Volvo Excavator EW160C Service and Repair Manual​
Total Size:
199.87 MB
Language:
English
Brand:
Volvo
Machine Type:
Excavator
EW160C
  • Service and Repair Manual
  • Electrical Diagrams
  • Hydraulic Diagrams
  • 5506 Pages
1. EW160C
Descriptions
Air cleaner, description
Air distribution, description
Anti-cavitation valve, description
Audio remote controller, description 1
Auto idle device, setting instructions
Automatic lubrication system, description
Auxiliary start
Axle lock
Back-up valves
Basic check, Engine
Boost control, description
Booting sequence
Bucket cylinder, description
Cab suspension, description 1
Calibration of cruise control
Camshaft, description
CareTrack system, description
Centre passage, description
Charge air cooler, description
Charging, description
Circuit breaker, description
Communication with data buses
Component descriptions]
Component list, Fuses
Component list, Heating coils
Component list, Lights
Component list, Miscellaneous
Component list, Relays
Component list, Sensors
Component list, Switches
Component locations engin e
Component locations
Component troubleshooting, checking component
Component troubleshooting, checking subsystem (circuit)
Component troubleshooting, checking wiring harness and input output on ECU
Component troubleshooting, structure, description
Connecting rod, description
Connecting special tools
Connectors, overview
Control levers, description
Control lockout lever, function check
Control lockout system
Control pattern change valve, description
Control unit, description
Control units changing, precaution
Cooling fan control valve, checking
Crankshaft, description
Cruise control, description
Cylinder head, description
Cylinder, description
Cylinder, troubleshooting
Data buses, function
DC–DC converter, description
Description, complete machine
Description, general
Display unit, content
Electric center passage, description 1
Electric horn, description
Electrical digging brake, description
Electronic climate control unit ECC, description
Elimination of trapped hydraulic pressure
Engine characteristic curve
Engine Protection
Engine speed control, function check
Engine start
Engine system
Engine, identification
E-tool Sleeve
Exhaust system, description
Front axle, description
Fuel feed pump, description
Fuel filler pump, description
Fuel filter, description
Fuel rail, description
Fuel tank, description
Fuse, description
Grab bucket, description
Grab equipment, tool change
Heating system, description
Hour counter, description
HVAC system
Hydraulic brake system, description
Hydraulic elevating cab, description
Hydraulic oil, cleaning
Hydraulic system
Hydraulically driven cooling fan, description
Injectors, description
Inlet system, description
Keypad, description 1
Keypad, description
Language
Lifting instructions
Limp Home
Load holding valve, description
Main control valve block, description
MAIN MENU
Main pump pressure, checking and adjusting
Manual travel control switch, description
Measuring tools and techniques
Measuring, general
Menu tree
Multi-function lever switch, description
Offset boom, description
Oil cooler fan motor, checking
Oil cooler, description
Oil sump, description
Optional hydraulic equipment, index
Overload warning
Parking brake, description
Piston cooling
Piston rings, description
Pistons, description
Pivot axle lock cylinder, description
Pivot axle lock, function check
Pop-up screen
Power OFF
Preheating, description
Pressure relief valves, description
Product plates
Radio with tape or CD player, descriptions
Radio with tape player, description
Relay, description
Rotating beacon, description
Rotating beacon, replacing
Service brakes, function check
Service mode
Service positions
Service
Servo pump, troubleshooting
Servo system, description
SETUP
Shaft seals, replacing
Shock and anti-cavitation valve, description
Slew motor, description
Slew ring gear, description
Stabilisers and stabiliser blade, description
Start lock, description
Start switch, description
Starter motor, description
Starting operation
Steering axle, description
Steering system, description
Steering system, function check
Swing motor, brake kit, upgrade
Terminology
Theft protection
Thermostatic function hydraulic oil, description
Tiltrotator control system, description
Towing
Travel alarm, description
Travel alarm, replacing
Travel gearbox, bleeding
Travel gearbox, description
Travel gearbox, troubleshooting
Travel motor, description
Travel pedal, description
Troubleshooting (5kw)
Troubleshooting tools
Troubleshooting
Turbocharger, description
Undercarriage, description
Valves, description
VCADS Pro, parameter programming
Vibration damper, description
Welding on the machine
Windscreen wiper, description
Wiper controller, description
Working pump, description
X1 pressure relief valve, adjusting
X1, description
X1, function check
X3, description
X3, function check
Component designations
Control system diagram
Hydraulic diagram, boom float valve
Hydraulic diagram, complete
Hydraulic diagram, complete-1
Hydraulic diagram, component list
Hydraulic diagram, control pattern selector valve
Hydraulic diagram, cruise control
Hydraulic diagram, dozer blade and outrigger
Hydraulic diagram, grab piping
Hydraulic diagram, offset boom
Hydraulic diagram, quick fit
Hydraulic diagram, with reversible cooling fan
Hydraulic diagram, X1 with flow control
Hydraulic diagram, X1 with pressure control 1
Hydraulic diagram, X3 FIG
Hydraulic diagram
Tiltrotator control system, diagram
Wiring diagram SCH01
Wiring diagram SCH02
Wiring diagram SCH03
Wiring diagram SCH04
Wiring diagram SCH05
Wiring diagram SCH06
Wiring diagram SCH07
Wiring diagram SCH08
Wiring diagram SCH09
Wiring diagram SCH10
Wiring diagram SCH11
Wiring diagram SCH12
Wiring diagram SCH13
Wiring diagram SCH14
Wiring diagram SCH15
Wiring diagram SCH16
Wiring diagram SCH17
Wiring diagram SCH18
Wiring diagram SCH19
Wiring diagram SCH20
Wiring diagram SCH21
Wiring diagram SCH22
Wiring diagram SCH22-1
Wiring diagram SCH24
Wiring diagram SCH25
Wiring diagram, general
Wiring harness
Installation Instructions
Auxiliary heater, installing new
Block heater 240V
Engine heater, installing new
Engine pre-heater, diesel
Float position valve, mono boom
Fuel filler pump
Hydraulic quickfit,
Rear view cam w lic.plate
Work light on 2 pcs boom, installing new
Work light on cab, installing new
Work light on counterweight and cab, rear
X3 control, X3 valve proportional on mono
X3 on arm 3,0m
X3 Valve on and off
2-piece boom, installation
2-piece boom, removal
Alternator, test
Antenna, replacing
Axle hubs, checking oil level
Axle, installing 1
Axle, installing
Axle, removing 1
Axle, removing
Axles, changing oil
Axles, checking oil level
Backrest, replacing
Battery condition, check
Boom cylinder, installation
Boom cylinder, removal
Boom foot bushing, replacing
Boom, installation
Boom, removal
Boost pressure charge-air temperature sensor, replacing
Brake accumulator charging pressure, adjusting
Brake discs, checking wear
Brake system bleeding
Bucket cylinder, installation
Bucket cylinder, removal
Bushing general, replacing
Cab door, installing door catch
Cab door, removing door catch
Cab elevating cylinder, replacing
Cab filter, replacing
Cab, main filter, clean
Cab, main filter, replacing
Cab, prefilter, clean
Cab, prefilter, replace
Calibration of X1 hydraulic with flow control
Calibration of X1 hydraulic with pressure control
Center passage, disassembly and assembly
Centre passage, installing
Centre passage, removing
Check engine oil level
Checking for cracks and leaks
Condenser, clean (with compressed air) (optional equipment)
Control lever, installation
Control lever, removal
Control valve (steering unit), description
Coolant level, check
Coolant pump, replacing
Coolant, change
Cooling fan pump, installation
Cooling fan pump, removal
Cooling fan speed, checking and adjusting with VCADS Pro
Counterweight, fitting
Counterweight, installing
Counterweight, removing 1
Creeping of hydraulic cylinder 1
Cylinder for hydraulic quickfit S1, installation
Cylinder for hydraulic quickfit S1, removal
Cylinder for hydraulic quickfit S6, installation
Cylinder for hydraulic quickfit S6, removal
Cylinder for hydraulic quickfit Universal, installation
Cylinder for hydraulic quickfit Universal, removal
Data links, fault tracing with Oscilloscope
Digging equipment bearings, measuring radial clearance
Digging equipment bearings, shimming
Dipper arm bushing-boom, replacing
Dipper arm bushing-bucket, replacing
Dipper arm bushing-lever, replacing
Dipper arm cylinder, removal
Dipper arm in speed, checking and adjusting
Dipper arm, installation
Dipper arm, removal
Discarded accumulators
Door hinges, lubricate with grease
Door window, replacing
Drive shaft seal, replacing
ECC control unit, replacing 1
ECC control unit, replacing 12
Electric center passage, replacing
Engine mount front, changing
Engine mounting
Engine oil pressure sensor, replacing
Engine rotation speed sensor (camshaft), replacing 1
Engine rotation speed sensor, replacing 1
Engine, oil and filter, change. 1
Engine, tightening torques
Exhaust manifold, replacing gasket
Expansion tank, replacing
Fan belt and or alternator-, compressor belt, replacing all belts
Feed pump, replacing
Foot brake valve, replacing
Fuel control valve (FCV), checking
Fuel filling pump, installing
Fuel filling pump, removing
Fuel filter extra, replacing 1
Fuel filter, checking
Fuel filters, replacing
Fuel pressure, checking
Fuel rail pressure, checking
Fuel rail, replacing
Fuel return pressure, checking
Fuel system, bleeding 1
Fuel tank water and sediment, drain
Fuel tank, replacing
Grease points on booms, lubrication
Grease points on dipper arm, lubrication
Grease points on superstructure, lubrication 1
Grease points on undercarriage, lubrication
Headlights, adjusting
Heater core, replacing
High pressure fuel pump, checking
Horn, replacing
Hub reduction gear, changing oil
Hydraulic oil cooler, installing
Hydraulic oil cooler, removing
Hydraulic oil return filter, changing
Hydraulic oil suction strainer, change
Hydraulic oil tank, releasing pressure
Hydraulic oil tank, removing
Hydraulic system, changing oil
Hydraulic system, checking oil level
Hydraulic system, position of main components on superstructure
Hydraulic system, warming up
Hydraulic tank breather filter, changing
Induction manifold, replacing gasket
Injectors, replacing all
Intake actuator, replacing
Intercooler, replacing
King pin and bushing, replacing
Lever link bushing-bucket cylinder, replacing
Line rupture valve pressure, checking and adjusting
Longitudinal adjustment cable, replacing
Longitudinal suspension cable, replacing
LS-pressure relief valve, replacing
Maintenance service, first 500 hours
Maintenance service, general
Measuring rotational clearance
Oil cooler fan motor, installation
Oil cooler fan motor, removal
Oil cooler, replacing
Oil level sensor, changing
Oil pump, replacing
Oil sump, replacing
Parking brake, manually releasing
Periodic maintenance
Pivot axle lock cylinder, changing seals
Pivot axle lock cylinder, installing
Pivot axle lock cylinder, releasing for towing
Pivot axle lock cylinder, removing
Preheating coil, replacing
Pressure relief valve (PRV), checking
Pressure relief valve (PRV), replacing
Propeller shaft, front, replacing
Propeller shaft, rear, replacing
Pump coupling, installing
Pump coupling, removing
Pump, installation
Pump, removal
Quickfit, function check
Quickfit, installation
Quickfit, removal
Radiator hose upper, replacing
Radiator hoses lower, replacing
Radiator, replacing
Rear window, replacing
Rupture valve, replacing (2pcs boom tilt cylinder)
Safety relief valve, replacing
Seat belt, replacing
Seat cushion, replacing
Seat support, replacing
Seat, replacing 1
Seat, replacing
Secondary lowering of digging equipment
Secondary pressure limiting valve, checking
Servo pump, installation
Servo pump, removal
Servo valve, installation 1
Servo valve, removal
Shock valve removed, checking
Side window, replacing
Silencer, replacing
Slew ring, axial clearance
Slew ring, rotational clearance
Speaker, replacing
Stabilisers, installation
Stabilisers, removal hydraulic cylinder 1
Starter motor, replacing
Starter motor, tests
Starter relay, replacing
Starter switch (engine start switch), replacing
Steering system working pressure, checking
Steering valve, installation
Steering valve, removal
Swing bath grease, check
Swing motor brake discs, replacing (motor removed)
Swing motor pressure, checking and adjusting
Swing ring, measuring axial clearance 1
Switch, replacing
Thermostat, checking
Thermostat, replacing
Tilt cylinder 2-piece boom, front bushing, replacing
Tilt cylinder 2-piece boom, installation
Tilt cylinder 2-piece boom, rear bushing, replacing
Tilt cylinder 2-piece boom, removal
Timing gear case, fitting new gasket in machine
Transmission mode, function check
Travel gearbox oil level, checking
Travel gearbox, changing oil
Travel gearbox, installation
Travel gearbox, removal
Travel motor pressure, checking and adjusting
Travel motor removed, replacing seal
Travel motor speed, checking and adjusting
Travel motor, installing
Travel motor, removing
Turbocharger inclusive inlet and exhaust systems, leakage, check
Turbocharger, inspection
Turbocharger, replacing
Vacuum pump, connection
Vacuum pump, disconnection
VCADS Pro, 91610-3 – X1 hydraulic pressure control system, test
Vent actuator, replacing
Water separator, drain
W-ECU, MID 142, replacing
Wheel nuts, check torque
Wheel, installing
Wheel, removing
Windscreen flusher pump, replacing
Windscreen wiper, replacing controller
Windscreen wiper, replacing switch
Windscreen, replacing
X3 pressure and flow, adjusting
9 Cab update, C-series
12 Cab update, C-series
14 Cab update, C-series
Air conditioning coolant volume
Ambient temperature sensor AC
Auto idle, function
Auxiliary heater
Blower motor
Boost temperature – incorrect warning
Cab door 2
Cab door latch 1
Cab door latch
Cable harness connector, engine
CD & MP3 player
Charge air cooler hose installation
Common hoses, outrigger cylinders
Coolant pump improvement
Cover fastener
Cruise control operation
Cylinder liner, specifications
D4 – D7 Alternator improvement
D6 D7 Exhaust gas leakage into the cooling system
D6E and D7E, high pressure pipe leakage
D6E Camshaft, insufficient hardening
Differential cracks on rear or front axle after improvement
Dozer blade cover improvement
ECU, functional check
Electric horn improvement
Electric horn
Emergency actuation of gearbox
Engine oil leakage
Engine speed control switch improvement
Engine starting in the manual mode
Fuel cap improvement
Fuel pump (Tier 3) manufacturing process improvement
Grease bar, boom
Hose leakage, brake line front axle
Hose leakage
Hour counter improvement
Hydraulic lock lever
Hydraulic oil
I-ECU, clock and rear view camera
Improved bracket for the AC compressor
Improved front cover lock
Improved painting process for undercarriage
Improvement of drive shaft seal, main pump
Injector yoke bolt
Injector yoke retention bolt loose
Instrument ECU change
Instrument ECU Improvement
Internal modem change
Leakage at engine oil pump gasket 1
Machine model
Main pump and gear pump suction hose clamping improvement
New coolant
New engine oil cooler
New engine oil level sensor
New fan bracket with profile washer
New fuel level sensor
New LS hose to main pump regulator
New method to check Δp pressure
New option Tiltrotator control system
New product 1
New product
New slew motor brake kit
New slew motor
New slew ring gear seal
New software for anti-theft and cold starting improvement
New software
New stone guard ring
New turbo charger for D6E D7E
Noise during slewing superstructure
Noise from pin connection 1st and 2nd boom
Noise in servo valve block
Oil analyses
Oil sampling, sampling points
Operating hour parameter
Option X1 pressure control
Overload function
Overload warning
Pipe leakage
Pressure sensor
Priority valve for steering
Protection cover
Quickfit valve block leakage at plug (optional equipment only)
Receiver drier improvement
Software update, X3 On Off function
Travel motor 30, 35 kmh (option)
Travel motor relief valve
Travel motor shifting delay
Travel starting delays after retardation use when stopping
Turbo outlet gasket change
Turbocharger
Washer pump improvement
Water separator drain valve
Wheeled Excavators - New C series machines
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Air cleaner, specification 1
Alternator, specifications
Audio remote controller, specifications
Auto idle pressure switch, specifications
Auto Manual pump control switch, specifications
Battery disconnect switch, specifications
Cab, specifications
Cab, weight
Capacities
Circuit breaker, specification
Control levers, specifications
Control lockout solenoid valve, specifications
Control valve (steering unit), specification
Coolant pump, thermostat, specifications
Counterweight, specifications 1
Cruise control, specifications
Cylinder data
Diesel coolant heater (5kw), specifications
Digging equipment bearings, specifications
Electric center passage, specification
Electric horn, specifications
Electronic climate control unit ECC, specification
Engine control unit E-ECU, specifications
Engine control, specifications
Engine speed control switch, specifications
Engine, specifications
Engine, volume
Engine, weights
Flasher relay, specifications
Flywheel, weight
Front axle, specification
Fuel filler pump, specifications
Fuel pressure, specifications
Fuel tank, specifications
Hour counter, specifications
Hydraulic oil filter pressure switch, specifications
Injectors, specifications
Keypad, specification
Lighting, specifications
Manual travel control switch, specifications
Multi-function lever switch, specifications
Power outlet, specifications
Preheating, specifications
Propeller shaft, specifications
Radio with tape or CD player, specifications
Rear axle, specification
Rear view camera, specifications
Relay, specifications
Rotating beacon, specifications
Servo Accumulator
Servo pump, specifications
Slew motor, specifications
Slew position sensor, specfications
Slew ring gear, specifications
Specifications, weight
Stabiliser solenoid valve, specifications
Start switch, specifications
Starter motor, specifications
Steering axle, specifications
Tightening torques
Travel alarm, specifications
Travel gearbox, specifications
Travel motor, specifications
Valve system specifications
Vehicle control unit V-ECU, specifications
Wheels, specifications
Windscreen flusher pump, specifications
Wiper controller, specifications
Wireless control unit W-ECU, specification
Working pump, specifications
X1, Specifications
  • Volvo Excavator EW160C Service and Repair Manual.txt
