If you download this document, you will be lost 2825 Beer
Opel Ampera E 2018 Electrical Wiring Diagrams & Component Locator​
Model: 2018 Opel Ampera E
Type of Document: Wiring Diagrams, Component Locator
Type of Machine: Automobile
Format: PDF, CGM, XPS,
Brand: Opel
Opel EWD - 2018 - Ampera E - Control Module U Code List.pdf
Opel EWD - 2018 - Ampera E - RPO Code List.pdf
Opel EWD - 2018 - Ampera E - Schematics RPO Code List.pdf
Opel EWD - 2018 - Ampera E - Service Interval reset 2018 MY.pdf
Opel EWD - 2018 - Ampera E - Component Locator - Master Electrical Component List.pdf
Opel EWD - 2018 - Ampera E - Component Locator - X84 Data Link Connector.pdf
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A10 Inside Rearview Mirror X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A10 Inside Rearview Mirror X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A11 Radio X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A11 Radio X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A11 Radio X3.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A11 Radio X4.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A11 Radio X5.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A11 Radio X6.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A11 Radio X8.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A20 Radio HVAC Controls.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A23C Liftgate Latch Assembly.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A23D Door Latch Assembly - Driver.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A23LR Door Latch Assembly - Left Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A23P Door Latch Assembly - Passenger.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A23RR Door Latch Assembly - Right Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A24D Door Handle Assembly - Driver Exterior.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A24LR Door Handle Assembly - Left Rear Exterior.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A24P Door Handle Assembly - Passenger Exterior.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A24RR Door Handle Assembly - Right Rear Exterior.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A28 Hybrid EV Battery Contactor Assembly.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A4 Hybrid EV Battery Pack X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A4 Hybrid EV Battery Pack X3.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - A4 Hybrid EV Battery Pack X4.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B1 AC Refrigerant Pressure Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B107 Accelerator Pedal Position Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B13 Transmission Fluid Temperature Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B15 Transmission Internal Mode Switch.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B153D Seat Belt Buckle - Driver.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B153P Seat Belt Buckle - Passenger.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B160 Windshield Temperature and Inside Moisture Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B174G Frontview Camera - Grille (UVH).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B18 Battery Current Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B197 Chnage Port Door Position Switch.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B1C AC Low Side Pressure Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B20 Brake Fluid Level Switch.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B200 Rain Sensor Module (CE1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B201 Brake Control Brake Pedal Position Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B202 Hybrid EV Electronics Coolant Temperature Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B204A Hybrid EV Battery Pack Coolant Temperature Sensor 1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B218L Side Object Sensor Module - Left (UKC).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B218R Side Object Sensor Module - Right (UKC).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B22 Brake Pedal Position Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B225L Sideview Camera - Left (UVH).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B225R Sideview Camera - Right (UVH).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B228 Drive Motor Position Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B24 Mobile Telephone Microphone (UE1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B258 Hybrid EV Battery Coolant Level Switch.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B27D Door Handle Switch - Driver Exterior.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B27LR Door Handle Switch - Left Rear Exterior.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B27P Door Handle Switch - Passenger Exterior.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B27RR Door Handle Switch - Right Rear Exterior.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B305 Ambient Light Sunload Sensor and Battery State of Charge Indicator.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306A Parking Assist Sensor - Front Left Outer (UD5 UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306B Parking Assist Sensor - Front Left Middle (UD5 UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306C Parking Assist Sensor - Front Right Middle (UD5 UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306D Parking Assist Sensor - Front Right Outer (UD5 UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306E Parking Assist Sensor - Rear Left Outer (UD5 UD7 UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306H Parking Assist Sensor - Rear Right Outer (UD5 UD7 UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306J Parking Assist Sensor - Rear Middle (UD5 UD7 UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306K Parking Assist Sensor - Side Left Front (UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306L Parking Assist Sensor - Side Right Front (UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306M Parking Assist Sensor - Side Left Rear (UFQ).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B306N Parking Assist Sensor - Side Right Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B55 Engine Hood Switch.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B59 front Impact Sensor (AY0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B59L Front Impact Sensor - Left (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B59R Front Impact Sensor - Right (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B5LF Wheel Speed Sensor - Left Front.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B5LR Wheel Speed Sensor - Left Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B5RF Wheel Speed Sensor - Right Front.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B5RR Wheel Speed Sensor - Right Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B60 Passenger Presence Sensor (-AL0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B61P Seat Belt Tension Sensor - Passenger (AL0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B63L Side Impact Sensor - Left (AY0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B63LF Side Impact Sensor - Left Front (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B63LR Side Impact Sensor - Left Rear (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B63R Side Impact Sensor - Right.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B63RF Side Impact Sensor - Right Front.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B63RR Side Impact Sensor - Right Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B7B Air Temperature Sensor - Duct Lower.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B7F Air Temperature Sensor - Duct Upper.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B87 Rearview Camera X1 (UVC).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B87 Rearview Camera X1 (UVH).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B87 Rearview Camera X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B88D Seat Belt Switch - Driver.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B88P Seat Belt Switch - Passenger (AL0+AY0 AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - B9 Ambient Air Temperature Sensor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C1 Battery (-).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C3 Telematics Communication Interface Control Module Battery (UE1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C4D Hybrid EV Battery Module 4 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5A Hybrid EV Battery Module 1 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5A Hybrid EV Battery Module 1 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5B Hybrid EV Battery Module 2 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5B Hybrid EV Battery Module 2 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5C Hybrid EV Battery Module 3 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5C Hybrid EV Battery Module 3 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5D Hybrid EV Battery Module 4 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5E Hybrid EV Battery Module 5 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5E Hybrid EV Battery Module 5 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5F Hybrid EV Battery Module 6 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5F Hybrid EV Battery Module 6 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5G Hybrid EV Battery Module 7 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5G Hybrid EV Battery Module 7 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5H Hybrid EV Battery Module 8 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5H Hybrid EV Battery Module 8 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5J Hybrid EV Battery Module 9 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5J Hybrid EV Battery Module 9 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5K Hybrid EV Battery Module 10 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - C5K Hybrid EV Battery Module 10 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E14A Seat Heating Element - Driver Back (KA1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E14B Seat Heating Element - Driver Cushion.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E14C Seat Heating Element - Passenger Back (KA1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E14D Seat Heating Element - Passenger Cushion.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E14F Seat Heating Element - Left Rear Cushion (KA6).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E14H Seat Heating Element - Right Rear Cushion (KA6).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E15 Steering Wheel Heater X2 (KI3).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E1G Accent Lamp - Left Instrument Panel.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E1H Accent Lamp - Right Instrument Panel.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E2LR Side Marker Lamp - Left Rear (TW5).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E2RR Side Marker Lamp - Right Rear (TW5).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E37D Dome Reading Lamps - Overhead Console.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E37R Dome Reading Lamps - Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E4LF Turn Signal Lamp - Left Front.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E4RF Turn Signal Lamp - Right Front.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E54 Hybrid EV Battery Pack Coolant Heater X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E54 Hybrid EV Battery Pack Coolant Heater X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E6 Center High Mount Stop Lamp.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E7L License Plate Lamp - Left.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E7R License Plate Lamp - Right.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - E8S Rear Compartment Courtesy Lamp.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F101 Passenger Instrument Panel Air Bag X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F101 Passenger Instrument Panel Air Bag X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F105L Roof Rail Air Bag - Left (AYF AY0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F105LR Roof Rail Air Bag - Left Rear (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F105R Roof Rail Air Bag - Right.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F106LF Seat Side Air Bag - Left Front.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F106LR Seat Side Air Bag - Left Rear (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F106P Seat Side Air Bag - Passenger (AY0 AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F106RR Seat Side Air Bag - Right Rear (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F107 Steering Wheel Air Bag X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F107 Steering Wheel Air Bag X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F112D Seat Belt Retractor Pretensioner - Driver (AY0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F112LR Seat Belt Retractor Pretensioner - Left Rear (SBK).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F112P Seat Belt Retractor Pretensioner - Passenger (AY0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F112RR Seat Belt Retractor Pretensioner - Right Rear (SBK).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F113D Seat Belt Anchor Pretensioner - Driver (AY0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F113P Seat Belt Anchor Pretensioner - Passenger (AY0).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F114D Knee Air Bag - Driver (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - F114P Knee Air Bag - Passenger.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - Frontview Camera Module (UEU UHX UHY UVX).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G1 AC Compressor X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G1 AC Compressor X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G10 Cooling Fan Motor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G19 Rear Window Washer Pump.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G24 Windshield Washer Pump.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G35 Hybrid EV Electronics Coolant Pump.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G36 Auxiliary Heater Coolant Pump.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G37 Hybrid EV Battery Pack Coolant Pump.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - G5 Transmission Fluid Pump - Electric Auxiliary.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K1 14V Power Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K1 14V Power Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K1 14V Power Module X3.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K1 14V Power Module X4.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K10 Coolant Heater Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K10 Coolant Heater Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K101 Trailer Interface Control Module X1 (MAH MBC MAW MCX).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K101 Trailer Interface Control Module X2 (MAH MBC MAW MCX).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K109 Frontview Camera Module (UEU UHX UHY UVX).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K114B Hybrid EV Powertrain Control Module 2 X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K114B Hybrid EV Powertrain Control Module 2 X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K118 Electric A C Compressor Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K118 Electric AC Compressor Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K132 Pedestrian Alert Sound Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K157 Video Processing Control Module X1 (UVH).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K157 Video Processing Control Module X2 (UVH).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K16 Battery Energy Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K16 Battery Energy Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K16 Battery Energy Control Module X3.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K16 Battery Energy Control Module X4.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K16 Battery Energy Control Module X5.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K16 Battery Energy Control Module X6.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K16 Battery Energy Control Module X7.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K16 Battery Energy Control Module X8.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K17 Electronic Brake Control Module.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K173 Transmission Range Control Module.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K177 Brake Booster Control Module.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K182 Parking Assist Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K182 Parking Assist Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K182 Parking Assist Control Module X3.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K183 UHF Short Range Low Energy Remote Control Access Transceiver.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K190 Power Line Communication Module X1 (CBT).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K190 Power Line Communication Module X2 (CBT).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K20 Engine Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K20 Engine Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K20 Engine Control Module X3.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K29F Seat Heating Control Module - Front X1 (KA1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K29F Seat Heating Control Module - Front X2 (KA1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K29R Seat Heating Control Module - Rear X1 (KA6).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K29R Seat Heating Control Module - Rear X2 (KA6).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K32 Steering Wheel Heating Control Module X1 (KI3).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K33 HVAC Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K33 HVAC Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K33 HVAC Control Module X3.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K36 Inflatable Restraint Sensing and Diagnostic Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K36 Inflatable Restraint Sensing and Diagnostic Module X2 (AY0+MAW).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K36 Inflatable Restraint Sensing and Diagnostic Module X2 (AY0+MBM).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K36 Inflatable Restraint Sensing and Diagnostic Module X2 (AYF).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K38 Chassis Control Module.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K43 Power Steering Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K43 Power Steering Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K56 Serial Data Gateway Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K56 Serial Data Gateway Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K57 Battery Charger Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K60 Steering Column Lock Module.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K68 Trailer Lighting Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K68 Trailer Lighting Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K73 Telematics Communication Interface Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K73 Telematics Communication Interface Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K73 Telematics Communication Interface Control Module X5 (UE1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K73 Telematics Communication Interface Control Module X7 (UE1).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K77 Remote Control Door Lock Receiver.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K8 Blower Motor Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K8 Blower Motor Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K84 Keyless Entry Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K84 Keyless Entry Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K85 Passenger Presence Module.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K89 Immobilizer Control Module.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K9 Body Control Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K9 Body Control Module X2.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K9 Body Control Module X3.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K9 Body Control Module X4.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K9 Body Control Module X5.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K9 Body Control Module X6.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - K9 Body Control Module X7.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M104L Park Brake Actuator - Left.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M104R Park Brake Actuator - Right.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M29L Head Lamp Leveling Actuator - Left (KA6).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M29R Headlamp Leveling Actuator - Right (TR6).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M37 Mode Door Actuator.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M45 Rear Wiper Motor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M46 Air Recirculation Door Actuator.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M6 Air Temperature Door Actuator.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M74D Window Motor - Driver.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M74LR Window Motor - Left Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M74P Window Motor - Passenger.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M74RR Window Motor - Right Rear.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M75L Windshield Wiper Motor Module - Left.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M75R Windshield Wiper Motor Module - Right.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M8 Blower Motor.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - M96 Active Grille Air Shutter Actuator.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P12L Horn - Left.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P12R Horn - Right.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P14 Passenger Air Bag Disabled Indicator.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P16 Instrument Cluster.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P17 Info Display Module X1.xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P19AC Speaker - Subwoofer (UQA).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P19AG Speaker - Left Front Door (UQ3).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P19AG Speaker - Left Front Door (UQA).xps
Opel EWD - 2018 - Ampera E - Component Locator - Component Connector End Views - P19AH Spea
DHT-opel-ampera-e-2018-electrical-wiring-diagrams-component-locator-19452022012025-1.jpg
DHT-opel-ampera-e-2018-electrical-wiring-diagrams-component-locator-19452122012025-2.jpg
