Mitsubishi MUT-III 12.2021 for J2534
Description: Mitsubishi MUT III is the new-generation diagnostic software of Mitsubishi. It offers powerful features for users with an intuitive interface. With the version that can be used with J2534 devices, it provides convenience and flexibility for technicians.
Version: 12.2021
Language: Multilanguage
* Simple
— Only CAN bus (approximately 2005+) ECUs and vehicles are supported, reprogramming and K-Line is not supported
— Licensing type: binding to one PC without the ability to use a virtual machine
* Full
Full functionality without restrictions.
— CAN;
— K-Line (OBD, ISO-MMC, KWP) only on pin 7 (see diagrams). For vehicles manufactured until the year 2000, approximately. Some ECUs require other pins in the diagnostic connector, thus, they will not work fully (this is a limitation of the original scanner);
— Reprogramming for CAN bus ECUs only;
— Licensing type: binding to one PC without the ability to use a virtual machine or USB key without the previously mentioned restrictions.
Feature:
- Diagnostics of all electronic systems of Mitsubishi vehicles.
- Viewing and recording of operating parameters in real time.
- ECU coding.
- ECU programming and updating.
- Adaptations impemention and resetting.
- Service procedures.
- VIN number changing in ECUs.
- ETACS option coding.
- Component calibration including hybrid engines.
- ETACS reset.
- Key programming....
Supported Hardwares:
- Tactrix OpenPort 2.0 (original) - Full Support
- ScanDoc Compact (J2534) - Full Support
- Scanmatik 2 Pro - Full Support
- Toyota Mini-VCI - CAN vehicles support without reprogramming and long codings writing (ETACS 2013+). For Simple driver version only. Driver for Mini-VCI.
- Chipsoft J2534 - Full support for CAN auto, partial support for K-line (SRS, ABS and ECUs that use pin 1 in the diagnostic connector will not work)
- Other J2534 adapters - provided that the adapter is 100% compliant.
- Free hard drive space: 60 GB or more
- CPU: Core i3 or above
- Ram: 4 GB or more
- Operating System: Windows 10 64 bit
Our policies and instructions
Contact link
