Toyota & Lexus Reprogramming CUW Files: Official ECU Calibration Updates
WHAT INSIDE:
* Toyota-Lexus TIS Calibration Files part 1-3.7z
* Toyota Tacoma CUW 30433300.zip
* Toyota Prado, Hilux, Fortuner (Diesel with problem Clogged DPF bulletin inside).zip
* Toyota LC150 AT.7z
* Toyota Corolla 2009 302a4200 + Calibration Supersession Notice.rar
1. MAIN FUNCTIONS AND COMPATIBILITY
OFFICIAL ECU FLASHING & BUG FIXING
* Engine ECU (ECM) Updates – optimizes fuel consumption, fixes sensor-related bugs, and improves emission standards.
* Transmission ECU (TCM) Updates – eliminates shifting jerks, resolves delays, and adapts transmission behavior.
* Other Systems Updates – fixes factory bugs in Climate Control, ABS/ESP, Body ECU, and Hybrid drive systems.
MODEL COVERAGE
* Compatible with any Toyota/Lexus vehicle equipped with Electronic Control Units (ECUs) that technically support OBD2 Flash Reprogramming.
* Note: This database is assembled manually, so coverage is partial. Please download and check for your specific vehicle.
2. PACK FEATURES
SAFE & TARGETED REPROGRAMMING
* Allows the ECU software to be updated without physically replacing the ECU itself.
* Flash calibration updates can only be applied to the specific vehicle/ECU combination for which they are intended.
* Built-in ECU internal security prevents programming with incorrect or incompatible files.
Toyota & Lexus Reprogramming / Calibration CUW files package is an essential collection of factory flash updates and Technical Service Bulletins (TSBs). It is designed to perform official field-fix procedures, eliminating known factory bugs in engine, transmission, and body control units. Using the included Calibration Update Wizard (CUW) and a compatible J2534 interface, specialists can safely update vehicle software to the latest official manufacturer versions without replacing the hardware.
WHAT INSIDE:
MODEL COVERAGE
2. PACK FEATURES
