Volvo Skid Steer Loader MC85C Service and Repair Manual​
Total Size:
94.34 MB
Language:
English
Brand:
Volvo
Machine Type:
Skid Steer Loader
MC85C
  • Service and Repair Manual
  • Hydraulic and Electric Diagrams
  • VOLVO MC85C old.pdf (792 Pages)
1 Volvo MC85C
1F3801, hour recorder
1F3802, daily hours
1F3803, time to service
2F2001, engine start
2F2002, engine stop
2F2202, engine oil pressure
2F2301, fuel level
2F2302, injection solenoid control
2F2501, engine heating
2F2502, engine air filter
2F2601, engine coolant temperature
2F2701, engine running
2F2702, engine speed
2F2703, acceleration
3F2701, startup shutdown sequence
3F3201, system voltage
3F3202, battery charge
3F3301, instrument cluster test
3F9901, anti-theft
5F5501, parking brake
8F8501, seat belt supervision
9F9001, hydraulic accessories
9F9002, hydraulic quick attach
9F9003, hydraulic control
9F9004, hydraulic flow limit
9F9101, hydraulic lock
9F9102, hydraulic oil temperature
9F9103, hydraulic oil filter
AC system, specifications
Accumulator, checking
Accumulator, discarding
Accumulator, specification 1
Accumulator, specification 2
Adjustable straight thread O-Ring fitting (fitting to port)
Air cleaner restriction monitor, description
Air cleaner restriction monitor, specification
Air cleaner, description
Air cleaner, specification
Air conditioning AC, basic principles
Air conditioning electrical system, description
Air conditioning, description
Air preheater, specifications
Alternator, specifications
Alternator, test
Attachment bracket, removal
Attachment, installation removal
Auxiliary electrical function, description
Auxiliary function, description
Axle assembly, installing
Axle assembly, removing
Back up alarm malfunction
Back-up alarm pressure monitor, specification
Back-up alarm, description
Back-up alarm, specification
Battery, cables and connections, check
Battery, cleaning and inspection
Battery, safety
Battery, specification
Belt tension, adjusting
Belt tension, checking
Bolted joints, engine mounting, hydrostatic pumps and charge implement pumps, tightening torques, check
Boom Suspension System, description
Cab description
Cab, air filter, clean (replace when necessary) (option)
Cab, specifications
Cab, weight
CareTrack Telematics system 1
CareTrack Telematics system 2
Charge pump, description
Charge system pressure priority valve relief test
Charge system pressure relief valve test
Charge system, specification
Cleaning engine compartment
Cleaning of the machine
Cold start device, description
Component descriptions
Connecting disconnecting vacuum pump - instructions
Control lever, adjustment
Control lever, changing
Control levers, description 1
Control levers, description 2
Control levers, specifications
Control unit, description
Coolant pump, installation
Coolant pump, removal
Coolant, change
Coolant, level, check
Coolant
Counterweight, specifications
Cracked exhaust pipe
Crankcase breather system, description
Cylinder block, description
Cylinder head for MC85C and MC95C description
Data bus system
Dealers retrofitter´s responsibility
Description, complete machine
Drive chain case, oil change and chain tension check adjust
Drive chain tension, adjustment
Drive chain, drive- and axle-sprocket, installation
Drive chain, drive- and axle-sprocket, removal
Drive chain, oil level and tension check
Drive Motor Shaft seal leakage
Drive motor, description
Drive motor, installing 1
Drive motor, installing 2
Drive motor, installing 3
Drive motor, removing 1
Drive motor, removing 2
Drive motor, removing 3
Drive motor, specification
Drive train, specification
Drive train, tightening torques
Drivetrain, description
Electrical cabling and connectors, checking
Electrical component list
Electronic control system, special tool measuring, component
Electronic control system, special tool measuring, E–ECU
Electronic control system, special tool measuring, general
Electronic control system, special tool measuring, I-ECU
Electronic control system, special tool measuring, V-ECU
Engine coolant temperature monitor, description
Engine coolant temperature monitor, specification
Engine oil pressure monitor, description
Engine oil pressure monitor, specification
Engine shut down solenoid, description
Engine, installing
Engine, oil level, check
Environment
Error causes
Error codes, build-up
Error detection
Exhaust manifold, replacing gasket
F.F.F.T Method (Flats From Finger Tight)
Five-button control function, description
Flared fitting (steel) (Tube or hose to fitting)
Flush valve, replacement
Flywheel, specifications
Foot pedal cable, installation
Foot pedal cable, removal
Fuel filter, change
Fuel level sensor, description
Fuel level sensor, specifications
Fuel system, water trap, check drain
Fuel, recommendation
Fuses, description
Gear pump, description
Gear train and camshaft, description
General vehicle electronics
Gerotor pump, description
Grease, recommendation
Grounding points (chassis ground)
High flow electrical system, description and operation
Horn, description
Horn, specification
Hourmeter, operation
Hydraulic cylinders, description
Hydraulic diagram, MC85C and MC95C, Mechanical controls 1
Hydraulic diagram, MC85C and MC95C, Pilot controls
Hydraulic drive motor mounting frame repair
Hydraulic filter restriction monitor, description
Hydraulic fluid temperature monitor, description
Hydraulic fluid temperature monitor, specification
Hydraulic fluid, level, check
Hydraulic oil Charge filter, change
Hydraulic oil tank, oil and filter change
Hydraulic quick attach, description
Hydraulic system oil contamination 1
Hydraulic system oil contamination 2
Hydraulic system, relieve pressure 1
Hydraulic system, relieve pressure 2
Hydrostatic drive motor test
Hydrostatic transmission, description
Ignition switch, description and operation
Implement pump, descripton
Improved travel motor controllability on pilot steering machines
Information and warning decals
Injection pump, description
Injection timing, checking and adjusting
Injectors, description
Installation of Extended Exhaust stacks
Instrument panels
Leakage, check
Left instrument panel
Lift and tilt lockout functions, components testing and adjustment
Lift and tilt lockout functions, description
Lift and tilt lockout functions, testing
Lift cylinder removed, repacking
Lift cylinder, installing
Lift cylinder, removing
Lift function, description
Lift lockout function, description
Lighting front, specification
Lightning rear, specification
Loader arm bearing, replacing 1
Loader arm bearing, replacing 2
Loader buckets, capacities
Locking lever and pin, inspection
Lubricating system, specification
Machine dimensions (with standard tires)
Machine view
Main control valve system relief test
Main control valve, maintenance
Main control valve, removal
Main relief valve, adjusting
Maintenance service, general
Manual lifting of loader arm 1
Manual lifting of loader arm 2
Manual lifting of loader arm 3
Manual lowering of loader arm, Pilot controls
Measuring, general
Neutral centring and control lever adjustment
Neutral centring test
Neutral centring, check
New coolant
New Multitool Carrier
New Pressure Switch for Back-Up Alarm on Pilot Machines
Oil and hydraulic fluid, recommendation
Oil cooler, description
Oil cooler, installation
Oil cooler, removal
Operator's seat, installation
Operator's seat, removing
Optional Engine Block Heater Extension Cable
Optional Front Counterweights
Over the tire tracks, check (option)
Park lock pin, adjustment
Park lock pin, inspection
Park lock system, specification
Park lock, installation
Park lock, removal
Pilot Control Loader Joystick Featherability
Pilot hose pin holes
Pilot Travel Joystick Featherability
Pipes, couplings and hoses, check
Piston and piston rings, description
Pivot pins, lubricate
Preheating system, description
Preheating, function check
Pressure priority valve, description
Product plates
Protecting plate, removal
Radiator pressure cap, description
Radiator, installation
Radiator, removal
Raising and blocking
Refrigerant, draining
Re-installation and sealing of fuel sending units
Relay, description
Relays testing
Repair instructions
Replacing hydraulic motor mounting hardware
Right instrument panel
Rules when handling tyres
SAE J1708 (Information bus)
Safety when servicing
Safety when working on pressurized systems
Seat bar, adjustment
Self level function, description
Self level valve, adjustment
Self level valve, bypass
Self level valve, description
Self level valve, removal and installation
Service position 1
Service position 2
Service position 3
Service
Servo pipe and hose, replacing
Servo pressure, check 1
Servo pressure, check 2
Servo system, description
Skid Steer Loaders, chassis
Skid Steer Loaders, new generation
Starter motor, replacing
Starter motor, specifications
Starter system, test
Starting system, description
Starting with booster battery 1
Starting with booster battery 2
Startup after hydraulic repair 1
Startup after hydraulic repair 2
Steering levers, locking of pivot pins, check
Thermostat, replacing
Throttle control cable, installation
Throttle control cable, removal
Throttle Control Description
Tilt cylinder removed, repacking
Tilt cylinder, installing
Tilt cylinder, removing
Tilt function, description
Transmission drive assembly, description
Transmission pump drive relief cartridge, replacement
Transmission pump neutral centering, checking and adjusting
Transmission pump, description
Transmission pump, drive relief test 1
Transmission pump, drive relief test 2
Transmission pump, drive relief valve, adjustment
Transmission pump, installing 1
Transmission pump, installing 2
Transmission pump, removing 1
Transmission pump, removing 2
Transmission pump, specification
Transporting and lifting the machine
Travel hydraulics, troubleshooting
Turbo, general specification
Turbocharger, description
Unauthorized modification of (ROPS) and (FOPS)
Valve mechanism, description
Valve, clearance, check adjust
VCADS Pro service tool, general
Warranty inspection 100 hours
Warranty inspection, general
Wear sleeve for front crankshaft seal
Wheel nuts, check torque
Wheel nuts, torque, check
Wheel, tightening torque
Wheel, weight (with standard tires)
Wiring diagram M01
Wiring diagram M02
Wiring diagram M03
Wiring diagram M04
Wiring diagram M05
Wiring diagram M06
Wiring diagram M07
Wiring diagram M08
Wiring diagram M09
Wiring diagram M11
Wiring diagram M13
Wiring diagram M22
Wiring diagram M26
Wiring diagrams
Wiring harnesses
Working hydraulic system, description
Working hydraulics, troubleshooting 1
Working hydraulics, troubleshooting 2
Working lights, description
Working under raised loader arm
Volvo MC85C Workshop Manual.pdf (5059 Pages)
1 Volvo MC85C
Battery isolator
Drive motor, description1
Electronic control unit (ECU), description
Fan reversing valve, description
Fault code list
Fault tracing on hydraulic system
Fuses
Gear pump, description1
Hydraulic contamination
Hydraulic service procedures
Main valve block, description
Multimeter
Operator's platform, lowering
Operator's platform, raising
Relays
Road lights, description
Service position 1
Service position 2
Throttle control
Component list, Fuses1
Component list, Fuses2
Component list, Miscellaneous1
Component list, Miscellaneous2
Component list, Motors1
Component list, Motors2
Component list, Relays1
Component list, Relays2
Component list, Sensors1
Component list, Sensors2
Component list, Solenoid valves1
Component list, Solenoid valves2
Component list, Switches1
Component list, Switches2
Hydraulic diagram1
Hydraulic diagram2
Wiring diagram 1-1
Wiring diagram 1-2
Wiring diagram 2-1
Wiring diagram 2-2
Wiring diagram 3-1
Wiring diagram 3-2
Wiring diagram 4-1
Wiring diagram 4-2
Wiring diagram 5-1
Wiring diagram 5-2
Wiring diagram 6-1
Wiring diagram 6-2
Wiring diagram 7-1
Wiring diagram 7-2
Wiring diagram 8-1
Wiring diagram 8-2
Wiring diagram 9-1
Wiring diagram 9-2
Wiring diagram 10-1
Wiring diagram 10-2
Wiring diagram 11
Wiring diagram 12
Installation Instruction
Air conditioning kit, installing new1
Attachment bracket, installation1
Cab, installing1
Road lights kit, right hand dip, installing new1
Air cleaner dust valve, changing1
Air cleaner dust valve, changing2
Air conditioning filters, changing1
Air conditioning filters, changing2
Alternator belt, checking
Alternator, installing
Alternator, removing
Alternator, testing
Axle hub, installing
Axle hub, removing
Battery isolator, checking
Battery, maintenance1
Battery, maintenance2
Battery, replacing
Boom suspension system accumulator, charging
Boom suspension system accumulator, discharging
Cab door, installing
Cab door, removing
Compressor belt, checking
Coolant level, checking
Coolant, draining
Coolant, filling
Cooling package, installing
Cooling package, removing
Door handle, replacing
Drive chain case oil level, checking1
Drive chain case oil level, checking2
Drive chain case oil, changing1
Drive chain case oil, changing2
Drive chain, installing
Drive chain, removing
Drive motor, installing1
Drive motor, removing1
Engine air cleaner system integrity, checking
Engine oil filter, replacing1
Engine oil filter, replacing2
Engine oil level, checking
Engine oil, changing
Engine oil, draining
Engine oil, filling
Engine, installing
Engine, installing1
Engine, removing1
Front end accessory drive (FEAD) belt condition, checking
Front end accessory drive (FEAD) belt, adjusting
Front idler wheel, assembling
Front idler wheel, disassembling
Fuel filter element, changing
Fuel system, bleeding1
Fuel system, bleeding2
Fuel water separator, draining1
Fuel water separator, draining2
Gear pump, installing
Gear pump, installing1
Gear pump, removing
Gear pump, removing1
Greasing, daily1
Greasing, daily2
Guide roller, assembling
Guide roller, disassembling
Hydraulic cylinders, checking
Hydraulic oil level, checking
Hydraulic oil tank, draining1
Hydraulic oil tank, draining2
Hydraulic oil tank, filling1
Hydraulic oil tank, filling2
Hydraulic oil tank, removing
Hydraulic oil, changing1
Hydraulic oil, changing2
Hydraulic pressure, testing
Hydraulic return filter, replacing
Hydraulic service procedures1
In-line fuel filter, changing
Loader arm lift cylinder, removing
Loader arm, installing
Loader arm, removing
Main control valve, installing
Main control valve, removing
Maintenance service, every 500 hours1
Maintenance service, every 1000 hours1
Radiator and coolers, cleaning1
Radiator and coolers, cleaning2
Rear door, installing
Rear door, removing
Rear idler wheel, assembling
Rear idler wheel, disassembling
Self level valve, replacing
Service and Maintenance Introduction
Spark arrester, cleaning
Starter motor, installing
Starter motor, removing
Starter motor, testing
Stop pad, adjusting
Stop pad, adjusting1
Track tension, adjusting
Transmission pump, adjusting
Tyre, replacing
Tyres, checking air pressure
Wheel nuts torque, checking
Window pane, installation
Window pane, removal
Repair1
1F3802, daily hours
2F2002, engine stop
2F2301, fuel level
3F9901, anti-theft
Alternator, test
Battery, safety
Cab description
Cab, specifications
Cab, weight
Coolant, change
Coolant
Data bus system
Engine, installing
Environment
Error causes
Error detection
Fuel filter, change
Fuses, description
Horn, description
Horn, specification
Instrument panels
Leakage, check
Machine view
Measuring, general
New coolant
Oil cooler, removal
Park lock, removal
Product plates
Radiator, removal
Relay, description
Relays testing
Repair instructions
Service position 1
Service position 2
Service position 3
Service
Wiring diagram M01
Wiring diagram M02
Wiring diagram M03
Wiring diagram M04
Wiring diagram M05
Wiring diagram M06
Wiring diagram M07
Wiring diagram M08
Wiring diagram M09
Wiring diagram M11
Wiring diagram M13
Wiring diagram M22
Wiring diagram M26
Wiring diagrams
Wiring harnesses
A few simple safety rules
Before operating
Before service, read
Charging batteries
Cleanliness
Service position
Bucket, not level
C Series Line Bore Procedure
Cab door leak
Cab gas strut configuration
ECU trouble shooting
Improved Cab Door Sealing
Improved ignition switch
Improved lap bar
Improved top glass skylight seal
Left Hand Armrest Rotation
Loader Arm Shimming
Loose wheel drive motor bolts and or leaks
New Magnetic Flywheel Speed Sensor
New Skid Steer Loader models
New Skid Steer Loader models1
Oil ejected from exhaust system
Optional precleaner available
Poor window adhesive
Rapid Assembly Hoses
Small platform loader and transmission setup
Tilt cylinder rod scoring
Top Window Leak
Window cracks and or breaks
Special Tools, Misc
GRD G700B LabourTimeGuide
G700B Labour Time Guide Foreword.pdf
Foreword, Labour Time Guide
The standard times are issued for the purpose of:
The following is not included in the listed times:
Recommended Special Tools
RM Compaction ABG Time Guide
Foreword
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Compaction Time guide
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Paving Systems ABG
Foreword
Screeds
Hydraulics
Structural
Drive system
Electrical
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Boom suspension system (BSS) valve block, specifications1
Charge pump, specifications
Charge pump, specifications1
Coolant, specifications
Engine, specification2
Engine, specification3
Engine, specifications1
Engine, specifications2
Fuel, lubricant and filling capacities
Fuel, specifications
Hydraulic connections, tightening torques1
Hydraulic connections, tightening torques2
Hydraulic tank, specifications1
Lights, specifications
Loader pump, specifications
Loader pump, specifications1
Main control valve, specifications1
Positional adapters
Push lock fittings
Quick release couplings1
Quick release couplings2
Radio, specifications
Radio, specifications1
Radio, specifications2
Rapid assembly fittings
Return line filter, specifications
Self levelling valve, specifications1
Transmission pump, specifications1
Transmission pump, specifications2
Tyres, specifications
  • Volvo Skid Steer Loader MC85C Service and Repair Manual.txt
