Volvo Wheel Loader L220F Service and Repair Manual
File Size: 146.31 MBFile Format: PDF
Machine Type: Wheel Loader
Manual Type: Service and Repair Manual, Hydraulic and Electrical Diagram
Model: Volvo L220F Wheel Loader
Number of Pages: 5830 Pages
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/1 Volvo L220F
Accelerator Pedal 1
Accelerator Pedal 2
Air cleaner, description
Air conditioning, description
Alarm, description
Alternator 80 A, description
Automatic brake valve, description
Automatic differential brake, Limited Slip, description
Basic checks
Battery disconnector switch, description
Boom suspension system, component location
Boom Suspension System, description 1
Boom Suspension System, description 2
Booting sequence
Brake accumulator, description 1
Brake accumulator, description 2
Braking system with RBB, description
Braking system, description 1
Braking system, description 2
Bus communication supervision
Cab and air conditioning
Cable and component marking explanations 1
CareTrack W-ECU, description
Central valve, description
Central warning
Charging of batteries
Chassis connection
Climate control unit ECC, description
Communication with data buses
Component list Diodes
Component list Fuses
Component list Heating coils, instruments, service socket
Component list Lights
Component list Motors, resistors, monitoring system
Component list PWM valves
Component list Relays
Component list Sensors
Component list Signals, shift solenoids
Component list Switches
Conditions when checking
Connectors, overview
Control valve, description 1
Control valve, description 2
Control valve, description 3
Cooling fan, description
CU6601, description and measuring
CU9901, description and measuring
Differential lock, description 1
Differential lock, description 2
Dosage valves, description
ECC, IO list
E-ECU PID158, description and measuring
E-ECU, IO list
Electric welding 1
Electric welding
Error codes, showing
Filling lubricant
Floating position, description
Foot brake valve, description
Frame joint, description
Frame, description
Front axle, description 1
Front axle, description 2
Fuel consumption
Fuel filter, description
Hand Throttle
Hydraulic attachment bracket, description
Hydraulic pumps, description
Hydraulic system and component positions
I-ECU, IO list
Information display, axles brakes 1
Information display, axles brakes 2
Information display, check 1
Information display, electrical system 1
Information display, electrical system 2
Information display, engine
Information display, general
Information display, hydraulics 1
Information display, hydraulics 2
Information display, service 1
Information display, service 2
Information display, service mode 1
Information display, service mode 2
Information display, settings
Information display, start lockout
Information display, vehicle info
Instrument control unit I-ECU, description
Instrument panels
Intercooler, description
Intermittent wiper and washer
Interruption in computer communication
Key feed
Lead and connector checks
Lift function, description 1
Lift function, description 2
Lighting, description
Limp Home
Lock up, description
MA2301-MA2306, description and measuring
MA2504, description and measuring
MA2601, description and measuring
MA2602, description and measuring
MA4603, description and measuring 1
MA4603, description and measuring 2
MA5501, description and measuring 1
MA5501, description and measuring 2
MA5502, description and measuring
MA9102, description and measuring
MA9103, description and measuring
MA9104, description and measuring
MA9106, description and measuring
MA9141, description and measuring
MA9142, description and measuring
Machine hours
Maintenance service, fire suppression system
Middle instrument panel with warning lights
MO6401, description and measuring 1
MO6401, description and measuring 2
MO8707, description and measuring
Parking brake, description 1
Parking brake, description 2
Pause heater, description 1
Pause heater, description 2
Power supply E-ECU, description and measuring
Power supply V2-ECU, description and measuring
Preheating, description 1
Pressure monitor, description
PWM2601, description and measuring
PWM4203, description and measuring
PWM5201, description and measuring
PWM6601, description and measuring 1
PWM6601, description and measuring 2
PWM6602, description and measuring 1
PWM6602, description and measuring 2
PWM9101, description and measuring 1
PWM9101, description and measuring 2
PWM9102, description and measuring 1
PWM9102, description and measuring 2
PWM9103, description and measuring 1
PWM9103, description and measuring 2
PWM9104, description and measuring 1
PWM9104, description and measuring 2
PWM9105, description and measuring
PWM9106, description and measuring
PWM9107, description and measuring
PWM9108, description and measuring
PWM9132, description and measuring
PWM9134, description and measuring
PWM9135, description and measuring
R2701, description and measuring
RBB, description
RE02, description and measuring 1
RE06, description and measuring
RE08, description and measuring
RE09, description and measuring
RE10, description and measuring
RE15, description and measuring
RE6401, description and measuring 1
RE6401, description and measuring 2
RE8701, description and measuring
Rear axle, description 1
Rear axle, description 2
Reduced computer communication
Repairing hydraulic system
SAE error codes MID 128 Engine control unit (E-ECU)
SAE error codes MID 146 Electronic climate control unit (ECC)
SAE error codes MID 187 Vehicle control unit (V-ECU)
SAE error codes, translation to error messages, general
SAE J1708 1587 Information link, description and measuring
SAE J1939 CAN1 Control link, description and measuring
SAE J1939 CAN2 Control link, description and measuring
SA-SF, description and measuring
SE2202, description and measuring 1
SE2202, description and measuring 2
SE2205, description and measuring
SE2302, description and measuring
SE2501, description and measuring
SE2502, description and measuring
SE2507, description and measuring
SE2508, description and measuring
SE2509, description and measuring
SE2601, description and measuring
SE2602, description and measuring
SE2702, description and measuring
SE2704, description and measuring
SE4209, description and measuring
SE4213, description and measuring
SE4226, description and measuring
SE4307, description and measuring
SE4311, description and measuring
SE4608, description and measuring 1
SE4608, description and measuring 2
SE4901, description and measuring
SE4903, description and measuring
SE4904, description and measuring
SE5201, description and measuring
SE5202, description and measuring
SE5205, description and measuring
SE5218, description and measuring
SE5503, description and measuring 1
SE5503, description and measuring 2
SE6401, description and measuring
SE6403, description and measuring
SE6407, description and measuring
SE6601, description and measuring 1
SE6601, description and measuring 2
SE8503, description and measuring
SE8708, description and measuring
SE8709, description and measuring
SE9101 SE9102, description and measuring
SE9104, description and measuring
SE9107, description and measuring
SE9145, description and measuring
SE9146, description and measuring
SE9147, description and measuring
SE9148, description and measuring
Shift valve, description
Software, description
Steering system, component location
Steering system, description
Steering valve, description
SW3801, description and measuring
SW4205 SW4206, description and measuring 1
SW4205 SW4206, description and measuring 2
SW4205 SW4206, description and measuring 3
SW4208, description and measuring
SW4209, description and measuring
SW4211, description and measuring
SW4212, description and measuring
SW4217, description and measuring
SW4219, description and measuring
SW4220, description and measuring
SW4221, description and measuring
SW4222, description and measuring
SW5501, description and measuring
SW8701, description and measuring
SW9143, description and measuring
SW9148, description and measuring
System voltage
Tech Tool, operations
Theft protection
Tilt function, description
TP-Linkage's bearing points
Transmission, component position
Travelling speed
Troubleshooting tools
Turbocharger, description 1
Turbocharger, description 2
Unit injector, Delphi, description
V2-ECU, IO list
VCADS Pro service tool
VCADS Pro, Error codes
V-ECU, IO list
Vehicle control unit V2-ECU, description
Washer fluid level
Working hydraulic system, function description
Hydraulic diagram transmission
Hydraulic diagram, complete 1
Hydraulic diagram, complete 2
Hydraulic diagram, complete 3
Hydraulic diagram, complete 4
Hydraulic diagram, complete 5
Hydraulic diagram, complete 6
Wiring diagram 201
Wiring diagram 202
Wiring diagram 203
Wiring diagram 204
Wiring diagram 205
Wiring diagram 206
Wiring diagram 207
Wiring diagram 301-1
Wiring diagram 301-2
Wiring diagram 301-3
Wiring diagram 302-1
Wiring diagram 302-2
Wiring diagram 302-3
Wiring diagram 303
Wiring diagram 304
Wiring diagram 305
Wiring diagram 306
Wiring diagram 308
Wiring diagram 309
Wiring diagram 310
Wiring diagram 311-1
Wiring diagram 311-2
Wiring diagram 311-3
Wiring diagram 312
Wiring diagram 313
Wiring diagram 314-1
Wiring diagram 314-2
Wiring diagram 315-1
Wiring diagram 315-2
Wiring diagram 315-3
Wiring diagram 316
Wiring diagram 317
Wiring diagram 319
Wiring diagram 401-1
Wiring diagram 401-2
Wiring diagram 402
Wiring diagram 403-1
Wiring diagram 403-2
Wiring diagram 404
Wiring diagram 405
Wiring diagram 407
Wiring diagram 408-1
Wiring diagram 408-2
Wiring diagram 409
Wiring diagram 501-1
Wiring diagram 501-2
Wiring diagram 501-3
Wiring diagram 601-1
Wiring diagram 601-2
Wiring diagram 602-1
Wiring diagram 602-2
Wiring diagram 604-1
Wiring diagram 604-2
Wiring diagram 801
Wiring diagram 802
Wiring diagram 804-1
Wiring diagram 804-2
Wiring diagram 805-1
Wiring diagram 805-2
Wiring diagram 806-1
Wiring diagram 806-2
Wiring diagram 807
Wiring diagram 901-1
Wiring diagram 901-2
Wiring diagram 902-1
Wiring diagram 902-2
Wiring diagram 903
Wiring diagram 904
Wiring diagram 909
Wiring diagram 910
Wiring diagram 911-1
Wiring diagram 911-2
Wiring diagram 912-1
Wiring diagram 912-2
Wiring diagram 913
Wiring diagram 915
Installation Instructions
3rd 4th hydraulic function, installing new
3rd hydraulic function, electric-hydraulic, installing new
3rd hydraulic function, installing new
3rd-4th hydraulic function, installing new
Attachment locking, installing new
Attachment work light, installing new
Automatic lift arm lowering (Return to dig), installing new
Axle oil cooler, installing new
Care Track 1
Care Track 2
Engine heater, 230V
Filtered alternator, installing new
Forward view camera, installing new
Front view mirror, installing new
Hand throttle, instaling new
Heated and adjustible rear view mirror
Lever steering (CDC), electric, installing new 1
Lever steering (CDC), electric, installing new 2
Lever steering (CDC), hydraulic, installing new 1
Lever steering (CDC), hydraulic, installing new 2
Pre celaner olibath type
Pre Cleaner
Protection for lighting, front, installing new
Protection for lighting, rear, installing new
Radiator grill guard, installaing new
Single lever control, installing new 1
Swing out fender, installing new
Work light extra front, installing new
Work light front, installing new
3rd 4th hydraulic function, checking and adjusting pressure
3rd 4th hydraulic function, shock valve, checking
3rd 4th hydraulic function, solenoid valve, replacing
Accumulator, boom suspension system, discarding
Accumulator, check
Accumulator, checking (pressure back-up for servo circuit)
Accumulator, discarding 1
Accumulator, discarding 2
Attachment locking, functional check
Automatic brake, function check
Axle, installing
Axle, removing
Battery condition, check 1
Battery condition, check 2
Bleeding air
Boom suspension accumulator, check and adjusting 1
Boom suspension accumulator, reconditioning
Boom suspension system, pressure reduction, safety valve, checking and adjusting
Brake disc, replacing 1
Brake disc, replacing 2
Brake disc, replacing 3
Brake disc, replacing 4
Brake discs, for service brake, checking
Brake discs, measuring wear 1
Brake discs, measuring wear 2
Brake pedal, adjusting angle
Brake piston, replacing seals 1
Brake piston, replacing seals 2
Brake piston, replacing seals 3
Brake piston, replacing seals 4
Brake system, bleeding
Brake system, checking function, retardation
Cab, installing 1
Cab, installing 2
Cab, installing 3
Cab, removing 1
Cab, removing 2
Cab, removing 3
Central valve, installation
Central valve, removal
Charge air system, inspection
Climate unit, installing
Climate unit, removing
Comfort drive control (CDC), control valve, installation
Comfort Drive Control (CDC), control valve, removal
Compression test 1
Compression test 2
Cooling fan hydraulics, funktion check
Cooling fan motor, replacing
Cylinder compression, VCADS Pro
Differential lock, adjusting
Differential lock, function check
Door lock cylinder, replacing
Door lock, changing
E 1708, Checking point
E1711
E-2000
E-2001
E-2005
E-2017
ECC control unit, replacing 1
ECC, MID 146, changing non-programmed ECU
ECC, MID 146, changing pre-programmed ECU
Engine hood, installing
Engine hood, removing
Engine, installing 1
Engine, installing 2
Engine, removing 1
Engine, removing 2
Error codes when calibrating 1
Error codes when calibrating 2
Evaporator, replacing incl draining and filling 1
Evaporator, replacing incl draining and filling 2
Fan control valve, installing
Fan control valve, removing
Fan control valve, seal replacement
Foot brake valve removed, reconditioning
Foot brake valve, installation
Foot brake valve, removal
Frame joint, changing bearings and pins
Frame joint, checking clearance
Front wheel, installation
Front wheel, removal
Fuel pump (valves), inspection
Fuel pump, inspection
Heat control valve, replacing
Heater core, replacing 1
Hub reduction, installing 1
Hub reduction, installing 2
Hub reduction, removing 1
Hub, replacing seal 1
Hub, replacing seal
Hydraulic power control valve, replacing
Hydraulic pump, checking and adjusting max working pressure 2
Hydraulic pump, checking and adjusting stand-by pressure (LS-line removed)
Hydraulic system, bleeding
Idle, VCADS Pro
Lift lower, angle sensor, changing 1
Lift lower, angle sensor, changing 2
Lift, functional check
Lift, solenoid valve, changing
Lifting time, checking 1
Lifting time, checking 2
Lock up valve, replacing
Lock up, function check
Lock up, solenoid valve, replacing
Lower, solenoid valve, changing
Main pressure valve, replacing
Maintenance service, every 4000 hours 1
Operator's seat, securing
Parking brake, component location
Parking brake, function checking 1
Parking brake, function checking 2
Parking brake, replacing discs and seals
Pump 3 (P3) standby pressure, checking and adjusting (LS-line removed)
Pump 3 (P3), max pressure and fan speed, checking and adjusting
Radiator, replacing
Rear wheel, installing
Rear wheel, removing
Receiver, replacing incl draining and filling 1
Receiver, replacing incl draining and filling 2
Secondary steering pump, checking and adjusting working pressure
Servo accumulator, removal
Servo pressure, checking at the spool in control valve 1
Servo pressure, checking at the spool in control valve 2
Servo valve, adjusting control
Servo valve, installation
Servo valve, removal
Shift valve, checking
Shift valve, installing
Shift valve, removing
Shock valve lift function, checking 1
Shock valve lift function, checking 2
Side window, replacing
Stall speed, checking
Stall speed, VCADS Pro
Steering system, checking and adjusting working pressure 1
Steering system, checking and adjusting working pressure 2
Steering system, checking and adjusting working pressure 3
Steering system, function check
Steering valve, replacing
Temperature sensor cooling system, replacing
Tilt in out, angle sensor, changing
Tilt in, solenoid valve, changing
Tilt out, solenoid valve, changing
Tilt, functional check
Towing
Transmission oil pressure, checking 1
Transmission oil pressure, checking 2
Transmission oil pressure, checking 3
Transmission oil pressure, checking 4
Transmission oil pressure, checking 5
Transmission oil pressure, checking 6
Transmission oil pressure, checking 7
Transmission pressure sensor, replacing
Transmission solenoid, replacing
Transmission, calibration
Transmission, installing
Transmission, removing
Unit injector, replacing 1
Unit injector, replacing 2
Update of automatic lubrication system
V2-ECU, MID 249, changing non-programmed ECU
V2-ECU, MID 249, changing pre-programmed ECU
Valves, adjusting 1
Valves, adjusting 2
VCADS Pro, central systems updating, replace component
VCADS Pro, MID 128, programming E-ECU
VCADS Pro, Operations 1
VCADS Pro, Operations 2
VCADS Pro, Operations 3
Viscous cab suspension, changing one unit
Warranty inspection 100 hours
Windscreen, replacing
CE-marking, EMC-directive
Checking function
Safety concerns everybody! 1
Safety concerns everybody! 2
Safety when lifting and supporting complete machine
Safety when working on hydraulic systems 1
Service position 1
Service position 1-1
Service position 1-2
Service position 2
Service position 2-2
Service position 2-3
Service position 2-4
Some simple rules regarding tyre handling 1
Working under raised boom
AC compressor, fill with oil
Air bleeding of the central lubrication system
Automatic shifting (APS)
Broken exhaust valve stem
Cab suspension 1
Cab suspension 2
Cab suspension
CareTrack, new software update 2008.3.0, including new Conversion kit part numbers for E series haulers and F series loaders
CDC function, disengaging
CDC-system, product improvements
Central lubrication 1
Central lubrication, oxide on pins
Central lubrication
Central valve, replacing priority spool
Changes in option secondary steering
Cleaning of the machine
Connector protection for axle oil temperature sensor
Control measurement for electric servo lever and tilt lift angle sensor
Cracks in cross tube
Cranking problems
D- arm cracks
D9B and D12D Stage 3, valve adjustment, camshaft marking
ECU improvements
ECU, functional check
Engine labelling
Engine oil diluted by fuel
Erroneous signal from accelerator pedal
Error code, check
Gearshifting
Ghost codes for F-series wheel loaders
Guide pins D12D
Heater element
Heater unit, external leakage
Heating core for cab heating
Hydraulic oil cooler
Hydraulic Power Control, troubleshooting
Improved fuel filling capacity
Improved hour recorder
Improved wiper motor
Incorrect symbol on lever carrier casing
Incorrectly assembled back-up ring in compensator
Inoperative audible reverse alarms
Introduction of new climate unit, HVAC II
Leaking cab heating element
Limitation, TP-linkage
Locking set screw installation on the double rocker arm
Loctite added on plugs and cartridges on BSS-valve
Loose seat base
Moved brake pressure sensor
New AC compressor
New accelerator pedal with gold plated terminals
New angle sensor installation for CDC
New angle sensor installation, lift and tilt function
New angle sensor kit introduced
New cab heater element
New CareTrack W-ECU2
New coolant pump connecting pipe
New engine rubber cushion
New equipment, OptiShift
New front and rear axles introduced
New fuel filter housing
New fuel tank gasket
New gas strut for cab door
New gear lever combi-switch
New hydraulic pump
New hydraulic transmission
New main control valve with integrated BSS-connection ports
New reverse alarm
New sealing method for oil sump
New sensor and new sensor installation
New software version 2008.6.0 and 2008.6.1
New software version 2012.3.0
New software version V2011.4.1
New system design to meet revised ISO 15998
New temperature sensor
New turbocharger for the D12 engine
New type of axle oils
New V-ECU and V2-ECU
Non - VCE buckets and attachments
Oil analyses
Oil jet nozzle eliminated from the D12D exhaust double rocker arm
Oil sump
Operator adaptation of electric servo lever functions with VCADS Pro
O-ring with improved fit between hydraulic pump and transmission
Parameter changes in VCADS Pro
Parking brake solenoid valve
Parking brake switch
Problems with leaking test port hoses
Protective grating, radiator
Reinforcing the general purpose and rock buckets
Repair report for central lubrication pumps
Return to dig, lifting arms lowering positioner
Seals
Secondary steering pump adjustment
Service solution, separate belts
Shaking or vibration in the working hydraulics
Smoother steering with improved draining of shift valve
Software release summary WLO F-models
Soot on silencer
Springs and plugs for main control valve
Transmission components
Transmission, introduced actions
Troubleshooting hydraulic pumps
Turbo Hot Shutdown
Tyres, various types
Ventilation hose
Warning decals
Windshield guard interferes with nipple
3rd 4th hydraulic function, specifications
Air conditioning, refrigerant, weight
Alternator 80 A, specification
Battery, specifications 1
Battery, weight
Boom Suspension System, tightening torques
Brake accumulator, specifications 1
Brake accumulator, specifications 2
Brake system, specifications
Brake valve, tightening torques
Cab, tightening torque
Control valve, lever steering (CDC), specifications
Control valve, specifications
Cooling fan rpm, specifications
Cooling system, volume
Engine, capacities 1
Engine, capacities
Engine, specification 1
Engine, specification 2
Engine, weight
Frame, tightening torque
Front and rear axles, specifications 1
Front and rear axles, specifications 2
Front and rear axles, tightening torque 1
Front and rear axles, tightening torque 2
Front and rear axles, volume
Function times, specifications
Hydraulic pump (P1), specifications
Hydraulic pump (P2), specifications
Hydraulic pump (P3), specifications
Hydraulic pumps, tightening torques
Hydraulic system, volume
Hydraulic transmission, specifications 1
Hydraulic transmission, specifications 2
Hydraulic transmission, tightening torques
Parking brake, specifications
Preheating, specifications
Rear axle mounting, volume
Recommended lubricants, oils
Secondary steering pump, specifications
Servo system, specifications
Starter motor, specifications
Steering, specifications
Temperature limits for cooling fan speed, specifications.
Tightening torques, cooling fan
Valve cover, tightening torque
Valve mechanism, tightening torques
Valve system, specification 1
Valve system, specification 2
Wheel brake, specification 1
Wheel brake, specification 2
Wheel brake, tightening torques
Wheels, tightening torques
Speical Tools, Misc
RM Compaction ABG Time Guide Old
RM Compaction Time guide old version
RM Paving Systems ABG Time Guide Old
Special Tools Recommendations
