Volvo Wheel Loader L150H Service and Repair Manual
Model: Volvo L150H Wheel LoaderBrand: Volvo
Type of Machine: Wheel Loader
Type of Manual: Hydraulic and Electrical Diagram, Service and Repair Manual
Number of Pages: 6179 Pages
1 L150H
Descriptions
3rd, or 3rd 4th hydraulic function, description
ACM, I O list
AdBlue®DEF pump unit diagnostics, description
Air conditioning, component location
Air conditioning, function description
Air conditioning, tightening torques
Alternator 80 A, description
Automatic brake valve, description
Automatic differential brake, Limited Slip, description
Axle oil cooler, component location
Axle oil cooler, description
Boom suspension system, component location
Boom Suspension System, description
Booting sequence
Brake accumulator, description
Braking system, description
Cab and air conditioning
Cab, description
Calibration of Comfort Drive Control (CDC), function description
Calibration of lift lower function, description
Calibration of tilt in out function, description
CareTrack W-ECU, description
CCM, IO list
CDC valve, lever steering, description
Central valve, description
Chassis connection
Comfort Drive Control (CDC), component location
Comfort Drive Control (CDC), description
Components list 1
Components list 2
Components list
Connectors, overview
Control valve, description
Cooling fan, component location
Cooling fan, description
Diagnostic tools, description
Differential lock, description
Dosage valves, description
Drive axles, description
Driver seat, component description
Drivetrain, component location
ECM, IO list
ECO - accelerator pedal
Electric door opener, description
Engine, description 1
Engine, description 2
Error codes, showing
Exhaust aftertreatment fuel system diagnostics, description
Filling lubricant
Foot brake valve, description
Frame joint, description
Frame, description
Front axle, component description
Fuel system, description 1
GPMECU1, IO list
GPMECU2, IO list
GPMECU3, IO list
HMICU, IO list
Hood opening
Hydraulic attachment locking, description
Hydraulic pumps, description
Hydraulic transmission calibration, description
Information display, general
Information display, service mode
Infrared Thermometer
Intermittent wiper and washer 1
Key feed
Lead and connector checks
Leak detector 951 1207, new model
Lever control, electric servo, description
Lifting cylinder, description
Lubrication system, component locations 1
Oil cooler, component location
Parameter settings
Parking brake, component description
Parking brake, component location
Pause heater, description
Power supply CCM, description and measuring
Power supply GPMECU 1, description and measuring
Power supply GPMECU 2, description and measuring
Power supply GPMECU 3, description and measuring
Power supply HMICU, description and measuring
Power supply W-ECU, description and measuring 1
Preheating, description
Pressure monitor, description 1
Propeller shaft, component description
Pump unit, description
Rear axle mounting, component description
Rear axle, component description
Rear vision system
Secondary steering, component location
Service
Servo system, description
Shift valve, description 1
Software, parameter settings and read-outs
Starter motor, description
Steering system, component location
Steering system, description
Steering valve, description
System voltage
Tech Tool, operations
Tilt cylinder, description
TP-Linkage's bearing points
Transmission, component position
W-ECU, IO list
Windows, general, gluing
Working hydraulic system, component location
Working hydraulic system, description
Hydraulic diagram transmission
Hydraulic diagram, basic machine 1 img
Hydraulic diagram, complete fig 1
Hydraulic diagram, complete fig 2
Table of contents, wiring diagrams 1
Table of contents, wiring diagrams 2
Wiring diagram - Aftertreatment
Wiring diagram - Brake
Wiring diagram - BSS
Wiring diagram - CDC
Wiring diagram - Electrically controlled battery disconnector - Key operated, with emergency stop
Wiring diagram - Electrically controlled battery disconnector - Manual, with emergency stop
Wiring diagram - Electrically controlled battery disconnector - Manual, without emergency stop
Wiring diagram - Gear
Wiring diagram - Start
Wiring diagram WD201
Wiring diagram WD202
Wiring diagram WD208
Wiring diagram WD210
Wiring diagram WD211
Wiring diagram WD212
Wiring diagram WD214
Wiring diagram WD220
Wiring diagram WD221
Wiring diagram WD223
Wiring diagram WD224
Wiring diagram WD275
Wiring diagram WD301
Wiring diagram WD303
Wiring diagram WD305
Wiring diagram WD306
Wiring diagram WD320
Wiring diagram WD321
Wiring diagram WD322 1
Wiring diagram WD324
Wiring diagram WD325
Wiring diagram WD326
Wiring diagram WD330
Wiring diagram WD331
Wiring diagram WD333
Wiring diagram WD334
Wiring diagram WD335
Wiring diagram WD337
Wiring diagram WD350
Wiring diagram WD351
Wiring diagram WD352
Wiring diagram WD360
Wiring diagram WD360-2
Wiring diagram WD361
Wiring diagram WD362
Wiring diagram WD363
Wiring diagram WD371
Wiring diagram WD372
Wiring diagram WD373
Wiring diagram WD374
Wiring diagram WD375
Wiring diagram WD376
Wiring diagram WD401
Wiring diagram WD402
Wiring diagram WD403
Wiring diagram WD404
Wiring diagram WD405
Wiring diagram WD406
Wiring diagram WD501
Wiring diagram WD601
Wiring diagram WD602
Wiring diagram WD604
Wiring diagram WD801
Wiring diagram WD802
Wiring diagram WD804
Wiring diagram WD805
Wiring diagram WD806
Wiring diagram WD807
Wiring diagram WD831
Wiring diagram WD903
Wiring diagram WD904
Wiring diagram WD909
Wiring diagram WD910
Wiring diagram WD911
Wiring diagram WD913
Wiring diagram WD915
Installation Instructions
3rd 4th hydraulic function, installing new
3rd hydraulic function, installing new
Alternator 120 Amp, installing new
Attachment locking, installing new
Attachment worklight, installing new
Back up alarm, installing new
Cab front work light LED, installing new
Cab illuminated entrance LED, installing new
Cab rear work light LED, installing new
Cab side work light LED, installing new
Cab, air pre cleaner, installing new
Decal set, installing new
Emergency stop, installing new
Engine heater, installing new
Forward view camera, installing new
Front work light LED, installing new
Grill work light LED, installing new
Hand throttle, instaling new
Lever steering (CDC), electric, installing new
Pre-cleaner turbo type, installing new
Radiator grill guard, installaing new
Radio, installing new
Rapid oil exchange (ROX), installing new
Reflecting stickers, installing new
Reversible fan, installing new
Single lever control, 2nd hydraulic function, installing new
Single lever control, 3rd hydraulic function, installing new
Single lever control, 4th hydraulic function, installing new
Warning beacon flashing strobe light, installing new
Wind shield guard, installing new
3rd 4th hydraulic function, checking and adjusting pressure
3rd 4th hydraulic function, shock valve, checking
3rd 4th hydraulic function, solenoid valve, replacing
3rd 4th hydraulic, functional check
Accumulator removed, checking1
Accumulator removed, checking2
Accumulator, boom suspension system, discarding
Accumulator, discarding
Accumulator, discarding1
Accumulator, discarding2
Accumulator, installation
Accumulator, removal
Accumulators, checking in machine
ACM (After treatment control module), replacing, non-programmed1
ACM (After treatment control module), replacing, pre-programmed1
Actuator, replacing
Actuator, variable turbocharger, replacing
AdBlue® DEF hoses, replacing
AdBlue® DEF nozzle, replacing
AdBlue® DEF pump unit, components, replacing
AdBlue® DEF pump unit, replacing
AdBlue® DEF quality, checking
AdBlue® DEF tank, breather filter, replacing
AdBlue® DEF tank, replacing
AdBlue® DEF tank, tank armature, replacing
AdBlue® DEF, draining
Aftertreatment fuel dosing unit, replacing
Aftertreatment fuel nozzle, cleaning
Aftertreatment fuel nozzle, replacing
Air conditioning, checking performance
Air drier cartridge, replacing
Air in fuel system, checking
Attachment locking, functional check
Automatic brake, function check
Automatic central lubrication filter, replacing
Axle breather filters, replacing
Axle oil cooler filter, replacing1
Axle oil cooler filter, replacing2
Axle, installing
Axle, removing
Basic service
Battery condition, check
Battery, checking
Bleeding air
Boom suspension accumulator, check and adjusting
Boom suspension accumulator, checking
Boom suspension accumulator, reconditioning
Boom suspension system, functional check
Boom suspension system, left accumulator, installation
Boom suspension system, left accumulator, removal
Boom suspension system, pressure reduction, safety valve, checking and adjusting
Boom suspension system, right accumulator, installation
Boom suspension system, right accumulator, removal
Brake disc, replacing
Brake disc, replacing1
Brake discs, measuring wear
Brake piston, replacing seals
Brake piston, replacing seals1
Brake pressure and function, checking
Brake system charging, checking
Brake system, bleeding
Brake system, checking function, retardation
Cab extra prefilter cyclone type, replacing
Cab main filter, replacing
Cab prefilter, replacing
Cab, position 1, restoring
Cab, position 1
Cab, position 2, restoring
Cab, position 2
Cab, tilt cylinder, replacing
Camshaft setting, checking1
Camshaft setting, checking2
Camshaft, replacing1
Camshaft, replacing2
CCM, replacing
Climate unit, installing
Climate unit, removing
Compression test1
Compression test2
Compressor, replacing
Compressor, replacing1
Condenser, replacing
Coolant freezing point, checking
Coolant level, checking
Coolers, cleaning
Cooling system, component location1
Cooling system, component location2
Cooling system, pressure control
Cooling unit, leak detection
Counterweight, fitting
Counterweight, removing
Diesel particulate filter, check and clean
Differential lock, adjusting
Differential lock, function check
Door lock cylinder, replacing
Drive axle oil, changing
Drying filter, replacing
E 1708, Checking point
E1711
E-2001
E-2005
E-2007
E-2014
E-2015
E-2017
E-2018
ECM (Engine control module), replacing non-programmed1
ECM (Engine control module), replacing non-programmed2
ECM (Engine control module), replacing pre-programmed1
ECM (Engine control module), replacing pre-programmed2
EGR cooler, cleaning
EGR cooler, pressure test
EGR cooler, replacing
EGR valve (internal), replacing
EGR valve, replacing
EGR venturi tube, cleaning
EGR Venturi tube, replacing
Electric door opener, control unit, replacing
Electric door opener, locking motor, replacing
Electric door opener, opening support motor, replacing
Electric door opener, rotor switch, replacing
Engine air cleaner primary filter, replacing1
Engine air cleaner primary filter, replacing2
Engine air cleaner secondary filter, replacing
Engine belt condition, checking
Engine belts, replacing
Engine oil and filter, changing1
Engine oil and filter, changing2
Engine oil level, checking
Engine pre cleaner cyclone type, cleaning
Engine rotation speed sensor (crank shaft), replacing
Engine, installing1
Engine, installing2
Engine, removing1
Engine, removing2
Error codes when calibrating
Evaporator, replacing
Exhaust aftertreatment system fuel flow, checking
Exhaust pipe, flexible tube, replacing1
Exhaust pipe, flexible tube, replacing2
Expansion valve, replacing
Extra fuel prefilter, replacing
Fan control valve, seal replacement
Fire suppression system, checking
Frame joint, replacing bearings
Front wheel, installation
Front wheel, removal
Fuel filters, replacing1
Fuel filters, replacing2
Fuel tank breather filter, replacing1
Fuel tank breather filter, replacing2
GPMECU1, changing non-programmed ECU
GPMECU1, changing pre-programmed ECU
GPMECU2, changing non-programmed ECU
GPMECU2, changing pre-programmed ECU
GPMECU3, changing non-programmed ECU
GPMECU3, changing pre-programmed ECU
Grease Locations
Heat control valve, replacing
Heater core, replacing
High pressure air system, pressure, checking
Hinge, lubricating
HMICU, changing non-programmed ECU
HMICU, changing pre-programmed ECU
Hub reduction, installing
Hub reduction, installing1
Hub reduction, removing
Hub reduction, removing1
Hub, replacing seal
Hub, replacing seal1
Hydraulic couplings
Hydraulic cylinder, installing piston's lock brace
Hydraulic oil level, checking
Hydraulic oil, changing
Hydraulic pressure, checking
Hydraulic pump P1, installation
Hydraulic pump P1, removal
Hydraulic pump P2, installation
Hydraulic pump P2, removal
Hydraulic pump P3, checking function
Hydraulic pump P3, installation
Hydraulic pump P3, removal
Hydraulic pump, checking and adjusting standby pressure and working pressure
Hydraulic system, bleeding
Hydraulic system, warming up
Hydraulic tank return oil filter and magnetic rod, cleaning and replacing
Hydraulic tank sediment, draining
Injector sleeves, replacing1
Injector sleeves, replacing2
Injectors, replacing all1
Injectors, replacing all2
Inlet and exhaust system, component location1
Inlet and exhaust system, component location2
Inlet throttle, replacing
Left steering cylinder, installation
Left steering cylinder, removal
Lift cylinder, repacking in machine
Lift lower function, checking
Lift lower, angle sensor, changing
Lift, solenoid valve, changing
Lock up valve, replacing
Lower, solenoid valve, changing
Lubrication oil consumption, checking
Lubrication, every 50 hours
Lubrication, every 250 hours
Lubrication, every 500 hours
Lubrication, every 1000 hours
Maintenance service, every 2000 hours1
Maintenance service, every 2000 hours2
Maintenance service, every 4000 hours1
Maintenance service, every 4000 hours2
Maintenance service, every 6000 hours1
Maintenance service, every 6000 hours2
MATRIS and Tech Tool, reading
Muffler with console, installing
Muffler with console, removing
Muffler, replacing
NOx sensor, replacing
Oil cooler, leakage check
Oil cooler, replacing
Oil level sensor, changing
Oil-bath air cleaner reservoir filter insert, cleaning
Oil-bath air cleaner reservoir oil, changing
Oil-bath air cleaner reservoir oil, checking
Operator's seat, securing
Parking brake function, checking
Parking brake, replacing discs and seals
Pressure back-up valve, replacing
Radiator, replacing
Rear axle bearing oil, changing
Rear axle pivot bearing, greasing
Refrigerant, draining
Restoring of the machine
Right steering cylinder, installation
Right steering cylinder, removal
Rocker arms, replacing
Rubber cushion, replacing1
Rubber cushion, replacing2
SCR system, dosing test
Seal for front output shaft, replacing
Secondary steering pump, checking and adjusting working pressure
Service brake disc wear, checking
Service brake, testing
Servo accumulator, removal
Servo pressure, checking at the spool in control valve
Shift valve, checking
Shock valve lift function, checking
Shock valve, tilt function, checking
Silencer, installing
Silencer, removing
Stall speed, checking
Starter motor, replacing
Steering accumulator removed, checking
Steering accumulator, installing
Steering accumulator, removing
Steering system, checking and adjusting working pressure
Steering system, function check
System test
Tilt cylinder, repacking in machine
Tilt in out, angle sensor, changing
Tilt in, solenoid valve, changing
Tilt out, solenoid valve, changing
Tilt, functional check
Transmission breather filter, replacing
Transmission oil level, checking
Transmission oil pressure, checking
Transmission oil, filter and suction strainer, changing and cleaning
Transmission, calibration
Transmission, function check
Turbocharger, replacing1
Turbocharger, replacing2
Tyre wear and air pressure, checking
Update of automatic lubrication system
Valves, adjusting1
Valves, adjusting2
Valves, adjusting3
Valves, adjusting4
Venturi tube, checking
W-ECU, replacing, non-programmed
W-ECU, replacing, pre-programmed
Window pane, installation
Windscreen, replacing
CE-marking, EMC-directive
Checking function
Safety when lifting and supporting complete machine
Service position 1
Service position 2
Working under raised boom
AC compressor, fill with oil
Cleaning of the machine
D13 Cylinder head valve cover leakage
ECU, functional check
Heater unit, external leakage
New control lever
New gear lever combi-switch
New inlet pipe for air compressor
New inlet pipes
New software release, W1434 BL4
New wheel loaders, L150H-L250H
Repair report for central lubrication pumps
Seals
Software programming with TechTool2
TechTool 2 communication
Tyres, various types
Special Tools, Misc
Volvo CETime Service Integration Manual
3rd 4th hydraulic function, specifications
3rd 4th hydraulic function, tightening torques
AdBlue® DEF
AdBlue® DEF1
Alternator 80 A, specification
Battery, weight
Belt pulley vibration damper, tightening torques
Boom Suspension System, tightening torques
Brake accumulator, specifications
Brake system, specifications
Cabin, tightening torques
Calibration of Comfort Drive Control (CDC), specification
Calibration of working hydraulics, specifications
Control valve, specifications
Control valve, torque value
Coolant
Cooling fan rpm, specifications
Counterweight, weight
Engine transmission, tightening torque
Engine, capacities
Engine, specification
Engine, tightening torques
Flywheel, tightening torques
Front and rear axles, specifications
Front and rear axles, tightening torque
Front and rear axles, volume
Fuel system, specifications
Function times, specifications
Hydraulic pump (P1), specifications
Hydraulic pump (P2), specifications
Hydraulic pump (P3), specifications
Hydraulic pumps, tightening torques
Hydraulic system, volume
Inlet and exhaust system, specification1
Inlet and exhaust system, specification2
Inlet and exhaust system, tightening torques1
Inlet and exhaust system, tightening torques2
Lift cylinder, tightening torques
Lighting, specifications
Parking brake, specifications
Preheating, specifications
Rear axle mounting, volume
Recommended lubricants1
Reversible cooling fan, tightening torques
Secondary steering pump, specifications
Servo system, specifications
Starter motor, specifications
Steering, specifications
Temperature limits for cooling fan speed, specifications1
Temperature limits for cooling fan speed, specifications2
Tightening torque, fuel system1
Tightening torque, fuel system2
Tightening torques, cooling fan
Tilt cylinder, tightening torques
Transmission, specifications
Transmission, specifications1
Valve system, specifications1
Valve system, specifications2
Wheel brake, specification
Wheels, tightening torques
