available
Poor window adhesive
Rapid Assembly Hoses
Small platform loader and transmission setup
Tilt cylinder rod scoring
Top Window Leak
Volvo Product incidentN accident report & Interview Form
Window cracks and or breaks
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Boom suspension system (BSS) valve block, specifications 1
Charge pump, specifications 1
Coolant, specifications
Engine, specification 1
Engine, specifications 2
Fuel, lubricant and filling capacities
Fuel, specifications
Lights, specifications
Loader pump, specifications 1
Positional adapters
Push lock fittings
Quick release couplings 1
Radio, specifications 1
Radio, specifications 2
Rapid assembly fittings
Return line filter, specifications
Self levelling valve, specifications 1
Transmission pump, specifications 1
  • Volvo Skid Steer Loader MCT85C Service and Repair Manual.txt
