Doorman
Vip Member
Jul 13, 2021
86
79
ISTA Standalone 4.29.3x
Description:
What does ISTA stand for? ISTA is a workshop system that contains BMW AG Data and Information. ISTA stands for Integrated Service Technical Application. Way back when, during the initial development of this tool, BMW used DIS (Diagnostics Information System), and as the programs evolved and due to the nature of the file naming conventions utilized by BMW, the workshop system became known as Rheingold in the enthusiast world. Rheingold in actuality is the folder that contains the main application and data. Rheingold became ISTA-D (D stands for Diagnostics) and BMW’s programming application (not discussed in this document) used the same nomenclature, ISTA except with a P (for programming) or ISTA-P. This document only discusses ISTA+.
Eventually, based on the direction that the company is taking, ISTA-D and ISTA-P for F-/I-/G-/Mini/RR series cars will be rolled up into ISTA+ for diagnostics AND programming. What does this mean? It means, that ISTAP will contain all chassis data until around August 2017, then BMW plans to phase out all BN2020 vehicle data in ISTA-P. So, ISTA-P will be used for Programming on E-series only and ISTA+ will be everything else.
Type of Software: Diagnostic
Capacity: 78.9GB
Version: 4.29.30 (30-05-2021)
Brand: BMW
Region: All regions
Languae: English
- Minimum system configuration is now hard coded into the program, although the standalone
versions have this check removed.
- 2.2Ghz CPU - 2 core minimum, core i5 or i7 recommended
- 4GB RAM, 8GB recommended
- Minimum 20+GB HDD free space for ISTA+ Diagnostics with ONE language, and minimum
100GB for Programming Data.
- This version has hardware check removed, however, future versions MAY not have this
feature. A faster system isrequired.
- This version discusses included English Databases only. If more required, add to SQLiteDBs
folder, which will need more space.
Hardware Support: K-line, K-DCAN and ENET cables, ICOM, OPS, OPPS, EDIC and EDICC, OMITEC and other interfaces.)
Luigi65
privato
ISTA indipendente 4.29.3x
Descrizione:
Cosa significa ISTA? ISTA è un sistema di officina che contiene i dati e le informazioni di BMW AG. ISTA è l'acronimo di Integrated Service Technical Application. Molto tempo fa, quando, durante lo sviluppo iniziale di questo strumento, la BMW utilizzava il DIS (Diagnostics Information System), e man mano che i programmi si evolvevano e a causa della natura delle convenzioni di denominazione dei file utilizzate da BMW, il sistema dell'officina divenne noto come Rheingold negli appassionati mondo. Rheingold in realtà è la cartella che contiene l'applicazione ei dati principali. Rheingold divenne ISTA-D (D sta per Diagnostics) e l'applicazione di programmazione BMW (non discussa in questo documento) usava la stessa nomenclatura, ISTA tranne che con una P (per programmazione) o ISTA-P. Questo documento tratta solo di ISTA+.
Alla fine, in base alla direzione che l'azienda sta prendendo, ISTA-D e ISTA-P per le auto della serie F-/I-/G-/Mini/RR verranno integrate in ISTA+ per la diagnostica E la programmazione. Cosa significa questo? Significa che ISTAP conterrà tutti i dati del telaio fino ad agosto 2017 circa, quindi BMW prevede di eliminare gradualmente tutti i dati del veicolo BN2020 in ISTA-P. Quindi, ISTA-P verrà utilizzato solo per la programmazione sulla serie E e ISTA+ sarà tutto il resto.
Tipo di software: diagnostico
Capacità: 78,9 GB
Versione: 4.29.30 (30-05-2021)
Marca: Bmw
Regione: tutte le regioni
Lingue: inglese
Requisiti informatici:
- La configurazione minima del sistema è ora codificata nel programma, sebbene sia autonomo
le versioni hanno questo controllo rimosso.
- CPU da 2,2 Ghz - 2 core minimo, core i5 o i7 consigliati
- 4 GB di RAM, 8 GB consigliati
- Almeno 20+ GB di spazio libero su HDD per ISTA+ Diagnostics con UNA lingua e minimo
100 GB per i dati di programmazione.
- Questa versione ha il controllo hardware rimosso, tuttavia, le versioni future POTREBBERO non averlo
caratteristica. È necessario un sistema più veloce.
- Questa versione discute solo i database inglesi inclusi. Se più richiesto, aggiungi a SQLiteDBs
cartella, che avrà bisogno di più spazio.
Supporto hardware: cavi K-line, K-DCAN e ENET, ICOM, OPS, OPPS, EDIC e EDICC, OMITEC e altre interfacce.)
View attachment 78157 View attachment 78158
Buongiorno
Mi puo dire se è possibile avere questo software
Grazie
Lucifer_iq85
Iraq
Description:
Capacity: 78.9GB
Brand: BMW
Region: All regions
Languae: English
Thanks you
