Scania 2015.3 multi setup
1. Mount disk 1 (Multi1503-1.iso).
2. If you have already installed NET Framework 4 or fresh - skip this step.
Run dotNetFx40_Full_x86_x64.exe Util folder to mount the disk. Looking forward ->
Put the check on I have read blablabla ... -> Install -> We are waiting for -> Finish
3. Run setup.exe to mount the disk. Put the check Accept the license ... -> Remove daw with Acrobat Reader ->
OK -> point stands on the Install application and data, the way I change C: \ Program Files \ Multi \ to c: \ Auto \ Scania,
where C: \ MultiDat changing to c: \ Auto \ Scania \ MultiDat, Will ask several times about creating directories ->
Next -> Install -> Next -> I accept ... -> Next-> Next -> Install -> Finish -> Long wait. -> Close.
4. Those who are relevant repair information necessary to mount a drive (Multi1503-2.iso).
Run setup.exe from the disc mount. -> Next -> We are waiting for a long time -> Ok
5. In the Start menu -> All Programs -> Accessories -> Command Prompt ->
Code:
echo sp_password NULL, 1234, 'sa' | OSQL.EXE -S localhost \ MULTI_SQL -E
-> Enter
Code:
echo use Multi_1503_NonEU; update multi_proparameter set text = "* '). $, # (" where item =' PROD_STAMP '| SQLCMD.EXE -U sa -P 1234 -S localhost \ MULTI_SQL -d Multi_1503_NonEU
-> Enter
In the start menu in the folder have Multi Multi Config, tab settings -> change language -> Apply -> Close.
Year / Release Date: 2015
Version: 6.15.0.1
Developer: Scania CV AB
Code:
-> Enter
Code:
-> Enter
Version: 6.15.0.1
