If you download this document, you will be lost 2225 Beer
Mitsubishi ATTRAGE / MIRAGE G4 2018 Workshop manuals
Type of manual: Mitsubishi Motors Service Manual
Format: DVD
Brand: Mitsubishi
Language:
English Language
Regions:
+ VEHICLES FOR Thailand
+ VEHICLES FOR GENERAL EXPORT
+ VEHICLES FOR GCC
Content:
Workshop manuals
00 -GENERAL
HOW TO USE THIS MANUAL
HOW TO USE TROUBLESHOOTING/INSPECTION SERVICE POINTS
CONTENTS OF TROUBLESHOOTING
DIAGNOSIS FUNCTION
HOW TO USE THE INSPECTION PROCEDURES
CONNECTOR MEASUREMENT SERVICE POINTS
CONNECTOR INSPECTION SERVICE POINTS
INSPECTION SERVICE POINTS FOR A BLOWN FUSE
HOW TO COPE WITH INTERMITTENT MALFUNCTIONS
HOW TO TREAT PAST TROUBLE
VEHICLE IDENTIFICATION
(2017 Basic) MODELS
(2018 Supplement) MODELS
(2017 Basic) VEHICLE IDENTIFICATION NUMBER (CHASSIS NUMBER)
(2018 Supplement) VEHICLE IDENTIFICATION NUMBER (CHASSIS NUMBER)
VEHICLE INFORMATION CODE PLATE
MANUFACTURER PLATE
(2017 Basic) VEHICLE IDENTIFICATION NUMBER (VIN) PLATE<VEHICLES FOR GCC>
(2018 Supplement) VEHICLE IDENTIFICATION NUMBER (VIN) PLATE<VEHICLES FOR GCC>
THEFT PROTECTION LABEL<VEHICLES FOR ARGENTINA>
ENGINE MODEL STAMPING
GENERAL DATA AND SPECIFICATIONS
(2017 Basic) GENERAL DATA AND SPECIFICATIONS<VEHICLES FOR THAILAND>
(2017 Basic) GENERAL DATA AND SPECIFICATIONS<VEHICLES FOR GENERAL EXPORT>
(2017 Basic) GENERAL DATA AND SPECIFICATIONS<VEHICLES FOR GCC>
(2018 Supplement) GENERAL DATA AND SPECIFICATIONS<VEHICLES FOR GENERAL EXPORT>
(2018 Supplement) GENERAL DATA AND SPECIFICATIONS<VEHICLES FOR GCC>
PRECAUTIONS BEFORE SERVICE
SUPPLEMENTAL RESTRAINT SYSTEM (SRS)
MULTI USE TESTER (M.U.T.-III) SUB ASSEMBLY
SERVICING ELECTRICAL SYSTEM
HOW TO SHIFT LOCK FORCED RELEASE
HOW TO PERFORM CHASSIS NUMBER (CHASSIS NO.) WRITING
CODING LIST
(2017 Basic) CODING LIST<VEHICLES FOR THAILAND>
(2017 Basic) CODING LIST<VEHICLES FOR GENERAL EXPORT>
(2017 Basic) CODING LIST<VEHICLES FOR GCC>
(2018 Supplement) CODING LIST<VEHICLES FOR GENERAL EXPORT>
INITIALISATION PROCEDURE FOR LEARNING VALUE IN MPI ENGINE
LEARNING PROCEDURE FOR IDLING IN MPI ENGINE
PRE-INSPECTION CONDITION
ENGINE OILS
FORM-IN-PLACE GASKET (FIPG)
BOLTS AND NUTS WITH STABILIZER FOR COEFFICIENT OF FRICTION
APPLICATION OF ANTI-CORROSION AGENTS AND UNDERCOATS
VEHICLE WASHING
SRS SERVICE PRECAUTIONS
SUPPORT LOCATIONS FOR LIFTING AND JACKING
00E-GENERAL <ELECTRICAL>
HOW TO READ WIRING DIAGRAMS
COMPOSITION AND CONTENTS OF WIRING DIAGRAMS
HOW TO READ CONFIGURATION DIAGRAMS
HOW TO READ CIRCUIT DIAGRAMS
MARKINGS FOR CONNECTOR AND EARTHING
WIRE COLOUR CODES
ABBREVIATION SYMBOLS
11A-ENGINE MECHANICAL
(2017 Basic) GENERAL INFORMATION
(2018 Supplement) GENERAL INFORMATION
SERVICE SPECIFICATIONS
SPECIAL TOOLS
ON-VEHICLE SERVICE
DRIVE BELT TENSION CHECK AND ADJUSTMENT
IGNITION TIMING CHECK
IDLE SPEED CHECK
IDLE MIXTURE CHECK
VALVE CLEARANCE CHECK AND ADJUSTMENT
COMPRESSION PRESSURE CHECK
MANIFOLD VACUUM CHECK
CRANKSHAFT PULLEY
CRANKSHAFT PULLEY REMOVAL AND INSTALLATION
ROCKER COVER ASSEMBLY
ROCKER COVER ASSEMBLY REMOVAL AND INSTALLATION
CAMSHAFT
CAMSHAFT REMOVAL AND INSTALLATION
OIL FEEDER CONTROL VALVE
OIL FEEDER CONTROL VALVE REMOVAL AND INSTALLATION
VALVE STEM SEAL
VALVE STEM SEAL REMOVAL AND INSTALLATION
OIL PAN
OIL PAN REMOVAL AND INSTALLATION
OIL PAN INSPECTION
CRANKSHAFT OIL SEAL
CRANKSHAFT OIL SEAL REMOVAL AND INSTALLATION
CYLINDER HEAD GASKET
CYLINDER HEAD GASKET REMOVAL AND INSTALLATION
TIMING CHAIN CASE ASSEMBLY
TIMING CHAIN CASE ASSEMBLY REMOVAL AND INSTALLATION
TIMING CHAIN
TIMING CHAIN REMOVAL AND INSTALLATION
ENGINE ASSEMBLY
ENGINE ASSEMBLY REMOVAL AND INSTALLATION
11B-ENGINE OVERHAUL
(2017 Basic) GENERAL SPECIFICATIONS
(2018 Supplement) GENERAL SPECIFICATIONS<Vehicles for Singapore>
REWORK DIMENSIONS
TORQUE SPECIFICATIONS
SEALANTS
SPECIAL TOOLS
ALTERNATOR AND IGNITION SYSTEM
ALTERNATOR AND IGNITION SYSTEM REMOVAL AND INSTALLATION
FUEL AND EMISSION PARTS
FUEL AND EMISSION PARTS REMOVAL AND INSTALLATION
INLET MANIFOLD
INLET MANIFOLD REMOVAL AND INSTALLATION
EXHAUST MANIFOLD
EXHAUST MANIFOLD REMOVAL AND INSTALLATION
WATER HOSE AND PIPE
WATER HOSE AND PIPE REMOVAL AND INSTALLATION
OIL PAN AND TIMING CHAIN CASE
OIL PAN AND TIMING CHAIN CASE REMOVAL AND INSTALLATION
TIMING CHAIN
TIMING CHAIN INSPECTION
CAMSHAFT
CAMSHAFT INSPECTION
CYLINDER HEAD AND VALVES
CYLINDER HEAD AND VALVES REMOVAL AND INSTALLATION
CYLINDER HEAD AND VALVES INSPECTION
PISTON AND CONNECTING ROD
PISTON AND CONNECTING ROD REMOVAL AND INSTALLATION
PISTON AND CONNECTING ROD INSPECTION
CRANKSHAFT AND CYLINDER BLOCK
CRANKSHAFT AND CYLINDER BLOCK REMOVAL AND INSTALLATION
CRANKSHAFT AND CYLINDER BLOCK INSPECTION
12 -ENGINE LUBRICATION
GENERAL INFORMATION
SEALANTS OR ADHESIVES
LUBRICANTS
SPECIAL TOOLS
ON-VEHICLE SERVICE
ENGINE OIL CHECK
ENGINE OIL CHANGE
ENGINE OIL FILTER REPLACEMENT
OIL FILTER STUD REPLACEMENT
OIL PRESSURE CHECK
ENGINE OIL PRESSURE SWITCH
ENGINE OIL PRESSURE SWITCH REMOVAL AND INSTALLATION
13A-MULTIPOINT FUEL INJECTION (MPI)
SPECIAL TOOLS
TROUBLESHOOTING
DIAGNOSIS TROUBLESHOOTING FLOW
DIAGNOSIS FUNCTION
DIAGNOSIS CODE CHART
DIAGNOSIS CODE PROCEDURES
CODE NO. P0010 OIL FEEDER CONTROL VALVE SYSTEM
CODE NO. P0011 VARIABLE VALVE TIMING SYSTEM
CODE NO. P0031 OXYGEN SENSOR (FRONT) HEATER CIRCUIT LOW INPUT
CODE NO. P0032 OXYGEN SENSOR (FRONT) HEATER CIRCUIT HIGH INPUT
CODE NO. P0037 OXYGEN SENSOR (REAR) HEATER CIRCUIT LOW INPUT<Vehicles with dual oxygen sensors>
CODE NO. P0038 OXYGEN SENSOR (REAR) HEATER CIRCUIT HIGH INPUT<Vehicles with dual oxygen sensors>
CODE NO. P0068 TRUSTFUL CHECK MANIFOLD ABSOLUTE PRESSURE SENSOR
CODE NO. P0107 MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT LOW INPUT
CODE NO. P0108 MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT HIGH INPUT
CODE NO. P0112 INTAKE AIR TEMPERATURE SENSOR CIRCUIT LOW INPUT
CODE NO. P0113 INTAKE AIR TEMPERATURE SENSOR CIRCUIT HIGH INPUT
CODE NO. P0117 ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW INPUT
CODE NO. P0118 ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH INPUT
CODE NO. P0121 TRUSTFUL CHECK THROTTLE POSITION SENSOR (MAIN)
CODE NO. P0122 THROTTLE POSITION SENSOR (MAIN) CIRCUIT LOW INPUT
CODE NO. P0123 THROTTLE POSITION SENSOR (MAIN) CIRCUIT HIGH INPUT
CODE NO. P0131 OXYGEN SENSOR (FRONT) CIRCUIT LOW VOLTAGE
CODE NO. P0132 OXYGEN SENSOR (FRONT) CIRCUIT HIGH VOLTAGE
CODE NO. P0133 OXYGEN SENSOR (FRONT) CIRCUIT SLOW RESPONSE
CODE NO. P0134 OXYGEN SENSOR (FRONT) CIRCUIT NO ACTIVITY DETECTED
CODE NO. P0137 OXYGEN SENSOR (REAR) CIRCUIT LOW VOLTAGE<Vehicles with dual oxygen sensors>
CODE NO. P0138 OXYGEN SENSOR (REAR) CIRCUIT HIGH VOLTAGE<Vehicles with dual oxygen sensors>
CODE NO. P0140 OXYGEN SENSOR (REAR) CIRCUIT NO ACTIVITY DETECTED<Vehicles for Argentina and Chile>
CODE NO. P0171 ABNORMAL FUEL SYSTEM (LEAN)
CODE NO. P0172 ABNORMAL FUEL SYSTEM (RICH)
CODE NO. P0221 TRUSTFUL CHECK THROTTLE POSITION SENSOR (SUB)
CODE NO. P0222 THROTTLE POSITION SENSOR (SUB) CIRCUIT LOW INPUT
CODE NO. P0223 THROTTLE POSITION SENSOR (SUB) CIRCUIT HIGH INPUT
CODE NO. P0261 NO.1 INJECTOR CIRCUIT LOW INPUT
CODE NO. P0262 NO.1 INJECTOR CIRCUIT HIGH INPUT
CODE NO. P0264 NO.2 INJECTOR CIRCUIT LOW INPUT
CODE NO. P0265 NO.2 INJECTOR CIRCUIT HIGH INPUT
CODE NO. P0267 NO.3 INJECTOR CIRCUIT LOW INPUT
CODE NO. P0268 NO.3 INJECTOR CIRCUIT HIGH INPUT
CODE NO. P0300 RANDOM/MULTIPLE CYLINDER MISFIRE DETECTED
CODE NO. P0301 NO.1 CYLINDER MISFIRE DETECTED
CODE NO. P0302 NO.2 CYLINDER MISFIRE DETECTED
CODE NO. P0303 NO.3 CYLINDER MISFIRE DETECTED
CODE NO. P0327 DETONATION SENSOR CIRCUIT LOW INPUT
CODE NO. P0328 DETONATION SENSOR CIRCUIT HIGH INPUT
CODE NO. P0335 CRANK ANGLE SENSOR SYSTEM
CODE NO. P0340 CAMSHAFT POSITION SENSOR SYSTEM
CODE NO. P0350 IGNITION COIL PRIMARY CIRCUIT MALFUNCTION<Vehicles with single oxygen sensor>
CODE NO. P0421 CATALYST MALFUNCTION
CODE NO. P0458 PURGE CONTROL SOLENOID VALVE CIRCUIT LOW INPUT
CODE NO. P0459 PURGE CONTROL SOLENOID VALVE CIRCUIT HIGH INPUT
CODE NO. P0500 VEHICLE SPEED SENSOR SYSTEM<M/T>
CODE NO. P0513 IMMOBILIZER SYSTEM<Vehicles without KOS>
CODE NO. P0513 IMMOBILIZER SYSTEM<Vehicles with KOS>
CODE NO. P0515 BATTERY TEMPERATURE SENSOR SYSTEM<Vehicles for Thailand>
CODE NO. P0532 A/C PRESSURE SENSOR CIRCUIT LOW INPUT
CODE NO. P0533 A/C PRESSURE SENSOR CIRCUIT HIGH INPUT
CODE NO. P0537 FIN THERMO SENSOR CIRCUIT LOW INPUT<A/C>
CODE NO. P0537 FIN THERMO SENSOR CIRCUIT LOW INPUT<Cooler>
CODE NO. P0538 FIN THERMO SENSOR CIRCUIT HIGH INPUT<A/C>
CODE NO. P0538 FIN THERMO SENSOR CIRCUIT HIGH INPUT<Cooler>
CODE NO. P0557 BRAKE BOOSTER PRESSURE SENSOR CIRCUIT LOW INPUT
CODE NO. P0558 BRAKE BOOSTER PRESSURE SENSOR CIRCUIT HIGH INPUT
CODE NO. P0602 VARIANT CODING SYSTEM
CODE NO. P0604 RAM ERROR
CODE NO. P0606 ENGINE-ECU MAIN PROCESSOR MALFUNCTION
CODE NO. P060B A/D CONVERTER
CODE NO. P060D TRUSTFUL CHECK ACCELERATOR PEDAL POSITION SENSOR
CODE NO. P061A TORQUE MONITORING
CODE NO. P061C TRUSTFUL CHECK ENGINE SPEED
CODE NO. P061F FAIL-SAFE CONTROL SYSTEM
CODE NO. P0620 ALTERNATOR CONTROL CIRCUIT<Vehicles for Thailand>
CODE NO. P0622 ALTERNATOR FR TERMINAL SYSTEM
CODE NO. P062F EEPROM MALFUNCTION
CODE NO. P0630 CHASSIS NUMBER NOT PROGRAMMED
CODE NO. P0638 THROTTLE VALVE CONTROL SERVO CIRCUIT RANGE/PERFORMANCE PROBLEM
CODE NO. P0642 THROTTLE POSITION SENSOR POWER SUPPLY
CODE NO. P0657 THROTTLE VALVE CONTROL SERVO RELAY CIRCUIT MALFUNCTION
CODE NO. P1231 TRUSTFUL CHECK ACTIVE STABILITY CONTROL (ASC)<Vehicles with ASC>
CODE NO. P1238 MANIFOLD ABSOLUTE PRESSURE SENSOR TRUSTFUL FOR TORQUE MONITORING
CODE NO. P1242 FAIL-SAFE CONTROL MONITORING
CODE NO. P1243 INQUIRY/RESPONSE ERROR
CODE NO. P1247 TRUSTFUL CHECK CVT<CVT>
CODE NO. P1537 LIN COMMUNICATION ERROR (SENDING MESSAGE TO CURRENT BATTERY CURRENT SENSOR)<Vehicles for Thailand>
CODE NO. P1538 LIN COMMUNICATION ERROR (RECEIVING MESSAGE FROM BATTERY CURRENT SENSOR)<Vehicles for Thailand>
CODE NO. P1570 RECEIVED FAILURE SIGNAL FROM FCM<Vehicles with FCM-LS>
CODE NO. P1590 COMMUNICATION ERROR IN TORQUE REDUCTION REQUEST<CVT>
CODE NO. P1603 BATTERY BACKUP CIRCUIT MALFUNCTION
CODE NO. P1608 BATTERY CURRENT SENSOR SYSTEM<Vehicles for Thailand>
CODE NO. P1611 BATTERY VOLTAGE SENSOR CIRCUIT<Vehicles for Thailand>
CODE NO. P170E ASC ERROR INFORMATION<Vehicles with FCM-LS>
CODE NO. P2100 THROTTLE VALVE CONTROL SERVO CIRCUIT (OPEN)
CODE NO. P2101 THROTTLE VALVE CONTROL SERVO MAGNETO MALFUNCTION
CODE NO. P2122 ACCELERATOR PEDAL POSITION SENSOR (MAIN) CIRCUIT LOW INPUT
CODE NO. P2123 ACCELERATOR PEDAL POSITION SENSOR (MAIN) CIRCUIT HIGH INPUT
CODE NO. P2127 ACCELERATOR PEDAL POSITION SENSOR (SUB) CIRCUIT LOW INPUT
CODE NO. P2128 ACCELERATOR PEDAL POSITION SENSOR (SUB) CIRCUIT HIGH INPUT
CODE NO. P2135 THROTTLE POSITION SENSOR (MAIN AND SUB) RANGE/PERFORMANCE PROBLEM
CODE NO. P2138 ACCELERATOR PEDAL POSITION SENSOR (MAIN AND SUB) RANGE/PERFORMANCE PROBLEM
CODE NO. P2252 OXYGEN SENSOR OFFSET CIRCUIT LOW VOLTAGE
CODE NO. P2253 OXYGEN SENSOR OFFSET CIRCUIT HIGH VOLTAGE
CODE NO. U0101 CVT-ECU TIME-OUT<CVT>
CODE NO. U0121 ABS-ECU TIME-OUT<Vehicles with ABS/ASC>
CODE NO. U0126 STEERING WHEEL SENSOR TIME-OUT<Vehicles with FCM-LS>
CODE NO. U0131 EPS-ECU TIME-OUT
CODE NO. U0141 ETACS-ECU TIME-OUT
CODE NO. U0155 COMBINATION METER TIME-OUT
CODE NO. U0164 A/C-ECU TIME-OUT<Automatic A/C>
CODE NO. U0167 ETACS-ECU (IMMOBILIZER) COMMUNICATION ERROR<Vehicles without KOS>
CODE NO. U0167 KOS-ECU COMMUNICATION ERROR<Vehicles with KOS>
CODE NO. U0168 KOS-ECU TIME-OUT<Vehicles with KOS>
CODE NO. U0415 ASC-ECU CAN DATA ABNORMALITY<Vehicles with ASC>
CODE NO. U1011 ACC/FCM PARITY/TOGGLE BIT ERROR<Vehicles with FCM-LS>
CODE NO. U1073 BUS-OFF<Vehicles with FCM-LS>
CODE NO. U1220 PARITY OR TOGGLE BIT ERROR OF ASC<Vehicles with FCM-LS>
CODE NO. U15A0 ACC/FCM ECU CAN TIME-OUT<Vehicles with FCM-LS>
SYMPTOM CHART
SYMPTOM PROCEDURES
THE COMMUNICATION BETWEEN M.U.T.-III AND ENGINE-ECU IS NOT POSSIBLE.
THE ENGINE WARNING LAMP DOES NOT ILLUMINATE RIGHT AFTER THE IGNITION SWITCH IS TURNED TO THE "ON" POSITION.
THE ENGINE WARNING LAMP REMAINS ILLUMINATING AND NEVER GOES OUT.
STARTING IMPOSSIBLE (STARTER NOT OPERATIVE)<M/T>
STARTING IMPOSSIBLE (STARTER NOT OPERATIVE)<CVT>
STARTING IMPOSSIBLE (STARTER OPERATIVE BUT NO INITIAL COMBUSTION)
STARTING IMPOSSIBLE (INITIAL COMBUSTION BUT NO COMPLETE COMBUSTION), IMPROPER STARTING (LONG TIME TO START)
UNSTABLE IDLING (ROUGH IDLING, HUNTING), IMPROPER IDLING SPEED (TOO HIGH OR TOO LOW), ENGINE STALLS DURING IDLING (DIE OUT)
THE ENGINE STALLS WHEN STARTING THE CAR. (PASS OUT), THE ENGINE STALLS WHEN DECELERATING.
ENGINE DOES NOT REVOLVE UP.
HESITATION, SAG, POOR ACCELERATION, STUMBLE OR SURGE
THE FEELING OF IMPACT OR VIBRATION WHEN ACCELERATING.
THE FEELING OF IMPACT OR VIBRATION WHEN DECELERATING.
KNOCKING
IGNITION TIMING DEVIATION
RUN ON (DIESELING)
ODOUR, WHITE SMOKE, BLACK SMOKE AND HIGH-CONCENTRATION OF CO/HC DURING IDLING.
BATTERY RUN DOWN
OVERHEATING
ENGINE-ECU POWER SUPPLY, ENGINE CONTROL RELAY, IGNITION SWITCH-IG1 SYSTEM
FUEL PUMP SYSTEM
IGNITION CIRCUIT SYSTEM
A/C SWITCH SYSTEM<Manual A/C>
A/C COMPRESSOR RELAY SYSTEM
FAN CONTROL RELAY SYSTEM<CVT(Except vehicles for Thailand and Malaysia)>
FAN CONTROL RELAY SYSTEM<M/T, CVT(Vehicles for Thailand and Malaysia)>
BLOWER FAN SIGNAL SYSTEM<Manual A/C>
BRAKE MONITORING SWITCH SYSTEM<CVT>
ENGINE OIL PRESSURE SWITCH SYSTEM
DATA LIST REFERENCE TABLE
ACTUATOR TEST REFERENCE TABLE
CHECK AT THE ECU TERMINALS
INSPECTION PROCEDURE USING AN OSCILLOSCOPE
ON-VEHICLE SERVICE
THROTTLE BODY (THROTTLE VALVE AREA) CLEANING
FUEL PRESSURE TEST
FUEL PUMP CONNECTOR DISCONNECTION (HOW TO REDUCE PRESSURIZED FUEL PRESSURE)
FUEL PUMP OPERATION CHECK
COMPONENT LOCATION
ENGINE CONTROL RELAY CONTINUITY CHECK
FUEL PUMP RELAY CONTINUITY CHECK
THROTTLE VALVE CONTROL SERVO RELAY CONTINUITY CHECK
INTAKE AIR TEMPERATURE SENSOR CHECK
ENGINE COOLANT TEMPERATURE SENSOR CHECK
OXYGEN SENSOR CHECK
INJECTOR CHECK
THROTTLE VALVE CONTROL SERVO CHECK
OIL CONTROL VALVE CHECK
INJECTOR
INJECTOR REMOVAL AND INSTALLATION
THROTTLE BODY ASSEMBLY
THROTTLE BODY ASSEMBLY REMOVAL AND INSTALLATION
ENGINE-ECU
ENGINE-ECU REMOVAL AND INSTALLATION
13B-FUEL SUPPLY
GENERAL INFORMATION
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
FUEL GAUGE UNIT CHECK
FUEL PUMP (MODULE) REPLACEMENT
FUEL LEAK CHECK OF FUEL TANK
FUEL TANK
FUEL TANK REMOVAL AND INSTALLATION
FUEL TANK DISASSEMBLY AND REASSEMBLY
FUEL PUMP (MODULE) DISASSEMBLY AND REASSEMBLY
FUEL FILLER NECK
FUEL FILLER NECK REMOVAL AND INSTALLATION
14 -ENGINE COOLING
SERVICE SPECIFICATION(S)
LUBRICANT(S)
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
ENGINE COOLANT LEAK CHECK
RADIATOR CAP OPENING PRESSURE CHECK
ENGINE COOLANT CHANGE
ENGINE COOLANT CONCENTRATION TEST
WATER PUMP COOLANT LEAK CHECK
FAN CONTROL RELAY CONTINUITY CHECK
COOLING FAN MOTOR CHECK
THERMOSTAT
THERMOSTAT REMOVAL AND INSTALLATION
THERMOSTAT INSPECTION
WATER PUMP
WATER PUMP REMOVAL AND INSTALLATION
WATER HOSE AND WATER PIPE
WATER HOSE AND WATER PIPE REMOVAL AND INSTALLATION
RADIATOR
RADIATOR REMOVAL AND INSTALLATION
15 -INTAKE AND EXHAUST
SPECIAL TOOL(S)
AIR CLEANER
AIR CLEANER REMOVAL AND INSTALLATION
INLET MANIFOLD
INLET MANIFOLD INSPECTION
EXHAUST MANIFOLD
EXHAUST MANIFOLD INSPECTION
EXHAUST PIPE AND MAIN MUFFLER
EXHAUST PIPE AND MAIN MUFFLER REMOVAL AND INSTALLATION
16 -ENGINE ELECTRICAL
CHARGING SYSTEM
GENERAL INFORMATION
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
ALTERNATOR OUTPUT LINE VOLTAGE DROP TEST
OUTPUT CURRENT TEST
REGULATED VOLTAGE TEST
WAVE PATTERN CHECK USING AN OSCILLOSCOPE
ALTERNATOR ASSEMBLY
ALTERNATOR ASSEMBLY REMOVAL AND INSTALLATION
STARTING SYSTEM
GENERAL INFORMATION
ON-VEHICLE SERVICE
STARTER RELAY CONTINUITY CHECK
STARTER MOTOR ASSEMBLY
STARTER MOTOR ASSEMBLY REMOVAL AND INSTALLATION
STARTER MOTOR ASSEMBLY INSPECTION
IGNITION SYSTEM
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
IGNITION COIL CHECK
SPARK PLUG CHECK, CLEANING AND REPLACEMENT
CAMSHAFT POSITION SENSOR CHECK
CRANK ANGLE SENSOR CHECK
DETONATION SENSOR CHECK
IGNITION COIL
IGNITION COIL REMOVAL AND INSTALLATION
CAMSHAFT POSITION SENSOR REMOVAL AND INSTALLATION
CRANK ANGLE SENSOR
CRANK ANGLE SENSOR REMOVAL AND INSTALLATION
DETONATION SENSOR
DETONATION SENSOR REMOVAL AND INSTALLATION
17 -ENGINE AND EMISSION CONTROL
ENGINE CONTROL
ACCELERATOR PEDAL
ACCELERATOR PEDAL REMOVAL AND INSTALLATION
EMISSION CONTROL
EMISSION CONTROL DEVICE REFERENCE TABLE
VACUUM HOSE
VACUUM HOSE PIPING DIAGRAM
VACUUM CIRCUIT DIAGRAM
VACUUM HOSE CHECK
VACUUM HOSE INSTALLATION
CRANKCASE EMISSION CONTROL SYSTEM
GENERAL INFORMATION (CRANKCASE EMISSION CONTROL SYSTEM)
COMPONENT LOCATION (CRANKCASE EMISSION CONTROL SYSTEM)
POSITIVE CRANKCASE VENTILATION SYSTEM CHECK
POSITIVE CRANKCASE VENTILATION (PCV) VALVE CHECK
EVAPORATIVE EMISSION CONTROL SYSTEM
GENERAL INFORMATION (EVAPORATIVE EMISSION CONTROL SYSTEM)
COMPONENT LOCATION (EVAPORATIVE EMISSION CONTROL SYSTEM)
PURGE CONTROL SYSTEM CHECK
PURGE CONTROL SOLENOID VALVE CHECK
CANISTER REMOVAL AND INSTALLATION
CATALYTIC CONVERTER
CATALYTIC CONVERTER REMOVAL AND INSTALLATION
21A-CLUTCH
GENERAL INFORMATION
ON-VEHICLE SERVICE
CLUTCH PEDAL CHECK AND ADJUSTMENT
CLUTCH PEDAL SWITCH CHECK AND ADJUSTMENT
CLUTCH CONTROL
CLUTCH CONTROL REMOVAL AND INSTALLATION
CLUTCH CONTROL INSPECTION
21B-CLUTCH OVERHAUL
GENERAL INFORMATION
LUBRICANTS
SPECIAL TOOLS
CLUTCH
CLUTCH REMOVAL AND INSTALLATION
CLUTCH INSPECTION
22A-MANUAL TRANSMISSION (FF)
LUBRICANTS
SPECIAL TOOLS
ON-VEHICLE SERVICE
TRANSMISSION OIL LEVEL CHECK
TRANSMISSION OIL CHANGE
TRANSMISSION CONTROL
TRANSMISSION CONTROL REMOVAL AND INSTALLATION
TRANSMISSION ASSEMBLY
TRANSMISSION ASSEMBLY REMOVAL AND INSTALLATION
22B-MANUAL TRANSMISSION OVERHAUL
GENERAL INFORMATION
SNAP RING, SPACER AND THRUST PLATE FOR ADJUSTMENT
SEALANT(S) AND ADHESIVE(S)
LUBRICANTS
SPECIAL TOOLS
TRANSMISSION
TRANSMISSION DISASSEMBLY AND REASSEMBLY
TRANSMISSION INSPECTION
INPUT SHAFT
INPUT SHAFT DISASSEMBLY AND REASSEMBLY
INPUT SHAFT INSPECTION
OUTPUT SHAFT
OUTPUT SHAFT DISASSEMBLY AND REASSEMBLY
OUTPUT SHAFT INSPECTION
CONTROL HOUSING
CONTROL HOUSING DISASSEMBLY AND REASSEMBLY
CLUTCH HOUSING
CLUTCH HOUSING DISASSEMBLY AND REASSEMBLY
TRANSMISSION CASE
TRANSMISSION CASE DISASSEMBLY AND REASSEMBLY
DIFFERENTIAL
DIFFERENTIAL DISASSEMBLY AND REASSEMBLY
23A-CVT
LUBRICANTS
SPECIAL TOOLS
TROUBLESHOOTING
STANDARD FLOW OF DIAGNOSIS TROUBLESHOOTING
LEARNED VALUE INITIALISATION PROCEDURE FOR CVT
CVT FLUID PRESSURE CONTROL LEARNING PROCEDURE
DIAGNOSIS FUNCTION
ROAD TEST
RATIO PATTERN
DAMPER CLUTCH OPERATION RANGE
CODE NO. P0705 INHIBITOR SWITCH MALFUNCTION
CODE No. P0712 CVT FLUID TEMPERATURE SENSOR MALFUNCTION
CODE No. P0713 CVT FLUID TEMPERATURE SENSOR MALFUNCTION
CODE NO. P0715 PRIMARY PULLEY SPEED SENSOR MALFUNCTION
CODE NO. P071B Ds POSITION SWITCH MALFUNCTION<6 POSITION TYPE>
CODE NO. P0720 OUTPUT SPEED SENSOR MALFUNCTION
CODE NO. P0741 LOCKUP MALFUNCTION
CODE NO. P0746 OIL PRESSURE CONTROL MALFUNCTION
CODE NO. P0791 SECONDARY PULLEY SPEED SENSOR MALFUNCTION
CODE NO. P0715,P0720,P0791 MALFUNCTION OF SPEED SENSOR POWER SUPPLY CIRCUIT
CODE NO. P0796 PRIMARY PRESSURE SOLENOID VALVE MALFUNCTION
CODE NO. P0841 SECONDARY PRESSURE SENSOR MALFUNCTION
CODE NO. P0842 SECONDARY PRESSURE SENSOR SYSTEM
CODE NO. P0843 SECONDARY PRESSURE SENSOR SYSTEM
CODE NO. P0962 LINE PRESSURE SOLENOID MALFUNCTION
CODE NO. P0963 LINE PRESSURE SOLENOID MALFUNCTION
CODE NO. P0970 PRIMARY PRESSURE SOLENOID MALFUNCTION
CODE NO. P0971 PRIMARY PRESSURE SOLENOID MALFUNCTION
CODE NO. P0973 LOW BRAKE SOLENOID MALFUNCTION
CODE NO. P0974 LOW BRAKE SOLENOID MALFUNCTION
CODE NO. P0976 HIGH CLUTCH AND REVERSE BRAKE SOLENOID MALFUNCTION
CODE NO. P0977 HIGH CLUTCH AND REVERSE BRAKE SOLENOID MALFUNCTION
CODE NO. P1607 SYSTEM POWER SUPPLY MALFUNCTION
CODE NO. P1637 MEMORY BACKUP MALFUNCTION
CODE NO. P1797 G SENSOR/BRAKE PRESSURE SENSOR MALFUNCTION
CODE NO. P2763 LOCKUP SOLENOID MALFUNCTION
CODE NO. P2764 LOCKUP SOLENOID MALFUNCTION
CODE No. P2857 AUXILIARY GEARBOX GEAR 1 INCORRECT RATIO RUN-UP
CODE No. P2858 AUXILIARY GEARBOX GEAR 2 INCORRECT RATIO RUN-UP
CODE No. P2859 AUXILIARY GEARBOX GEAR 1 INCORRECT RATIO
CODE No. P285A AUXILIARY GEARBOX GEAR 2 INCORRECT RATIO
CODE NO. U0001 CAN COMMUNICATION CIRCUIT MALFUNCTION
CODE NO. U0100 CAN TIMEOUT ERROR (ENGINE)
CODE NO. U0121 CAN TIMEOUT ERROR (ABS)
CODE NO. U0141 CAN TIMEOUT ERROR (ETACS)
CODE NO. U0155 CAN TIMEOUT ERROR (COMBINATION METER)
CODE No. U1195 VARIANT CODING NOT IMPLEMENTED
CODE No. U1197 WRONG CODING DATA RECEIVED
TROUBLE SYMPTOM DIAGNOSIS CHART
CHECK AT CVT-ECU TERMINALS
INSPECTION PROCEDURES BY USING OSCILLOSCOPE
ON-VEHICLE SERVICE
ESSENTIAL SERVICE
CVT FLUID CHECK
CVT FLUID CHANGE
INHIBITOR SWITCH CONTINUITY CHECK
INHIBITOR SWITCH AND CONTROL CABLE ADJUSTMENT
CVT CONTROL COMPONENT LOCATION
CVT CONTROL COMPONENT CHECK
CVT CONTROL SOLENOID VALVE ASSEMBLY CHECK
CVT FLUID TEMPERATURE SENSOR CHECK
TORQUE CONVERTER STALL TEST
HYDRAULIC PRESSURE TEST
SELECTOR LEVER OPERATION CHECK
SHIFT LOCK MECHANISM CHECK
SELECTOR LEVER ASSEMBLY CONTINUITY CHECK
CVT-ECU
CVT-ECU REMOVAL AND INSTALLATION
CVT FLUID COOLER LINE
CVT FLUID COOLER LINE REMOVAL AND INSTALLATION
23B-CONTINUOUSLY VARIABLE TRANSMISSION OVERHAUL
GENERAL INFORMATION
LUBRICANT(S)
SPECIAL TOOLS
TRANSMISSION
26 -FRONT AXLE
LUBRICANT(S)
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
WHEEL BEARING AXIAL PLAY CHECK
HUB BOLT REPLACEMENT
FRONT AXLE HUB ASSEMBLY
FRONT AXLE HUB ASSEMBLY REMOVAL AND INSTALLATION
FRONT AXLE HUB ASSEMBLY DISASSEMBLY AND REASSEMBLY
DRIVESHAFT ASSEMBLY
(2017 Basic) DRIVESHAFT ASSEMBLY REMOVAL AND INSTALLATION
(2018 Supplement) DRIVESHAFT ASSEMBLY REMOVAL AND INSTALLATION
DRIVESHAFT ASSEMBLY DISASSEMBLY AND REASSEMBLY
EBJ BOOT REPLACEMENT
27 -REAR AXLE
GENERAL INFORMATION
SEALANT(S) OR ADHESIVE(S)
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
REAR HUB ROTARY-SLIDING RESISTANCE CHECK
REAR AXLE HUB ASSEMBLY
REAR AXLE HUB ASSEMBLY REMOVAL AND INSTALLATION
REAR AXLE HUB ASSEMBLY DISASSEMBLY AND REASSEMBLY
31 -WHEEL AND TYRE
GENERAL INFORMATION
SPECIAL TOOL(S)
TROUBLESHOOTING
TROUBLESHOOTING
WHEEL BALANCE ACCURACY
TYRE PRESSURE MONITORING SYSTEM (TPMS) DIAGNOSIS<VEHICLES FOR GCC (VEHICLE WITH TPMS)>
INTRODUCTION
DIAGNOSTIC FUNCTION
TPMS WARNING LAMP CHECK
TPMS DIAGNOSIS CODE CHART
TPMS DIAGNOSIS CODE PROCEDURES
CODE No.C1564 VEHICLE SPEED DATA INVALID
CODE No.C1900 ID CODE FAILURE
CODE No.C1901 TPMS ABNORMALITY (VEHICLE SPEED SENSOR INPUT ABNORMALITY)
CODE No.C1910, C1920, C1930, C1940 TRANSMITTER BATT. VOLTAGE TYRE1, 2, 3, 4/ C1911, C1921, C1931, C1941 TYRE ID RECEPTION FAIL TYRE1, 2, 3, 4
CODE No.C1912, C1922, C1932, C1942 TYRE AIR PRESSURE LOW TYRE1, 2, 3, 4
CODE No.C1913, C1923, C1933, C1943 ACCELERATION SENSOR TYRE1, 2, 3, 4/ C1914, C1924, C1934, C1944 TYRE AIR PRESSURE SENSOR TYRE1, 2, 3, 4
CODE No.C1915, C1925, C1935, C1945 TRANSMITTER OFF MODE TYRE1, 2, 3, 4
TPMS SYMPTOM CHART
TPMS SYMPTOM PROCEDURES
THE TPMS WARNING LAMP STAYS ON
TPMS WARNING LAMP FLASHES
TPMS SERVICE DATA LIST
CHECK AT TPMS RECEIVER
ON-VEHICLE SERVICE
TYRE INFLATION PRESSURE CHECK
TYRE WEAR CHECK
WHEEL RUNOUT CHECK
TPMS TRANSMITTER CHECK OR REPLACE<VEHICLES FOR GCC (VEHICLE WITH TPMS)>
TPMS SPECIAL FUNCTION<VEHICLES FOR GCC (VEHICLE WITH TPMS)>
TYRE PRESSURE SENSOR ID REGISTRATION
TYRE PRESSURE SENSOR ID CHECK
TYRE PRESSURE SENSOR CHECK
WHEEL AND TYRE
WHEEL AND TYRE REMOVAL AND INSTALLATION
TYRE PRESSURE MONITORING SYSTEM (TPMS)<VEHICLES FOR GCC (VEHICLE WITH TPMS)>
TPMS RECEIVER
TPMS RECEIVER REMOVAL AND INSTALLATION
TPMS TRANSMITTER
TPMS TRANSMITTER REMOVAL AND INSTALLATION
32 -POWER PLANT MOUNT
GENERAL INFORMATION
ENGINE MOUNTING
ENGINE MOUNTING REMOVAL AND INSTALLATION
TRANSMISSION MOUNTING
TRANSMISSION MOUNTING REMOVAL AND INSTALLATION
ENGINE ROLL STOPPER ROD
ENGINE ROLL STOPPER ROD REMOVAL AND INSTALLATION
FRONT AXLE CROSSMEMBER
FRONT AXLE CROSSMEMBER REMOVAL AND INSTALLATION
33 -FRONT SUSPENSION
GENERAL INFORMATION
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
FRONT WHEEL ALIGNMENT CHECK AND ADJUSTMENT
LOWER ARM BALL JOINT AXIAL PLAY CHECK
LOWER ARM BALL JOINT DUST COVER CHECK
STRUT ASSEMBLY
STRUT ASSEMBLY REMOVAL AND INSTALLATION
STRUT ASSEMBLY INSPECTION
STRUT ASSEMBLY DISASSEMBLY AND REASSEMBLY
STRUT ASSEMBLY INSPECTION (DISASSEMBLY AND REASSEMBLY)
LOWER ARM
LOWER ARM REMOVAL AND INSTALLATION
LOWER ARM INSPECTION
LOWER ARM BUSHING REPLACEMENT
STABILIZER BAR
STABILIZER BAR REMOVAL AND INSTALLATION
STABILIZER BAR INSPECTION
34 -REAR SUSPENSION
GENERAL INFORMATION
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
REAR WHEEL ALIGNMENT CHECK AND ADJUSTMENT
SHOCK ABSORBER AND COIL SPRING
SHOCK ABSORBER AND COIL SPRING REMOVAL AND INSTALLATION
TORSION AXLE ARM ASSEMBLY
TORSION AXLE ARM ASSEMBLY REMOVAL AND INSTALLATION
INSPECTION
35A-BASIC BRAKE
GENERAL INFORMATION
LUBRICANTS
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
BRAKE PEDAL CHECK AND ADJUSTMENT
STOP LAMP RELAY REPLACEMENT
BRAKE BOOSTER OPERATING CHECK
CHECK VALVE OPERATION CHECK
PROPORTIONING VALVE FUNCTION TEST<Vehicles without ABS or ASC>
BASIC BRAKE SYSTEM BLEEDING
BRAKE FLUID LEVEL SENSOR CHECK
BRAKE PAD CHECK
BRAKE PAD REPLACEMENT
BRAKE DISC CHECK
BRAKE DRAG FORCE CHECK
BRAKE LINING THICKNESS CHECK
BRAKE DRUM INSIDE DIAMETER CHECK
BRAKE LINING AND BRAKE DRUM CONTACT CHECK
BRAKE PEDAL
BRAKE PEDAL REMOVAL AND INSTALLATION
INSPECTION
STOP LAMP SWITCH CHECK
MASTER CYLINDER ASSEMBLY AND BRAKE BOOSTER ASSEMBLY
MASTER CYLINDER ASSEMBLY AND BRAKE BOOSTER ASSEMBLY REMOVAL AND INSTALLATION<LHD>
MASTER CYLINDER ASSEMBLY AND BRAKE BOOSTER ASSEMBLY REMOVAL AND INSTALLATION<RHD>
FRONT DISC BRAKE ASSEMBLY
FRONT DISC BRAKE ASSEMBLY REMOVAL AND INSTALLATION
FRONT DISC BRAKE ASSEMBLY DISASSEMBLY AND REASSEMBLY
INSPECTION
REAR DRUM BRAKE
REAR DRUM BRAKE REMOVAL AND INSTALLATION
REAR DRUM BRAKE WHEEL CYLINDER ASSEMBLY DISASSEMBLY AND REASSEMBLY
35B-ANTI-SKID BRAKING SYSTEM (ABS)
SPECIAL TOOLS
TROUBLESHOOTING
NOTES WITH REGARD TO DIAGNOSIS
ABS WARNING LAMP INSPECTION
DIAGNOSIS FUNCTION
CODE NO. C1200, C1205, C1210, C1215 ABS SENSOR (OPEN CIRCUIT OR SHORT CIRCUIT)
CODE NO. C1201, C1206, C1211, C1216 ABS SENSOR
CODE NO. C1202, C1207, C1212, C1217 WHEEL SPEED SENSOR SYSTEM MALFUNCTION (POWER CIRCUIT)
CODE NO. C1225 ABS SENSOR SYSTEM (OUTPUT SIGNAL MALFUNCTION)
CODE NO. C1226, C1231, C1236, C1241, C1246, C1251, C1256, C1261, C1278, C1279 CONTROL SOLENOID VALVE PRESSURE HOLDING SYSTEM
CODE NO. C1266, C1273, C1274 MOTOR SYSTEM
CODE NO. C1278 VALVE RELAY STUCK OFF
CODE NO. C1340 STOP LAMP SWITCH OPEN CIRCUIT
CODE NO. C1395 BRAKE FLUID NOT REFILLED
CODE NO. C1860 ABS-ECU POWER SUPPLY HIGH VOLTAGE
CODE NO. C1861 ABS-ECU POWER SUPPLY LOW VOLTAGE
CODE NO. U1073 BUS OFF
CODE NO. U1108 METER CAN TIMEOUT ERROR
CODE NO. U1109 ETACS CAN TIMEOUT ERROR
CODE NO. U1195 VARIANT CODING NOT COMPLETED
CODE NO. U1197 VARIANT CODING VALUE INVALID
SYMPTOM CHART
SYMPTOM PROCEDURES
THE SCAN TOOL CANNOT COMMUNICATE WITH THE ABS-ECU.
ABS WARNING LAMP DOES NOT ILLUMINATE WHEN IGNITION SWITCH IS TURNED TO THE ON POSITION (ENGINE STOPPED).
BRAKE WARNING LAMP STAYS ON WITH THE PARKING BRAKE LEVER RELEASED.
ABS WARNING LAMP STAYS ON AFTER THE ENGINE IS STARTED.
BRAKES DO NOT FUNCTION NORMALLY.
ABS SYSTEM INOPERATIVE
ABS-ECU POWER SUPPLY CIRCUIT SYSTEM
ABS OPERATES TOO FREQUENTLY.
THE INITIAL CHECK SOUND OF HYDRAULIC UNIT LOUD
CHECK AT ECU TERMINAL
ON-VEHICLE SERVICE
WHEEL SPEED SENSOR OUTPUT CURRENT MEASUREMENT
HYDRAULIC UNIT CHECK
REMEDY FOR A DISCHARGED BATTERY
HYDRAULIC UNIT
HYDRAULIC UNIT REMOVAL AND INSTALLATION
WHEEL SPEED SENSOR
WHEEL SPEED SENSOR REMOVAL AND INSTALLATION
WHEEL SPEED SENSOR INSPECTION
35C-ACTIVE STABILITY CONTROL SYSTEM (ASC)
SPECIAL TOOLS
TROUBLESHOOTING
INSPECTION OF ASC INDICATOR LAMP, ASC OFF INDICATOR LAMP, ABS WARNING LAMP, AND BRAKE WARNING LAMP
DIAGNOSIS FUNCTION
CODE NO. C1011, C101C, C1027, C1032 ABNORMALITY IN WHEEL SPEED SENSOR SIGNAL
CODE NO. C1014, C101F, C102A, C1035 MUTUAL MONITORING OF WHEEL SPEED SENSOR
CODE NO. C1041, 1042, 1043, 1044 WHEEL SPEED SENSOR SIGNAL IMPLAUSIBLE IN CYCLES
CODE NO. C1200, C1205, C1210, C1215 WHEEL SPEED SENSOR SYSTEM (OPEN CIRCUIT OR SHORT TO EARTH OR POWER SUPPLY)
CODE NO. C1225 WHEEL SPEED SENSOR SYSTEM (SENSOR OUTPUT ERROR)
CODE NO. C1226, C1231, C1236, C1241, C1246, C1251, C1256, C1261, C1300, C1305, C1310, C1315 CONTROL SOLENOID VALVE SYSTEM
CODE NO. C1266, C1271, C1273, C1274 MOTOR SYSTEM
CODE NO. C1276, C1278, C1279 VALVE RELAY SYSTEM
CODE NO. C1291: REVERSE SIGNAL (SEIZURE)<Vehicles with M/T>
CODE NO. C1340 STOP LAMP SWITCH SIGNAL ERROR
CODE NO. C1346 STOP LAMP DRIVE RELAY CIRCUIT<Vehicles with FCM>
CODE NO. C1364 INTERNAL MALFUNCTION OF PRESSURE SENSOR
CODE NO. C1366 LATERAL G-SENSOR SIGNAL ERROR
CODE NO. C1392 INCOMP. LEARN NEUTRAL (LONGITUDINAL G)
CODE NO. C1394 STEERING WHEEL SENSOR NEUTRAL POINT NOT LEARNED
CODE NO. C1395 BRAKE FLUID FILLING NOT COMPLETED
CODE NO. C1396 ENGINE TORQUE INTERVENTION REJECTED
CODE NO. C1505 STEERING WHEEL SENSOR ERROR
CODE NO. C1607 MALFUNCTION OF ASC-ECU
CODE NO. C1608 EEPROM FAIL
CODE NO. C1707 IMPLAUSIBLE CODING DATA
CODE NO. C1802 FCM ECU fail<Vehicles with FCM>
CODE NO. C1860 ABNORMAL RISE OF ASC-ECU POWER SUPPLY VOLTAGE
CODE NO. C1861 ABNORMAL DROP OF ASC-ECU POWER SUPPLY VOLTAGE
CODE NO. C2206 RE-EXECUTION OF VARIANT CODING
CODE NO. U0401 ENGINE CAN MESSAGE
CODE NO. U0402 T/M CAN MESSAGE
CODE NO. U0428 SAS CAN MESSAGE
CODE NO. U1011 ACC/FCM Parity/Toggle bit error<Vehicles with FCM>
CODE NO. U1014 FCM (CAN message)<Vehicles with FCM>
CODE NO. U1100 ENGINE-RELATED CAN TIME-OUT ERROR
CODE NO. U1101 T/M CAN TIMEOUT
CODE NO. U1104 STEERING WHEEL SENSOR CAN TIME-OUT ERROR
CODE NO. U1108 METER CAN TIMEOUT/NOT EQUIPPED
CODE NO. U1109 ETACS CAN TIMEOUT/NOT EQUIPPED
CODE NO. U1195 CODING NOT COMPLETED
CODE NO. U1200, U1204 SAS ERROR
CODE NO. U1211 ENGINE PARITY/TOGGLE BIT ERROR
CODE NO. U15A0 ACC/FCM ECU CAN timeout<Vehicles with FCM>
SYMPTOM CHART
SYMPTOM PROCEDURES
THE M.U.T.-III CANNOT COMMUNICATE WITH TCL/ACTIVE STABILITY CONTROL SYSTEM-ECU
WHEN THE IGNITION SWITCH IS TURNED TO THE "ON" POSITION (ENGINE STOPPED), THE TCL OFF INDICATOR LAMP DOES NOT ILLUMINATE.
BRAKE WARNING LAMP DOES NOT ILLUMINATE WHEN THE IGNITION SWITCH IS TURNED TO ON POSITION (ENGINE STOPPED).
ASC INDICATOR LAMP STAYS ON AFTER THE ENGINE IS STARTED.
ABNORMALITY IN BRAKE OPERATION
ABNORMAL ACTIVE STABILITY CONTROL SYSTEM OPERATION
TCL/ACTIVE STABILITY CONTROL SYSTEM-ECU POWER SUPPLY CIRCUIT SYSTEM
ABS/STABILITY CONTROL/TCL OPERATES TOO FREQUENTLY.
ESS INOPERATIVE OR IMPROPER OPERATIVE
HSA DOES NOT WORK.
HSA WORKS ON A FLAT ROAD.
ASC-OFF INDICATOR LAMP STAYS ON AFTER THE ENGINE IS STARTED.
THE ASC SYSTEM CANNOT BE DISABLED WHEN ASC OFF SWITCH IS PRESSED TO TURN THE SYSTEM OFF.
ON-VEHICLE SERVICE
G AND YAW RATE SENSOR CALIBRATION
STEERING WHEEL SENSOR CALIBRATION
ASC OFF SWITCH
ASC OFF SWITCH REMOVAL AND INSTALLATION
ASC OFF SWITCH
HYDRAULIC UNIT
WHEEL SPEED SENSOR
STEERING WHEEL SENSOR REMOVAL AND INSTALLATION
36 -PARKING BRAKES
ON-VEHICLE SERVICE
PARKING BRAKE LEVER STROKE CHECK AND ADJUSTMENT
PARKING BRAKE SWITCH CHECK
PARKING BRAKE LEVER
PARKING BRAKE LEVER REMOVAL AND INSTALLATION
PARKING BRAKE CABLE
PARKING BRAKE CABLE REMOVAL AND INSTALLATION
37 -ELECTRIC POWER STEERING (EPS)
GENERAL INFORMATION
LUBRICANT(S)
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS FUNCTION
CHECK OF ELECTRIC POWER STEERING SYSTEM (EPS) WARNING LAMP
C1511/C1512 TORQUE SENSOR ABNORMALITY
C1513 LARGE DIFFERENCE BETWEEN MAIN TORQUE SENSOR AND SUB TORQUE SENSOR
C1514 TORQUE SENSOR POWER SUPPLY ABNORMALITY
C1531 MOTOR TERMINAL VOLTAGE ABNORMALITY
C1532 OVER REAL CURRENT OF MOTOR
C1534 UNDER REAL CURRENT OF MOTOR
C1550 ECU INTERNAL ERROR
C1560 VEHICLE SPEED DATA (CAN) INPUT MALFUNCTION
C1565 ENGINE REVOLUTION DATA INVALID
C1657 IMPLAUSIBLE VARIANT CODING DATA
C1860 POWER SUPPLY VOLTAGE ABNORMALITY (HIGH VOLTAGE)
C1861 POWER SUPPLY VOLTAGE ABNORMALITY (LOW VOLTAGE)
U0100 ENGINE CAN TIMEOUT
U0126 SAS CAN TIMEOUT
U0141 ETACS CAN TIMEOUT
U1073 BUS OFF
CODE No. U1108 METER CAN TIMEOUT/NOT EQUIPPED
U1190 NO RECEIVE FAULT DETECT SIGNAL
SYMPTOM CHART
SYMPTOM PROCEDURES
M.U.T.-III CANNOT COMMUNICATE WITH ELECTRIC POWER STEERING SYSTEM (EPS) <ECU POWER SUPPLY CIRCUIT SYSTEM CHECK>
ELECTRIC POWER STEERING SYSTEM (EPS) WARNING LAMP ILLUMINATES BUT DIAGNOSIS CODE IS NOT STORED.
STEERING WHEEL HAS BECOME HEAVY, BUT EPS WARNING DISPLAY DOES NOT ILLUMINATE (POWER SUPPLY VOLTAGE ASSIST FALL)
ON-VEHICLE SERVICE
STEERING WHEEL FREE PLAY CHECK
STEERING ANGLE CHECK
BALL JOINT DUST COVER INSPECTION
TIE ROD END BALL JOINT STARTING TORQUE CHECK
STATIONARY STEERING EFFORT CHECK
STEERING WHEEL RETURN TO CENTRE CHECK
STEERING COLUMN SHAFT ASSEMBLY SHOCK ABSORBING MECHANISM CHECK
STEERING WHEEL
STEERING WHEEL REMOVAL AND INSTALLATION
STEERING SHAFT REMOVAL AND INSTALLATION
INSPECTION
STEERING SHAFT DISASSEMBLY AND REASSEMBLY
INSPECTION
POWER STEERING GEAR BOX AND LINKAGE
POWER STEERING GEAR BOX AND LINKAGE REMOVAL AND INSTALLATION
INSPECTION
POWER STEERING GEAR BOX AND LINKAGE DISASSEMBLY AND REASSEMBLY
ELECTRIC POWER STEERING CONTROL UNIT (EPS-ECU)
ELECTRIC POWER STEERING CONTROL UNIT (EPS-ECU) REMOVAL AND INSTALLATION
42A-BODY
HOOD
ON-VEHICLE SERVICE
ADJUSTMENT OF CLEARANCE AROUND HOOD
ADJUSTMENT OF ALIGNMENT OF HOOD STEPPED PORTION AND HOOD STRIKER
ADJUSTMENT OF HOOD HEIGHT
HOOD
HOOD REMOVAL AND INSTALLATION
FENDER
FENDER REMOVAL AND INSTALLATION
SPLASH SHIELD
SPLASH SHIELD REMOVAL AND INSTALLATION
FUEL FILLER LID
FUEL FILLER LID REMOVAL AND INSTALLATION<LH DRIVE VEHICLES>
FUEL FILLER LID REMOVAL AND INSTALLATION<RH DRIVE VEHICLES>
WINDOW GLASS
VISIBLE RAY TRANSMISSIVITY RATE FOR WINDOW GLASS
(2017 Basic) SEALANT(S) OR ADHESIVE(S)
(2018 Supplement) SEALANT(S) OR ADHESIVE(S)
(2017 Basic) LUBRICANT(S)
(2018 Supplement) LUBRICANT(S)
(2017 Basic) SPECIAL TOOL(S)
(2018 Supplement) SPECIAL TOOL(S)
WINDSHIELD
(2017 Basic) WINDSHIELD REMOVAL AND INSTALLATION
(2018 Supplement) WINDSHIELD REMOVAL AND INSTALLATION
REAR WINDOW GLASS
REAR WINDOW GLASS REMOVAL AND INSTALLATION
DOOR
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART<CENTRAL DOOR LOCKING SYSTEM>
SYMPTOM PROCEDURES<CENTRAL DOOR LOCKING SYSTEM>
CENTRAL DOOR LOCKING SYSTEM DOES NOT OPERATE
SOME DOORS DO NOT LOCK OR UNLOCK
SELECTOR "P" POSITION-LINKED DOOR UNLOCK FUNCTION DOES NOT OPERATE.<CVT>
KEY-IN WARNING FUNCTION DOES NOT WORK.
SYMPTOM CHART<POWER WINDOW (Vehicles without safety system)>
SYMPTOM PROCEDURES<POWER WINDOW (Vehicles without safety system)>
POWER WINDOWS DO NOT WORK AT ALL<POWER WINDOW (Vehicles without safety system)>
Front right power window does not work<POWER WINDOW (Vehicles without safety system)>
Front left power window does not work<POWER WINDOW (Vehicles without safety system)>
POWER WINDOW TIMER FUNCTION DOES NOT WORK NORMALLY<POWER WINDOW (Vehicles without safety system)>
SYMPTOM CHART<POWER WINDOW (Vehicles with safety system)>
SYMPTOM PROCEDURES<POWER WINDOW (Vehicles with safety system)>
POWER WINDOWS DO NOT WORK AT ALL<POWER WINDOW (Vehicles with safety system)>
POWER WINDOW MAIN SWITCH CANNOT OPERATE DRIVER''S WINDOW
POWER WINDOW SUB SWITCH CANNOT OPERATE PASSENGER''S OR REAR WINDOWS.<POWER WINDOW (Vehicles with safety system)>
POWER WINDOW MAIN SWITCH CANNOT OPERATE EITHER OF PASSENGER''S OR REAR POWER WINDOWS<POWER WINDOW (Vehicles with safety system)>
POWER WINDOW TIMER FUNCTION DOES NOT WORK NORMALLY<POWER WINDOW (Vehicles with safety system)>
POWER WINDOW ANTI-TRAP FUNCTION DOES NOT WORK<DRIVER SIDE DOOR>
WHEN THE GLASS IS RAISED, THEN IT LOWERS AUTOMATICALLY<DRIVER SIDE DOOR>
POWER WINDOW MAIN SWITCH ONE-TOUCH FUNCTION DOES NOT WORK
CHECK AT ECU TERMINAL<POWER WINDOW (Vehicles with safety system)>
ON-VEHICLE SERVICE
DOOR FIT ADJUSTMENT
DOOR WINDOW GLASS ADJUSTMENT
POWER WINDOW CHECK
ADJUSTMENT AND REPLACEMENT WHEN POWER WINDOWS FAIL
POWER WINDOW SAFETY MECHANISM CHECK<Vehicles with safety system (driver side)>
POWER WINDOW TIMER FUNCTION CHECK
POWER WINDOW OPERATING CURRENT CHECK
POWER WINDOW RELAY CHECK
POWER WINDOW INITIALIZED ADJUSTMENT<Vehicles with safety system (driver side)>
CENTRAL DOOR LOCKING SYSTEM INSPECTION
CHECK OF KEY LOCK PREVENTION FUNCTION
SHIFT "P" INTERLINK DOOR UNLOCK FUNCTION CHECK<CVT>
DOOR HANDLE AND LATCH INSPECTION
DOOR OUTSIDE HANDLE PLAY CHECK
DOOR INSIDE HANDLE PLAY ADJUSTMENT
CUSTOMISATION FUNCTION
DOOR ASSEMBLY
DOOR ASSEMBLY REMOVAL AND INSTALLATION
DOOR SWITCH CHECK
DOOR GLASS AND REGULATOR
DOOR GLASS AND REGULATOR REMOVAL AND INSTALLATION
DOOR GLASS AND REGULATOR INSPECTION
DOOR HANDLE AND LATCH REMOVAL AND INSTALLATION
INSPECTION
WINDOW GLASS RUNCHANNEL AND DOOR OPENING WEATHERSTRIP
WINDOW GLASS RUNCHANNEL AND DOOR OPENING WEATHERSTRIP REMOVAL AND INSTALLATION
TRUNK LID
SPECIAL TOOL(S)
ON-VEHICLE SERVICE
ADJUSTMENT OF CLEARANCE AROUND TRUNK LID
TRUNK LID STRIKER ADJUSTMENT
TRUNK LID
TRUNK LID REMOVAL AND INSTALLATION
TRUNK LID LATCH INSPECTION
KEYLESS ENTRY SYSTEM<Vehicles without Keyless operation system>
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
KEYLESS ENTRY SYSTEM DOES NOT OPERATE
THE DOME LAMP, THE HAZARD WARNING LAMPS AND THE HORN DO NOT OPERATE THROUGH THE ANSWERBACK FUNCTION.
AFTER THE DOORS ARE UNLOCKED BY USING THE KEYLESS ENTRY SYSTEM, THE TIMER LOCK FUNCTION DOES NOT WORK.
MULTIMODE KEYLESS ENTRY FUNCTION DOES NOT WORK AT ALL.<Vehicles with electric retractable remote control>
ON-VEHICLE SERVICE
KEYLESS ENTRY SYSTEM INSPECTION
KEYLESS ENTRY SYSTEM TIMER LOCK FUNCTION INSPECTION
MULTIMODE KEYLESS ENTRY FUNCTION CHECK<Vehicles with electric retractable remote control>
METHOD OF REGISTERING A SECRET CODE
TRANSMITTER
TRANSMITTER DISASSEMBLY AND REASSEMBLY
LOOSE PANEL
LOOSE PANEL REMOVAL AND INSTALLATION
42B-KEYLESS OPERATION SYSTEM (KOS)
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS FUNCTION
TROUBLESHOOTING PROCEDURE WHEN VEHICLE POWER DOES NOT TURN ON
FORCED POWER SUPPLY OUTPUT PROCEDURE
WARNING AND WARNING INDICATOR LIST
B1130 Power output status unmatched
B1131 Starter output internal fail
B1132 Starter output external fail
B1133 IG1 output internal fail
B1134 ECU power supply
B1135 Push start switch
B1136 Stop lamp switch
B1137 P range detect SW
B1138 Vehicle speed data fail
B1141 ESL authenticate timeout
B1142 ESL authenticate error
B1143 ESL status unmatched
B1144 ESL lock/unlock fail
B1145 ESL power supply circuit
B1146 ESL drive circuit
B1147 ESL LIN communication fail
B1148 ESL power control
B1149 KOS power control monitor input
B1150 OSS authenticate timeout(ESL)
B1155 EEPROM fail(ESL)
B1156 Power supply voltage fail
B1157 OSS EEPROM fail
B1160 Key code not programmed
B1161 Chassis No. mismatch
B1163 Coding data mismatch
B1164 Chassis No. not programmed(ESL)
B1166 Special mode
B1168 ACC system fail
B1169 IG2 system fail
B1731 Engine ECU communication timeout
B1A08 KOS Key 1 Malfunction
B1A10 KOS Key 1 Low Battery
B1A24 Key not Registered
B1A25 Key Registered to Another Vehicle
B1A28 Engine ECU authenticate error
B2352 Immobilizer Antenna Malfunction
B2400 KOS Key Registration Fail
B2401 KOS Key ID not registered
B240A FR Antenna (Outdoor) Open Circuit
B240B FL Antenna (Outdoor) Open Circuit
B240C Tail Gate Antenna (Outdoor) Open Circuit
B240D Front Antenna (Indoor) Open Circuit
B240E RR Antenna (Indoor) Open Circuit
U0100 Engine CAN timeout
U0101 T/M CAN timeout
U0141 ETACS-ECU CAN Timeout
U0155 Meter CAN Timeout
U0164 A/C CAN Timeout
U1190 No receive fault detect signal
U1195 Coding not completed
SPECIAL FUNCTION TABLE
SYMPTOM CHART
SYMPTOM PROCEDURES
M.U.T.-III CANNOT COMMUNICATE WITH KOS-ECU.
KEYLESS OPERATION KEY CANNOT BE REGISTERED WITH M.U.T.-III
ABNORMALITY IN KOS-ECU POWER SUPPLY AND EARTH CIRCUITS
KEYLESS OPERATION WARNING LAMP DOES NOT GO OUT.
NO DOOR CAN BE OPERATED BY OPERATING A KEYLESS OPERATION SWITCH ON ANY DOOR, OR BY TOUCHING THE TOUCH SENSOR.
DRIVER''S KEYLESS OPERATION SWITCH (LOCK) DOES NOT WORK.
TRUNK LID OPENER FUNCTION DOES NOT WORK.
KEYLESS ENTRY SYSTEM DOES NOT WORK AT ALL.
KOS TIMER LOCK FUNCTION DOES NOT WORK.
KEYLESS ENTRY HAZARD ANSWERBACK FUNCTION OR THE ROOM LAMP ANSWERBACK FUNCTION DOES NOT WORK NORMALLY.
OUTER BUZZER DOES NOT SOUND.
Vehicle power does not turn ON. (not possible with both of power supply mode ACC and ON)
Engine does not start (cranking is not performed).
Vehicle power cannot be turned OFF when the shift position is in "P." (Power supply mode ON to ACC is possible)<CVT vehicle>
Electric steering lock does not become locked. (At power supply mode OFF)
ACC POWER AUTO CUT FUNCTION DOES NOT WORK NORMALLY
VEHICLE POWER CANNOT BE TURNED OFF.
TERMINAL VOLTAGE REFERENCE CHART
ON-VEHICLE SERVICE
ID CODES REGISTRATION PROCEDURE
ANTENNA COMMUNICATION TEST
CHECK OF ENGINE SWITCH OPERATION FUNCTION
CHECK OF ENGINE SWITCH INDICATOR FUNCTION
CHECK OF ENGINE SWITCH REMINDER BUZZER
REGISTRATION WHEN REPLACING OSS-ECU AND ELECTRIC STEERING LOCK
RELAY INSPECTION
CUSTOMIZATION FUNCTION
KOS & OSS-ECU
KOS-ECU REMOVAL AND INSTALLATION
OUTSIDE TRANSMISSION ANTENNA ASSEMBLY, INSIDE TRANSMISSION ANTENNA ASSEMBLY
OUTSIDE TRANSMISSION ANTENNA ASSEMBLY, INSIDE TRANSMISSION ANTENNA ASSEMBLY, RECEIVER ANTENNA MODULE REMOVAL AND INSTALLATION
KEYLESS OPERATION KEY DISASSEMBLY AND REASSEMBLY
LOCK/UNLOCK SWITCH
LOCK/UNLOCK SWITCH REMOVAL AND INSTALLATION
LOCK/UNLOCK SWITCH INSPECTION
KEY SLOT
(2017 Basic) KEY SLOT REMOVAL AND INSTALLATION
(2018 Supplement) KEY SLOT REMOVAL AND INSTALLATION<LHD>
KEY SLOT INSPECTION
ENGINE SWITCH
ENGINE SWITCH REMOVAL AND INSTALLATION
ENGINE SWITCH INSPECTION
ELECTRIC STEERING LOCK REMOVAL AND INSTALLATION
51 -EXTERIOR
GENERAL INFORMATION
FRONT BUMPER ASSEMBLY AND RADIATOR GRILLE
FRONT BUMPER ASSEMBLY AND RADIATOR GRILLE REMOVAL AND INSTALLATION
FRONT BUMPER ASSEMBLY AND RADIATOR GRILLE DISASSEMBLY AND REASSEMBLY
REAR BUMPER ASSEMBLY
REAR BUMPER ASSEMBLY REMOVAL AND INSTALLATION<VEHICLES FOR GCC>
REAR BUMPER ASSEMBLY REMOVAL AND INSTALLATION<EXCEPT VEHICLES FOR GCC>
GARNISHES AND MOULDINGS
SPECIAL TOOL(S)
LUBRICANT(S)
MOULDING REMOVAL AND INSTALLATION
DOOR SASH TAPE
SPECIAL TOOL(S)
LUBRICANT(S)
DOOR SASH TAPE REMOVAL AND INSTALLATION
UNDER COVER
UNDER COVER REMOVAL AND INSTALLATION<VEHICLES FOR THAILAND>
UNDER COVER REMOVAL AND INSTALLATION<EXCEPT VEHICLES FOR THAILAND>
WINDSHIELD WIPER AND WASHER
LUBRICANT(S)
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
THE WINDSHIELD WIPERS DO NOT WORK AT ALL
THE WINDSHIELD WIPERS DO NOT WORK WHEN THE WIPER SWITCH IS AT INT, WASHER OR MIST POSITION.
THE WINDSHIELD WIPERS DO NOT STOP AT THE SPECIFIED PARK POSITION
THE WINDSHIELD WIPERS DO NOT WORK NORMALLY
THE INTERMITTENT WIPER INTERVAL CANNOT BE ADJUSTED BY OPERATING THE WINDSHIELD INTERMITTENT WIPER VOLUME CONTROL
THE INTERMITTENT WIPER INTERVAL IS NOT CHANGED ACCORDING TO THE VEHICLES SPEED
THE WINDSHIELD WASHER DOES NOT WORK
ON-VEHICLE SERVICE
WINDSHIELD INTERMITTENT WIPER INSPECTION
WINDSHIELD WIPER
WINDSHIELD WIPER REMOVAL AND INSTALLATION<L.H. DRIVE VEHICLES>
WINDSHIELD WIPER REMOVAL AND INSTALLATION<R.H. DRIVE VEHICLES>
WINDSHIELD WIPER INSPECTION
WINDSHIELD WASHER
WINDSHIELD WASHER REMOVAL AND INSTALLATION
WINDSHIELD WASHER INSPECTION
MARK
LUBRICANT(S)
MARK REMOVAL AND INSTALLATION
DOOR MIRROR
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
ELECTRIC RETRACTABLE REMOTE CONTROLLED DOOR MIRROR DOES NOT WORK AT ALL
LEFT OR RIGHT SIDE ELECTRIC RETRACTABLE REMOTE CONTROLLED DOOR MIRROR DOES NOT WORK
ELECTRIC RETRACTABLE REMOTE CONTROLLED DOOR MIRROR TIMER FUNCTION DOES NOT WORK
VEHICLE SPEED-DEPENDENT UNFOLDING FUNCTION DOES NOT WORK NORMALLY
INSPECTION OF IGNITION SWITCH POSITION-LINKED FOLDING AND UNFOLDING FUNCTION FOR OUTSIDE MIRRORS
INSPECTION OF KEYLESS ENTRY SYSTEM-LINKED FOLDING AND UNFOLDING FUNCTION FOR OUTSIDE MIRRORS
ON-VEHICLE SERVICE
INSPECTION OF OUTSIDE MIRROR VEHICLE SPEED-DEPENDENT AUTOMATIC UNFOLDING FUNCTION
INSPECTION OF OUTSIDE MIRROR TIMER FUNCTION
DOOR MIRROR
DOOR MIRROR REMOVAL AND INSTALLATION
DOOR MIRROR INSPECTION
52A-INTERIOR
GENERAL INFORMATION
(2017 Basic) SPECIAL TOOLS
INSTRUMENT PANEL ASSEMBLY
INSTRUMENT PANEL ASSEMBLY REMOVAL AND INSTALLATION
GLOVE BOX
GLOVE BOX REMOVAL AND INSTALLATION
INSTRUMENT CENTRE PANEL
INSTRUMENT CENTRE PANEL REMOVAL AND INSTALLATION
INSTRUMENT LOWER PANEL
INSTRUMENT LOWER PANEL REMOVAL AND INSTALLATION<L.H. DRIVE VEHICLES>
INSTRUMENT LOWER PANEL REMOVAL AND INSTALLATION<R.H. DRIVE VEHICLES>
FLOOR CONSOLE ASSEMBLY
(2017 Basic) FLOOR CONSOLE ASSEMBLY REMOVAL AND INSTALLATION
(2018 Supplement) FLOOR CONSOLE ASSEMBLY REMOVAL AND INSTALLATION
TRIMS
INTERIOR TRIM
TRIM REMOVAL AND INSTALLATION
DOOR TRIM
DOOR TRIM REMOVAL AND INSTALLATION
HEADLINING
(2017 Basic) HEADLINING REMOVAL AND INSTALLATION
(2018 Supplement) HEADLINING REMOVAL AND INSTALLATION<VEHICLES FOR SINGAPORE>
INSIDE REAR VIEW MIRROR
SEAT ASSEMBLY
FRONT SEAT ASSEMBLY<HIGH SEATBACK TYPE>
FRONT SEAT ASSEMBLY REMOVAL AND INSTALLATION
FRONT SEAT ASSEMBLY DISASSEMBLY AND REASSEMBLY
FRONT SEAT ASSEMBLY<LOW SEATBACK TYPE>
FRONT SEAT ASSEMBLY<VEHICLES FOR SINGAPORE>
(2018 Supplement) FRONT SEAT ASSEMBLY REMOVAL AND INSTALLATION
(2018 Supplement) INSPECTION
(2018 Supplement) FRONT SEAT ASSEMBLY DISASSEMBLY AND REASSEMBLY
REAR SEAT ASSEMBLY
REAR SEAT ASSEMBLY REMOVAL AND INSTALLATION
REAR SEAT ASSEMBLY DISASSEMBLY AND REASSEMBLY
SEAT BELT
FRONT SEAT BELT
FRONT SEAT BELT REMOVAL AND INSTALLATION
INSPECTION
REAR SEAT BELT
REAR SEAT BELT REMOVAL AND INSTALLATION
52B-SUPPLEMENTAL RESTRAINT SYSTEM (SRS)
GENERAL DESCRIPTION
(2017 Basic) SERVICE PRECAUTIONS
(2018 Supplement) SERVICE PRECAUTIONS
TEST EQUIPMENT
TROUBLESHOOTING
DIAGNOSIS FUNCTION
SRS WARNING LAMP CHECK
(2017 Basic) DIAGNOSIS CODE CHART
(2018 Supplement) DIAGNOSIS CODE CHART
DTC B1400 DRIVER''S AIR BAG SQUIB SHORT-CIRCUITED
DTC B1401 DRIVER''S AIR BAG SQUIB OPEN-CIRCUITED
DTC B1402 DRIVER''S AIR BAG SQUIB DRIVE CIRCUIT (EARTH SIDE) SHORT-CIRCUITED
DTC B1403 DRIVER''S AIR BAG SQUIB DRIVE CIRCUIT (POWER SUPPLY SIDE) SHORT-CIRCUITED
(2017 Basic) DTC B1404 SYSTEM INSIDE SRS-ECU
(2018 Supplement) DTC B1404 SYSTEM INSIDE SRS-ECU
DTC B1410 FRONT PASSENGER''S AIR BAG SQUIB SHORT-CIRCUITED
DTC B1411 FRONT PASSENGER''S AIR BAG SQUIB OPEN-CIRCUITED
DTC B1412 FRONT PASSENGER''S SIDE AIR BAG SQUIB DRIVE CIRCUIT (EARTH SIDE) SHORT-CIRCUITED
DTC B1413 FRONT PASSENGER''S SIDE AIR BAG SQUIB DRIVE CIRCUIT (POWER SUPPLY SIDE) SHORT-CIRCUITED
DTC B1416 FRONT IMPACT SENSOR (LH) SYSTEM
DTC B1417 FRONT IMPACT SENSOR (LH) VOLTAGE ERROR
DTC B1418 FRONT IMPACT SENSOR (LH) COMMUNICATION ERROR
DTC B1476 POWER SUPPLY VOLTAGE [IG1 (A) VOLTAGE] DROPS ABNORMALLY
DTC B1499 IGNITION OF THE AIR BAG COMPLETED
DTC B1509 INCORRECT SRS-ECU
DTC B1519 SRS-ECU CONNECTOR LOCK OUT OF ORDER
DTC B1603 DRIVER''S SIDE SEAT BELT PRE-TENSIONER (SQUIB) SYSTEM
DTC B1604 DRIVER''S SIDE SEAT BELT PRE-TENSIONER (SQUIB) SYSTEM
DTC B1605 DRIVER''S SIDE SEAT BELT PRE-TENSIONER (SQUIB) SYSTEM
DTC B1606 DRIVER''S SIDE SEAT BELT PRE-TENSIONER (SQUIB) SYSTEM
DTC B1609 FRONT PASSENGER''S SIDE SEAT BELT PRE-TENSIONER (SQUIB) SYSTEM
DTC B1610 FRONT PASSENGER''S SIDE SEAT BELT PRE-TENSIONER (SQUIB) SYSTEM
DTC B1611 FRONT PASSENGER''S SIDE SEAT BELT PRE-TENSIONER (SQUIB) SYSTEM
DTC B1612 FRONT PASSENGER''S SIDE SEAT BELT PRE-TENSIONER (SQUIB) SYSTEM
DTC B1619 DRIVER''S SIDE SEAT LAP PRE_TENSIONER (SQUIB) SYSTEM
DTC B1620 DRIVER''S SIDE SEAT LAP PRE_TENSIONER (SQUIB) SYSTEM
DTC B1621 DRIVER''S SIDE SEAT LAP PRE_TENSIONER (SQUIB) SYSTEM
DTC B1622 DRIVER''S SIDE SEAT LAP PRE_TENSIONER (SQUIB) SYSTEM
DTC B1646 Coding data mismatch
DTC B1699 SRS collective deployment
DTC U1100 Engine CAN timeout
DTC U1102 ASC/TCL/ABS timeout/Not equipped
DTC U1108 Meter CAN timeout/Not equipped
DTC U1109 ETACS CAN timeout/Not equipped
DTC U1190 No receive fault detect signal
DTC U1195 Coding not completed
DTC U1199 Chassis No. not programmed
DTC U119A Chassis No. mismatch
(2018 Supplement) DTC B1420 SIDE-AIRBAG SQUIB (RH) SHORT-CIRCUITED
(2018 Supplement) DTC B1421 SIDE-AIRBAG SQUIB (RH) OPEN-CIRCUITED
(2018 Supplement) DTC B1422 SIDE-AIRBAG SQUIB (RH) DRIVE CIRCUIT (EARTH SIDE) SHORTED
(2018 Supplement) DTC B1423 SIDE-AIRBAG SQUIB (RH) DRIVE CIRCUIT (POWER SUPPLY SIDE) SHORTED
(2018 Supplement) DTC B1426 G-SENSOR OF SIDE IMPACT SENSOR (RH)FAILURE
(2018 Supplement) DTC B1427 SIDE IMPACT SENSOR (RH) VOLTAGE ERROR
(2018 Supplement) DTC B1428 SIDE IMPACT SENSOR (RH) COMMUNICATION ERROR
(2018 Supplement) DTC B1430 SIDE-AIRBAG SQUIB (LH) SHORT-CIRCUITED
(2018 Supplement) DTC B1431 SIDE-AIRBAG SQUIB (LH) OPEN-CIRCUITED
(2018 Supplement) DTC B1432 SIDE-AIRBAG SQUIB (LH) DRIVE CIRCUIT (GROUND SIDE) SHORTED
(2018 Supplement) DTC B1433 SIDE-AIRBAG SQUIB (LH) DRIVE CIRCUIT (POWER SUPPLY SIDE) SHORTED
(2018 Supplement) DTC B1437 SIDE IMPACT SENSOR (LH) VOLTAGE ERROR
(2018 Supplement) DTC B1438 SIDE IMPACT SENSOR (LH) COMMUNICATION ERROR
(2018 Supplement) DTC B1440 CURTAIN AIR BAG SQUIB (RH) SHORT-CIRCUITED
(2018 Supplement) DTC B1441 CURTAIN AIR BAG SQUIB (RH) OPEN-CIRCUITED
(2018 Supplement) DTC B1442 CURTAIN AIR BAG SQUIB (RH) DRIVE CIRCUIT (EARTH SIDE) SHORTED
(2018 Supplement) DTC B1443 CURTAIN AIR BAG SQUIB (RH) DRIVE CIRCUIT (POWER SUPPLY SIDE) SHORTED
(2018 Supplement) DTC B1450 CURTAIN AIR BAG SQUIB (LH) SHORT-CIRCUITED
(2018 Supplement) DTC B1451 CURTAIN AIR BAG SQUIB (LH) OPEN-CIRCUITED
(2018 Supplement) DTC B1452 CURTAIN AIR BAG SQUIB (LH) DRIVE CIRCUIT (EARTH SIDE) SHORTED
(2018 Supplement) DTC B1453 CURTAIN AIR BAG SQUIB (LH) DRIVE CIRCUIT (POWER SUPPLY SIDE) SHORTED
(2018 Supplement) DTC B1625 LAP PRE-TENSIONER SQUIB SHORT-CIRCUITED
(2018 Supplement) DTC B1626 LAP PRE-TENSIONER SQUIB OPEN-CIRCUITED
(2018 Supplement) DTC B1627 LAP PRE-TENSIONER SQUIB DRIVE CIRCUIT (EARTH SIDE) SHORT-CIRCUITED
(2018 Supplement) DTC B1628 LAP PRE-TENSIONER SQUIB DRIVE CIRCUIT (POWER SUPPLY SIDE) SHORT-CIRCUITED
SYMPTOM CHART
SYMPTOM PROCEDURES
THE M.U.T.-III CANNOT COMMUNICATE WITH THE SRS-ECU.
WHEN THE IGNITION SWITCH IS TURNED TO "ON", THE SRS WARNING LAMP DOES NOT ILLUMINATE.
AFTER THE IGNITION SWITCH IS TURNED TO "ON", THE SRS WARNING LAMP DOES NOT GO OUT.
(2017 Basic) POST-COLLISION DIAGNOSIS
(2018 Supplement) POST-COLLISION DIAGNOSIS
INDIVIDUAL COMPONENT SERVICE
(2017 Basic) WARNING/CAUTION LABELS
(2018 Supplement) WARNING/CAUTION LABELS
FRONT IMPACT SENSORS
FRONT IMPACT SENSOR REMOVAL AND INSTALLATION
FRONT IMPACT SENSOR INSPECTION
SRS CONTROL UNIT (SRS-ECU)
SRS CONTROL UNIT (SRS-ECU) REMOVAL AND INSTALLATION
SRS CONTROL UNIT (SRS-ECU) INSPECTION
DRIVER''S AIR BAG MODULE AND CLOCK SPRING
DRIVER''S AIR BAG MODULE AND CLOCK SPRING REMOVAL AND INSTALLATION
DRIVER''S AIR BAG MODULE INSPECTION
PASSENGER''S (FRONT) AIR BAG MODULE
PASSENGER''S (FRONT) AIR BAG MODULE REMOVAL AND INSTALLATION
PASSENGER''S (FRONT) AIR BAG MODULE INSPECTION
SEAT BELTS WITH PRE-TENSIONER
(2017 Basic) REMOVAL AND INSTALLATION OF SEAT BELTS WITH PRE-TENSIONER
(2018 Supplement) REMOVAL AND INSTALLATION OF SEAT BELTS WITH PRE-TENSIONER<VEHICLES FOR SINGAPORE>
CHECK OF SEAT BELTS WITH PRE-TENSIONER
SIDE-AIRBAG MODULE(S)
(2018 Supplement) SIDE-AIRBAG MODULE(S) REMOVAL AND INSTALLATION
(2018 Supplement) SIDE-AIRBAG MODULE(S) INSPECTION
CURTAIN AIR BAG MODULE(S)
(2018 Supplement) CURTAIN AIR BAG MODULE(S) REMOVAL AND INSTALLATION
(2018 Supplement) CURTAIN AIR BAG MODULE(S) INSPECTION
SIDE IMPACT SENSOR
(2018 Supplement) SIDE IMPACT SENSOR REMOVAL AND INSTALLATION
(2018 Supplement) SIDE IMPACT SENSOR INSPECTION
AIR BAG MODULE AND SEAT BELT PRE-TENSIONER DISPOSAL PROCEDURES
PRE-TENSIONER FITTED SEATBELT DISPOSAL PROCEDURE
54A-CHASSIS ELECTRICAL
BATTERY
ON-VEHICLE SERVICE
FLUID LEVEL AND SPECIFIC GRAVITY INSPECTION
BATTERY CHARGING
BATTERY TEST
BATTERY REMOVAL AND INSTALLATION
IGNITION SWITCH
SPECIAL TOOL(S)
TROUBLESHOOTING
STANDARD FLOW OF DIAGNOSTIC TROUBLE SHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
MALFUNCTION OF THE IGNITION SWITCH POWER SUPPLY SYSTEM
ON-VEHICLE SERVICE
IGNITION KEY REMINDER TONE ALARM INSPECTION<Vehicles for GCC>
IGNITION SWITCH REMOVAL AND INSTALLATION
INSPECTION
IGNITION SWITCH INSPECTION
KEY REMINDER SWITCH INSPECTION
COMBINATION METER
TROUBLESHOOTING
STANDARD FLOW OF DIAGNOSTIC TROUBLESHOOTING
DIAGNOSIS FUNCTION
CODE NO.B1200 ODOMETER FAILURE
CODE NO.B1201 FUEL INFORMATION ERROR
CODE No.B1209 TEST MODE
CODE No.B2463 RHEOSTAT SWITCH SEIZURE
CODE No.U0100 TIME-OUT DURING CAN COMMUNICATION WITH ENGINE-ECU
CODE NO. U0101 COMMUNICATION TIME-OUT BETWEEN CVT-ECU AND CAN
CODE NO.U0121 ASC/TCL/ABS TIMEOUT/NOT EQUIPPED
CODE No.U0131 TIME-OUT DURING CAN COMMUNICATION WITH EPS-ECU
CODE No.U0141 TIME-OUT DURING CAN COMMUNICATION WITH ETACS-ECU
CODE No.U0151 TIME-OUT DURING CAN COMMUNICATION WITH SRS-ECU
CODE No.U0168 TIME-OUT DURING CAN COMMUNICATION WITH WCM
CODE No.U1000 TIME-OUT DURING CAN COMMUNICATION WITH OSS-ECU
CODE No.U1110 TIME-OUT DURING CAN COMMUNICATION WITH A/C-ECU
CODE NO.U1190 NO RECEIVE FAULT DETECT SIGNAL
CODE No.U1195 CODING DATA NOT WRITTEN
CODE No.U15A0 FCM ECU CAN TIMEOUT
(2017 Basic) SYMPTOM CHART
(2018 Supplement) SYMPTOM CHART
SYMPTOM PROCEDURES
THE SPEEDOMETER DOES NOT WORK (BUT THE OTHER METERS WORK).
TACHOMETER DOES NOT WORK (BUT THE OTHER METERS WORK).
BUZZER DOES NOT WORK.
FUEL GAUGE DOES NOT WORK (BUT THE OTHER METERS WORK).
THE COMBINATION METER LIGHT DOES NOT ILLUMINATE NORMALLY OR THE MULTI INFORMATION DISPLAY IS NOT DISPLAYED NORMALLY.
THE MULTI INFORMATION DISPLAY SCREEN CANNOT BE CHANGED WITH THE OPERATION OF THE METER INFORMATION SWITCH.
PARKING BRAKE REMINDER BUZZER DOES NOT SOUND.
AMBIENT TEMPERATURE SENSOR DOES NOT WORK (BUT THE OTHER METERS WORK).
(2017 Basic) THE SEAT BELT INDICATOR LAMP DO NOT ILLUMINATE OR FLASH<LHD>
(2018 Supplement) THE SEAT BELT INDICATOR LAMP DO NOT ILLUMINATE OR FLASH<VEHICLES FOR SINGAPORE>
ON-VEHICLE SERVICE
SPEEDOMETER CHECK
TACHOMETER CHECK
SETTING SERVICE REMINDER FUNCTION
COMBINATION METER
COMBINATION METER REMOVAL AND INSTALLATION
COMBINATION METER DISASSEMBLY AND REASSEMBLY
HEADLAMP
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS FUNCTION
DIAGNOSIS CODE No.B1706 DETECTION OF TURN SIGNAL LAMP (FUSE BLOWOUT)
DIAGNOSIS CODE No.B1707 DETECTION OF TURN SIGNAL LAMP (OPEN CIRCUIT)
SYMPTOM CHART
SYMPTOM PROCEDURES
HEADLAMPS (LOW-BEAM) DO NOT ILLUMINATE.
HEADLAMPS (HIGH-BEAM) DO NOT ILLUMINATE.
HEADLAMPS DO NOT ILLUMINATE WHEN THE PASSING SWITCH IS TURNED ON.
THE RIGHT OR LEFT HEADLAMP DOES NOT ILLUMINATE.
HIGH-BEAM INDICATOR LAMP DOES NOT ILLUMINATE NORMALLY.
HEADLAMP AUTOMATIC SHUTDOWN FUNCTION DOES NOT WORK NORMALLY.
THE POSITION LAMP DOES NOT ILLUMINATE.
EITHER OF THE POSITION LAMPS DOES NOT ILLUMINATE.
WHEN THE ELECTRIC MOTOR SWITCH IS TURNED TO THE ON POSITION WITH THE LIGHTING SWITCH AT THE OFF OR TAIL POSITION, THE HEADLAMPS WILL ILLUMINATE BRIEFLY.
TURN-SIGNAL LAMPS DO NOT FLASH.
THE COMFORT FLASHING FUNCTION DOES NOT WORK NORMALLY.
TURN-SIGNAL LAMP INDICATOR DOES NOT ILLUMINATE/GO OUT NORMALLY.
THE RIGHT OR LEFT TURN-SIGNAL LAMP DOES NOT ILLUMINATE.
THE COMING-HOME LIGHT DOES NOT WORK NORMALLY.<Vehicles for Thailand>
THE WELCOME LIGHT DOES NOT WORK NORMALLY.<Vehicles for Thailand>
ON-VEHICLE SERVICE
HEADLAMP AIMING
LUMINOUS INTENSITY MEASUREMENT
REPLACEMENT OF REPLACEABLE BULB
HEADLAMP AUTOMATIC-SHUTDOWN FUNCTION CHECK
COMING-HOME LIGHT FUNCTION CHECK<Vehicles for Thailand>
WELCOME LIGHT FUNCTION CHECK<Vehicles for Thailand>
ADJUSTMENT FUNCTION
HEADLAMP
HEADLAMP REMOVAL AND INSTALLATION
HEADLAMP LEVELLING SWITCH
HEADLAMP LEVELLING SWITCH REMOVAL AND INSTALLATION
INSPECTION
HEADLAMP RELAY CHECK
HEADLAMP LEVELLING SWITCH CHECK
REAR COMBINATION LAMP
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
TAIL LAMPS DO NOT ILLUMINATE.
THE RIGHT OR LEFT TAIL LAMP DOES NOT ILLUMINATE.
THE BACK-UP LAMPS DO NOT ILLUMINATE NORMALLY.
THE STOP LAMPS DO NOT ILLUMINATE OR GO OUT NORMALLY.
ON-VEHICLE SERVICE
REAR COMBINATION LAMP REMOVAL AND INSTALLATION
FRONT FOG LAMP
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
FRONT FOG LAMPS DO NOT ILLUMINATE NORMALLY.
THE RIGHT OR LEFT FOG LAMP DOES NOT ILLUMINATE.
FOG LAMP INDICATOR DOES NOT ILLUMINATE/GO OUT NORMALLY.
ON-VEHICLE SERVICE
FRONT FOG LAMP AIMING
FRONT FOG LAMP REMOVAL AND INSTALLATION
INSPECTION
FRONT FOG LAMP RELAY CHECK
REAR FOG LAMP<VEHICLES FOR ARGENTINA AND GCC>
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
REAR FOG LAMPS DO NOT ILLUMINATE NORMALLY.
REAR FOG LAMP INDICATOR DOES NOT ILLUMINATE/GO OUT NORMALLY.
ON-VEHICLE SERVICE
REAR FOG LAMP REMOVAL AND INSTALLATION
INSPECTION
REAR FOG LAMP RELAY CHECK
SIDE TURN-SIGNAL LAMP
SIDE TURN-SIGNAL LAMP REMOVAL AND INSTALLATION
INTERIOR LAMP
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
FRONT ROOM LAMP DOES NOT ILLUMINATE NORMALLY.
LUGGAGE COMPARTMENT LAMP DOES NOT ILLUMINATE NORMALLY.
THE INTERIOR LAMP AUTO-CUT FUNCTION DOES NOT OPERATE CORRECTLY.
ON-VEHICLE SERVICE
ADJUSTMENT FUNCTION
ROOM LAMP REMOVAL AND INSTALLATION
CARGO ROOM LAMP REMOVAL AND INSTALLATION
HIGH-MOUNTED STOP LAMP
HIGH-MOUNTED STOP LAMP REMOVAL AND INSTALLATION
LICENCE PLATE LAMP
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
THE LICENCE PLATE LAMP DOES NOT ILLUMINATE.
EITHER OF LICENCE PLATE LIGHTS DOES NOT ILLUMINATE.
LICENCE PLATE LAMP REMOVAL AND INSTALLATION
HAZARD WARNING LAMP SWITCH
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
HAZARD WARNING LAMPS DO NOT FLASH.
HAZARD WARNING LAMP SWITCH REMOVAL AND INSTALLATION
INSPECTION
HAZARD WARNING LAMP SWITCH CHECK
HORN
HORN REMOVAL AND INSTALLATION
INSPECTION
HORN RELAY CHECK
ACCESSORY SOCKET
ACCESSORY SOCKET REMOVAL AND INSTALLATION
CIGARETTE LIGHTER
CIGARETTE LIGHTER REMOVAL AND INSTALLATION
CIGARETTE LIGHTER CHECK
COLUMN SWITCH
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS FUNCTION
DIAGNOSIS CODE No.B1763, No.B1764 COLUMN SWITCH ABNORMALITY
COLUMN SWITCH REMOVAL AND INSTALLATION
INSPECTION
COLUMN SWITCH INSPECTION
REAR VIEW CAMERA
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
REAR VIEW CAMERA IMAGE IS NOT CORRECTLY DISPLAYED.
CAMERA REMOVAL AND INSTALLATION
RADIO AND CD PLAYER
SPECIAL TOOL(S)
TROUBLESHOOTING
TROUBLESHOOTING STRATEGY
AUDIO ERROR CODE<1DIN TYPE>
AUDIO ERROR CODE<UNIQ TYPE>
SYMPTOM CHART
SYMPTOM PROCEDURES
WHEN POWER SWITCH IS TURNED "ON," NO POWER IS AVAILABLE
NO SOUND.
POOR RECEPTION.
AUDIO ILLUMINATION DOES NOT WORK NORMALLY.
An audio file, which is stored in the USB memory/iPod, cannot be played.
An audio file, which is connected through the external input (AUX) terminal, cannot be played.
RADIO WITH CD PLAYER REMOVAL AND INSTALLATION<1DIN TYPE>
RADIO WITH CD PLAYER REMOVAL AND INSTALLATION<UNIQ TYPE>
USB CABLE
(2017 Basic) USB CABLE REMOVAL AND INSTALLATION
(2018 Supplement) USB CABLE REMOVAL AND INSTALLATION
USB ADAPTER
(2018 Supplement) USB ADAPTER REMOVAL AND INSTALLATION
HANDS FREE-ECU<VEHICLES WITH RADIO AND CD PLAYER (UNIQ TYPE)>
SPECIAL TOOL(S)
TROUBLESHOOTING
INTRODUCTION
DIAGNOSIS MODE
SYMPTOM CHART
SYMPTOM PROCEDURES
CHECK THE HANDS-FREE-ECU POWER SUPPLY CIRCUIT.
USB ADAPTER DATA CANNOT BE REPLAYED.
WHEN THE SPEECH SWITCH IS PRESSED, THE VOICE INFORMATION IS OUTPUT, BUT THE VOICE RECOGNITION IS NOT PERFORMED.
WHEN THE SPEECH SWITCH IS PRESSED, THE VOICE INFORMATION IS NOT OUTPUT.
DIAGNOSIS MODE CANNOT BE MADE AN ENTRY.
VOICE GUIDE "Unable to obtain vehicle speed. Please try again or contact your dealer for service" IS SENT FROM THE SPEAKER.
ON-VEHICLE SERVICE
PAIRING THE BLUETOOTH DEVICE
HANDS FREE-ECU
(2017 Basic) HANDS FREE ECU REMOVAL AND INSTALLATION
(2018 Supplement) HANDS FREE ECU REMOVAL AND INSTALLATION
MICROPHONE UNIT
MICROPHONE UNIT REMOVAL AND INSTALLATION
STEERING WHEEL VOICE CONTROL SWITCH
STEERING WHEEL VOICE CONTROL SWITCH REMOVAL AND INSTALLATION
STEERING WHEEL VOICE CONTROL SWITCH INSPECTION
SPEAKER
ON-VEHICLE SERVICE
SPEAKER TEST
SPEAKER REMOVAL AND INSTALLATION
ANTENNA
ANTENNA REMOVAL AND INSTALLATION
ETACS
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS FUNCTION
DIAGNOSIS CODE No.B1709 ETACS-ECU INTERNAL ERROR
DIAGNOSIS CODE No.B1760 VARIANT CODING UNMATCHED
B1761 VIN NOT RECORDED
CODE No. B1762 IGNITION OFF CURRENT DRAW (IOD) FUSE DISCONNECTED
CODE NO.B2206 CHASSIS NO. MISMATCH
CODE No. U1000 OSS-ECU TIMEOUT
DIAGNOSIS CODE NO.U1100 ENGINE-ECU TIME-OUT
DIAGNOSIS CODE NO.U1101 T/M CAN TIMEOUT/NOT EQUIPPED
DIAGNOSIS CODE No.U1102 ABS-ECU TIME-OUT
DIAGNOSIS CODE NO.U1108 METER CAN TIMEOUT/NOT EQUIPPED
DIAGNOSIS CODE NO.U1110 A/C-ECU TIME-OUT
DIAGNOSIS CODE NO.U1116 KOS CAN TIMEOUT/NOT EQUIPPED
DIAGNOSIS CODE No.U1150 VEHICLE SPEED FAILURE INFORMATION
SYMPTOM CHART
SYMPTOM PROCEDURES
CHECK THE CIRCUIT (POWER SUPPLY LINE) FROM BATTERY
LIGHT REMINDER TONE ALARM FUNCTION DOES NOT WORK NORMALLY
INPUT SIGNAL CHART
INPUT SIGNAL PROCEDURES
THE IGNITION SWITCH (ACC) SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE IGNITION SWITCH (IG1) SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE KEY REMINDER SWITCH SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE DRIVER''S DOOR LOCK ACTUATOR SWITCH SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE FRONT DOOR SWITCH (RH) SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE FRONT DOOR SWITCH (LH) SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE DOOR SWITCHES SIGNALS IS NOT SENT TO THE ETACS-ECU.
THE HAZARD WARNING LAMP SWITCH SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE COLUMN SWITCH SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE STOP LAMP SWITCH SIGNAL IS NOT SENT TO THE ETACS-ECU.
THE REMOTE CONTROLLED MIRROR SWITCH SIGNAL IS NOT RECEIVED
THE REAR WINDOW DEFOGGER SWITCH SIGNAL IS NOT RECEIVED<VEHICLES WITH COOLER>
THE REAR WINDOW DEFOGGER SWITCH SIGNAL IS NOT RECEIVED<VEHICLES WITH AUTOMATIC AIR CONDITIONER>
THE BACK-UP LAMP SWITCH SIGNAL IS NOT SENT TO THE ETACS-ECU.<M/T>
ON-VEHICLE SERVICE
ADJUSTMENT FUNCTION
ETACS-ECU
ETACS-ECU REMOVAL AND INSTALLATION
DEFOGGER
SPECIAL TOOL(S)
TROUBLESHOOTING
SYMPTOM CHART
SYMPTOM PROCEDURES
REAR WINDOW DEFOGGER DOES NOT OPERATE<vehicles with cooler>
REAR WINDOW DEFOGGER DOES NOT OPERATE<Vehicles with automatic air conditioner>
DEFOGGER SWITCH REMOVAL AND INSTALLATION
INSPECTION
REAR WINDOW DEFOGGER SWITCH CHECK
ON-VEHICLE SERVICE
PRINTED-HEATER LINE CHECK
DEFOGGER RELAY CHECK
IMMOBILIZER SYSTEM<VEHICLES WITHOUT KOS>
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS FUNCTION
B1702 RECEPTION ERROR OF TRANSPONDER DATA
B1703 TRANSPONDER DATA INCONSISTENT
B1722 TRANSPONDER ANTENNA FAILURE
B1731 IMMOBILIZER COMMUNICATION FAILURE
B1766 TRANSPONDER REGISTERED FOR OTHER VEHICLE
B1A28 ENG ECU AUTHENTIFICATION ERROR
SYMPTOM CHART
SYMPTOM PROCEDURES
IGNITION KEY CANNOT BE REGISTERED WITH M.U.T.-III
Engine does not Start (Cranking but no Initial Combustion)
ON-VEHICLE SERVICE
IMMOBILIZER ID CODE REGISTRATION
IMMOBILIZER-ECU REMOVAL AND INSTALLATION
FORWARD COLLISION MITIGATION SYSTEM (Low speed range) (FCM-LS)
GENERAL INFORMATION
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS FUNCTION
CODE NO. C1394 INCOMP. LEARN NEUTRAL (SAS)
CODE NO. C1505 STEERING ANGLE SENSOR FAIL
CODE NO. C1747 SHIFT SIGNAL UNDETERMINED
CODE NO. C1749 TOO LONG FCM ACTIVATION
CODE NO. C1750 FCM VOLTAGE OUT OF RANGE
CODE NO. C1751 FCM ECU FAILURE
CODE NO. C1752 FCM RADAR TEMP. OUT OF RANGE
CODE NO. C1753 FCM RADAR BLOCKAGE DETECTED
CODE NO. C1777 ACC SYSTEM FAIL DETECTED (ASC)
CODE NO. C1778 VEHICLE SPEED SIGNAL FAIL
CODE NO. C1779 BRAKE MASTER CYLINDER PRS. SIGNAL
CODE NO. C1781 SAS INTERNAL FAIL
CODE NO. C1782 SAS SIGNAL FAIL
CODE NO. C1784 FCM SWITCH FIXED ON
CODE NO. C1787 APS SIGNAL FAIL
CODE NO. C1788 LONGITUDINAL G SENSOR SIGNAL FAIL
CODE NO. C1789 FCM CONTROL SIGNAL FAIL (ASC NO RES.)
CODE NO. C1790 FCM CONTROL SIGNAL FAIL (ASC)
CODE NO. C1791 VEHICLE SPEED SIGNAL FAIL (INVALID)
CODE NO. C1792 BRAKE M/C PRS. SIGNAL (INVALID)
CODE NO. C1793 LATERAL ACC. SIGNAL FAIL (INVALID)
CODE NO. C1794 LONGITUDINAL G SENSOR SIGNAL FAIL (INVALID)
CODE NO. C1795 YAWRATE SIGNAL FAIL (INVALID)
CODE NO. C1796 APS SIGNAL FAIL (INVALID)
CODE NO. C1797 TOO MANY FCM INTERVENTIONS
CODE NO. C1798 FCM CONTROL DISABLED (ASC)
CODE NO. C1799 FCM CONTROL DISABLED (ENGINE)
CODE NO. U0100 ENGINE CAN TIMEOUT
CODE NO. U0101 T/M CAN TIMEOUT
CODE NO. U0121 ABS/ASC CAN TIMEOUT
CODE NO. U0126 SAS CAN TIMEOUT
CODE NO. U0141 ETACS CAN TIMEOUT
CODE NO. U1197 CODING DATA UNAVAILABLE
SYMPTOM CHART
SYMPTOM PROCEDURES
POWER SUPPLY CIRCUIT IS FAILED
THE FCM-LA OR RMS IS NOT TURNED ON OR OFF WHEN THE FCM OFF SWITCH IS OPERATED.
WHEN THE IGNITION SWITCH IS ON (ENGINE STOPPED), SOME OF THE INDICATOR LAMPS OR ANY OF THEM DO NOT LIGHT.
THE FCM-LS OR RMS DOES NOT WORK NORMALLY.
ON-VEHICLE SERVICE
LASER RADAR CHECK
LASER RADAR
LASER RADAR REMOVAL AND INSTALLATION
FCM-LS OFF SWITCH
FCM-LS OFF SWITCH REMOVAL AND INSTALLATION
FCM-LS OFF SWITCH INSPECTION
54B-LOCAL INTERCONNECT NETWORK (LIN)
SPECIAL TOOLS
TROUBLESHOOTING
DIAGNOSIS FUNCTION
CODE NO. U1500 COLUMN SWITCH TIME-OUT
CODE NO. U1507 BIT ERROR (LIN)
CODE No.U1530 COLUMN-ECU CHECKSUM ERROR
CODE No.U1570 NO BUS ACTIVITY ERROR FOR LIN
54C-CONTROLLER AREA NETWORK (CAN)
GENERAL INFORMATION
SPECIAL TOOL(S)
TEST EQUIPMENT
SERVICE PRECAUTIONS
PRECAUTIONS ON HOW TO REPAIR THE CAN BUS LINES
EXPLANATION ABOUT THE M.U.T.-III CAN BUS DIAGNOSTICS
TROUBLESHOOTING
CAN BUS DIAGNOSIS CHART
CAN-RELATED CONNECTOR POSITION
CAN BUS DIAGNOSIS
DIAGNOSIS ITEM 1
DIAGNOSIS ITEM 2
DIAGNOSIS ITEM 3
DIAGNOSIS ITEM 4
DIAGNOSIS ITEM 5
DIAGNOSIS ITEM 6
DIAGNOSIS ITEM 7
DIAGNOSIS ITEM 8<Vehicles with KOS>
DIAGNOSIS ITEM 9<Vehicles with auto A/C>
DIAGNOSIS ITEM 10<Vehicles with FCM>
DIAGNOSIS ITEM 11<Vehicles with ASC>
DIAGNOSIS ITEM 12
DIAGNOSIS ITEM 13
DIAGNOSIS ITEM 14<Vehicles with ABS_ASC>
DIAGNOSIS ITEM 15<Vehicles with CVT>
DIAGNOSIS ITEM 16
CAN COMMUNICATION-RELATED DIAGNOSIS CODE TABLE
55A-HEATER, AIR CONDITIONER AND VENTILATION
GENERAL INFORMATION
LUBRICANT(S)
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS TROUBLESHOOTING FLOW
SYMPTOM CHART
SYMPTOM PROCEDURES
COOL AIR DOES NOT COME
BLOWER MOTOR DOES NOT OPERATE
BLOWER AIR AMOUNT CANNOT BE CHANGED.
THE COMPRESSOR DOES NOT WORK
ON-VEHICLE SERVICE
COMPRESSOR DRIVE BELT ADJUSTMENT
REFRIGERANT LEVEL CHECK, DRAINING AND CHARGING
REFILLING OF OIL IN THE A/C SYSTEM
PERFORMANCE TEST <VEHICLES USING R-134a REFRIGERANT>
DIAGNOSIS BY REFRIGERANT PRESSURE
SIMPLE INSPECTION OF THE A/C PRESSURE SENSOR
POWER RELAY CHECK
IDLE-UP OPERATION CHECK
REPLACE THE AIR REFRESHER
HEATER CONTROL UNIT
HEATER CONTROL UNIT REMOVAL AND INSTALLATION
HEATER CONTROL ASSEMBLY AND A/C SWITCH INSPECTION
HEATER CONTROL ASSEMBLY DISASSEMBLY AND REASSEMBLY
HEATER UNIT AND BLOWER ASSEMBLY
HEATER UNIT AND BLOWER ASSEMBLY REMOVAL AND INSTALLATION
HEATER UNIT AND BLOWER ASSEMBLY DISASSEMBLY AND REASSEMBLY
INSPECTION
HEATER HOSE
HEATER HOSE REMOVAL AND INSTALLATION
BLOWER ASSEMBLY AND RESISTOR
BLOWER MOTOR AND RESISTOR REMOVAL AND INSTALLATION
INSPECTION
COMPRESSOR ASSEMBLY
COMPRESSOR ASSEMBLY REMOVAL AND INSTALLATION
COMPRESSOR ASSEMBLY INSPECTION
COMPRESSOR ASSEMBLY DISASSEMBLY AND ASSEMBLY
CONDENSER ASSEMBLY
CONDENSER ASSEMBLY REMOVAL AND INSTALLATION
REFRIGERANT LINE
REFRIGERANT LINE REMOVAL AND INSTALLATION
DUCTS
DUCT REMOVAL AND INSTALLATION
VENTILATORS
VENTILATOR REMOVAL AND INSTALLATION
55B-AUTOMATIC AIR CONDITIONER
SPECIAL TOOL(S)
TROUBLESHOOTING
DIAGNOSIS FUNCTION
B1001 INTERIOR TEMPERATURE SENSOR SYSTEM
B1041 POTENTIOMETER SYSTEM FOR THE FRONT AIR MIX DAMPER
B1045 MOTOR DRIVE SYSTEM FOR THE FRONT AIR MIX DAMPER
B1061 AIR OUTLET DAMPER POTENTIO.HIGH
B1065 AIR OUTLET CHANGEOVER DMPR.MOTOR
B1083 EEPROM ERROR
U1100 ENGINE CAN TIMEOUT
U1108 COMBINATION METER CAN COMMUNICATION TIME-OUT
U1190 THE NETWORK SYSTEM DIAGNOSIS CODE SET PERMITTED SIGNAL CANNOT BE RECEIVED.
SYMPTOM CHART
SYMPTOM PROCEDURES
COMMUNICATION WITH THE M.U.T.-III IS NOT POSSIBLE
INSIDE/OUTSIDE AIR CHANGEOVER IS NOT POSSIBLE.
A/C PRESSURE SENSOR SYSTEM
A/C-ECU POWER SUPPLY SYSTEM
HEATER CONTROL UNIT
DAMPER CONTROL MOTOR ASSEMBLY
DAMPER CONTROL MOTOR ASSEMBLY REMOVAL AND INSTALLATION
DAMPER CONTROL MOTOR ASSEMBLY INSPECTION
AMBIENT TEMPERATURE SENSOR REMOVAL AND INSTALLATION
INSPECTION
OTHER PARTS
OTHER PART REMOVAL AND INSTALLATION
70 -COMPONENT LOCATIONS
RELAY
ECU
SENSOR
SOLENOID AND SOLENOID VALVE
FUSIBLE LINK AND FUSE
INSPECTION CONNECTOR AND SPARE CONNECTOR
EARTH CABLE
EARTH
80 -CONFIGURATION DIAGRAMS
OVERALL CONFIGURATION DIAGRAM
ENGINE COMPARTMENT
ENGINE COMPARTMENT<LHD>
ENGINE COMPARTMENT<RHD>
ENGINE AND TRANSMISSION
INSTRUMENT PANEL
INSTRUMENT PANEL<LHD>
INSTRUMENT PANEL<RHD>
FLOOR
FLOOR<LHD>
FLOOR<RHD>
ROOF
DOOR
DOOR<LHD>
DOOR<RHD>
TRUNK (LUGGAGE COMPARTMENT)
90 -CIRCUIT DIAGRAMS
JUNCTION BLOCK (J/B)
JOINT CONNECTOR (J/C)
CENTRALIZED JUNCTION
POWER DISTRIBUTION SYSTEM
STARTING SYSTEM
STARTING SYSTEM<M/T>
STARTING SYSTEM<CVT>
IGNITION SYSTEM
IGNITION SYSTEM<LHD>
IGNITION SYSTEM<RHD>
CHARGING SYSTEM
CHARGING SYSTEM<LHD>
CHARGING SYSTEM<RHD>
ENGINE CONTROL SYSTEM
ENGINE CONTROL SYSTEM<LHD>
ENGINE CONTROL SYSTEM<RHD>
COOLING SYSTEM
COOLING SYSTEM<LHD>
COOLING SYSTEM<RHD>
SHIFT LOCK MECHANISM<CVT (LHD)>
SHIFT LOCK MECHANISM<CVT (RHD)>
CVT
CVT<LHD>
CVT<RHD>
HEADLAMP
HEADLAMP<LHD>
HEADLAMP<RHD>
TAIL LAMP, POSITION LAMP, LICENCE PLATE LAMP AND LIGHTING MONITOR BUZZER
TAIL LAMP, POSITION LAMP, LICENCE PLATE LAMP AND LIGHTING MONITOR BUZZER<LHD>
TAIL LAMP, POSITION LAMP, LICENCE PLATE LAMP AND LIGHTING MONITOR BUZZER<RHD>
DAYTIME RUNNING LAMP (DRL)
HEADLAMP MANUAL LEVELLING SYSTEM
HEADLAMP MANUAL LEVELLING SYSTEM<LHD>
HEADLAMP MANUAL LEVELLING SYSTEM<RHD>
FRONT FOG LAMP
FRONT FOG LAMP<LHD>
FRONT FOG LAMP<RHD>
REAR FOG LAMP
ROOM LAMP AND LUGGAGE COMPARTMENT LAMP
ROOM LAMP AND LUGGAGE COMPARTMENT LAMP<LHD>
ROOM LAMP AND LUGGAGE COMPARTMENT LAMP<RHD>
TURN-SIGNAL LAMP AND HAZARD WARNING LAMP
TURN-SIGNAL LAMP AND HAZARD WARNING LAMP<LHD>
TURN-SIGNAL LAMP AND HAZARD WARNING LAMP<RHD>
HORN
BACK-UP LAMP
BACK-UP LAMP<LHD>
BACK-UP LAMP<RHD>
STOP LAMP
STOP LAMP<LHD>
STOP LAMP<RHD>
METER AND GAUGE
METER AND GAUGE<LHD>
METER AND GAUGE<RHD>
FUEL WARNING LAMP, OIL PRESSURE WARNING LAMP AND BRAKE WARNING LAMP
FUEL WARNING LAMP, OIL PRESSURE WARNING LAMP AND BRAKE WARNING LAMP<LHD>
FUEL WARNING LAMP, OIL PRESSURE WARNING LAMP AND BRAKE WARNING LAMP<RHD>
POWER WINDOWS
POWER WINDOWS<VEHICLES WITHOUT SAFETY SYSTEM (LHD)>
POWER WINDOWS<VEHICLES WITHOUT SAFETY SYSTEM (RHD)>
POWER WINDOWS<VEHICLES WITH SAFETY SYSTEM (LHD)>
POWER WINDOWS<VEHICLES WITH SAFETY SYSTEM (RHD)>
CENTRAL DOOR LOCKING SYSTEM<LHD>
CENTRAL DOOR LOCKING SYSTEM<RHD>
TRUNK LID OPENER
TRUNK LID OPENER<VEHICLES WITH KOS (LHD)>
TRUNK LID OPENER<VEHICLES WITH KOS RHD>
HEATER
HEATER<LHD>
HEATER<RHD>
COOLER
COOLER<LHD>
COOLER<RHD>
MANUAL AIR CONDITIONER
MANUAL AIR CONDITIONER<LHD>
MANUAL AIR CONDITIONER<RHD>
AUTOMATIC AIR CONDITIONER<LHD>
AUTOMATIC AIR CONDITIONER<RHD>
WINDSHIELD WIPER AND WASHER<LHD>
WINDSHIELD WIPER AND WASHER<RHD>
REAR WINDOW DEFOGGER<VEHICLES WITH COOLER OR MANUAL AIR CONDITIONER>
REAR WINDOW DEFOGGER<VEHICLES WITH AUTOMATIC AIR CONDITIONER>
ELECTRIC RETRACTABLE REMOTE CONTROLLED MIRROR
AUDIO SYSTEM
AUDIO SYSTEM<UNIQUE TYPE AUDIO (LHD)>
AUDIO SYSTEM<UNIQUE TYPE AUDIO (RHD)>
AUDIO SYSTEM<1-DIN TYPE AUDIO (LHD)>
AUDIO SYSTEM<1-DIN TYPE AUDIO (RHD)>
HANDS-FREE INTERFACE SYSTEM
SPARE CONNECTOR (FOR REAR VIEW CAMERA)
ACCESSORY SOCKET AND CIGARETTE LIGHTER
ABS, ASC AND HSA
ABS, ASC AND HSA<LHD>
ABS, ASC AND HSA<RHD>
FORWARD COLLISION MITIGATION (FCM) AND PRE-COLLISION ACCELERATION CONTROL
EMERGENCY STOP SIGNAL SYSTEM<VEHICLES FOR THAILAND>
SRS
SRS<LHD>
SRS<RHD>
ELECTRIC POWER STEERING SYSTEM<LHD>
ELECTRIC POWER STEERING SYSTEM<RHD>
IGNITION KEY REMINDER BUZZER<VEHICLES FOR GCC>
KEY INTERLOCK<VEHICLES WITHOUT KOS (CVT)>
ONE-TOUCH START SYSTEM
ONE-TOUCH START SYSTEM<LHD>
ONE-TOUCH START SYSTEM<RHD>
DOOR AJAR WARNING BUZZER
DOOR AJAR WARNING BUZZER<LHD>
DOOR AJAR WARNING BUZZER<RHD>
PARKING BRAKE REMINDER BUZZER<LHD>
PARKING BRAKE REMINDER BUZZER<RHD>
SEAT BELT WARNING
SEAT BELT WARNING<LHD>
SEAT BELT WARNING<RHD>
TYRE PRESSURE MONITORING SYSTEM (TPMS)<VEHICLES FOR GCC>
SPEED ALARM BUZZER<VEHICLES FOR GCC>
CONTROLLER AREA NETWORK (CAN)<LHD>
CONTROLLER AREA NETWORK (CAN)<RHD>
Technical Information Manuals (2013)
00 -GENERAL
HOW TO USE THIS MANUAL
TARGETS OF DEVELOPMENT
PRODUCT FEATURES
TECHNICAL FEATURES
EXTERIOR
INTERIOR
SPACIOUS CABIN
ACTIVE SAFETY
PASSIVE SAFETY
EQUIPMENTS
SERVICEABILITY AND RELIABILITY
VEHICLE IDENTIFICATION
(2013 Basic) MODELS
(2013 Supplement) MODELS
(2013 Basic) MAJOR SPECIFICATIONS
(2013 Supplement) MAJOR SPECIFICATIONS
11 -ENGINE MECHANICAL
GENERAL INFORMATION
BASE ENGINE
12 -ENGINE LUBRICATION
GENERAL INFORMATION
OIL PASSAGE
13A-MULTIPOINT FUEL INJECTION (MPI)
GENERAL INFORMATION
CONTROL UNIT
SENSOR
ACTUATOR
FUEL INJECTION CONTROL
IGNITION TIMING AND CONTROL FOR CURRENT CARRYING TIME
THROTTLE VALVE OPENING ANGLE CONTROL AND IDLE SPEED CONTROL
MIVEC (Mitsubishi Innovative Valve Timing Electronic Control System)
RELAY CONTROL
FUEL PUMP RELAY CONTROL
STARTER RELAY CONTROL
OXYGEN SENSOR HEATER CONTROL
A/C COMPRESSOR RELAY CONTROL
ALTERNATOR CONTROL
FAN RELAY CONTROL
PURGE CONTROL
DIAGNOSIS SYSTEM
13B-FUEL SUPPLY
GENERAL INFORMATION
FUEL TANK
14 -ENGINE COOLING
(2013 Basic) GENERAL INFORMATION
(2013 Supplement) GENERAL INFORMATION
WATER PASSAGE
WATER PUMP
AIR INTAKE SYSTEM
AIR DUCT AND AIR CLEANER
INLET MANIFOLD
EXHAUST SYSTEM
EXHAUST MANIFOLD
EXHAUST PIPE AND MUFFLER
STARTER MOTOR
ALTERNATOR
IGNITION COIL
EMISSION CONTROL<MPI>
GENERAL INFORMATION
EMISSION REDUCTION SYSTEM
21 -CLUTCH
GENERAL INFORMATION
22 -MANUAL TRANSMISSION
MANUAL TRANSMISSION
GENERAL INFORMATION
SECTIONAL VIEW
GENERAL INFORMATION
23 -CONTINUOUSLY VARIABLE TRANSMISSION (CVT)
CVT
GENERAL INFORMATION
DESCRIPTION OF STRUCTURE AND OPERATION
SECTIONAL VIEW
TORQUE CONVERTER
OIL PUMP
PULLEY AND STEEL BELT
AUXILIARY GEARBOX
CVT FLUID COOLER
OIL PRESSURE CONTROL SYSTEM
OUTLINE OF CONTROL
ELECTRONIC CONTROL SYSTEM
OUTLINE OF CONTROL
GEAR CONTROL
IDLE NEUTRAL CONTROL
LINE PRESSURE CONTROL
SELECT CONTROL
DIRECTLY ENGAGED CONTROL (DAMPER CLUTCH CONTROL)
CONTROLLER AREA NETWORK (CAN) COMMUNICATION
SELF-DIAGNOSIS FUNCTION
GENERAL INFORMATION
26 -FRONT AXLE
GENERAL INFORMATION
27 -REAR AXLE
GENERAL INFORMATION
31 -WHEEL AND TYRE
GENERAL INFORMATION
GENERAL INFORMATION
34 -REAR SUSPENSION
35A-BASIC BRAKE SYSTEM
GENERAL INFORMATION
CONSTRUCTION DESCRIPTION
MASTER CYLINDER
BRAKE BOOSTER
FRONT BRAKE
REAR BRAKE
BRAKE LINE<Vehicles without ABS>
GENERAL INFORMATION
SENSORS
ACTUATORS
ABS-ECU
36 -PARKING BRAKES
GENERAL INFORMATION
37 -POWER STEERING
STEERING WHEEL
ELECTRIC STEERING WHEEL LOCK
STEERING SHAFT AND COLUMN
STEERING GEAR
GENERAL INFORMATION
MOTOR
TORQUE SENSOR
ELECTRIC POWER STEERING-ECU
OPERATION
42A-BODY
MAIN BODY
BODY PANELING
BODY SHELL
BODY COLOUR CHARTS
PEDESTRIAN PROTECTION
DOOR AND TAILGATE
DOOR LOCK
(2013 Basic) KEYLESS ENTRY SYSTEM
(2013 Supplement) KEYLESS ENTRY SYSTEM
POWER WINDOW
WINDOW GLASS
SYSTEM OPERATION
DOOR ENTRY FUNCTION
(2013 Basic) KEYLESS ENTRY FUNCTION
(2013 Supplement) KEYLESS ENTRY FUNCTION
(2013 Basic) OSS (one-touch start system)
(2013 Supplement) OSS (one-touch start system)
WARNINGS/ALARMS
51 -EXTERIOR
(2013 Basic) BUMPER AND RADIATOR GRILLE
(2013 Supplement) BUMPER AND RADIATOR GRILLE
AERO PARTS
WIPER AND WASHER
REAR WIPER AND WASHER
DOOR MIRROR
52A-INTERIOR
INSTRUMENT PANEL AND FLOOR CONSOLE
SEAT
(2013 Basic) FRONT SEAT
(2013 Supplement) FRONT SEAT
(2013 Basic) REAR SEAT
(2013 Supplement) REAR SEAT
(2013 Basic) SEAT BELT
(2013 Supplement) SEAT BELT
TRIMS
INTERIOR TRIMS
DOOR TRIM
HEADLINING
SYSTEM OPERATION
(2013 Basic) FRONT AIR BAG AND SEAT BELT WITH PRE-TENSIONER
(2013 Supplement) FRONT AIR BAG AND SEAT BELT WITH PRE-TENSIONER
SYSTEM CONSTRUCTION
DRIVER''S SIDE AIR BAG MODULE
FRONT PASSENGER''S SIDE AIR BAG MODULE<Vehicles with passenger air bag>
FRONT IMPACT SENSOR
SEAT BELT WITH PRE-TENSIONER<Driver side>
SRS-ECU
SRS AIR BAG SPECIAL CONNECTOR
DIAGNOSIS SYSTEM
GENERAL INFORMATION
BATTERY
LIGHTING
GENERAL INFORMATION
(2013 Basic) EXTERIOR LAMPS
(2013 Supplement) EXTERIOR LAMPS
INTERIOR LAMPS
FUNCTION AND CONTROL BY ETACS-ECU
COMBINATION METER
GENERAL INFORMATION
MULTI-INFORMATION DISPLAY
BUZZER
ACCESSORY SOCKET
GENERAL INFORMATION
HORN
GENERAL INFORMATION
COLUMN SWITCH
GENERAL INFORMATION
AUDIO AND NAVIGATION SYSTEM
MITSUBISHI MULTI ENTERTAINMENT SYSTEM (MMES)
(2013 Basic) RADIO AND CD PLAYER
(2013 Supplement) RADIO AND CD PLAYER
USB CONNECTOR
ANTENNA
SPEAKER
REAR VIEW CAMERA
GENERAL INFORMATION
ETACS
GENERAL INFORMATION
GENERAL INFORMATION
GENERAL INFORMATION
GENERAL INFORMATION
STRUCTURE
SYSTEM OPERATION
GENERAL INFORMATION
STRUCTURE
SYSTEM OPERATION
SELF-DIAGNOSIS
CAN BUS DIAGNOSTICS
55 -HEATER, AIR CONDITIONER AND VENTILATION
HEATER AND AIR CONDITIONER SYSTEM
(2013 Basic) HEATER CONTROL
(2013 Supplement) HEATER CONTROL
AIR CONDITIONING CONTROL SYSTEM
A/C COMPRESSOR
VENTILATION SYSTEM
BODY REPAIR MANUALS (2017)
0 -GENERAL
MAJOR SPECIFICATIONS<VEHICLES FOR THAILAND>
MAJOR SPECIFICATIONS<VEHICLES FOR GENERAL EXPORT>
MAJOR SPECIFICATIONS<VEHICLES FOR GCC>
1 -BODY CONSTRUCTION
BODY COMPONENTS
BODY MAIN CROSS-SECTIONAL VIEWS
MAINTENANCE AND SERVICEABILITY
BODY CONSTRUCTION CHARACTERISTICS
FRONT BODY
SIDE BODY
REAR BODY
ROOF
UNDER BODY
DOOR
SILENCER APPLICATION LOCATIONS
FOAM, URETHANE FOAM USAGE LOCATIONS
STIFFENER APPLICATION LOCATIONS
2 -BODY DIMENSIONS
BODY DIMENSIONS AND MEASUREMENT METHODS
TYPE A (PROJECTED DIMENSIONS)
UNDER BODY
TYPE B (ACTUAL-MEASUREMENT DIMENSIONS)
UNDER BODY
FRONT BODY
SIDE BODY
REAR BODY
INTERIOR
HEADLAMP SUPPORT PANEL
3 -WELDED PANEL REPLACEMENT
ULTRA HIGH STRENGTH STEEL PLATE
FENDER SHIELD
FRONT SIDEMEMBER (PARTIAL REPLACEMENT)
FRONT PILLAR
CENTRE PILLAR
SIDE SILL
QUARTER OUTER
REAR END PANEL
REAR FLOOR
ROOF
QUARTER INNER
QUARTER INNER LOWER
FRONT DOOR OUTER PANEL (WELDED TYPE)
FRONT DOOR OUTER PANEL (ADHESION TYPE)
REAR DOOR OUTER PANEL (WELDED TYPE)
REAR DOOR OUTER PANEL (ADHESION TYPE)
FRONT END CROSSMEMBER
4 -CORROSION PROTECTION
BODY SEALING LOCATIONS
ANTICORROSION PRIMER LOCATIONS
UNDERCOAT APPLICATION LOCATIONS
5 -SYNTHETIC-RESIN PARTS
LOCATION OF SYNTHETIC-RESIN PARTS
6 -BODY COLOUR
Mitsubishi ATTRAGEMIRAGE G4 2018 Workshop manuals-1.png Mitsubishi ATTRAGEMIRAGE G4 2018 Workshop manuals-2.png
Mitsubishi ATTRAGEMIRAGE G4 2018 Workshop manuals-3.png Mitsubishi ATTRAGEMIRAGE G4 2018 Workshop manuals-4.png
  • MaMiAT2005.txt
