- If you download this document, you will be lost 500 Beer
Lexus RX350, 270 Workshop Manual 2012
Support IE 5.5, 6, 7, 8, 9, 10, 11
REPAIR MANUAL
ENGINE CONTROL SYSTEM
1AR-FE - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Mass Air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Relay
2GR-FE - SFI system, Ignition system, Camshaft oil control valve, Throttle body, Vacuum switching valve, Active control engine mount, ECM, Accelerator pedal, Mass Air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Relay
ENGINE MECHANICAL
1AR-FE - Engine, Drive Belt, Camshaft, Cylinder head gasket, Front crankshaft oil seal, Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
2GR-FE - Engine, Drive Belt, Camshaft, Cylinder head gasket, Front crankshaft oil seal, Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
FUEL
1AR-FE - Fuel system, Fuel injector, Fuel pressure regulator,Fuel pressure pulsation damper, Fuel pump, Fuel tank, Fuel sender gauge assembly
2GR-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
EMISSION CONTROL
1AR-FE - Emission control system, Canister, Purge valve, Fuel tank cap, PCV valve
2GR-FE - Emission control system, Canister, Purge valve, Fuel tank cap, PCV valve
INTAKE / EXHAUST
1AR-FE - Intake system, Intake manifold, Intake air control valve actuator, Intake air control valve, Vacuum switching valve, Exhaust manifold, Exhaust pipe
2GR-FE - Intake system, Intake manifold, Intake air control valve, Vacuum tank, Vacuum switching valve, Exhaust manifold, Exhaust pipe
LECTRICAL WIRING DIAGRAM
COOLING FAN, IGNITION, SHIFT LOCK, AIR SUSPENSION, TIRE PRESSURE WARNING SYSTEM, VEHICLE DYNAMICS INTEGRATION MANAGEMENT, EPS, POWER TILT AND POWER TELESCOPIC, AUDIO SYSTEM, PARKING ASSIST, SAFETY CONNECT, MULTIPLEX COMMUNICATION, POWER SOURCE, SRS, HYBRID SYSTEM, LIGHT and others
BODY REPAIR
INTRODUCTION, BODY PANEL REPLACEMENT, BODY DIMENSIONS, PAINTING / COATING
REPAIR MANUAL
ENGINE MECHANICAL
FUEL
EMISSION CONTROL
INTAKE / EXHAUST
BODY REPAIR
