ohenry
730
80
ho chi minh
If you download this document, you will be lost 2725 Beer
Doosan EDIA e-Doctor v2.3.5.6 English Include Training
Description:
Doosan Engine Diagnostic, referred to as Doosan E-Doctor is a specialized diagnostic software for Doosan engines, such as DL06, DL08, DV11, DV11S, etc. These engines are very commonly used on DX140, DX300, and Daewoo trucks, bus,…. The software helps to communicate between the computer and Engine ECU, helping users to diagnose and repair quickly and accurately
In addition, the software supports many advanced features such as: Register Machine ID, Re-Programing to help program the engine ECU after replacement.
Capacity: 85.1 MB
Region: All region
OS
: Windows 7, 8, 10 32/ 64 bit
Free hard drive space: 2 GB or above
CPU: Intel Core I3 or above
Ram: 4 GB or above
Software Feature:
- Read information of current fault codes, historical fault.
- Look up the fault code repair guide, circuit diagrams.
- Clear fault codes
- Display data of sensors, actuators.
- View Snap-Shot data of sensors when fault codes appear.
- Check the power balance between the cylinders: Run-up Test
- Check compression diviation between cylinders: Compression Test
- Re-program ECU
Supported Hardware:
uVIM
Adapter K9001683
Supported models:
Most of the engine models Doosan DL06, DL08, DV11, DV11S,… are available on the market. Use on excavators, loaders, trucks, bus,…
Installation guide:
  • Doosan EDIA e-Doctor v2.3.5.6 English Include Training.txt
