Volvo Excavator ECR145DL Service Repair Manual
Model: Volvo ECR145DL ExcavatorBrand: Volvo
Type of Machine: Excavator
Type of Manual: Service Repair Manual, Electrical Wiring Diagram, Hydraulic Diagram
Number of Pages: 2154 Pages
1 Volvo ECR145D L
3 way selector valve, specifications
8920-00280 Drift
8920-00550 Drift
8920-00570 Drift
8932-00040 Impact puller
8932-00600 Drift
9990008 Measuring equipment
9990014 Break out harness
9990025 Break out harness
9990062 Cable
9990133 Template
9990216 Break out harness
9998534 Break out harness
9998699 Adapter
14360000 Vacuum pump 24V
14548448 Pump
14560748 Track pin press
14566479 Pin kit
14576840 Measuring tool
88830028 Break out harness
88830037 Template
88830272 Drift
88830273 Socket wrench
88890016 Break out harness
88890019 Template
88890074 Multimeter
Accumulator, replacing
ACM, I O list
Adapter
Adjustable boom, specifications
Air cleaner, cleaning filter element
Air cleaner, primary filter replacing
Air cleaner, secondary filter replacing
Air conditioner compressor belt, check
Air conditioning evaporator
Air distribution, description
Air pump, replacing
Alternator, specifications 1
Alternator, test
Antenna, replacing
Anti-theft system
Arm parallel conflux changeover valve, disassembly
Arm regenerating valve, disassembly
Audio remote controller, specifications
Auto Idle
Auto Manual pump control switch, specifications
Automatic engine shut-down
Auxiliary heater, description
Auxiliary heater, principles
Auxiliary heater, specifications
Auxiliary start
Backrest, replacing
Battery condition, check
Battery disconnector, replacing
Battery, storage
Bearings
Blade lift cylinder, installing
Blade lift cylinder, removing
Boom cylinder, description
Boom cylinder, installation
Boom cylinder, removal
Boom cylinder, replacing
Boom cylinder, specifications
Boom holding valve, disassembly and assembly
Boom regenerating check valve, disassembly
Boom, description
Boom, installation
Boom, removal
Boom, replacing
Boom, specifications
Boost control, description
Bottom roller, description
Bottom roller, replacing one
Bottom roller, replacing seal
Break out harness 1
Break out harness 2
Break out harness
Breather, replacing
Bucket assembly, installation
Bucket assembly, removal
Bucket assembly, replacing
Bucket cylinder, description
Bucket cylinder, installation
Bucket cylinder, removal
Bucket cylinder, replacing
Bucket drift
Bucket flow control valve, disassembly
Bucket regenerating valve, disassembly
Burner ignition device improvement
Cab filter, replacing
Cab suspension, description
Cab, prefilter, clean
Cab, prefilter, replace
Cab, weight
Cable
CareTrack antenna, replacing
CareTrack battery, replacing
CareTrack W-ECU, description
CareTrack with anti-theft
Cautions during operation
CE-marking, EMC-directive
Center passage, assembly
Center passage, description 1
Center passage, description 2
Center passage, disassembly
Center passage, maintenance standard
Center passage, replacing seal kit
Center passage, specifications 1
Center passage, specifications 2
Change capacities
Charging, description
Check valve, description
Circuit breaker, specification
Cleaning prior to repair
Coasting left and right swing
Communication with data buses
Component designations
Component list, Fuses
Component list, Heating coils
Component list, Lights
Component list, Miscellaneous
Component list, Relays
Component list, Sensors
Component locations
Compressor, replacing magnetic clutch (compressor removed)
Conditions when checking
Conflux check valve, disassembly
Connecting rod yoke, removal
Control pattern selector valve, specifications
Control system diagram
Control valve, replacing
Coolant level, check
Coolant level, checking
Coolant, changing 1
Coolant, checking anti-freeze resistance 1
Coolant
Cooling fan control
Cooling system, description 1
Counterweight, description
Counterweight, fitting
Counterweight, removing
Counterweight, specifications
CU2501, description and measuring
CU2503, description and measuring
Cylinder speed
Cylinder, description
Cylinder, troubleshooting
D4H - D8H EATS air pump improvement
D4H EGR actuator failure
D4H, D6H, D8H air pump
Data buses, function
DC–DC converter, description
Defroster actuator, replacing
Description, general
Diesel particulate filter, checking and cleaning 1
Digging unit, maintenance
Dipper arm cylinder, removal
Dipper arm, description
Dipper arm, installation
Dipper arm, removal
Dipper arm, replacing
Dipper arm, specifications
Disassembly tool
Display unit 1
Display unit 2
Display unit 3
Door, replacing
Dozer blade, description
Dozer blade, specifications
DPF regeneration control
Driver's seat, description
Driver's seat, specifications
Earth lead to battery, replacing
ECC, I O list
ECU, functional check
E-ECU, I O list
E-ECU, MID 128, changing pre-Programd ECU
Electric horn, specifications
Electronic climate control unit ECC, description 1
Electronic climate control unit ECC, specification
Engine air cleaner primary filter, cleaning and replacing
Engine characteristic curve
Engine hood, replacing
Engine limp home switch, specifications 1
Engine oil level, checking
Engine oil pressure sensor, replacing
Engine oil
Engine rotation speed sensor (camshaft), replacing 1
Engine rotation speed sensor (camshaft), replacing 2
Engine speed control switch, replacing 1
Engine speed control switch, replacing 2
Engine system
Engine temperature sensor, replacing
Engine, oil level, check
Engine, software specifications
Engine, specifications
Engine, tightening torques 1
Engine, tightening torques 2
Error codes, build-up
E-tools, NET 8940-00310 Replace tool for the swing ring gear
E-tools, NET 8940-00320 Swing motor guide pin
Excavator unit, greasing
Exhaust Aftertreatment System, description 1
Exhaust aftertreatment system, specifications
Exhaust Gas Recirculation (EGR), description 1
Expansion tank, replacing
Fan belt and belt tension, check
Fan belt and or alternator-, compressor belt, replacing all belts 1
Fan belt, checking
Fan motor, assembly
Fan motor, description
Fan motor, disassembly
Fan motor, tools
Fan motor, troubleshooting
Fan pump, description
Front idler, replacing one
Fuel filler pump, specifications
Fuel filling pump, installing
Fuel filling pump, removing
Fuel filter, change
Fuel level sender, replacing
Fuel system, description 1
Fuel system, specifications
Fuel tank sediment, drain
Fuel tank, description
Fuel tank, volume
Fuel
Full track guard, replacing
Function description 1
Function description 2
Function description 3
Fuse, description
FX1006, description and measuring
FX1031, description and measuring
General, precautions
General, tools
Grading and lifting control, description
Grease
Hammer and shear pedal valve (RCV), replacing
Hammer and shear selector and shuttle valve, description
Heater core, replacing
Heating system, description
Hoses and tubes
Hour counter, specifications
HVAC system
Hydraulic diagram, schematic
Hydraulic diagram, standard
Hydraulic diagram, with option components
Hydraulic oil level, check
Hydraulic oil tank, replacing
Hydraulic oil tank, specifications
Hydraulic oil, changing
Hydraulic oil
Hydraulic pump, description
Hydraulic pump, replacing
Hydraulic system
Idler, assembly
Idler, description
Idler, disassembly
Idler, measurement of wear
I-ECU, I O list
IG2501, description and measuring
Ignition switch, replacing
Information display, check
Intake actuator, replacing
Intercooler, replacing
Interface
Keypad, description
Keypad, specification
Lead and connector checks
Leak detector
Line rupture valve relief pressure, adjustment
Link, description
Longitudinal adjustment cable, replacing
Longitudinal suspension cable, replacing
Lubricating system, description 1
Lubricating system, description 2
Lubricating system, description 3
Lubrication and service chart
MA2301-MA2304, description and measuring
MA2508, description and measuring
MA2509, descripton and measuring
MA2510, description and measuring
MA2512, description and measuring
MA4212, description and measuring
MA9118, description and measuring
MA9121, description and measuring
MA9122, description and measuring
MA9125, description and measuring
Machine model
Machine view
Machine weight, specifications
Main pump, proportional reducing valve
Main relief valve, adjustment
Main relief valve, assembly
Maintenance service, every 6000 hours 1
Maintenance service, every 6000 hours 2
Maintenance service, first 500 hours
Measurement conversion tables
Measuring condition
Measuring equipment
Measuring tool
MID140 PID251, description and measuring
MID140 PPID1144, description and measuring
MO2502, description and measuring
Mode selection, description
MS.Internal.Documents
Multimeter
New log for DPF and ECO mode
New product 1
New product 2
New product 3
New product
New software for regeneration
New software for semi auto function and overload pressure
New software I-ECU, W1349
New software, I-ECU
New software, V-ECU
New Tiltrotator control system
Oil cooler fan motor, replacing
Oil cooler fan pump, replacing
Oil cooler line bypass valve (check valve), replacing
Oil cooler, replacing
Oil filter wrench
Oil level gauge, replacing
Oil level sensor, changing
Oil sampling, sampling points
Overload warning
Power supply E-ECU, description and measuring
PPID1336, description and measuring
Preheating coil, replacing
Pre-heating relay, replacing
Preheating, description
Preheating, specifications 1
Pressure testing
Product plates
Proportional solenoid valve, description 1
Proportional solenoid valve, specifications 1
Pump gearbox coupling assembly, replacing
Pump regulator, replacing
Pump suction hose and pipe, replacing
Pump, assembly
Pump, disassembly
Pump, maintenance standard
Pump, tools
Pump, troubleshooting
PWM9129, description and measuring
PWM9141, description and measuring
PWM9142, description and measuring
PWM9143, description and measuring
PWM9145, description and measuring
PWM9146, description and measuring
PWM9156, description and measuring
PWM9157, description and measuring
Quickfit system, operation
Quickfit, installation
Quickfit, removal 1
Quickfit, removal
Radiator hoses all, replacing
Radiator, description
Radiator, replacing
Radio with CD and MP3 player, specifications
Radio, description
Radio, replacing
RE3302, description and measuring
Rear-view mirror, changing
Recoil spring cylinder seal kit, replacing
Refractometer
Regulator, description
Relay, description
Relay, specifications 1
Remote control valve (dozer blade), specifications
Remote control valve (pedal), specifications 1
Replacement parts
Response mode
Rotating beacon, description
Rotating beacon, replacing
Rotating beacon, specifications
Rotation tool
Rotator pump, specifications
Rotator valve, adjustment
Rubber pads 1
Rubber pads 2
Rubber shoe pad usage
SAE J1708 1587 Information link, description and measuring
SAEJ1939 CAN7 Control link, descripton and measuring
Safe start and stop, description
Safety when servicing
SE2512, description and measuring
SE2520, description and measuring
SE2523, description and measuring
SE2524, description and measuring
SE2526, description and measuring
SE2529, description and measuring
SE8708, description and measuring
SE9121, description and measuring
SE9122, description and measuring
SE9123, description and measuring
SE9124, description and measuring
SE9125, description and measuring
SE9126, description and measuring
SE9127, description and measuring
SE9128, description and measuring
SE9129, description and measuring
SE9130, description and measuring
SE9131, description and measuring
SE9132, description and measuring
SE9138, description and measuring
Seat cushion, replacing
Seat heater, checking
Seat support, replacing
Seat, replacing
Selection of track shoes
Service methods
Service mode
Service positions
Service
Servo hydraulic block
Servo pump, description
Servo pump, parts inspection
Servo pump, replacing
Servo pump, specifications
Shockless boom control, description
SID211, description and measuring
Single pedal stopper position
Slew priority valve, disassembly
Software parameters, description 1
Software parameters, description 2
Solenoid valve for rotator
Solenoid valve, description 1
Solenoid valve, replacing
Solenoid valve, specifications 1
Spark plug, replacing 1
Speaker, replacing
Specification, filling capacities
Spring package, disassembly
Sprocket, measurement of wear
Sprocket, replacing one
Start lock, description
Start switch, description
Start switch, specifications
Starter motor, description
Starter motor, replacing
Starter motor, specifications 1
Starter motor, tests
Starter relay, replacing
Starter switch, testing
Starting operation
Stop valve
Superstructure, installing
Superstructure, removing 1
SW9160, description and measuring
SW9161, description and measuring
Swing bath grease, check
Swing gearbox removed, replacing seal
Swing gearbox removed, replacing shaft
Swing gearbox, assembly
Swing gearbox, description 1
Swing gearbox, description 2
Swing gearbox, disassembly
Swing gearbox, maintenance standard
Swing gearbox, replacing
Swing gearbox, specifications
Swing motor, assembly
Swing motor, description
Swing motor, disassembly
Swing motor, replacing plate (brake)
Swing motor, specifications
Swing ring gear inner seal, replacing 1
Swing ring gear inner seal, replacing 2
Swing ring gear outer seal, replacing 1
Swing ring gear outer seal, replacing 2
Swing ring gear seal
Swing ring gear, description
Swing ring gear, replacing
Swing ring gear, specifications
Swing speed
Swing unit, replacing 1
Tech Tool
Template
The authorization for new Anti-theft function
Thermostat, checking
Thermostat, replacing
Thermostat, specifications
Tightening torque, specifications 3
Tightening torques 1
Tightening torques 2
Tightening torques 3
Tightening torques 4
Tightening torques 5
Tightening torques 6
Tightening torques
Timing tool
Tool box assembly, replacing
Tools & equipment
Top roller, assembly
Top roller, description
Top roller, disassembly
Top roller, replacing one
Track chain, description
Track gearbox, assembly 1
Track gearbox, description 1
Track gearbox, disassembly 1
Track gearbox, maintenance standard 1
Track gearbox, replacing cover 1
Track gearbox, specifications 1
Track guard, replacing one
Track guards
Track link, dimension
Track links, replacing
Track motor, assembly
Track motor, description
Track motor, disassembly
Track motor, specifications
Track running speed
Track shoe bolts, check
Track shoe, replacing one
Track shoes
Track unit, checking shoe screws
Track unit, replacing 1
Track, adjusting track sag
Travel alarm, description
Travel alarm, replacing
Travel alarm, specifications
Travel alarm
Travel gear box hub improvement
Travel Speed
Troubleshooting (10kw)
Troubleshooting tools
Troubleshooting
Turbocharger, description
Turbocharger, replacing
Undercarriage, description
VCADS Pro service tool
VCADS Pro socket, measuring
VCADS Pro, Operations 1
VCADS Pro, Operations 2
VCADS Pro, Operations 3
VCADS Pro, Operations 4
V-ECU, I O list
Vehicle information
Vent actuator, replacing
Voltage converter, replacing
Washer fluid level, check
Washer reservoir
Water separator, check drain
Water separator, draining
Water valve, replacing
W-ECU, I O list
W-ECU, MID142, changing non-Programd ECU 1
W-ECU, MID142, changing non-Programd ECU 2
W-ECU, MID142, changing non-Programd ECU 3
W-ECU, MID142, changing pre-Programd ECU 1
W-ECU, MID142, changing pre-Programd ECU 2
W-ECU, MID142, changing pre-Programd ECU 3
Windscreen flusher pump, replacing
Windscreen wiper, replacing controller
Windscreen wiper, replacing switch
Wireless control unit W-ECU, specification
Wiring diagram SCH01
Wiring diagram SCH02
Wiring diagram SCH03
Wiring diagram SCH04
Wiring diagram SCH05
Wiring diagram SCH07
Wiring diagram SCH08
Wiring diagram SCH10
Wiring diagram SCH11
Wiring diagram SCH12
Wiring diagram SCH13
Wiring diagram SCH14
Wiring diagram SCH15
Wiring diagram SCH16
Wiring diagram SCH17
Wiring diagram SCH18
Wiring diagram SCH22
Wiring diagram SCH24 1
Wiring diagram SCH24 2
Wiring diagram SCH30
Wiring diagram
Wiring harnesses
Work lighting, replacing one head lamp assy 1
Work lighting, replacing one head lamp assy 2
X1 control, description
X1 Line, description 1
X1 Line, description 2
X1 operating improvement
X3 control, description
