If you download this document, you will be lost 5550 Beer
TOYOLEX 3 - PRODUCT SPECIFICATIONS
Description: The ToyoLex 3 program is designed to disable DPF, EGR, Adblue, lambda, immo, DTC, in the firmware of Toyota and Lexus cars with Denso blocks. The program allows you to work with files of the first, second and third generation (Gen 1, Gen 2, Gen 3) of the Denso ECU from Toyota and Lexus cars, the DTC error disable function and allows you to disable special functions on diesel, gasoline and hybrid engines.
To work, you will need a firmware file in a standard binary "bin" format, read (kess, ktag, bitbox, pcmflash, trasdata, etc.), load it into the ToyoLex program, select in a couple of clicks what needs to be disabled, overwrite the necessary errors, if necessary, save and write the saved file to the block.
Attention! The program does not know how to read checksums after making changes to the firmware file, but most modern bootloaders can quickly read the COP before writing the firmware.
Version: v7.00.67.77 - no further free updates
Language: English version
Platform: Windows 7-11
Toyolex3 - has the following functionality:
+ A new algorithm has been added that can recognize the 3rd generation DTC table structure built into the 2nd generation Denso ECU files.
+ A new algorithm has been added to clear DTCs on hybrid vehicles.
+ Function to disable the Adblue / SCR system.
+ Diesel particulate filter [DPF] cut-off function for all Denso Generations ECUs.
+ Vehicle speed limiter correction function [Vmax] for 1GD-FTV, 2GD-FTV, 1KD-FTV and 2KD-FTV + + Diesel engines.
+ Catalytic shutdown function [CAT lambda probe] for 1GD-FTV and 2GD-FTV diesel engines.
+ Catalytic shutdown function [CAT lambda probe] for all petrol engines.
+ Exhaust gas recirculation [EGR] deactivation function.
+ Intake manifold valve deactivation function [IMV].
+ Intake manifold shutoff function [IMR].
+ Immobilizer disable function [IMMO OFF] on 1KD-FTV, 2KD-FTV, 1GD-FTV and 2GD-FTV with Denso GEN 2 ECU.
+ An automatic file recognition function that simplifies the process of selecting a function to run.
Are you concerned about risk after payment?
We know you are concerned about the prepayment, receive the software later. Don’t worry, you should use Paypal and remember to choose a payment method Pay for goods or services, you will be guaranteed safety by Paypal.
It is a form of assurance that gives you peace of mind, but in fact you will never need Paypal to resolve a dispute, because we would not be foolish to exchange a DHTauto.com brand that we have built it. When there was bad feedback, our Paypal account was also locked. And will affect our brand. So if the case does not support you, we are ready to Refund the money you sent us.
Please refer: Refund policy.
Are you concerned that you will not know how to use the software?
If you are newbie, you can refer to our videos on our Youtube channel or Facebook. We regularly upload video instructions to test the vehicle or perform the functions of programming, review software, install software,.... Is it important that you take the time and effort to learn?. There are many tutorials, and many videos and documents that are completely free.
Also, if you need us to do it for you, check out: DHT AUTO STORE
  • SoToV7Ch.txt
DHTmaster
Administrators
Staff member
Dec 15, 2021
840
100
You can add beer depend on this tutorial
