aleksey-ms
283
204
43
Ukraine
vc2.motorstate.com.ua
XENTRY OpenShell & PassThru + Daimler Truck Diagnostic
WHAT INSIDE:
* Xentry OpenShell 26.6.4
* Xentry PassThru 26.6.4
* Daimler Truck Diagnostic DTPID 24.4.3
* Daimler Truck Diagnostic PassThru DTDPT 25.1.3
1. MAIN FUNCTIONS AND MODULE ACCESS
PASSENGER CARS & LIGHT VANS (XENTRY)
* Xentry OpenShell: Dealer software for passenger cars (versions up to 09.2023 also cover trucks), compatible with dedicated scanners (SD Connect and similar).
* Xentry PassThru: A lightweight version that works via the J2534-PassThru VCI, with some limitations for specific vehicle bodies.
HEAVY COMMERCIAL VEHICLES (DAIMLER TRUCK)
* Daimler Truck Diagnostic DTPID: Dealer software explicitly for trucks (Actros, Arocs, etc.) and buses, compatible with multiplexers (SD Connect and similar).
* Daimler Truck Diagnostic PassThru DTDPT: Dealer software for trucks and buses designed specifically for use via the PassThru VCI standard.
Need it? Push button Thanks, PM for pass | or by email right now for OpenShell or Passthru.
  • Xentry PassThru new.txt
  • Xentry OpenShell new.txt
aleksey-ms
283
204
43
Ukraine
Xentry OpenShell 26.3.4
Xentry PassThru 26.3.4
Xentry OpenShell:
Dealer software for passenger cars (versions up to 09.2023 and for trucks), compatible with scanners (SD Connect and similar).
Xentry PassThru: A lightweight version that works via the j2534-PassThru VCI, with limitations for some vehicle bodies.
Daimler Truck Diagnostic DTPID: Dealer software for trucks (Actros, Arocs, etc.) and buses, compatible with scanners (SD Connect and similar).
Daimler Truck Diagnostic PassThru DTDPT: Similar to the above, but designed for use via the PassThru VCI.
[Image: xentry-openshell-passthru-daimler-truck.jpg]
What's new in 26.3.4 (Release 03.2026) for Xentry OpenShell and PassThru:
Online login only: Mandatory two-factor authentication (2FA) has been implemented.
Updated 2026 certificates: Fixed crashes caused by outdated certificates (including C003).
New databases: Added firmware and protocols for the latest 2025–2026 Mercedes-Benz models and electric vehicles (EQ series).
Purchasing credits (PassThru): A button for quickly purchasing temporary licenses (Time Credits) has been added directly to the menu.
B2B Connect: Improved VIN search and integration with the RMI documentation portal.
In short:
Updating is only worthwhile for diagnosing the newest vehicles (2025–2026) and obtaining current certificates for online access. There are no changes for older vehicles.
aleksey-ms
283
204
43
Ukraine
Added XENTRY 26.6.4 (release 2026.06)
What's New:
  • Strict ZenZefi certificates. Verification of diagnostic certificates has been strengthened. Without them, it is impossible to access the Security Gateways on the latest Mercedes-Benz models.
  • Support for 2026 models. The database and SCN-coding capabilities have been expanded for the latest body styles, including the new generations of the AMG GT and SL (platforms 192, 232), as well as updated electric and hybrid platforms.
  • Parts management update (B2B Connect). Smart import has been added: parts lists can be uploaded as images (JPEG), and the built-in tool automatically recognizes and extracts part numbers.
  • DoIP and Pass Thru optimization. Improved stability of data transmission and control unit firmware updates when working with modern multiplexers (e.g., C6) and J2534 devices.
