Volvo Wheel Loader L45G Service and Repair Manual
File Size: 63.67 MBFile Format: PDF
Machine Type: Wheel Loader
Manual Type: Service and Repair Manual, Hydraulic and Electrical Diagram
Model: Volvo L45G Wheel Loader
Number of Pages: 911 Pages
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/1 Volvo L45G
Accumulator, check
Accumulator, discarding
Air conditioning, capacity
Attachment bracket cylinder, reconditioning
Attachment locking hydraulic cylinder (vision-optimised bracket), replacing
Automatic engine shut-down
Axle, installing
Axle, removing
Axles, changing oil
Axles, tightening torques
Battery, cables and connections, check
Bolted joints, check tightening torque
Boom suspension system, functional check
Boom Suspension System, general description
Booting sequence
Brake calliper removed, reconditioning
Brake disc, replacing one
Brake linings, checking wear
Brake system, adjusting unloading pressure
Brake system, bleeding
Brakes, specifications
Burner, checking
Burner, replacing
Bus communication supervision
Cab description
Cab filter, replace (clean when necessary)
Cab mounts, tightening torques
CareTrack W-ECU, description
CE-marking, EMC-directive
Central warning
Charging batteries
Check coolant level
Cleanliness when working on hydraulic components
Comfort drive control (CDC), control valve, installation
Comfort Drive Control (CDC), control valve, removal
Comfort Drive Control (CDC), description
Communication with data buses 1
Component descriptions
Component list Fuses
Component list Heating coils, instruments, service socket
Component list Lights
Component list Relays
Component list Switches
Component list, PWM valves
Component list, Sensors
Component list, Sounders
Component locations
Conditions when checking
Connectors, overview
Control units, changing
Coolant pump, replacing
Coolant
Cooling system, capacity
Counterweight, fitting
Counterweight, removing
CU2501, description and measuring
CU2503, description and measuring
CU6601, description and measuring
Description brake system
Diesel particulate filter, check and clean 1
DPF regeneration control
Drive axles, description
Electric welding
Engine hood, installing
Engine hood, removing
Engine oil pressure sensor, replacing
Engine suspension, tightening torques
Engine, capacity
Engine, installing
Engine, oil level, check
Engine, specification
Engine, weights
Error codes when calibrating
Error codes, build-up
E-tool Cab support
E-Tool copy
Frame joint, assembly of separated machine
Frame joint, replacing bearings
Frame, weight
Front axle, capacity
Front axle, specification
Front axle, weight
Fuel feed pump, description
Fuel pump, replacing
Fuel system, specifications
FX1031, description and measuring
General information to note when working on the hydraulic system
Glow plug, replacing
Heating system, description
Hydraulic attachment bracket (quickfit), description
Hydraulic diagram transmission
Hydraulic diagram with option components
Hydraulic diagram with option components1
Hydraulic diagram with option components2
Hydraulic diagram with option components3
Hydraulic diagram with option components4
Hydraulic diagram, Boom Suspension System
Hydraulic diagram, brake system
Hydraulic diagram, control valve
Hydraulic diagram, cooling fan
Hydraulic diagram, steering incl. lever steering (CDC)
Hydraulic diagram, working hydraulic system1
Hydraulic diagram, working hydraulic system2
Hydraulic diagram, working hydraulics, 3rd and 4th functions, attachment lock
Hydraulic motor, replacing
Hydraulic oil level, check
Hydraulic oil tank, sediment drain
Hydraulic pressure, check
Hydraulic pump, checking and adjusting max working pressure
Hydraulic pump, description
Hydraulic pump, replacing 1
Hydraulic system, changing oil.
Hydraulic system, volume
Hydrostatic pump charge pressure, check and adjust
Hydrostatic pump cut off valve, check and adjust
Hydrostatic pump high pressure valve, check and adjust
Hydrostatic pump mechanical zero position, check and adjust
Hydrostatic pump, description
Hydrostatic transmission, description
Implemental attachment hydraulic cylinder, replacing
Information display, check 1
Information display, engine
Information display, general
Information display, service mode
Information display, settings
Information display, start lockout
Information display, vehicle info
Injector sleeves, replacing
Injectors, replacing all
Instrument panels
Lead and connector checks
Lighting, description
Lights, specifications
Limp home
Loader boom, safety strut
Lubrication oil pressure, checking
Lubrication
MA2301-MA2304, description and measuring
MA2508, description and measuring
MA2509, descripton and measuring
MA2510, description and measuring
MA2512, description and measuring
MA2602, description and measuring
MA4220, description and measuring
MA4221, description and measuring
MA4228, description and measuring
MA4603, description and measuring
MA4710, description and measuring
MA4720, description and measuring
MA9172, description and measuring
MA9173, description and measuring
MA9174, description and measuring
Machine dimensions
Machine, Calibration
Main control valve, removal
Maintenance service, general
Marking connector pin description
MATRIS and Tech Tool, reading
Middle instrument panel with warning lights
MO2505, description and measuring
MO6401, description and measuring
MS.Internal.Documents
Parking brake pads, check
Pause heater, description
Power supply T-ECU, description and measuring
Power supply V2-ECU, description and measuring
Power transmission, specifications
PPID 437 explanation
Preheating, description
Pressure settings steering system
PWM2602, description and measuring
PWM4225, description and measuring
PWM4226, description and measuring
PWM4227, description and measuring
PWM6601, description and measuring
PWM6602, description and measuring
R2701, description and measuring
R4201, description and measuring
RE02, description and measuring
RE06, description and measuring
RE09, description and measuring
RE10, description and measuring
RE15, description and measuring
RE6401, description and measuring
RE8712, description and measuring
Rear axle, capacity
Rear axle, specification
Rear axle, weight
Reduced computer communication
SAE error codes, translation to error messages, general
SAE J1708 1587 Information link, description and measuring
SAE J1939 CAN1 Control link, description and measuring
SAE J1939 CAN2 control link, description and measuring
SAEJ1939 CAN7 Control link, descripton and measuring
SE2512, description and measuring
SE2520, description and measuring
SE2523, description and measuring
SE2524, description and measuring
SE2525, description and measuring
SE2526, description and measuring
SE2702, description and measuring
SE4201, description and measuring
SE4405, description and measuring
SE4406, description and measuring
SE4407, description and measuring
SE5205, description and measuring
SE6401, description and measuring
SE6403, description and measuring
SE6404, description and measuring
SE6601, description and measuring
SE8708, description and measuring
SE8709, description and measuring
SE9109, description and measuring
Semi-auto DPF regeneration
Service brake pressure, checking
Service brake, brake disc wear, check
Service brake, checking pressure
Service position 1
Service position 2
Service position 11
Servo valve, description
Side window, replacing2
Spark plug, replacing 1
Start hydraulic motor control, check and adjust
Start hydraulic pump control, check and adjust
Starter motor, replacing
Steering cylinders, locking of pivot pins, check
Steering system, checking and adjusting working pressure
Steering system, description
Steering system, troubleshooting and elimination
SW4205 SW4206, description and measuring
SW4208, description and measuring
SW4217, description and measuring
SW8701, description and measuring
Thermostat, replacing
Tire size
Towing
Transmission circuit hydraulic schematic
Transmission oil filter
Transmission sensor, replacing
Transmission shutdown
Transmission solenoid, replacing
Transmission, function check
Transmission, installing
Transmission, removing
Travel motor, description
Troubleshooting chart
Troubleshooting tools
Turbocharger, description
Vacuum pump, connection
Valve cover, installing
Valve cover, removing
VCADS Pro service tool
VCADS Pro, Operations
Water separator, drain
Wheel nuts, check torque
Wheel, tightening torque
Windscreen, replacing1
Wiring diagram WD201
Wiring diagram WD202
Wiring diagram WD203
Wiring diagram WD204
Wiring diagram WD205
Wiring diagram WD206
Wiring diagram WD301
Wiring diagram WD302
Wiring diagram WD303
Wiring diagram WD304
Wiring diagram WD305
Wiring diagram WD306
Wiring diagram WD307
Wiring diagram WD308
Wiring diagram WD309
Wiring diagram WD310 1
Wiring diagram WD310 2
Wiring diagram WD311
Wiring diagram WD312
Wiring diagram WD313
Wiring diagram WD314
Wiring diagram WD315
Wiring diagram WD316
Wiring diagram WD317
Wiring diagram WD318
Wiring diagram WD401
Wiring diagram WD402
Wiring diagram WD403
Wiring diagram WD404
Wiring diagram WD501
Wiring diagram WD601
Wiring diagram WD602
Wiring diagram WD603
Wiring diagram WD801
Wiring diagram WD802
Wiring diagram WD803
Wiring diagram WD804
Wiring diagram WD901
Wiring diagram WD902
Wiring diagram WD903
Wiring diagram WD904
Wiring diagram WD905
Wiring diagram WD906
Work on the machine's electrical system
Working under raised boom
