Volvo Wheel Loader L110G Service and Repair Manual
Model: Volvo L110G Wheel LoaderBrand: Volvo
Type of Machine: Wheel Loader
Type of Manual: Electrical and Hydraulic Diagram, Service and Repair Manual
Number of Pages: 5451 Pages
1 L110G L120G
Descriptions
3rd, or 3rd-4th hydraulic function, component location
3rd, or 3rd-4th hydraulic function, description
5 V Power supply E-ECU, description and measuring
Air conditioning, tightening torques
Alarm, description
Automatic brake valve, description
Automatic differential brake, Limited Slip, description
Axle oil cooler, component location
Axle oil cooler, description
Battery disconnector switch, description
Boom suspension system, component location
Boom Suspension System, description
Booting sequence
Braking system, description
Branching in cables
Cab and air conditioning
Cab, description
CareTrack W-ECU, description
CDC valve, lever steering, description
Central valve, description
Central warning
Comfort Drive Control (CDC), component location
Comfort Drive Control (CDC), description
Communication with data buses
Component locations
Connectors, overview
Control valve, description
Cooling fan, component location
Cooling fan, description
Diagnostic tools, description
Differential lock, description
Dosage valves, description
Drive axles, description
Drivetrain, component location
ECO - accelerator pedal
Electric door opener, description
Electric welding
Error codes, showing
Filling lubricant
Foot brake valve, description
Frame joint, description
Frame, description
Front axle, component description
Hydraulic attachment bracket, description
Hydraulic pumps, description
Information display, check
Information display, engine
Information display, general
Information display, service mode
Information display, settings
Information display, start lockout
Information display, vehicle info
Instrument panels
Intermittent wiper and washer
Key feed
Leak detector 951 1207, new model
Lighting, description
Middle instrument panel with warning lights
MS.Internal.DocumentsBrake accumulator
Oil cooler, component description
Parameter settings
Parking brake, component description'
Parking brake, component location
Pause heater, description
Power supply V2-ECU, description and measuring
Preheating, description
Pressure monitor, description
Propeller shaft, component description
Pump unit, description
Rear axle mounting, component description
Rear axle, component description
Secondary steering pump, description
Secondary steering, component location
Service
Shift valve, description
Software, description
Software, parameter settings and read-outs
Steering system, component location
Steering system, description
Steering valve, description
System voltage'
TP-Linkage's bearing points
Transmission, component position
Turbocharger, description
VCADS Pro service tool
VCADS Pro, Operations
Vehicle control unit V2-ECU, description
Windows, general, gluing
Working hydraulic system, component location
Working hydraulic system, description
Hydraulic diagram transmission 1
Hydraulic diagram, basic machine 1
Hydraulic diagram, complete fig 1
Wiring diagram - Aftertreatment
Wiring diagram - Brake
Wiring diagram - BSS
Wiring diagram - Electrically controlled battery disconnector
Wiring diagram - Gear
Wiring diagram - Start
Wiring diagram WD201
Wiring diagram WD202
Wiring diagram WD260
Wiring diagram WD261
Wiring diagram WD262
Wiring diagram WD263
Wiring diagram WD264
Wiring diagram WD265
Wiring diagram WD266
Wiring diagram WD267
Wiring diagram WD268
Wiring diagram WD270 Update G
Wiring diagram WD301 Update G
Wiring diagram WD302
Wiring diagram WD303 Update G
Wiring diagram WD304
Wiring diagram WD306 Update G
Wiring diagram WD308 Update G
Wiring diagram WD320
Wiring diagram WD321
Wiring diagram WD322
Wiring diagram WD323
Wiring diagram WD324
Wiring diagram WD325
Wiring diagram WD326
Wiring diagram WD330
Wiring diagram WD331
Wiring diagram WD333 Update G
Wiring diagram WD334
Wiring diagram WD335 Update G
Wiring diagram WD337 Update G
Wiring diagram WD350 Update G
Wiring diagram WD351
Wiring diagram WD352 Update G
Wiring diagram WD360
Wiring diagram WD361
Wiring diagram WD362 Update G
Wiring diagram WD363 Update G
Wiring diagram WD364 Update G
Wiring diagram WD371
Wiring diagram WD372
Wiring diagram WD373
Wiring diagram WD374 Update G
Wiring diagram WD375 Update G
Wiring diagram WD376
Wiring diagram WD401
Wiring diagram WD402
Wiring diagram WD403
Wiring diagram WD404
Wiring diagram WD405
Wiring diagram WD406
Wiring diagram WD501 Update G
Wiring diagram WD601
Wiring diagram WD602
Wiring diagram WD604
Wiring diagram WD801
Wiring diagram WD802
Wiring diagram WD804 Update G
Wiring diagram WD805
Wiring diagram WD806
Wiring diagram WD807
Wiring diagram WD808
Wiring diagram WD831 Update G
Wiring diagram WD903
Wiring diagram WD904
Wiring diagram WD905
Wiring diagram WD909
Wiring diagram WD910
Wiring diagram WD911 Update G
Wiring diagram WD913
Wiring diagram WD914 Update G
Wiring diagram WD915 Update G
Installation Instructions
3rd hydraulic function, installing new
24V connector, installing new
Anti theft device, installing new
Attachment locking, installing new
Back up alarm, installing new
Cab front work light LED, installing new
Cab illuminated entrance LED, installing new
Cab rear work light LED, installing new
Cab side work light LED, installing new
Cab, air pre cleaner, installing new
Engine heater, installing new
Forward view camera, installing new
Front work light LED, installing new
Grill work light LED, installing new
Hand throttle, instaling new
Lever steering (CDC), electric, installing new
Pre-cleaner turbo type, installing new
Protection for lighting, front, installing new
Radiator grill guard, installaing new
Radio, installing new
Reflecting stickers, installing new
Reversible fan, installing new
Single lever control, 2nd hydraulic function, installing new
Single lever control, 3rd hydraulic function, installing new
Single lever control, 4th hydraulic function, installing new
Warning beacon flashing strobe light, installing new
Wind shield guard, installing new
Work light extra front, installing new
3rd 4th hydraulic function, shock valve, checking
3rd 4th hydraulic function, solenoid valve, replacing
3rd-4th hydraulic function, checking and adjusting pressure
Accelerator pedal, replace
Accumulator, boom suspension system, discarding
Accumulator, discarding
Accumulator, installation
Accumulator, removal
Accumulators, checking in machine
Actuator, replacing
Air conditioning, checking performance
Air pump safety valve, replacing
Air pump, replacing
Alternator, installing
Alternator, removing
Attachment locking, functional check
Automatic brake, function check
Automatic central lubrication, filter, cleaning replacing
Axle oil cooler, front axle, filter, replacing
Axle oil cooler, rear axle, filter, replacing
Axle suspension, replacing bushes and seals rear
Axle, installing rear
Axle, installing
Axle, removing rear
Axle, removing
Back-up valve, replacing
Battery condition, check
Battery, cables and connections, check
Bleeding air
Boom suspension accumulator, check and adjusting
Boom suspension accumulator, reconditioning
Boom suspension system, functional check
Boom suspension system, left accumulator, installation 1
Boom suspension system, left accumulator, removal 1
Boom suspension system, pressure reduction, safety valve, checking and adjusting
Boom suspension system, right accumulator, installation 1
Boom suspension system, right accumulator, removal 1
Brake disc, replacing rear
Brake discs, measuring wear
Brake piston, replacing seals rear
Brake system charging, checking 1
Brake system, bleeding
Brake system, checking function, retardation
Burner, replacing
Cab, extra prefilter, replacing
Cab, main filter, replacing
Cab, prefilter, replace when required
CareTrack battery, replacing
Climate unit, installing
Climate unit, removing
Comfort Drive Control (CDC), joystick, changing
Compression test
Coolant level, checking
Coolant pump, replacing'
Coolant, change
Cooling system, pressure control
Counterweight, fitting
Counterweight, removing
Diesel oxidation catalyst, replacing
Diesel particulate filter, checking and cleaning 1
Differential lock, adjusting
Differential lock, function check
Door lock cylinder, replacing
DPF bracket, replacing
Drive axles, oil, draining
Drive axles, oil, filling
Drive belts, check
ECC, MID 146, changing non-programmed ECU
ECC, MID 146, changing pre-programmed ECU
EGR Actuator, replacing
EGR cooler, cleaning
EGR cooler, replacing
EGR pressure sensor, replacing
EGR reed valve, checking
EGR reed valve, replacing
EGR temperature sensor, replacing
EGR valve, replacing
EGR Venturi tube, replacing
Electric door opener, control unit, replacing
Electric door opener, locking motor, replacing
Electric door opener, opening support motor, replacing
Electric door opener, rotor switch, replacing
Engine air cleaner, replacing
Engine belts, replacing
Engine hood, installing
Engine hood, raising and securing
Engine hood, removing
Engine oil filter, replacing
Engine oil level, checking
Engine oil, draining
Engine oil, filling
Engine radiator, oil cooler and condensor (if installed), clean
Engine rotation speed sensor (crank shaft), replacing
Engine, installing
Error codes when calibrating hydraulics
Error codes when calibrating steering
Exhaust Aftertreatment System, T-junction, replacing
Expansion valve, replacing
Fan control valve, seal replacement
Frame joint, replacing bearings
Front axle, breather filter, replacing
Front wheel, installation
Front wheel, removal
Fuel metering unit A, replacing
Fuel metering unit B, replacing
Fuel pump, replacing
Gear selector valve, replacing one solenoid
Glow plug control unit, replacing
Glow plug, replacing
Grease Locations
Heat control valve, replacing
High pressure fuel system, pressure relief
Hinge, lubricating
Hub reduction, installing rear
Hub reduction, removing rear
Hub, replacing seal
Hydraulic couplings
Hydraulic cylinder, installing piston's lock brace
Hydraulic oil level, checking
Hydraulic oil tank, draining
Hydraulic oil tank, return oil filter, replace, and magnetic rod, clean
Hydraulic oil tank, sediment drain
Hydraulic oil, filling
Hydraulic pump P1, installation
Hydraulic pump P1, removal
Hydraulic pump P2, installation
Hydraulic pump P2, removal
Hydraulic pump P3, checking function
Hydraulic pump P3, installation
Hydraulic pump P3, removal
Hydraulic pump, checking and adjusting standby pressure and working pressure
Hydraulic tank and transmission, breathing filter, replacing
Injector sleeves, replacing
Injectors, replacing all
Intercooler, replacing
Left steering cylinder, installing
Left steering cylinder, removing
Left steering cylinder, replacing bearings
Lift cylinder, repacking in machine
Lift lower function, checking
Lift lower, angle sensor, changing
Lift, solenoid valve, changing
Lifting time, checking
Lock up valve, replacing
Lower, solenoid valve, changing
Lubrication, 50 hours maintenance interval
Lubrication, 250 hours maintenance interval
Lubrication, 500 hours maintenance interval
Lubrication, 1000 hours maintenance interval
Lubrication, 2000 hours maintenance interval
Lubrication, 4000 hours maintenance interval
Maintenance service, fire suppression system
NOx sensor, replacing
Oil bath air cleaner oil, changing
Oil plugs, installing
Operator's seat, securing
Parking brake, replacing discs and seals
Pause heater, replacing'
Plastic hood, repairing
Preheating coil, replacing
Pressure relief valve (PRV), replacing
Radiator, installing
Radiator, removing
Rear axle bearing, oil, draining
Rear axle bearing, oil, filling
Rear axle, breather filter, replace
Rear wheel, installing
Rear wheel, removing
Refrigerant, draining
Restore operating condition after all test and adjustment work
Restore the machine to original condition
Right steering cylinder, installing
Right steering cylinder, removing
Right steering cylinder, replacing bearings
Seal for front output shaft, replacing
Secondary steering pump, checking and adjusting working pressure
Servo accumulator, removal
Servo pressure, checking at the spool in control valve
Shock valve lift function, checking
Shock valve, tilt function, checking
Single lever control electric servo, replacing
Spark plug cable, replacing
Spark plug control unit, replacing
Spark plug, checking'
Spark plug, replacing 1
Stall speed, checking
Steering cylinder removed, reconditioning incl replacing bearings
Steering cylinder, repacking
Steering system, checking and adjusting working pressure 1
Steering system, function check
System test
Take the hose away from the draining point of engine oil and replace the cap
Thermostat, replacing
Throttle, replacing
Tilt cylinder, repacking in machine
Tilt in out, angle sensor, changing
Tilt in, solenoid valve, changing
Tilt out, solenoid valve, changing'
Tilt, functional check
Towing
Transmission oil filter, replacing
Transmission oil pressure, checking
Transmission oil, checking level
Transmission oil, draining
Transmission oil, filling
Transmission suction strainer, cleaning
Transmission, calibration
Transmission, function check
Transmission, installing
Transmission, removing
Turbocharger, installing
Turbocharger, removing
Update of automatic lubrication system
Valves, adjusting'
Warming up machine
Waste gate, testing
Wheel brakes, functional check
Window pane, installation
Windscreen, replacing
AC compressor, fill with oil
Air bleeding of the central lubrication system
Air cleaner
Air pump filter cleaning - PSID133 FMI 12, PPID340 FMI 12
Air pump
Attachment brackets 86453 and 86454 1
Boom Suspension System connection change
Burner ignition device improvement
Cables cut under operator seat
CDC function, disengaging
CDC-system, product improvements
Central lubrication 1
Central lubrication, oxide on pins
Central lubrication
Chafing battery cable
Cleaning of the machine
Clogged T-fitting
Connector protection for axle oil temperature sensor
Control measurement for electric servo lever and tilt lift angle sensor
Cranking problems
D- arm cracks
D4H - D8H EATS air pump improvement
D8H Camshaft, insufficient hardening
Diagnostic improvements D4H-D8H
EATS burner improvement
EATS sensor failure
ECU improvements
ECU, functional check
EGR cooler leaking coolant internally
Engine coolant expansion tank
Engine hood actuator
Fuel pressure read-out
Function Reduction of Low Idle
Fuse box decal with wrong information
Heater element
Heater unit, external leakage
Improved climate control system
Improved EATS air pump
Improved hour recorder
Improved wiper motor 1
Injector fuel return flow measurement
Installation of ferrites on the cable harness to the air pump for the regeneration system
Lamp bracket with rubber suspension
Lift and tilt function
Limitation, TP-linkage
Missing decal information in the Operator's manual
New air breather filter to the hydraulic oil tank
New angle sensor kit introduced
New brake pressure sensor
New BSS valve
New cab heater element
New CareTrack W-ECU2
New condenser
New gear lever combi-switch
New I-ECU introduction
New NOx sensor for Tier 4i Stage IV engines D6H -D8H
New plug on non-return valve
New reverse alarm
New routing for detector cable
New software for full-automatic regeneration (option)
New software release V2013.2.1
New software release V2013.4.0
New software release V2013.6.0
New software release V2014.6.0
New software release V2015.3.0
New software release V2015.3.1
New software V2014.3.0
New software version V2013.6.1
New software, V2014.3.1
New sound absorbers
New switch for attachment lock
New V-ECU and V2-ECU
New wheel loaders L110G and L120G
New wiper arm and wiper motor
Oil analyses
Operator adaptation of electric servo lever functions with VCADS Pro
Partition wall
Piston seal leakage
Protection cover
Protection of the cab's main wire harness
Radio band setting
Rear vision system - activation of operator menu
Regeneration problems
Reinforced attachment bracket
Repair report for central lubrication pumps
Repair Report for Volvo transmissions
Seals
Semi-automatic regeneration
Serial number location on machine components
Shaking or vibration in the working hydraulics
Software release summary WLO G-models
Tyres, various types
Water intrusion in cab
Windshield guard interferes with nipple
3rd 4th hydraulic function, tightening torques
3rd-4th hydraulic function, specifications
Alternator 80 A, specification
Alternator, specification
Battery, weight
Boom Suspension System, tightening torques
Brake accumulator, specifications
Brake system, specifications
Cabin, tightening torques
Control valve, lever steering (CDC), specifications
Control valve, specifications
Control valve, torque value
Coolant
Cooling fan rpm, specifications
Cooling fan, tightening torques
Counterweight, weight
Engine, capacities
Engine, software specifications
Engine, specification
Engine, tightening torques
Engine, tightening torques]
Exhaust aftertreatment system, specifications
Exhaust aftertreatment system, tightening torques
Flywheel, tightening torques
Front and rear axles, specifications
Front and rear axles, tightening torque
Front and rear axles, volume
Fuel system, specifications
Function times, specifications
Hydraulic pump (P1), specifications
Hydraulic pump (P2), specifications
Hydraulic pump (P3), specifications
Hydraulic pumps, tightening torques
Hydraulic system, volume
Lever steering CDC, tightening torques
Lift cylinder, tightening torques
Lighting, specifications
Oil sump, tightening torque
Parking brake, specifications
Preheating, specifications
Rear axle mounting, volume
Secondary steering pump, specifications
Servo system, specifications
Starter motor, specifications
Steering, specifications
Temperature limits for cooling fan speed, specifications
Thermostat, specifications
Tilt cylinder, tightening torques
Transmission, specifications
Turbocharger, tightening torques
Wheel brake, specification
Wheel, tightening torque
