Volvo Excavator ECR145C L Service Repair Manual​
Model: Volvo ECR145C L Excavator
Type of Machine: Excavator
Type of Manual: Service Repair Manual, Wiring Diagram
Number of Pages: 1523 Pages
1VOLVO ECR145CL
2 stage port relief valve, disassembly
11 666 140 Multimeter
999 0014 Adapter cable
999 0025 Adapter cable
999 0062 Extension cable
999 3893 Adapter cable
999 3894 Template
8883 0028 Adapter cable
Accumulator, replacing
Adjustable boom, description
Air distribution, description
Alternator, test
Arm holding valve, disassembly
Arm parallel conflux changeover valve, disassembly
Arm parallel conflux check valve, disassembly
Arm regenerating valve, disassembly
Auxiliary start
Basic check, Engine
Batteries, checking charging capacity
Battery, storage
Bearings
Biodegradable hydraulic oil
Blade Lift Cylinder - Installation
Blade Lift Cylinder - Removal
Blower motor
Boom 2 conflux shut-off valve, disassembly
Boom holding valve, description 1
Boom holding valve, disassembly 1
Boom regenerating check valve, disassembly
Boom, description
Boom, installation
Boom, removal
Boom, replacing
Boost control, description
Booting sequence
Bottom roller, description
Bottom roller, replacing one
Bucket assembly, installation
Bucket assembly, removal
Bucket assembly, replacing
Bucket cylinder, description
Bucket cylinder, installation
Bucket cylinder, removal
Bucket cylinder, replacing
Bucket flow control valve, disassembly
Bucket operation
Bucket regenerating valve, disassembly
Cab filter, replacing
Cab suspension, description
Camshaft, description
Carbon monoxide in fuel system, check
CareTrack W-ECU, description
CE-marking, EMC-directive
Center passage, assembly
Center passage, description
Center passage, disassembly
Charge air cooler connection (hose, tube), replacing
Charge air cooler, description
Charge air system, inspection
Charging, description
Check valve, description
Cigar lighter and ashtray change
Circuit breaker, description
Cleaning of the machine
Cleaning prior to repair
Coasting left and right slew
Communication with data buses
Component descriptions
Component designations
Component list, Fuses
Component list, Heating coils
Component list, Lights
Component list, Miscellaneous
Component list, Relays
Component list, Sensors
Component list, Switches
Component locations 1
Component locations
Component troubleshooting, checking component
Component troubleshooting, checking subsystem (circuit)
Component troubleshooting, checking wiring harness and input output on ECU
Component troubleshooting, structure, description
Conflux check valve, disassembly
Connecting rod, description
Connecting special tools
Connectors, overview
Control levers, description
Control system diagram
Control units changing, precaution
Control units, changing
Cooler and Heater assembly, installation
Cooler and Heater assembly, removal
Counterweight, fitting
Counterweight, removing
Crankshaft, description
CU9901, description and measuring
Cylinder block, description
Cylinder head, description
Cylinder speed
Cylinder, description 1
Cylinder, troubleshooting
Data buses, function
DC–DC converter, description
Defroster actuator, replacing
Description, general
Digging unit, maintenance
Dipper arm cylinder, removal
Dipper arm, description
Display unit, content
Dozer blade, description
ECC control unit, replacing 1
ECC control unit, replacing 2
ECU, functional check
Electric horn improvement
Electric horn, description
Electrical distribution box 1
Electronic climate control unit ECC, description 1
Electronic climate control unit ECC, description 2
Engine characteristic curve
Engine mounting
Engine Protection
Engine speed control switch improvement
Engine starting in the manual mode
Engine system
Engine, identification
Engine, tightening torques
Error code information, description
Error codes, build-up
Examples, hydraulic system
Examples, power transmission
Exhaust system, description
Expansion tank, changing
Expansion valve, replacing incl draining and filling 1
Expansion valve, replacing incl draining and filling 2
Fan belt and or alternator compressor belt, replacing all belts
Fan motor, assembly
Fan motor, description
Fan motor, disassembly
Fan motor, tools
Fan motor, troubleshooting
Fan pump, description
Feed pump, replacing
Front idler, replacing one
FU6, description and measuring
Fuel feed pump, description
Fuel filler pump, description
Fuel filling pump, installing
Fuel filter extra, replacing
Fuel filter, check
Fuel filters, replacing
Fuel pump (Tier 3) manufacturing process improvement
Fuel pump, inspection
Fuel rail pressure, checking
Fuel return pressure, checking
Fuel tank, description
Fuse, description
General, precautions
Hammer and shear selector and shuttle valve, description
Heater core, replacing
Heating system, description
High pressure fuel pump, checking
Horn, replacing
Hoses and tubes
Hour counter improvement
Hour counter, description
HVAC system 1
HVAC system
Hydraulic circuits, ports
Hydraulic diagram ports, standard
Hydraulic diagram ports, with option components
Hydraulic diagram, schematic
Hydraulic diagram, standard
Hydraulic diagram, with option components
Hydraulic oil tank, changing breather filter
Hydraulic oil tank, changing oil
Hydraulic oil tank, return oil filter change
Hydraulic oil
Hydraulic pump, description
Hydraulic system
Hydraulic tank air breather
Idler, assembly
Idler, description
Idler, disassembly
Idler, measurement of wear
Injector, replacing one
Injectors, description
Injectors, replacing all
Inlet system, description
Instrument ECU change
Instrument ECU Improvement
Intake actuator, replacing
Intercooler, replacing
Keypad, description 1
Keypad, description
Language
Line rupture valve relief pressure, adjustment
Link, description
MA2301-MA2304, description and measuring
MA2602, description and measuring
MA4216, description and measuring
MA9103, description and measuring
MA9104, description and measuring
MA9105, description and measuring
MA9106, description and measuring
MA9107, description and measuring
MA9109, description and measurement
MA9118, description and measuring
MA9166, description and measuring
Machine model
MAIN MENU
Main relief valve, adjustment
Main relief valve, assembly
Main switch, replacing
Maintenance service, according to display message
Maintenance service, as required
Maintenance service, every 100 hours
Measurement conversion tables
Measuring condition
Measuring of slew bearing clearance
Measuring, general
Menu tree
Mode selection, description
Mounting Bolts for the roof hatch and anti-vandal box
New engine oil level sensor
New product 1
New product 2
New product
New software 1
New software 2
New software 3
New software release 1
New software release 2
New software update 2010.3.0 for CareTrack
New software, V-ECU
Oil analyses
Oil cooler fan motor, replacing
Oil cooler fan pump, replacing
Oil cooler, replacing
Oil level gauge, replacing
Oil level sensor, changing
Oil sampling, sampling points
Oil sump, description
Overload warning device, description
Pipe and hose (pump - valve), replacing
Piston cooling
Piston rings, description
Pistons, description
Plastic shims for Boom Arm pin joints
Poor straight travel operation
Pop-up screen
Port relief valve pressure, adjustment
Port relief valve pressure, measuring and adjusting
PPID1336, description and measuring
Preheating coil, replacing
Pressure sensor
Pressure testing
Product plates
Proportional solenoid valve, description 1
Pump regulator, replacing
Pump, assembly
Pump, disassembly
Pump, maintenance standard
Pump, tools
Pump, troubleshooting
PWM9101, description and measuring
PWM9102, description and measuring
PWM9103, description and measuring
Quickfit, installation
Quickfit, removal
Radiator hose upper, replacing
Radiator hoses lower, replacing
Radiator, replacing
Radio with tape player, description
Radio, description
Radio, replacing
Recoil spring package rod
Regulator, description
Relay, description
Replacement parts
Reversible fan, modes and setting
Rotating beacon, description
Rotating beacon, replacing
Rotator pump, description
Rotator valve, adjustment
Rubber pads
SAE code, conversion for component designation, E-ECU
SAE code, conversion to component designation, ECC
SAE code, conversion to component designation, I–ECU
SAE code, conversion to component designation, V-ECU
SAE J1708 1587 information link, description and measuring
Safety when servicing
Selection of track shoes
Service methods
Service mode
Service positions
Service
Servo hydraulic block
Servo pump, description
SETUP
Silencer, replacing
Slew brake, description
Slew gearbox, assembly
Slew gearbox, description
Slew gearbox, disassembly
Slew gearbox, lubrication
Slew gearbox, maintenance standard
Slew gearbox, troubleshooting
Slew motor gearbox, changing oil
Slew motor relief valve, replacing
Slew motor, adjustment
Slew motor, assembly
Slew motor, description
Slew motor, disassembly
Slew motor, lubrication and air purging
Slew motor, principle of operation
Slew motor, troubleshooting
Slew motor, wear and damage limits for repair
Slew priority valve, disassembly
Slew ring gear seals, installation
Slew ring gear, description
Slew speed
Solenoid valve, description 1
Solenoid valve, inspection
Solenoid valve, replacing
Spring package, disassembly
Sprocket, measurement of wear
Sprocket, replacing one
Start lock, description
Start switch, description
Starter motor, description
Starter motor, replacing
Starter motor, tests
Starter relay, replacing
Starter switch (engine start switch), replacing
Starter switch, testing
Starting operation
Superstructure, installation
Superstructure, removal
Swing motor, improvement
Swing stop on a slope improvement
SWxxxx, description and measuring
Terminology
Theft protection
Thermostat, check
Thermostat, replacing
Tools & equipment
Top roller, assembly
Top roller, description
Top roller, disassembly
Top roller, replacing one
Track chain assembly, installation
Track chain assembly, removal
Track chain, description
Track chain, wear limit
Track gearbox, description
Track guard, replacing one
Track link, dimension 1
Track link, dimension 2
Track motor, description
Track motor, troubleshooting
Track running speed
Track shoe, replacing one
Track, adjusting track sag
Travel alarm, description
Travel alarm, replacing
Travel motor auto travel speed shifting malfunction improvement
Travel Speed
Troubleshooting (5kw)
Troubleshooting tools
Troubleshooting, diagnosing procedure
Troubleshooting
Turbocharger, description
Turbocharger, inspection
Turbocharger, replacing
Undercarriage, description
Valves, description
VCADS Pro service tool
Vent actuator, replacing 1
Vent actuator, replacing 2
Vibration damper, description
Voltage converter, replacing
Water valve, replacing
Welding on the machine
When using rubber tracks
Windscreen wiper, replacing controller
Windscreen, replacing
Wireless control unit W-ECU, specification
Wiring diagram 1
Wiring diagram SCH01
Wiring diagram SCH02
Wiring diagram SCH03
Wiring diagram SCH04
Wiring diagram SCH07
Wiring diagram SCH08
Wiring diagram SCH10
Wiring diagram SCH11
Wiring diagram SCH12
Wiring diagram SCH13
Wiring diagram SCH14
Wiring diagram SCH15 1
Wiring diagram SCH15 2
Wiring diagram SCH15 3
Wiring diagram SCH16
Wiring diagram SCH17
Wiring diagram SCH18 1
Wiring diagram SCH18 2
Wiring diagram SCH22
Wiring diagram SCH24
Wiring diagram
Wiring harnesses
X1 control, description
X1 stop valve
X3 control, description
  • Volvo Excavator ECR145C L Service Repair Manual.txt
