lavenue
71
7
6
35
thailand
TOYOTA HILUX 1997 - 2005 SERVICE & REPAIR INFORMATION MANUAL
Code:
Product Code: Toyota
Availability: In Stock
Update : 08.1997 - 08.2005
Region :  All Regions
Qty : 1 CD
Toyota Hilux Service information library 08.1997 - 08.2005
RZN142, 144, 147, 148, 149, 154, 168, 169, 173, 174, 193, 194 series
VZN167, 172 series
LN140, 141, 145, 146, 147, 150, 152, 155, 157, 165, 166, 167, 170, 171, 172, 190, 191, 192 series
KZN165, 190 series
KDN145, 150, 155, 165, 170, 190 series
Engines:
5VZ-FE - 3.4L V6 24 Valve DOHC,
3RZ-F - 2.7L 4 cylinder 16 Valve DOHC,
3RZ-FE - 2.7L 4 cylinder 16 Valve DOHC,
1RZ - 2.0L 4 cylinder OHC,
2RZ - 2.4L 4 cylinder 16 Valve,
2RZ-E - 2.4L 4 cylinder 16 Valve SOHC,
1RZ-E - 2.0L 4 cylinder OHC,
1KZ-TE - 3.0L 4 cylinder 8 Valve OHC diesel,
2L - 2.4L 4 cylinder OHC diesel,
3L - 2.8L 4 cylinder diesel,
5L - 3.0L 4 cylinder OHC diesel,
2KD-FTV - 2.5L 4 cylinder 16 Valve D-4D DOHC diesel
Electrical wiring diagram
Body Repair
New Car Features
Service data sheet
REPAIR MANUAL
Repair manual - Introduction, Preparation, Service specifications, Diagnostics, Clutch, Manual transmission (G52,G54,G58), Manual transmission G50, Manual transmission W56, Manual transmission R150F, Manual transmission R151F, Automatic transmission A340E, Automatic transmission A340F, Transfer, Propeller shaft, Suspension and axle, Brake system, Steering, Supplemental restraint system, Body electrical system, Body, Air conditioning system
Engine Repair manual (5VZ-FE engine) - Introduction, Preparation, Service specifications, Diagnostics, Engine, Ignition, Engine mechanical, Emission control, Electronic fuel injection, Cooling, Lubrication, Starting, Charging
Engine Repair manual (3RZ-F, 3RZ-FE engine) - Introduction, Preparation, Service specifications, Diagnostics, Engine, Ignition, Engine mechanical, Emission control, Electronic fuel injection, Cooling, Lubrication, Starting, Charging
Engine Repair manual (1RZ, 2RZ, 2RZ-E engine) - Introduction, Engine mechanical, EFI system, Cooling system, Lubrication system, Ignition, Starting, Charging, Service specifications, SST and SSM, Preparation, Diagnostics, Emission cpntrol, Electronic fuel injection, Lubrication
Engine Repair manual (1RZ-E) - Introduction, Engine, Engine mechanical, EFI system, Cooling system, Lubrication system, Ignition, Starting, Charging, Service specifications, Preparation, Diagnostics, Emission cpntrol, Electronic fuel injection, Lubrication
Engine Repair manual (1KZ-TE engine) - Introduction, Preparation, Service specifications, Diagnostics, Engine mechanical, Turbocharging, Emission control, Electronic control, Fuel, Cooling, Lubrication, Starting, Charging
Engine Repair manual (2L engine) - Introduction, Preparation, Service specifications, Diagnostics, Engine, Engine mechanical, Turbocharging, Emission control, Fuel, Cooling, Lubrication, Starting, Charging
Engine Repair manual (3L engine) - Introduction, Preparation, Service specifications, Engine, Fuel, Engine mechanical, Turbocharging, Emission control, Cooling, Lubrication, Starting, Charging
Engine Repair manual (5L engine) - Introduction, Preparation, Service specifications, Engine, Fuel, Engine mechanical, Turbocharging, Emission control, Electronic control, Cooling, Lubrication, Starting, Charging
Engine Repair manual (2KD-FTV engine) - Introduction, Preparation, Service specifications, Diagnostics, Fuel, Engine mechanical, Turbocharging, Emission control, Electronic control, Cooling, Lubrication, Starting, Charging
Automatic transmission repair manual (A340E,F,H) - Description, Operation, Preparation, Component parts, Component parts removal, Oil pump, Direct clutch, Forward clutch, Front planetary gear, Second brake, Rear planetary gear, Transmission case, Valve body, Transfer
NEW CAR FEATURES
Introduction, New model outline, Engine, Chassis, Body, Body electrical
New car features, Technical specifications, Exterior
ELECTRICAL WIRING DIAGRAM
Introduction, Relay locations, Electrical wiring routing, Connector list, Part number of connectrors, Overall electrical wiring diagram
BODY REPAIR
Introduction, Body Panel Replacement, Body panel construction, Plastic body parts, Body Dimensions
OTHER INFORMATION
  • TOYOTA HILUX SERVICE & REPAIR MANUAL UPDATE 1997 - 2005 DOWNLOAD LINK.txt
  • Like
Reactions: Asiya1999
