BMW 7 Series F02 2010 Service and Repair Manual
Size: 149 MBFormat: PDF
Brand: BMW
Manual Type: Service and Repair Manual
Model: BMW 7-Series (F01)
Date Model: 2013
Number of Pages: 3,841 Pages
Audio, Navigation and Information System
Overview of aerial diversity
Overview of audio components
Overview of sensors for airbag system and pedestrian protection
Remove and installing replacing outside temperature sensor
Remove and installing replacing outside temperature sensor1
Removing and installing (replacing) amplifier (Top HiFi system)
Removing and installing (replacing) left front door sensor
Removing and installing (replacing) left pedestrian protection sensor
Removing and installing (replacing) Touchbox controller control unit
Removing and installing renewing aerial amplifier (diversity)
Removing and installing renewing central bass speaker -passenger side- (under front seat)
Removing and installing renewing speaker (mid-range speaker, in instrument panel)
Removing and installing replacing AM choke (interference suppression filter)
Removing and installing replacing amplifier
Removing and installing replacing central sensor
Removing and installing replacing cover for Central Information Display (CID, JC)
Removing and installing replacing cover for rear cabin monitor display at front and rear
Removing and installing replacing cover for rear passenger compartment monitor at front
Removing and installing replacing cover on speaker system
Removing and installing replacing DVD changer
Removing and installing replacing DVD player in rear console
Removing and installing replacing friction hinges for rear cabin monitor
Removing and installing replacing front left sensor
Removing and installing replacing front right sensor
Removing and installing replacing front speaker carrier (instrument panel)
Removing and installing replacing left or right blocking circuit
Removing and installing replacing left or right rear monitor
Removing and installing replacing left or right rear monitor1
Removing and installing replacing middle pedestrian protection sensor
Removing and installing replacing rear mid-range speaker (in storage shelf)
Removing and installing replacing rear speaker carrier (in storage shelf)
Removing and installing replacing rear telephone aerial
Removing and installing replacing rear treble speaker (in rear shelf)
Removing and installing replacing right pedestrian protection sensor
Removing and installing replacing speaker (mid-range speaker, door at rear)
Removing and installing replacing speaker (tweeter, door at rear)
Removing and installing replacing speaker (tweeter, triangular mirror section, left or right)
Removing and installing replacing speaker system
Removing and installing replacing suppression filter
Removing and installing replacing trim for rear monitor display at rear
Removing and installing replacing TV module
Removing and installing replacing ultrasound sensor for parking assistant
Removing and installing replacing video switch
Replacing audio unit
Replacing hinges for rear monitor
Replacing seat occupancy mat for front passenger seat occupancy detector
Replacing sensor mat (CIS mat) for front passenger seat occupancy detector
Replacing sensor mat (OC3 mat) for front passenger seat occupancy detector
Automatic Transmission
Adjusting gear lever (parking lock emergency release)
Checking topping up oil level in automatic transmission
Danger of poisoning if oil is ingested absorbed through the skin
External shift linkage
Gearbox emergency release for GA6HP GA8HP, phase-in as of 03-2010
Hydraulic electric control parts and controlling elements
Installing exchange gearbox
Manual emergency release of transmission lock
Manually releasing parking lock (from vehicle underbody) 6HP transmission
Notes on mechatronics (GA8HP45Z)
Overview of gearbox housing (GA8HP45Z,GA8HP70Z)
Precautionary measures on vehicles with active pedestrian protection system
Removing and installing automatic transmission (8HP70Z)
Removing and installing replacing torque converter
Removing and installing sealing or replacing transmission oil sump
Removing and installing sealing or replacing transmission oil sump 1
Replace radial shaft seal for output flange (GA8HP70Z)
Replacing emergency operation
Replacing mechatronics (GA8HP70Z)
Replacing oil accumulator (GA8HP45Z)
Replacing oil reservoir (GA8HP70Z)
Replacing sealing sleeve for transmission housing (GA8HP70Z)
Replacing shaft seal for selector shaft (GA8HP70Z)
Replacing shaft seal for selector shaft (GA8HP70Z)1
Replacing torque converter shaft seal (GA8HP70Z)
Risk of injury if oil comes into contact with eyes and skin
Safety instructions for handling oil
Torque converter
Transmission Extension, Bearings, Sealing Ring
Transmission filling capacities
Transmission filling capacities1
Transmission housing, transmission oil sump
Transmission in general
Unlock transmission lock electronically
Body Equipment
Adjusting rear lid lock
Adjusting replacing bump stops
Adjusting replacing bump stops1
Adjusting replacing bump stops2
Attach front spoiler
Attaching rear spoiler
Calibrating the compass on the inside mirror
Check actuator
Disassembling and assembling lock barrel (lock barrel removed)
Engine compartment lid service position
Fitting front spoiler (BMW ALPINA B7)
