Level Calibration Suspension of Mercedes S450 2016 (W222)
Calibration Process:
Step 1: Select the N51/3 – AIRMATIC system and select Error codes / Events to read the error.
Step 3: Adjusting the Rear Suspension height values for the vehicle already in the required range will appear green. Click Continue to go to the next step.
Step 4: Entry of values stored in inclinometer. The allow range values of the tilt angles are in steps 3 and 4 (Front axle: -6.3° to -0.2°, Rear axle: -4.3° to -0.5°).
Step 5: The message "Level calibration is performed with the following values" appears click Countinue to perform calibration with the entered value.
Step 7: Notice "Level calibration was successful" the calibration has successfully, click Countinue to end the process.
Step 8: Select Error codes / Events to check the error code. The error code has been successfully removed.
