DHTAuto Support
264
77
33
Singapore
If you download this document, you will be lost 2725 Beer
JPRO 2019v1​
Description: JPRO® Professional ™ Diagnostic Software is a versatile diagnostic software that can diagnose many systems, including engines, gearboxes, ABS, body, and more. The software can read, display, delete more than 44,000 trouble codes, and also comes with the software for searching and displaying DTC guide.
Type of software: Diagnostic software
Capacity: 636MB
Version: 2019v1
Manufacturer: Noregon
Region: International
OS: Windows: 7, 10 32/ 64 Bit
Free hard drive: 10 GB or more
CPU: Core i3 or above
Ram: 4GB or more
Software Feature:
Displays vehicle temps, battery voltage, gauges, switches and more
Reads and clears active and inactive fault codes
Performs critical commanded tests and bi-directional functions
DPF Regen
Cylinder Cut-out test
Resetting of learned data
Resetting of trip data
Sets select customer parameters
Generates trip and life of vehicle reports
Supported Hardware:
Nexiq USB link 1, 2
DPA5
Noregon DLA
And some other RP1210 devices
Vehicle supported:
The software is capable of diagnosing heavy trucks, construction machines such as Mack, Volvo, Detroit, International, PACCAR, Isuzu, Wabco, and Bendix. Diagnosis of medium duty vehicles such as Ford, GM, and Sprinter can also be made.
Body and Chassis: Bluebird, Ford, Freightliner, GM, International, Kenworth, Mack, Peterbilt, Sprinter, Sterling, Thomas Built, Volvo, and Western Star
Engines: CAT, Detroit, Ford, GM, International, Mack, Mercedes, PACCAR MX, Sprinter, Volvo
ABS: Bendix, Ford, GM, Haldex, Sprinter, Wabash, WABCO
Transmission: Allison, Detroit, Eaton, Ford, GM, Mack, Sprinter, Volvo, ZF
  • JPRO 2019 V1.txt
Teodor192
www.obdii.shop
Jpro software currently version is 2023 V1.2
Whats coverage for Jpro latest software ? Which functions did it support ?
Lets check the instructions as following :
JPRO Heavy-Duty Features:
Engine Support
HEAVY-DUTY SUPPORT FOR
ClearFlame
Supports the ability to identify ClearFlame components.
Cummins
Data monitor now displays proprietary data for EPA02 CM800.
Data monitor now displays spark plug voltage data for CNG CM2380A.
Bi-Directional support for Cummins engines:
NOTE: JPRO must connect and identify the correct Cummins engine module software versions to enable bi-directional support.
Aftertreatment History now supports EPA 10: all ISB, ISC, ISL, and ISX | EPA 13: all ISB, ISL, and ISX | GHG17: all B6.7, L9, and X15 | GHG21: all B6.7, LP, and X15
Cylinder Cut-Out Test now supports EPA 02: ISB (3.9L)
Maintenance Monitor Parameters now supports EPA 10: all ISB, ISC, ISL, and ISX | EPA 13: all ISB, ISL, and ISX | GHG17: all B6.7, LP, and X15 | CNG: all ISL, ISX, and ISB
NOTE: To see Software Version, select the engine and look in the bottom left of JPRO.
Deutz
Supports reading proprietary sensor data on Deutz engines:
EMR 3 – EDC 16 UC40 on TBL-180, Safeaero 220, and Tug MT
EMR 3 – EDC 7 UC31 on TBL-180, Safeaero 220, and Tug MT
EMR 4 – EDC 17 CV52 on TBL-180, TBL-400, Safeaero 220, Tug 660, Tug GT-35, Tug M1A, Tug MA, Tug MH, and Tug M
EMR 4 – EDC 17 CV54 on TBL-180, Tug GT-35, Tug MH, and Tug MR
EMR4 – EDC 17 CV56 on Safeaero 220
NOTE: Deutz 12-pin Off-Highway cables are required.
EControls
Supports reading SAE faults and sensor data on EControls engines:
EControls ECM on Tug 660, Tug M1A, and Tug MA
EControls ECM 4G on Tug 660, Tug Alpha, Tug M1A, and Tug MA
NOTE: EControls 8-pin Off-Highway cables are required.
Paccar
Addressed communication issues when connecting to PACCAR vehicles 2022 and newer.
Brake Support
Bendix Tractor Brakes
Updated Intellipark Systems support for latest firmware versions.
Bendix Driver Assistance Systems (DAS)
Updated Active Steering by Bendix CVS support for newer ECU models.
Bendix Tire Pressure Monitoring System (TPMS)
Bi-Directional support for Bendix TPMS:
TPMS Ambient Sensor Configuration now supports Ambient Application Configuration
Ambient Pressure Source
JPRO Off-Highway Features
Bobcat
Supports reading proprietary diagnostic fault codes, event codes, and data for the following equipment types, models, and engines:
Excavators
E45, E50, and E55 with DL02 engine
Compact Track Loaders
T450, T550, T590, and T650 with DL02 engine
T630, T740, T770, and T870 with DL03 engine
Skid Steer Loaders
S530, S630, and S650 with DL02 engine
S740 and S770 with DL02 engine
NOTE: Bobcat 6-pin Off-Highway cables are required.
OFF-HIGHWAY SUPPORT FOR
Caterpillar
Backhoe Loaders
Model 416, Model 420, and Model 420 XE with C3.6 engine
Dozers
D4 with C4.4 engine
D5 with C7.1 engine
D6 and D6 XE with C9.3B engine
D8 with C15 engine
Excavators
315 and 315 GC with C3.6 engine
320 GC, 320 T4f/EU, and 323 T4f/EU with C4.4 engine
336 GC with C7.1 engine
349 with C13 engine
Wheel Loaders
926M, 930M, 930, Ag Handler, 930M Waste Handler, 938M, 950 GC, and 950M with C7.1 engine
966M with C9.3 engine
966. 966 GC, 966 XE, and 966M XE with C9.3B engine
980 with C13 engine
John Deere
Supports SAE faults and sensor data for the following equipment types, models, and engines:
Backhoes
310L, 310SL, 310SL HL, and 410L with John Deere 6068 engine
310L EP with Yanmar 4TNV engine
Dozers
450K, 450K LGP, 650K, and 650K LGP with John Deere 4045 engine
700L XLT, 700L LGP, 750L, 750L XLT, and 750L LGP with John Deere 6068 engine
Compact Loaders
317G, 325G, 331G, and 333G with Yanmar 4TNV engine
Excavators
35G and 30G with Yanmar 3TNV engine
50G, 75G, 60G, and 85G with Yanmar 4TNV engine
130G, 160G LC, and 200G with John Deere 4.5L engine
210G LC with John Deere 6.8L 6068HT106 engine
250G LC with John Deere 6.8 L engine
350 P-Tier with John Deere 9.0 L engine
470 P-Tier with John Deere 6135 engine
Skid Steer Loaders
317G, 318G, 320G, and 330G with Yanmar 4TNV engine
Wheel Loaders
524P, 544 P-Tier, 624 P-Tier, and 644P with John Deere 6.8 L engine
844 P-Tier with John Deere 6135 engine
Komatsu
Excavators
PC88MR-10 with SAA4D95LE-6 engine
PC138USLC-11 with SAA4D95LE-7 engine
PC-200-LC-8 with SAA6D107E-1 engine
PC210LC-11 with SAA6D107E-3 engine
PC290LC-11 with SAA6D107E-3 engine
PC360LC-10 with SAA6D114E-5 engine
PC360LC-11 with SAA6D114E-6 engine
PC490LC-11 with SAA6D125E-7 engine
Wheel Loaders
WA270-7, WA320-7, WA380-7 with SAA6D107E-2 engine
WA270-8, WA320-8, WA380-8 with SAA6D107E-3 engine
JPRO Medium-Duty Features
Aftertreatment Diagnostics displays data from aftertreatment related components, including Soot Level, and EGR data for rapid troubleshooting of the aftertreatment system.
Ability to view the following subsystems with related data:
DEF Tank and Pump
DPF and DOC
Engine, EGR, and Turbocharger
SCR
Search the Data tab to quickly identify parameters of interest.
Aftertreatment Diagnostics supports the following Medium-Duty manufacturers:
Ford
GM
Hino
Isuzu
DHTmaster
Administrators
Staff member
Dec 15, 2021
840
100
Engine Support
ClearFlame
Cummins
Deutz
EControls
Paccar
Brake Support
Bobcat
Excavators
Skid Steer Loaders
Caterpillar
Backhoe Loaders
Dozers
D4 with C4.4 engine
D5 with C7.1 engine
D8 with C15 engine
Excavators
349 with C13 engine
Wheel Loaders
980 with C13 engine
John Deere
Backhoes
Dozers
Compact Loaders
Excavators
Skid Steer Loaders
Wheel Loaders
Komatsu
Excavators
Wheel Loaders
DEF Tank and Pump
DPF and DOC
SCR
Ford
GM
Hino
Isuzu
thank for information
