If you download this document, you will be lost 2825 Beer
Opel Astra K 2018 Electrical Wiring Diagrams & Component Locator​
Format: PDF, CGM, XPS
Model: 2018 Opel Astra K
Type of Machine: Automobile
Brand: Opel
Type of Document: Electrical Wiring Diagrams, Component Locator
Opel EWD - 2018 - Astra K - Control Module U Code List.pdf
Opel EWD - 2018 - Astra K - RPO Code List.pdf
Opel EWD - 2018 - Astra K - Schematics RPO Code List.pdf
Opel EWD - 2018 - Astra K - Service Interval reset 2018 MY.pdf
Opel EWD - 2018 - Astra K - Belts and Chains - 1.0L (LE1) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.0L (LE1) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.0L (LE1) - Camshaft Timing Chain Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.0L (LE1) - Drive Belt Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.0L (LE1) - Engine Mechanical Specifications (LE1).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.0L (LE1) - Oil Pump Drive Chain Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LE2, LFE) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LE2, LFE) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LE2, LFE) - Camshaft Timing Chain Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LE2, LFE) - Drive Belt Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LE2, LFE) - Engine Mechanical Specifications (LE2, LFE).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LE2, LFE) - Oil Pump Drive Chain Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LV7) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LV7) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LV7) - Camshaft Timing Chain Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LV7) - Drive Belt Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LV7) - Engine Mechanical Specifications (LV7).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.4L (LV7) - Oil Pump Drive Chain Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Camshaft Timing Chain Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Drive Belt Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Engine Mechanical Specifications (1.6L Diesel LVK).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Engine Mechanical Specifications (1.6L Diesel LVL & NCV & PL6, LXO).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Engine Mechanical Specifications (1.6L Diesel LVL & NCV).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Engine Mechanical Specifications (1.6L Diesel LVL).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Engine Mechanical Specifications (1.6L Diesel LWQ & PL5).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Engine Mechanical Specifications (1.6L Diesel LWQ).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Engine Mechanical Specifications (1.6L Diesel LWV).xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LVK, LVL, LWQ, LWV, LXO) - Oil Pump Drive Chain and Sprocket Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LWC) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LWC) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LWC) - Camshaft Timing Chain Installation.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LWC) - Camshaft Timing Chain Removal.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LWC) - Drive Belt Replacement.xps
Opel EWD - 2018 - Astra K - Belts and Chains - 1.6L (LWC) - Engine Mechanical Specifications.xps
Opel EWD - 2018 - Astra K - Component Locator - Master Electrical Component List.pdf
Opel EWD - 2018 - Astra K - Component Locator - X84 Data Link Connector.pdf
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A10 Inside Rearview Mirror.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X1 (IO6 IP1 -IOB).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X1 (IOB).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X2 (IO6).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X2 (IOB).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X3 (IOB).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X3 (IP1 IO6).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X4 (IOB IO6 US3).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X4 (IP1+U91).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X5 (IO6+US3).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X6 (IOB+U2Q).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X7 (IOB).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X8 (IP1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X9 (IO6+U2Q).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A11 Radio X9 (IP1+U2Q).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A14D Seat Lumbar Support Pump - Driver (-AG1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A14P Seat Lumbar Support Pump - Passenger (AVU).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A22 Radio Controls (IOB).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A23C Liftgate Latch Assembly (HATCHBACK).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A23C Liftgate Latch Assembly (Wagon+TC2).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A23C Liftgate Latch Assembly (Wagon-TC2).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A23D Door Latch Assembly - Driver.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A23LR Door Latch Assembly - Left Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A23P Door Latch Assembly - Passenger.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A23RR Door Latch Assembly - Right Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A24D Door Handle Assembly - Driver Exterior.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A24P Door Handle Assembly - Passenger Exterior (ATH).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A26 HVAC Controls.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A33 Media Disc Player X1.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A3L Sunshade - Left.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A3R Sunshade - Right.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A7 Fuel Pump and Level Sensor Assembly.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A9A Outside Rearview Mirror - Driver.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - A9B Outside Rearview Mirror - Passenger.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B1 AC Refrigerant Pressure Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B107 Accelerator Pedal Position Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B10B Ambient Light Sunload Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B110 Battery Sensor Module X2 (KL9).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B110 Battery Sensor Module.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B111 Turbocharger Boost Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B112 Turbocharger Vane Position Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B119 Multi-axis Acceleration Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B131A Exhaust Temperature Sensor 1.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B131B Exhaust Temperature Sensor 2.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B131C Exhaust Temperature Sensor 3.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B136 Exhaust Particulate Matter Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B14C Transmission Input Shaft Speed Sensor (MJA).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B153D Seat Belt Buckle - Driver.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B153MR Seat Belt Buckle - Rear Middle Right.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B153P Seat Belt Buckle - Passenger (1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B153P Seat Belt Buckle - Passenger.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B153RR Seat Belt Buckle - Right Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B154 Diesel Particulate Filter Exhaust Differential Pressure Sensor ((LVK+NCV) LXO).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B154 Diesel Particulate Filter Exhaust Differential Pressure Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B16 Backup Lamp Switch.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B160 Windshield Temperature and Inside Moisture Sensor ((ASV-CE1)+UHX).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B160 Windshield Temperature and Inside Moisture Sensor ((ASV-CE1)-UHX).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B165 Content Theft Deterrent Sensor Module.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B177 Rain Ambient Light Sensor Module.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B18 Battery Current Sensor (-KL9).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B18 Battery Current Sensor (LFE).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B195A Nitrogen Oxides Sensor 1.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B19B Brake Booster Vacuum Sensor (KL9+LHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B19B Brake Booster Vacuum Sensor (KL9+RHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B20 Brake Fluid Level Switch (LHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B20 Brake Fluid Level Switch (RHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B203 Radiator Coolant Temperature Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B209 Neutral Position Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B22 Brake Pedal Position Sensor (MM1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B22 Brake Pedal Position Sensor (MM3).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B221 Alternative Fuel Tank Pressure Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B229 Alternative Fuel Rail Pressure Temperature Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B23 Camshaft Position Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B233B Radar Sensor Module - Long Range.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B23E Camshaft Position Sensor - Exhaust (LE2 LE1 LFE LV7).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B23E Camshaft Position Sensor - Exhaust (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B23F Camshaft Position Sensor - Intake (LE2 LE1 LFE LV7).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B23F Camshaft Position Sensor - Intake (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B24 Mobile Telephone Microphone.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B257 Alternative Fuel Pressure Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B25B Clutch Pedal Position Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LV7 LE2 LE1 LFE).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (MZ4 MNP MYJ LVK).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B267 Piston Cooling Oil Pressure Switch.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B27D Door Handle Switch - Driver Exterior.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B27LR Door Handle Switch - Left Rear Exterior (ATH).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B27P Door Handle Switch - Passenger Exterior.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B27RR Door Handle Switch - Right Rear Exterior (ATH).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B280 Automatic Transmission Accumulator Solenoid Valve (MHG).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B280 Automatic Transmission Accumulator Solenoid Valve (MNU+KL9).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306A Parking Assist Sensor - Front Left Outer.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306B Parking Assist Sensor - Front Left Middle.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306C Parking Assist Sensor - Front Right Middle.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306D Parking Assist Sensor - Front Right Outer.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306E Parking Assist Sensor - Rear Left Outer.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306F Parking Assist Sensor - Rear Left Middle.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306G Parking Assist Sensor - Rear Right Middle.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306H Parking Assist Sensor - Rear Right Outer.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306K Parking Assist Sensor - Side Left Front.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306L Parking Assist Sensor - Side Right Front.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306M Parking Assist Sensor - Side Left Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B306N Parking Assist Sensor - Side Right Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B34 Engine Coolant Temperature Sensor (LE1 LE2 LFE LV7).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B34 Engine Coolant Temperature Sensor (LVK LVL).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B34 Engine Coolant Temperature Sensor (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B35 Engine Oil Level Switch.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B37B Engine Oil Pressure Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B39 AC Evaporator Temperature Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B47 Fuel Pressure Sensor (LE1 LE2 LVK LVL LWQ LWV LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B47B Fuel Rail Pressure Sensor (LE1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B47B Fuel Rail Pressure Sensor (LE2).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B47B Fuel Rail Pressure Sensor (LVL LVM LVK).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B47B Fuel Rail Pressure Sensor (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B51F Suspension Height Sensor - Front.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B51R Suspension Height Sensor - Rear (T4L).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LV7 LFE LE2 LE1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LVL LVK).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LWC MM3).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (LE1 LE2 LV7 LFE).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (LVK).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (LWC MM3).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (M60).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B55 Engine Hood Switch.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B59L Front Impact Sensor - Left.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B59R Front Impact Sensor - Right.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B5LF Wheel Speed Sensor - Left Front.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B5LR Wheel Speed Sensor - Left Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B5RF Wheel Speed Sensor - Right Front.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B5RR Wheel Speed Sensor - Right Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B6 Clutch Position Sensor (MJA).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B60 Passenger Presence Sensor (LFE LE2 LE1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B60 Passenger Presence Sensor (LV7).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B60 Passenger Presence Sensor (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B63LF Side Impact Sensor - Left Front (LHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B63LF Side Impact Sensor - Left Front (RHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B63LR Side Impact Sensor - Left Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B63RF Side Impact Sensor - Right Front (LHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B63RF Side Impact Sensor - Right Front (RHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B63RR Side Impact Sensor - Right Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B65 Intake Manifold Pressure and Air Temperature Sensor (LFE LE2 LE1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B65 Intake Manifold Pressure and Air Temperature Sensor (LWC LVL LVK).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B66C Inside Air Temperature Sensor - Auxiliary (S07).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B68 Knock Sensor (LE1 LE2 LFE).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B68 Knock Sensor (LV7).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B68 Knock Sensor (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B70 Liftgate Close Switch.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B71L Liftgate Object Sensor - Left.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B71R Liftgate Object Sensor - Right.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B74 Manifold Absolute Pressure Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B75B Mass Air Flow Intake Air Temperature Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B75C Multifunction Intake Air Sensor (LV7 LE2).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B75C Multifunction Intake Air Sensor.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B7D Air Temperature Sensor - Duct Left Lower (ASV CJ2).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B7E Air Temperature Sensor - Duct Right Lower (CJ2).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B7H Air Temperature Sensor - Duct Left Upper (ASV CJ2).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B7J Air Temperature Sensor - Duct Right Upper (CJ2).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B80 Park Brake Switch.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B87 Rearview Camera (HATCHBACK).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B87 Rearview Camera (Wagon).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B87 Rearview Camera (Wagon+UVC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B88LR Seat Belt Switch - Left Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B88MR Seat Belt Switch - Rear Middle.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B88RR Seat Belt Switch - Right Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B9 Ambient Air Temperature Sensor (UD5 UFQ).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B9 Ambient Air Temperature Sensor (-UD5-UFQ).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - B96 Cylinder Head Temperature Sensor (LVK LVL LWQ LWV).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery ((-)(KL9)).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery ((-)(-KL9)).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery ((-)).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery ((+) (LFE)).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery ((+) (-LFE)).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery ((+) LFE).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery ((+) -LFE).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery ((+)).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery (-KL9).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery (LE2 -KL9).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery (LFE).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - C1 Battery (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E11A Fuel Heater Water in Fuel Sensor (LVK LVL LWQ LWV).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E12A Glow Plug 1.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E12B Glow Plug 2.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E12C Glow Plug 3.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E12D Glow Plug 4.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E14A Seat Heating Element - Driver Back (KA1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E14B Seat Heating Element - Driver Cushion (KA1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E14C Seat Heating Element - Passenger Back (KA1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E14D Seat Heating Element - Passenger Cushion (KA1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E14E Seat Heating Element - Left Rear Back (KA6).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E14F Seat Heating Element - Left Rear Cushion (KA6).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E14G Seat Heating Element - Right Rear Back (KA6).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E14H Seat Heating Element - Right Rear Cushion (KA6).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E15 Steering Wheel Heater (UVD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X1 (HATCHBACK+US3).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X1 (HATCHBACK-US3).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X1 (Wagon).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X2 (HATCHBACK-US3).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X2 (Wagon).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E1D Accent Lamp - Driver Door (C9B Hatchback LHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E1D Accent Lamp - Driver Door (C9B Hatchback RHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E1D Accent Lamp - Driver Door (C9B LHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E1D Accent Lamp - Driver Door (C9B RHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E1P Accent Lamp - Passenger Door (C9B).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E29LF Fog Lamp - Left Front (T3U).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E29LF Fog Lamp - Left Front (T3U -UD5).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E29RF Fog Lamp - Right Front (T3U).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E29RF Fog Lamp - Right Front (T3U -UD5).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E32 Cigarette Lighter Receptacle.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E37E Dome Reading Lamps - Front Overhead Console.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E37R Dome Reading Lamps - Rear.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E40 Electrical Auxiliary Heater X2 (C32).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E40 Electrical Auxiliary Heater.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E41 Engine Coolant Thermostat Heater (LE1).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E41 Engine Coolant Thermostat Heater (LWC).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E42L Tail Lamp Assembly - Left.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E42R Tail Lamp Assembly - Right.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E43L Liftgate Tail Lamp Assembly - Left.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E43R Liftgate Tail Lamp Assembly - Right.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E4Y Turn Signal Repeater Lamp - Left.xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E4Z Turn Signal Repeater Lamp - Right (LHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E4Z Turn Signal Repeater Lamp - Right (RHD).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E6 Center High Mounted Stop Lamp (HATCHBACK).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E6 Center High Mounted Stop Lamp (Wagon).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E7L License Plate Lamp - Left (HATCHBACK+BP5).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E7L License Plate Lamp - Left (HATCHBACK-BP5).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E7L License Plate Lamp - Left (HATCHBACK-UD5).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E7R License Plate Lamp - Right (HATCHBACK+BP5).xps
Opel EWD - 2018 - Astra K - Component Locator - Component Connector End Views - E7R License Plate Lamp - Right (HATCHBACK-BP5).xps
Opel EWD -
DHT-opel-astra-k-2018-electrical-wiring-diagrams-component-locator-07094323012025-2.jpg
DHT-opel-astra-k-2018-electrical-wiring-diagrams-component-locator-07094423012025-3.jpg
DHT-opel-astra-k-2018-electrical-wiring-diagrams-component-locator-07094423012025-4.jpg
DHT-opel-astra-k-2018-electrical-wiring-diagrams-component-locator-07094323012025-1.jpg
