aleksey-ms
268
203
43
Ukraine
vc2.motorstate.com.ua
Cummins InPower Pro: Generator & Power System Diagnostic Software
WHAT INSIDE:
* InPower_16.rar
1. MAIN FUNCTIONS AND COMPATIBILITY
DIAGNOSTICS & TESTING
* Live Data Monitoring – displays real-time operational parameters of the power station (voltage, frequency, engine RPM, oil pressure, temperature).
* Fault Code Management (DTC) – viewing and clearing active/stored fault codes and associated historical data.
* Testing & Simulation – simulates fault conditions (NFPA 110 compliance) and tests Automatic Transfer Switch (ATS) mechanisms.
* Plotting & Reporting – plots critical parameters in a strip chart format, saves operation logs, and generates detailed diagnostic reports.
CALIBRATION & PROGRAMMING
* Parameter Adjustment – modifies nearly every operating parameter of the connected controller (voltage, frequency levels, protection set-points, overloads).
* Convenient programming of configurable inputs in the controllers.
* Enables official firmware upgrades for PowerCommand genset controls.
SUPPORTED EQUIPMENT & MODELS
* PowerCommand Controls (PCC 1301, 1302, 2100, 2300, 3100, 3201, 3300, etc.).
* Detector and Sentinel control systems.
* Engine Control Modules (ECM) on diesel and gas generator sets.
* Used on standby domestic generators, industrial container stations, gas piston power plants, marine generators, and stationary pumping/fire stations.
2. PACK FEATURES
PROFESSIONAL ENGINEERING TOOL
* Offers multi-level user access capabilities (Read-only, Read/Change, Administrator).
* Connects directly from a PC to genset, transfer, and system controls.
* Hardware Requirements: Requires a standard RP1210 diagnostic interface (e.g., Nexiq USB Link) or an original Cummins INLINE (6, 7, or 8) adapter.
Cummins InPower Pro is a highly advanced diagnostic, calibration, and configuration software for Cummins Power Generation equipment. Designed for industrial use, it allows technicians to connect directly to electronic control systems of diesel and gas generator sets. The software provides deep-level access for adjusting protection parameters, monitoring real-time data, simulating fault conditions, and flashing firmware, making it an essential tool for maintaining and repairing stationary power systems.
  • Cummins InPower Pro new.txt
