Volvo Skid Steer Loader MC110C Service and Repair Manual
Format: PDFTotal Size: 71.05 MB
Machine Type: Skid Steer Loader
Model: MC110C
- Service and Repair Manual
- Electrical and Hydraulic Diagrams
- 4912 Pages
1.MC110C MC115C
Descriptions
Boom suspension system valve, description
Combination valve, description
Description, complete machine
Drive motor, description
Electronic throttle control, description
Fault code list
Forwards drive, description
Fuels, lubricants and filling capacities (litres)
Fuses and Relays
Fuses
Gear pump, description
Hydraulic contamination
Hydraulic cylinders, precautions during use
Hydraulic diagrams explanations
Hydraulic service procedures
Lead and connector checks
Left spin turn, description
Load sensing valve block, description
Logic control
Main valve block, description
MS.Internal.Documents
Multimeter
No drive circuit, description
Operator's platform, lowering
Operator's platform, raising
Positional adapters
Pump engine coupling, description
Push lock fittings'
Rapid assembly fittings
Rear demolition guard, description
Relays
Reverse drive, description
Road lights, description
Self level valve, description
Service position 1
Service position 2
Throttle control
Transmission motor, description
Valves, checking and adjusting
Work lights, description'
Component list, Fuses 1
Component list, Lights 1
Component list, Relays 1
Component list, Sensors
Component list, Switches
Hydraulic diagram 1
Hydraulic diagram 1-2
Hydraulic diagram 2
Wiring diagram 1
Wiring diagram 2
Wiring diagram 2-1
Wiring diagram 3
Wiring diagram 3-1
Wiring diagram 4
Wiring diagram 4-1
Wiring diagram 5
Wiring diagram 5-1
Wiring diagram 6
Wiring diagram 6-1
Wiring diagram 7
Wiring diagram 7-1
Wiring diagram 8
Wiring diagram 8-1
Wiring diagram 9
Wiring diagram 9-1
Wiring diagram 10
Wiring diagram 10-1
Wiring diagram 11
Wiring diagram 11-2
Wiring diagram 12
Wiring diagram 14
Installation Instructions
Air pre-cleaner, installing new
Air cleaner dust valve, changing
Air conditioning filters, changing
Alternator removing, inspecting and installing
Alternator, installing
Alternator, removing
Auxiliary hydraulic pressure, releasing
Axle hub, installing
Axle hub, removing
Battery isolator
Battery maintenance
Battery, maintenance
Boom suspension system accumulator, charging and discharging
Boom suspension system valve, replacing
Cab door, installing
Cab door, installing1
Cab door, removing 1
Cab door, removing
Cleaning of the machine
Closed crankcase ventilation filter, cleaning
Combination valve, replacing 1
Control lever, installing
Control lever, removing
Coolant level, checking
Cylinder, disassembling and assembling
Cylinder, sealing
Door handle, replacing 1
Drive chain case oil level, checking
Drive chain case oil level, checking1
Drive chain, installing
Drive chain, removing
Drive chains, replacing
Drive motor, disassembling and assembling
Drive motor, installing
Drive motor, removing
Drive motor, replacing
Drive pulley, replacing
Drive sprocket, installing
Drive sprocket, removing
Engine hour meter, replacing
Engine oil filter, replacing 1
Engine oil level, checking'
Engine oil, changing
Flushing valve, disassembly and assembly
Front casing, disassembling and assembling
Front end accessory drive (FEAD) belt condition, checking 1
Front idler wheel, installing
Front idler wheel, removing
Fuel water separator, changing
Fuel water separator, draining
Gear pump, disassembling and assembling
Gear pump, installing
Gear pump, removing
Gear pump, replacing 1
Greasing, 50 hours
Greasing, 500 hours
Greasing, daily
Guide roller, installing
Guide roller, removing
Hydraulic fan motor, replacing
Hydraulic oil level, checking
Hydraulic oil tank, draining'
Hydraulic oil tank, filling 1
Hydraulic oil tank, replacing 1
Hydraulic oil, changing
Hydraulic system, bleeding
Jump starting
Load sensing valve block, replacing
Loader arm lift cylinder, radial lift, replacing
Loader arm lift cylinder, vertical lift, replacing
Loader arm lift ram, installing
Loader arm lift ram, removing
Loader arm, installing
Loader arm, removing
Loader arm, replacing
lternator, disassembling and assembling
Main valve block, replacing
Main valve, replacing
Park brake, disassembling and assembling
Primary fuel filter, changing
Quickhitch tilt cylinder, radial lift, replacing
Quickhitch tilt cylinder, vertical lift, replacing
Rear casing, disassembling and assembling
Rear door, installing
Rear door, removing
Rear idler wheel, installing
Rear idler wheel, removing
Return line filter (high flow), replacing
Return line filter, replacing
rive chain case oil, changing
Roadwheels, replacing
ROPS FOPS structure, check
Rubber track, installing
Rubber track, removing
Self level valve, replacing
Self levelling valve, replacing
Service position 1
Starter motor removing, inspecting and installing
Starter motor, disassembling and assembling
Stop pad, adjusting 1
Stop pad, adjusting
Throttle actuator, replacing
Track frame, installing
Track frame, removing
Transmission pump start-up procedure
Transmission pump, adjusting 1
Transmission pump, disassembling and assembling
Transmission pump, installing
Transmission pump, removing
Transmission pump, replacing
Two speed spool, disassembling and assembling
Tyres, checking air pressure
Voltage regulator and brushes, replacing
Wheel hub assembly, disassembling and assembling
Wheel hub assembly, replacing
Wheel nuts torque, checking
Window pane, installation
Window pane, installing
Window pane, removal
Window pane, removing
Alternator terminal labeling and location change
Applies to
Automatic Belt Tensioner Improvement
Boom drift
C Series Line Bore Procedure
Cab door leak
Cab gas strut configuration
Cold Weather Flushing Valve
Drive motor leaks
ECU trouble shooting
EGR fault code diagnostics procedures
Engine Compartment Inspection 1
Engine Fuel Filter Change
Engine oil pressure test
High pressure fuel pipe bracket installation (mechanical injection)
Hydraulic pipes improvement
Improved Cab Door Sealing
Improved ignition switch
Improved lap bar
Improved top glass
Inspection form for engine failure or suspected failure
Intermittent or complete loss of throttle response
Large Platform Pre-cleaner Kit
Large Platform Rear Door Grill Kit
Large platform Tier 4 Stage IIIB loader and transmission setup
Left Hand Armrest Rotation
Manual Flushing Valve Procedure Instructions
New generation of skidsteer and compact track loaders
New joystick stud with 25 angle
New Skid Steer Loader models
Oil change procedure
Optional precleaner available
Poor window adhesive
Precautionary engine oil pressure cranking test
Rapid Assembly Hoses
Software Distribution Procedure
Top Window Leak
Water Temperature Sensor Failure
Window cracks and or breaks
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Alternator, specifications
Battery, specification
Charge pump, specifications
Engine, specification 1
Fuel, specifications
Gear pump, specifications
Load sensing valve block, specifications
Loader pump, specifications
Main valve, specifications
Quick release couplings
Radio, specifications 1
Radio, specifications 2
Self level valve, specifications
Servo cut off manifold, specifications
Starter motor, specifications
VOLVO MC115C PARTS CATALOG
37° Flared fitting (steel) (Tube or hose to fitting)
Adjustable straight thread O-Ring fitting (fitting to port)
Air cleaner restriction light, description
Air cleaner restriction switch, description
Air cleaner restriction switch, specification 1
Air Cleaner
Alternator light, description
Alternator, specifications 1
Alternator, test
Attachment bracket installation
Attachment bracket, description
Attachment bracket, maintenance
Attachment bracket, removal
Attachment tilt hydraulic circuit
Attachment tilt spool control, with optional self level, description
Attachment tilt spool control, without optional self level, description
Attachment, installation removal
Auxiliary hydraulic cable, inspection
Auxiliary hydraulic cable, installation
Auxiliary hydraulic cable, removal
Auxiliary hydraulic circuit
Auxiliary hydraulic system control, description
Auxiliary Spool Control, description
Axle assemblies, reconditioning
Axle assembly, axle sprocket and drive sprocket, description
Axle assembly, installation
Axle assembly, removing
Back-up alarm, operation
Back-up alarm, specification
Back-up alarm, Switch, specification
Back-up alarm, testing and adjustment
Battery cable and main switch
Battery, safety
Battery, specification 1
Bearings
Bucket 1
Bucket 2
Bucket 3
Cab Operator's protective structure, specifications
Cable harness, engine
Cable harnesses, cab
Cable harnesses, front
Charge Implement pump flow displacement test
Charge implement pump, description
Charge system pressure priority valve relief test
Charge system pressure relief valve test
Charge system pressure relief valve, replacement
Checklist after a fire or exposure to other intense heat
Control lever crossmember removal installation
Control lever removal and installation
Control lockout (lift and tilt functions), components testing and adjustment
Control lockout (lift and tilt functions), description
Control lockout (lift and tilt functions), testing and adjustment
Control lockout solenoid valve (lift and tilt functions) description
Control Terminology
Dealers retrofitter´s responsibility
Decals
Disclaimer
Door, installing, without jumper harness
Door, installing
Door, removal, without jumper harness
Door, removal
Drive chain case, oil change
Drive chain case, specification
Drive chain tension, adjustment
Drive chain, drive- and axle-sprocket, installation
Drive chain, drive- and axle-sprocket, removal
Drive chain, oil level and tension check
Drive Motor Case Drain Filtration
Drivers cab
Drivetrain capacities MC90, specification 1
Drivetrain capacities MC110, specification 1
Drivetrain component terminology
Drivetrain components
Drivetrain, description and operation
Drivetrain, tightening torques 1
Electrical component list
Electrical troubleshooting
Enclosed cab (optional) 11840139,11840268
Enclosed cab (optional) 11840142,11840268
Enclosed cab (optional) 11840190,11840191
Enclosed cab front door (optional) 11840191
Enclosed cab heater (optional) 11840192,11840268
Engine block heater
Engine cooling system, specification 1
Engine Crankcase oil, specification 1
Engine manufacturer manuals
Engine mounting
Engine oil pressure light, description
Engine oil pressure switch, description
Engine oil pressure switch, testing
Engine shut down solenoid, description
Engine shut down solenoid, specification 1
Engine shut down solenoid, testing and adjustment
Engine water temperature light, description
Engine water temperature switch, description
Engine water temperature switch, specification 1
Engine water temperature switch, testing
Engine, general specification 1
Engine, mounting
Engine, removal
Exhaust system 11840121,11840122,11840123
Exhaust system, general
Extending attachment tilt cylinder circuit
F.F.F.T Method (Flats From Finger Tight)
Fan protector, improvement
Final drive components, MC80 and MC90, description 1
Final drive components, MC110, description 1
Foot Pedal, cable installation
Foot pedal, cable removal
Forks (optional)
Forward reverse auxilary control lever
Frame
Front control pump
Fuel gauge testing
Fuel gauge, description
Fuel gauge, installation
Fuel gauge, removal
Fuel level sender removal
Fuel level sender, installation
Fuel level sender, testing
Fuel level sensor, specifications 1
Fuel system, bleeding air
Fuel system, specifications 1
Fuel system
Fuses, specification
Fuses
General part replacement
Grease, recommendation
Grounding points (chassis ground)
Hammer 11840212
Hammer 11840213
High flow electrical system, component tests 1
High flow electrical system, components
High flow electrical system, description and operation
High flow gauge, description
High flow hydraulic circuit
High flow hydraulic supply, return and cooling circuits
High flow pump flow displacement test
High flow pump, mounting
High flow pump, removal installation
High flow switch, description
High flow system hydraulic circuit
High flow system wiring harness
High flow system
High flow valve 11840184,11840185,11840186,11840187
High flow valve, installation
High flow valve, maintenance
High flow valve, removal
High flow valve
Horn, specification
Hoses and tubes
Hourmeter, operation
Hydraulic circuit
Hydraulic component terminology 1
Hydraulic component terminology 2
Hydraulic cylinder, tilting
Hydraulic cylinders, description
Hydraulic cylinders, general maintenance
Hydraulic oil cooler, maintenance
Hydraulic oil cooler, with optional 'High flow', maintenance
Hydraulic oil filter restriction light, description
Hydraulic oil filter restriction switch(es), testing
Hydraulic oil filter restriction, description
Hydraulic oil filter restriction, specification
Hydraulic oil heater 11840173
Hydraulic oil temperature light, description
Hydraulic oil temperature switch, description
Hydraulic oil temperature switch, testing
Hydraulic oil temperature, specification
Hydraulic pumps MC 110, specifications 1
Hydraulic pumps MC80, specification 1
Hydraulic pumps MC90, specifications 1
Hydraulic schematic MC80
Hydraulic schematic MC90, with optional 'High flow'
Hydraulic schematic MC110, with optional 'High flow'
Hydraulic system oil contamination 1
Hydraulic system testing, MC80
Hydraulic system testing, MC90 optional 'High flow'
Hydraulic system testing, MC110 optional ' High flow'
Hydraulic system Transport
Hydraulic system, oil capacities, specifications
Hydraulic system, specification 1
Hydraulic system, specification 2
Hydraulic testing schedule
Hydrostatic control pump drive relief cartridge, replacement
Hydrostatic drive motor test
Hydrostatic drive, specification 1
Ignition switch, description and operation
Ignition switch, testing
Implement pump, descripton
Implement pump, installation
Implement pump, removal
Incorrect Engine Oil Service Interval on Decal
Information, purpose
Instrument panel removal and installation
Instrument panel
Lift cylinder removed, repacking
Lift cylinder, installing
Lift cylinder, removing
Light bulbs, specification
Lighting front, specifications
Lighting, front
Lightning rear, specification
Linkage rod spring centring link removal installation
Loader arm cylinder retracting circuit
Loader arm cylinder
Loader arm hydraulic circuit (with self level valve)
Loader Arm replacement
Loader arm spool control, with optional self level, description
Loader arm spool control, without optional self level, description
Loader buckets
Loader cycle times, MC80 1
Loader cycle times, MC90 1
Loader cycle times, MC110 1
Loading unit
Locking lever and pin, assembly
Locking lever and pin, disassembly
Machine dimensions (with standard tires)
Machine hydraulic circuit
Machine weights
Main control valve system relief test
Main control valve, cables, adjustment 1
Main control valve, maintenance
Main control valve, removal
Main fuse, specification
Main hydrostatic travel control pump, description 1
Main travel control pump (MC80 only), installation
Main travel control pump (MC80 only), removal
Main travel control pump (MC90 and MC110 only), installation
Main travel control pump (MC90 and MC110 only), removal
Manual lifting of loader arm
Neutral centring and control lever adjustment
Neutral centring test
New Auxiliary Hydraulic Lock Pin
New boom cylinder hose routing
New fuel level sensor
New hydraulic oil cooler
Oil and hydraulic fluid, recommendation
Operating data
Operator's seat 11840264,11840268
Operator's seat, installation
Operator's seat, removing
Optional auxiliary hydraulic cable, installation
Optional auxiliary hydraulic cable, removal
Optional auxiliary hydraulic pedal lock control
Optional hand controls 11840187,11840188
Park lock pin, adjustment
Park lock pin, inspection
Park lock, inspection
Park lock, installation
Park lock, operation
Park lock, removal
Park lock
Parking lock, troubleshooting
Power train, specification 1
Pressure priority valve (MC80 only), description
Pressure testing
Product identification plate
Quick attach group
Quick Attach Supersession
Radiator mounting
Radiator pressure cap, description
Raising and blocking
Rear door and engine cover
Recommended Special tools
Relays, specification
Replacement parts
Restraint bar, inspection
Retracting attachment tilt cylinder circuit
Rotating beacon 11840140
Safety when working with batteries 1
Seal service kit – Main control valve
Seat, seat belt and restraint bar
Self level valve (optional) (eaton valve part number 39055-day)
Service and maintenance
Service methods
Service position 2
Service
Sign plates and decals
Sound-proofing panels (optional)
Specification, Control lamp 1
Standard foot controls
Starter motor, specifications 1
Starter motor, tests
Startup after hydraulic repair 1
Supply return and Cooling Circuits 1
Teminology
Thermo start plug, description and operation
Thermo start plug, inspection and testing
Thermo start plug, installation
Thermo start plug, removal
Thermo start plug, specification 1
Thermostat, replacing
Throttle Control Description
Throttle control
Tilt cylinder removed, repacking
Tilt cylinder, installing
Tilt cylinder, removing
Tires, MC90 and MC110
Track equipment 11840217
Transmission complete
Transmission drive assembly, description
Transmission drive assembly, replacement
Transmission pump, drive relief test
Transmission pump, flow displacement test
Transporting and lifting the machine
Travel alarm, acoustic 11840004
Travel hydraulics, troubleshooting
Travel motor, MC80 MC90, description
Travel motor, MC110, description
Travel motor, operation
Travel motor, removing
Travel motor, specifications 1
Travel motor
Travel speeds
Travel Steering Levers, description
Travel system, hydraulic components, MC80, description
Travel system, hydraulic components, MC90, description
Travel system, hydraulic components, MC110, description
Warning lights test Worklight switch
Warning lights, general
Wheel and tire 11840124
Wheel and tire
Wheel nuts, check torque
Windshield wiper, front 11840190,11840191,11840268
Wiring diagram M01
Wiring diagram M02
Wiring diagram M03
Wiring diagram M04
Wiring diagram M05
Wiring diagram M06
Wiring harnesses
Working under raised loader arm
Wrist control cable, installation and adjustment
Wrist control cable, removal
Wrist hydraulic controls (optional), description
