Volvo Wheel Paver PF2181 Service and Repair Manual
File Size: 50.21 MBFile Format: PDF
Machine Type: Wheel Paver
Model: Volvo PF2181 Wheel Paver
Number of Pages: 4170 Pages
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/1 Volvo PF2181
2 Volvo PF2181
PF2181 Description
Auger conveyor hydraulic system flow, checking
Auger conveyor motor case drain, checking
Auger conveyor motor, description
Auger conveyor pump case drain, checking
Auger conveyor pump force motor, adjusting
Auger conveyor pump, description
Auger conveyor servo activation pressure, checking
Auger conveyor system pressure, checking
Auger conveyor system, description
Auger lift cylinder pressure, checking
Diesel fuels - quality and function1
Failure Mode
Fume recovery function description
Fume recovery motor, description
Fume recovery motor, specifications
Fume recovery motor, specifications1
Fume recovery valve, description
General purpose hydraulic system flow, checking
General purpose hydraulic system pressure, checking
General purpose hydraulic system, description
General purpose pump, description
Generator hydraulic system flow, checking
Generator hydraulic system pressure, checking
Hopper cylinder pressure, checking
Hydraulic oil, specifications
Hydrostatic drive system, description
Lead and connector checks1
Lead and connector checks2
Lubricant recommendation
Lubricants and fluids, capacities (litres)
MA4001, description and measuring
MA4206, description and measuring
MA4410, description and measuring
MA4411, description and measuring
MA5501, description and measuring
MA6401, description and measuring
MA6402, description and measuring
MA9133, description and measuring
MA9402, description and measuring
MA9403, description and measuring
MA9410, description and measuring
MA9411, description and measuring
MA9412, description and measuring
MA9413, description and measuring
MA9425, description and measuring
MA9454, description and measuring
MA9455, description and measuring
MA9456, description and measuring
MA9457, description and measuring
MA9460, description and measuring
MA9464, description and measuring
MA9465, description and measuring
MA9470, description and measuring
MA9471, description and measuring
MA9476, description and measuring
MA9477, description and measuring
MA9478, description and measuring
MA9479, description and measuring
MA9540, description and measuring
MA9541, description and measuring
Main valve, description1
Main valve, description2
Multimeter
Pressure at brake shift valve, checking
Propulsion motor case drain flow, checking
Propulsion motor, description
Propulsion pump, charge pressure checking
Propulsion pump, description
Propulsion system pressure, checking
RE2708, description and measuring
RE2709, description and measuring
RE3611, description and measuring
RE3702, description and measuring
RE3705, description and measuring
RE3705, description and measuring1
RE3706, description and measuring
RE3707, description and measuring
RE3708, description and measuring
RE3709, description and measuring
RE4233, description and measuring
RE4410, description and measuring
RE5501, description and measuring
RE5502, description and measuring
RE5502, description and measuring1
RE8709, description and measuring
RE9401, description and measuring
RE9402, description and measuring
RE9403, description and measuring
RE9404, description and measuring
RE9405, description and measuring
RE9460, description and measuring
RE9474, description and measuring
SE5501, description and measuring
SE9155, description and measuring
Service position
Steering system, description
SW2705, description and measuring
SW2706, description and measuring
SW4234, description and measuring
SW5501, description and measuring
SW9402, description and measuring
SW9425, description and measuring
SW9426, description and measuring
SW9454, description and measuring
SW9455, description and measuring
SW9456, description and measuring
SW9457, description and measuring
SW9460, description and measuring
SW9470, description and measuring
SW9471, description and measuring
SW9472, description and measuring
SW9473, description and measuring
PF2181 Diagrams
Component list, Circuit breakers
Component list, Fuses
Component list, Instruments
Component list, Lights
Component list, Miscellaneous
Component list, Relays
Component list, Resistors
Component list, Sensors
Component list, Switches
Hydraulic diagram
Wiring diagram 1-1
Wiring diagram 1-2
Wiring diagram 2-1
Wiring diagram 2-2
Wiring diagram 3-1
Wiring diagram 3-2
Wiring diagram 4-1
Wiring diagram 4-2
Wiring diagram 5-1
Wiring diagram 5-2
Wiring diagram 6-1
Wiring diagram 6-2
Wiring diagram 7-1
Wiring diagram 7-2
Wiring diagram 8-1
Wiring diagram 8-2
Wiring diagram 9-1
Wiring diagram 9-2
Wiring diagram 10-1
Wiring diagram 10-2
Wiring diagram 11-1
Wiring diagram 11-2
Wiring diagram 12-1
Wiring diagram 12-2
Wiring diagram 13
Wiring diagram 14
PF2181 Installation Instruction
10 foot auger extension, installing new
12 foot auger extension, installing new
14 foot auger extension, installing new
16 foot auger extension, installing new
18 foot auger extension, installing new
20 foot auger extension, installing new
Double joint matcher, installing new
Electric fuel gauge, installing new
Feed control paddle, installing new
Material indicator, installing new
Oscillating push roller, installing new
Single joint matcher, installing new
Ultrasonic feeder control, installing new
Ultrasonic feeder control, installing new1
PF2181 Repair
Air cleaner primary filter, cleaning
Air cleaner system, checking
Air cleaner, replacement of primary filter and secondary filter
Auger conveyor drive chains, adjusting
Auger conveyor drive chains, checking
Auger conveyor motor, installing
Auger conveyor motor, removing
Auger conveyor planetary oil level, checking
Auger conveyor planetary oil, changing
Auger conveyor planetary oil, draining
Auger conveyor planetary oil, filling
Auger conveyor planetary, installing
Auger conveyor planetary, removing
Auger conveyor pump control filter, changing
Auger conveyor pump, installing
Auger conveyor pump, removing
Auger sections, inspecting
Battery, cleaning and inspection
Battery, connecting
Battery, disconnecting
Battery, installing
Battery, removing
Bogie wheel king pins, greasing
Bogie wheels, greasing
Brake shift valve, replacing
Charge oil filter, changing
Charge pressure relief valve, adjusting
Charge pressure relief valve, replacing
Clutch assembly, installing
Clutch assembly, removing
Clutch operating shaft, greasing
Clutch throw out collar, greasing
Clutch torque measurement; checking
Clutch torque; adjusting
Conveyor chain, adjusting
Conveyor chain, checking
Coolant level, check
Coolant quality, checking
Coolant, draining
Coolant, filling
Cooling package, installing
Cooling package, removing
Cooling system integrity, checking
Drive shaft, greasing
Drive shaft, installing
Drive shaft, removing
Drive wheel mounting bolt torque, checking
Dust evacuator check valve, checking
E-7007
Engine hood, installing
Engine hood, removing
Engine oil filter, replacing
Engine oil level, checking
Engine oil, changing
Engine oil, draining
Engine oil, filling
Engine, installing
Fan belt, checking
Fuel level, checking
Fuel water separator, changing
Fuel water separator, draining
Fuel water separator, draining1
General purpose pump, installing
General purpose pump, removing
Generator pump, installing
Generator pump, removing
High low valve, replacing
Hopper hinge, inspection
Hopper lock pins, greasing
Hydraulic oil level, checking
Hydraulic oil suction strainer, change
Hydraulic oil system, priming
Hydraulic oil tank relief valve, cleaning
Hydraulic oil tank relief valve, installing
Hydraulic oil tank relief valve, removing
Hydraulic oil tank, draining
Hydraulic oil tank, filling
Hydraulic oil, changing
MA4206, replacing
MA4412, replacing
MA4413, replacing
MA5501, replacing
MA9470, replacing
MA9471, replacing
Main distribution valve, installing
Main distribution valve, removing
Maintenance service, daily1
Maintenance service, daily2
Maintenance service, every 50 hours1
Maintenance service, every 50 hours2
Maintenance service, every 250 hours1
Maintenance service, every 250 hours2
Maintenance service, every 500 hours1
Maintenance service, every 500 hours2
Maintenance service, every 1000 hours1
Maintenance service, every 1000 hours2
Maintenance service, first 50 hours1
Maintenance service, first 50 hours2
Parking brake, checking
Primary fuel filter, changing
Propulsion planetary oil level, checking
Propulsion planetary oil, changing
Propulsion planetary oil, draining
Propulsion planetary oil, filling
Propulsion planetary, installing
Propulsion planetary, removing
Propulsion pump, installing, left side
Propulsion pump, installing, right side
Propulsion pump, multi function valve, replacing
Propulsion pump, removing, left side
Propulsion pump, removing, right side
PTO main bearing, greasing
Pump drive box oil level, checking
Pump drive box oil, changing
Pump drive box oil, draining
Pump drive box oil, filling
Pump drive box, installing
Pump drive box, removing
RE3706, replacing
RE5501, replacing
RE5501, replacing1
Screed, installing
Screed, removing
SE5501, replacing
Servo shunt valve spool, replacing
SW3703, replacing
SW4233, replacing
SW4234, replacing
SW5501, replacing
Tandem bogie pivot, greasing
Washdown fuel filter, changing
Wheel, installing
Wheel, removing
PF2181 Safety
A few simple safety rules
Before operating
Before service, read
Charging batteries
Cleanliness
Environment
Service positions
Welding and grinding work
PF2181 Service Bulletins
Dynex pump priming procedures
High altitude and cold weather start of Tier III engine
Hydraulic oil dye
Hydraulic system flush procedure
New arm rest
New product
Preservation
Screed Lift solenoid valve improvement
PF2181 Special Tools, Misc
GRD G700B LabourTimeGuide
Recommended special tools
RM Compaction ABG Time Guide
RM Compaction Time guide
RM Paving Systems ABG Time Guide
PF2181 Specifications
Auger conveyor motor, specifications
Auger conveyor pump, specifications
Auger lift cylinder, specifications
Auger lift cylinder, specifications1
Brake valve, specifications
Brake valve, specifications1
Flow gate cylinder, specifications
Flow gate cylinder, specifications1
Frame and wheels, tightening torque
General purpose pump, specifications
General purpose pump, specifications1
Hopper lift cylinder, specifications
Hopper lift cylinder, specifications1
Power transmission, tightening torque
Propulsion motor, specifications
Propulsion motor, specifications1
Propulsion planetary, specifications
Propulsion planetary, specifications1
Propulsion pump, specifications
Propulsion pump, specifications1
Screed lift cylinder, specifications
Steering cylinder, specification
Steering cylinder, specification1
Tightening torque, specifications1
Tightening torque, specifications2
Tightening torque, specifications3
Tightening torque, specifications4
Tightening torque, specifications5
Tightening torque, specifications6
Tow point cylinder, specifications
Vibration motor, specifications
