Haynes WorkshopData™ Truck
Description:HaynesPro WorkshopData™ Tech
The cornerstone of our ingenious WorkshopData application. This module contains extensive identification, repair and maintenance information, all at your disposal.
HaynesPro WorkshopData™ Electronics
Helps technicians identify, locate and resolve electrical system and component errors using intelligent data applications such as our Vehicle Electronics Smart Assistant (VESA™).
HaynesPro WorkshopData™ Smart
Helps technicians reduce the time spent on fixing common faults and includes OEM Technical Service Bulletins (TSBs) and recalls.
Information account:
Duration of use:
- Option 1: One month
- Option 2: Six months
- Option 3: One year
Free 2-hour trial experience
Supported device: computer, smart phone, tablet, smart diagnostic machine or any device with internet access
Language: Multi language
Supported region: EU, USA
Supported year: The current latest 2023
HaynesPro Workshop Data™ provides features:
Identification data:
-VIN and identification plate locations
-VIN decoder
Maintenance:
-Maintenance schedules (OEM-based)
-Smart links to adjustment data
-Printable work sheets and cost estimates
-Reset procedure for the Service indicator
-Links to generic parts
Adjustment data:
-Emission data
-Wear limits
-Wheel alignment settings
-Torque settings
-Capacities
Lubricants and fluids:
-Qualities and viscosities
Repair manuals:
-Automatic transmission level and drain / refill
-Tyre pressure monitoring system (TPMS)
-Semi-automatic transmission level and drain / refill
-Clutch: removal/installation
-Valve clearances
-Injector: removal/installation
Recalls:
-Safety related recall actions issued by OEM
Repair times:
-Overlap technology
-Standard labour times
-Link to generic parts
-Follow-up work
Technical drawings:
-Torque settings
-Truck and trailer configurator:
-Create your own truck/trailer configuration from scratch
-Save truck and/or trailer configurations
-Transmission database
-Axle database
VESA guided diagnostics:
-ABS/EBS
-Engine management
-ECAS (Electronically Controlled Air Suspension)
-Diagnostic wizard
-Fault codes (manufacturer’s and EOBD)
Fuses and relays:
-Fuse and relay box locations
-Fuse and relay overview
Comfort wiring diagrams:
-Wiring diagrams covering e.g. door locks, windows, airbags, exterior lights, starting/charging and wash/wiper systems
-Pan and zoom functionality
-Highlight functionality to trace corresponding wires and components
Technical Service Bulletins (SMARTFIX™):
-Technical Service Bulletins
-Link to fault codes and related cases
Verified fixes and tips (SmartCASE™):
-Verified fixes and tips
Supported models:
Google Sheets: Sign-in
Access Google Sheets with a personal Google account or Google Workspace account (for business use).docs.google.com
