Volvo Excavator EC480D L Service Repair Manual​
Total Size:
256.56 MB
Language:
English
Brand:
Volvo
Machine Type:
Excavator
EC480D L
Manual Type:​
  • Service Repair Manual
  • Electrical Wiring Diagram
  • Hydraulic Diagram
Number of Pages:​
  • 3345 Pages
1 Volvo EC480DL
8932-00400 Drive ring
936442 Testing nipple
9986173 Puller
9990006 Puller
9990014 Break out harness
9990062 Cable
9990262 Adapter
9993590 Gear wheel
9996400 Impact puller
9998250 Ring
9998251 Sealing plug
9998264 Lifting tool
9998534 Break out harness
9998567 Break out harness
9998599 Cleaning tool
9998699 Adapter
11666052 Pressure gauge
11668024 Rotation tool
11712316 Inspection tool
14290266 Hose
14548448 Pump
14560748 Track pin press
14566479 Pin kit
14576840 Measuring tool
14609309 Lifting device
15018967 Testing nipple
88800196 Flaring tool (copper sleeve)
88800342 Puller
88800352 Lifting tool
88800457 Counterhold
88830028 Break out harness
88830037 Template
88830188 Measuring tool
88880003 Bracket
88880024 Cable
88890016 Break out harness
88890019 Template
88890027 Cable
88890074 Multimeter
88890105 Refractometer
88890180 Interface
88890300 Interface
Accumulator, replacing
Actuator, variable turbocharger, replacing
Aftertreatment support unit (ASU), replacing
Air breather, description
Air conditioning unit, specifications 1
Air distribution, description
Air dryer cartridge, change
Air in fuel system, checking
Air pump flow, checking
Air pump oil level, check
Air pump oil, change
Air pump, replacing
Alternator, specifications 1
Alternator, test
AM injector available as separate spare part
Antenna, replacing
Anti-theft system
Application of sealant paste on injectors
Arm and bucket cylinder lock nut
Arm conflux check valve, disassembly
Arm cylinder hose rupture protection piping, installing new
Arm cylinder hose
Arm parallel conflux changeover valve, disassembly
Arm piping with X3
Atomization unit, replacing
Attachment shims for clearance adjustment of pin joint
Audio remote controller, specifications 1
Auto Idle
Auto idling sensor, replacing
Auto Manual pump control switch, specifications 1
Automatic engine shut-down
Automatic lubrication system, description
Automatic lubrication system, specifications 1
Auxiliary heater, description 1
Auxiliary heater, description 2
Auxiliary heater, principles 1
Auxiliary heater, principles 2
Auxiliary heater, specifications 1
Auxiliary heater, specifications 2
Auxiliary start
Backrest, replacing
Battery charger, description
Battery charger, specifications
Battery condition, check 1
Battery condition, check 2
Battery disconnector, replacing 1
Battery disconnector, replacing 2
Battery, specifications 1
Battery, storage
Bearings
Belts and belt tension, check, replace when needed. 1
Belts and belt tension, check, replace when needed. 2
Bleeding air
Boom 2 conflux shut-off valve, disassembly
Boom and arm holding valve (Boom-1, Arm-1), description
Boom and arm holding valve (Boom-1, Arm-1), disassembly
Boom boost check valve, disassembly
Boom cylinder hose rupture protection piping with over load signal , installing new
Boom cylinder, description 1
Boom cylinder, description 2
Boom cylinder, installation
Boom cylinder, removal
Boom cylinder, repacking in machine
Boom cylinder, replacing
Boom cylinder, specifications 1
Boom cylinder, specifications 2
Boom down operation improvement
Boom rear bushing
Boom servo hydraulic check valve
Boom, description 1
Boom, description 2
Boom, installation 1
Boom, installation 2
Boom, removal 1
Boom, removal 2
Boom, replacing
Boom, specifications 1
Boom, specifications 2
Boost control, description
Bottom roller, description
Bottom roller, replacing one
Bottom roller, replacing seal
Breather, replacing
Bucket assembly, installation
Bucket assembly, removal
Bucket assembly, replacing
Bucket cylinder, description 1
Bucket cylinder, description 2
Bucket cylinder, installation
Bucket cylinder, removal
Bucket cylinder, repacking in machine
Bucket cylinder, replacing
Bucket cylinder, specifications 1
Bucket cylinder, specifications 2
Burner, replacing
Cab door
Cab filter cover sealing
Cab filter, replacing
Cab suspension, description
Cab, prefilter, clean
Cab, prefilter, replace
Cab, weight 1
Cab, weight
Camshaft and rocker arms wear
Camshaft, replacing
CareTrack antenna, replacing
CareTrack battery, replacing
CareTrack W-ECU, description
CareTrack with anti-theft
Cautions during operation
CE-marking, EMC-directive
Center bypass valve (for bucket conflux), disassembly
Center passage, assembly
Center passage, description
Center passage, disassembly
Center passage, replacing seal kit
Center passage, specifications 1
Charging, description
Check valve (for arm parallel conflux, slew priority), disassembly
Check valve (for straight travel changeover valve), disassembly
Check valve, description
Circuit breaker, specification 1
Cleaning prior to repair
Coasting left and right swing
Communication with data buses 1
Communication with data buses 2
Component designations
Component list, Fuses 1
Component list, Fuses 2
Component list, Heating coils
Component list, Lights
Component list, Miscellaneous 2
Component list, Relays 1
Component list, Relays 2
Component list, Sensors 1
Component list, Sensors 2
Component list, Sensors 3
Component list, Solenoid valves 1
Component list, Solenoid valves 2
Component list, Switches 1
Component list, Switches 2
Component locations 1
Component locations 2
Compressed-air system, specifications 1
Compressor, replacing magnetic clutch (compressor removed)
Conditions when checking
Connecting rod yoke, removal
Connectors, overview 1
Connectors, overview 2
Control lockout lever switch, specifications 1
Control pattern selector valve, specifications 1
Control pattern selector valve, specifications 2
Control system diagram 1
Control system diagram 2
Control valve, part inspection
Control valve, replacing 1
Control valve, replacing 2
Coolant level, check 1
Coolant level, check 2
Coolant, change
Coolant, checking anti-freeze resistance 1
Coolant
Cooling fan control
Cooling system, component location 1
Cooling system, component location 2
Cooling system, tightening torques 1
Cooling system, tightening torques 2
Cooling system, tightening torques 3
Cooling system, tightening torques 4
Counterweight side bolt
Counterweight, description
Counterweight, fitting
Counterweight, removing
Counterweight, specifications 1
Counterweight, specifications 2
Counterweight, specifications 3
Counterweight, specifications 4
Counterweight, tightening torques 1
Counterweight, tightening torques 2
Counterweight, tightening torques 3
Counterweight, tightening torques 4
Cover assembly (for preventing Boom-1 spool rotation), disassembly
Crank mechanism, description
Crankcase ventilation, description 1
Crankcase ventilation, description 2
CU9901, description and measuring
Current pressure, specifications 1
Cylinder head, description
Cylinder speed 1
Cylinder speed 2
Cylinder, description
Cylinder, troubleshooting
D13 Cylinder head valve cover leakage
Data buses, function
DC–DC converter, description
DC–DC converter, specifications 1
Description, general
Diesel coolant heater 10 KW, installing new
Diesel particulate filter, checking and cleaning 1
Digging unit, maintenance
Dipper arm cylinder, description 1
Dipper arm cylinder, description 2
Dipper arm cylinder, removal
Dipper arm cylinder, repacking in machine
Dipper arm cylinder, specifications 1
Dipper arm cylinder, specifications 2
Dipper arm, description
Dipper arm, installation
Dipper arm, removal
Dipper arm, replacing
Dipper arm, specifications 1
Dipper arm, specifications 2
Door window, replacing
Door, replacing
DPF regeneration control
Driver's seat, description
Driver's seat, specifications
Earth lead to battery, replacing 1
Earth lead to battery, replacing 2
EATS functional check
ECC, I O list
ECO mode, description
ECU, functional check
E-ECU, I O list
E-ECU, MID 128, changing non-Programd ECU 1
E-ECU, MID 128, changing non-Programd ECU 2
E-ECU, MID 128, changing pre-Programd ECU 1
E-ECU, MID 128, changing pre-Programd ECU 2
EGR cooler, cleaning
EGR cooler, pressure test
EGR cooler, replacing
EGR pressure sensor, replacing
EGR system, tightening torques 1
EGR valve, replacing
EGR Venturi tube, checking 1
Electric horn, specifications 1
Electrical distribution box 1
Electrical distribution box 2
Electrical system, specifications 1
Electronic climate control unit ECC, description 1
Electronic climate control unit ECC, specification 1
Engine - Pump control, specification 1
Engine - Pump control, specification 2
Engine - Pump control, specification 3
Engine - Pump control, specification 4
Engine characteristic curve
Engine control unit E-ECU, function description 1
Engine control unit E-ECU, function description 2
Engine hood, replacing 1
Engine hood, replacing 2
Engine limp home switch, specifications 1
Engine mounting, tightening torque 1
Engine mounting, tightening torque 2
Engine mounting, tightening torque 3
Engine mounting, tightening torque 4
Engine oil 1
Engine oil 2
Engine oil pressure sensor, replacing 1
Engine oil pressure sensor, replacing 2
Engine speed control switch, replacing
Engine system
Engine temperature sensor, replacing
Engine transmission, tightening torque
Engine wire harness, replacing 1
Engine wire harness, replacing 2
Engine, description 1
Engine, description 2
Engine, general specifications 1
Engine, general specifications 2
Engine, identification
Engine, installing 1
Engine, installing 2
Engine, oil level, check
Engine, removing 1
Engine, removing 2
Error codes, build-up
E-tools, NET 8940-00290 Swing motor guide pin
Excavator unit, greasing 1
Excavator unit, greasing 2
Exhaust aftertreatment fuel injector, replacing
Exhaust aftertreatment system fuel flow, checking
Exhaust aftertreatment system, fuel pump, replacing
Exhaust aftertreatment system, specifications 1
Exhaust aftertreatment system, tightening torques 1
Exhaust manifold, tightening torques 1
Exhaust manifold, tightening torques 2
Exhaust manifold, tightening torques 3
Exhaust manifold, tightening torques 4
Expansion tank, replacing
Extra water separator (optional equipment), check drain
Extra water separator (optional equipment), filter element, change
Extra work lamp
Fan belt and or alternator-, compressor belt, replacing all belts 1
Fan belt and or alternator-, compressor belt, replacing all belts 2
Fan motor, assembly
Fan motor, description
Fan motor, disassembly
Fan motor, tools
Fan motor, troubleshooting
Fan pump, assembly
Fan pump, description
Fan pump, disassembly
Fan pump, parts inspection
Flywheel, tightening torques 1
Fog
Foot relief valve (flow sensing valve), description
FOPS
Frame and track unit, description 1
Frame and track unit, description 2
Frame and track unit, specifications 1
Front idler, installing
Front idler, removing
Front idler, replacing one
Fuel 1
Fuel 2
Fuel feed pump, description
Fuel filler pump, specifications 1
Fuel filling pump, installing
Fuel filling pump, removing
Fuel filter, change
Fuel level sender, replacing
Fuel pump, inspection
Fuel system, bleeding 1
Fuel system, bleeding 2
Fuel system, component location 1
Fuel system, component location 2
Fuel system, specifications 1
Fuel tank sediment, drain
Fuel tank, description
Fuel tank, specifications 1
Full track guard, replacing
Function description 1
Function description 2
Fuse, description
FX1006, description and measuring
FX1032, description and measuring
Gear pump, parts inspection
General description
General, precautions
General, tools
GPS control unit GPS-ECU, description
GPS control unit GPS-ECU, specifications
Grease
Hammer and shear pedal valve (RCV), replacing
Hammer return filter, description
Hammer return filter, specifications 1
Hammer return filter, specifications 2
Heater core, replacing
Heating system, description
High pressure air system, pressure, checking
High Sulphur Fuel Conversion kit, installing new
Horn, replacing
Hose (MCV to arm cylinder) leakage
Hose rupture valves
Hoses and tubes
Hour counter, specifications 1
Hour meter, replacing
HVAC system
Hydraulic components, description 1
Hydraulic components, description 2
Hydraulic diagram, ports 1
Hydraulic diagram, ports 2
Hydraulic diagram, schematic
Hydraulic diagram, standard 1
Hydraulic diagram, standard 2
Hydraulic diagram, with option components 1
Hydraulic diagram, with option components 2
Hydraulic diagram, with option components 3
Hydraulic diagram, with option components 4
Hydraulic fan modification kit, installing new
Hydraulic oil 1
Hydraulic oil 2
Hydraulic oil cooler outside, cleaning
Hydraulic oil cooling system, specifications 1
Hydraulic oil level, check
Hydraulic oil tank, replacing 1
Hydraulic oil tank, replacing 2
Hydraulic oil tank, specifications 1
Hydraulic oil temperature sensor, replacing
Hydraulic oil, changing
Hydraulic pump, description
Hydraulic pump, replacing 1
Hydraulic pump, replacing 2
Hydraulic pump, specifications 1
Hydraulic quickfit, adjustment
Hydraulic system
Idler gear nut comes off, D13 & D16
Idler, assembly
Idler, description
Idler, disassembly
Idler, measurement of wear
I-ECU, I O list
IG2501, description and measuring
Ignition switch, replacing
Information display, check
Injector sleeves, replacing
Inlet and exhaust system, component location 1
Inlet and exhaust system, component location 2
Inlet and exhaust system, description 1
Inlet and exhaust system, description 2
Inlet and exhaust system, tightening torques 1
Inlet and exhaust system, tightening torques 2
Inlet and exhaust system, tightening torques 3
Inlet and exhaust system, tightening torques 4
Instrument control unit I-ECU, specifications 1
Instruments and controls, front instrument panel 1
Instruments and controls, front instrument panel 2
Instruments and controls, left instrument panel 1
Instruments and controls, left instrument panel 2
Instruments and controls, overview 1
Instruments and controls, overview 2
Instruments and controls, rear instrument panel 1
Instruments and controls, rear instrument panel 2
Instruments and controls, right instrument panel 1
Instruments and controls, right instrument panel 2
Intake actuator, replacing
Intercooler, replacing 1
Intercooler, replacing 2
Keypad, description 1
Keypad, description 2
Keypad, description 3
Keypad, specification 1
Keypad, specification 2
Lead and connector checks
Line rupture valve (arm), assembly
Line rupture valve (arm), specifications 1
Line rupture valve (boom), assembly
Line rupture valve (boom), specifications 1
Line rupture valve pressure, checking and adjusting
Link, description
Longitudinal adjustment cable, replacing
Longitudinal suspension cable, replacing
Lower wiper motor, specifications 1
Lubrication and service chart 1
Lubrication and service chart 2
Lubrication oil consumption, checking
Lubrication system, component locations 1
Lubrication system, component locations 2
MA2301-MA2306, description and measuring
MA2506, description and measuring
MA2507, description and measuring
MA4212, description and measuring
MA9110, description and measuring
MA9111, description and measuring
MA9118, description and measuring
MA9121, description and measuring
MA9122, description and measuring
MA9123, description and measuring
MA9125, description and measuring
Machine model
Machine view 1
Machine view 2
Machine weight, specifications 1
Main control valve, description 1
Main control valve, description 2
Main control valve, disassembly and assembly
Main control valve, port size and tightening torque 1
Main control valve, port size and tightening torque 2
Main relief valve, adjustment
Maintenance service, every 12000 hours
Maintenance service, first 500 hours 1
Maintenance service, first 500 hours 2
Maintenance service, general
Make up valve, description
Measurement conversion tables
Measuring condition
Menu tree
MID128 SID230, description and measuring
MID140 PID251, description and measuring
MID140 PPID1144, description and measuring
MO2501, description and measuring
MO2504, description and measuring
Mode selection, description 1
Mode selection, description 2
New EATS burner
New EATS fuel pump
New E-ECU introduced
New expansion tank
New fuel filter housing
New inlet pipe for air compressor
New log for DPF and ECO mode
New method for fuel system bleeding
New method for installing injectors
New product
New product 1
New product 2
New product 3
New product 4
New product 5
New software for blue smoke issue
New software for E-ECU and ACM
New software for semi auto function and overload pressure
New software, E-ECU & ACM
New software, I-ECU
Oil cooler fan motor, replacing
Oil cooler fan pump, replacing
Oil cooler line bypass valve (check valve), replacing
Oil cooler, replacing
Oil cooler, tightening torques 1
Oil level gauge, replacing
Oil level sensor, changing 1
Oil level sensor, changing 2
Oil sampling, sampling points
Oil sump, tightening torque 1
Option confluence check
Overflow valve, replacing
Overload warning
Overview
Pedal control on X1 (proportional 2-way), installing new
Pilot filter hose and gear pump hose
Port relief valve pressure, measuring and adjusting
Power derating
Power supply E-ECU, description and measuring
PPID1336, description and measuring
Preheating coil, replacing 1
Preheating coil, replacing 2
Pre-heating relay, replacing
Preheating, description
Pressure accumulator, specifications 1
Pressure testing
Product plates
Proportional relief valve, specifications 1
Proportional solenoid valve, description 1
Proportional solenoid valve, specifications 1
Proportional solenoid valve, specifications 2
Proportional solenoid valve, specifications 3
Proportional solenoid valve, specifications 4
Pump double acting for preset, installing new
Pump double acting piping for preset, installing new
Pump double acting piping, installing new
Pump gearbox coupling assembly, replacing
Pump gearbox flange, replacing
Pump regulator, replacing
Pump suction hose and pipe, replacing
Pump, assembly
Pump, disassembly
Pump, installation
Pump, maintenance standard
Pump, troubleshooting
PWM2503, description and measuring
PWM9129, description and measuring
PWM9130, description and measuring
PWM9141, description and measuring
PWM9143, description and measuring
PWM9145, description and measuring
PWM9146, description and measuring
Quick fit in basic machine, installing new
Quick fit piping on arm, installing new
Quick fit piping on arm-UQF, installing new
Quick fit piping on Base machine-UQF
Quick fit piping on boom, installing new
Quickfit system, operation
Quickfit, installation
Quickfit, removal
Quickfit, replacing
Radiator hose upper, replacing
Radiator hoses lower, replacing
Radiator outside, cleaning
Radiator, description 1
Radiator, description 2
Radiator, description 3
Radiator, replacing
Radio with CD and MP3 player, description 1
Radio with CD and MP3 player, description 2
Radio with CD and MP3 player, specifications 1
Radio, description
Radio, installing new
Radio, replacing
RE3302, description and measuring
Rear view camera, replacing
Rear view camera, specifications 1
Rear window, replacing
Rear-view mirror, changing
Recoil spring cylinder seal kit, replacing
Recoil spring grease valve
Recommended lubricants 1
Recommended lubricants 2
Recommended lubricants 3
Regulator, assembly
Regulator, description
Regulator, disassembly
Regulator, maintenance
Relay, description
Relay, specifications 1
Remote control valve (Lever), specifications 1
Remote control valve (pedal), specifications 1
Remote control valve (pedal), specifications 2
Remote control valve (pedal), specifications 3
Removable counterweight cylinder, description
Removable counterweight cylinder, specifications 1
Removable counterweight, installing
Removable counterweight, removing
Replacement parts
Retractable track, installing
Retractable track, removing
Return filter for hammer shear, installing new
Rocker arm shaft, tightening torques 1
Rocker arms, replacing
Rotating beacon, replacing
Rotating beacon, specifications 1
Rotating beacon
Rotator pump, specifications
Rotator valve, adjustment
SAE J1708 1587 Information link, description and measuring 1
SAE J1708 1587 Information link, description and measuring 2
SAEJ1939 CAN7 Control link, descripton and measuring
Safe start and stop, description
Safety net, installing new
Safety when servicing
SE2509, description and measuring
SE2510, description and measuring
SE2514, description and measuring
SE2515, description and measuring
SE2516, description and measuring
SE2527, description and measuring
SE2528, description and measuring
SE2529, description and measuring
Seat cushion, replacing
Seat heater, checking
Seat support, replacing 1
Seat support, replacing 2
Seat, replacing 1
Seat, replacing 2
Seats with heating, installing new
Selection of track shoes
Service connection and programming connection 1
Service connection and programming connection 2
Service methods
Service mode 1
Service mode 2
Service positions
Service
Servo hydraulic block
Servo pump, assembly 1
Servo pump, assembly 2
Servo pump, description
Servo pump, disassembly 1
Servo pump, disassembly 2
Servo pump, replacing 1
Servo pump, replacing 2
Servo pump, specifications 1
Shock reducing valve, description
Shock reducing valve, specifications 1
SID211, description and measuring
SID232, description and measuring 1
SID232, description and measuring 2
Side window, replacing
Slew priority valve, disassembly
Slope rotator piping on boom, installing new
Software parameters, description 1
Software parameters, description 2
Software parameters, description 3
Solenoid valve, description 1
Solenoid valve, inspection
Solenoid valve, replacing
Solenoid valve, specifications 1
Solenoid valve, specifications 2
Solenoid valve, specifications 3
Solenoid valve, specifications 4
Spark plug cable, replacing 1
Spark plug, checking
Spark plug, replacing 1
Speaker, replacing
Specification, filling capacities 1
Specification, filling capacities 2
Specification, filling capacities 3
Specification, filling capacities 4
Spring package, assembly dimension 1
Spring package, assembly dimension 2
Spring package, disassembly
Sprocket, installation
Sprocket, measurement of wear
Sprocket, removal
Sprocket, replacing one
Start lock, description
Start switch, description
Start switch, specifications 1
Starter motor, description
Starter motor, replacing 1
Starter motor, replacing 2
Starter motor, specifications 1
Starter motor, tests
Starter relay, replacing 1
Starter relay, replacing 2
Starter switch, testing
Starting operation
Stop valve
Sun shield front, installing new
Superstructure, installing
Superstructure, removing
Support information
SW9160, description and measuring
SW9161, description and measuring
Swing bath grease, check
Swing gearbox removed, replacing seal
Swing gearbox, assembly
Swing gearbox, description 1
Swing gearbox, description 2
Swing gearbox, disassembly
Swing gearbox, maintenance standard
Swing gearbox, replacing
Swing gearbox, specifications 1
Swing motor, assembly
Swing motor, description
Swing motor, disassembly
Swing motor, replacing
Swing motor, specifications 1
Swing ring gear inner seal, replacing 1
Swing ring gear inner seal, replacing 2
Swing ring gear, description
Swing ring gear, replacing
Swing ring gear, specifications 1
Swing speed
Swing unit, replacing
Switch control on X1 (on off, 2-way), installing new
Switch control on X1 (On Off,1-way), installing new
Tech Tool Service Tool
The authorization for new Anti-theft function
Thermostat, checking
Thermostat, replacing
Thermostat, specifications 1
Thermostat, specifications 2
Thermostat, specifications 3
Thermostat, specifications 4
Tightening torque, cylinder head 1
Tightening torque, fuel system 1
Tightening torque, specifications 3
Tightening torque, specifications 4
Tightening torque, specifications 5
Tightening torque, specifications 6
Tightening torque, specifications 7
Tightening torque, specifications 8
Tightening torque, specifications 9
Tightening torque, specifications 10
Tightening torques, unit injector 1
Tightening torques, unit injector 2
Tightening torques, unit injector 3
Tightening torques, unit injector 4
Tightening torques, valve cover 1
Tightening torques
Tool box assembly, replacing
Tools & equipment
Top roller, description 1
Top roller, description 2
Top roller, measurement of wear 1
Top roller, measurement of wear 2
Top roller, replacing one
Track chain, description
Track gearbox (removed), replacing floating seal
Track gearbox, assembly 1
Track gearbox, assembly 2
Track gearbox, description 1
Track gearbox, description 2
Track gearbox, description 3
Track gearbox, description 4
Track gearbox, disassembly 1
Track gearbox, disassembly 2
Track gearbox, maintenance standard 1
Track gearbox, maintenance standard 2
Track gearbox, replacing cover 1
Track gearbox, replacing cover 2
Track gearbox, specifications
Track gearbox, specifications 1
Track gearbox, specifications 2
Track gearbox, specifications 3
Track gearbox, specifications 4
Track gearbox, specifications 5
Track gearbox, specifications 6
Track gearbox, specifications 7
Track gearbox, specifications 8
Track guard, replacing one
Track guards
Track link, dimension
Track link
Track links, replacing
Track motor relief valve, replacing 1
Track motor relief valve, replacing 2
Track motor, assembly 1
Track motor, assembly 2
Track motor, assembly 3
Track motor, description 1
Track motor, description 2
Track motor, description 3
Track motor, disassembly 1
Track motor, disassembly 2
Track motor, disassembly 3
Track motor, maintenance standard 1
Track motor, maintenance standard 2
Track motor, replacing 1
Track motor, replacing 2
Track motor, specifications
Track motor, specifications 1
Track motor, specifications 2
Track motor, specifications 3
Track motor, specifications 4
Track motor, specifications 5
Track motor, specifications 6
Track running speed 1
Track running speed 2
Track shoe bolts, check
Track shoe, replacing one
Track shoes 1
Track shoes
Track unit, replacing
Track, adjusting track sag
Travel alarm, installing new
Travel alarm, replacing
Travel alarm, specifications 1
Travel alarm
Travel Speed 1
Travel Speed 2
Troubleshooting (10kw)
Troubleshooting 1
Troubleshooting tools
Troubleshooting
Turbocharger, description 1
Turbocharger, description 2
Turbocharger, replacing 1
Turbocharger, replacing 2
Turbocharger, specifications 1
Turbocharger, specifications 2
Turbocharger, specifications 3
Turbocharger, specifications 4
Turbocharger, tightening torques 1
Turbocharger, tightening torques 2
Turbocharger, tightening torques 3
Turbocharger, tightening torques 4
Under cover, superstructure
Undercarriage, description 1
Undercarriage, description 2
Undercarriage, tightening torque 1
Undercarriage, tightening torque 2
Undercarriage, tightening torque 3
Undercarriage, tightening torque 4
Undercarriage, tightening torque 5
Undercarriage, tightening torque 6
Undercarriage, tightening torque 7
Undercarriage, tightening torque 8
Unit injector, replacing
Unit injectors, description
Upper wiper motor, specifications 1
Valves, adjusting 1
Valves, adjusting 2
Valves, adjusting 3
Valves, adjusting 4
VCADS Pro service tool
VCADS Pro socket, measuring
VCADS Pro, MID 128, programming E-ECU 1
VCADS Pro, MID 128, programming E-ECU 2
VCADS Pro, Operations
VCADS Pro, Operations 1
VCADS Pro, Operations 2
VCADS Pro, Operations 3
VCADS Pro, Operations 4
VCADS Pro, Operations 5
VCADS Pro, Operations 6
V-ECU, I O list 1
V-ECU, I O list 2
V-ECU, I O list 3
Vehicle control unit V-ECU, function description 1
Vehicle control unit V-ECU, function description 2
Vehicle information
Vent actuator, replacing
Voltage converter, replacing
Washer check valve
Washer fluid level, check
Water separator, check drain
W-ECU antenna connector
W-ECU, I O list
W-ECU, MID142, changing non-Programd ECU 1
W-ECU, MID142, changing non-Programd ECU 2
W-ECU, MID142, changing pre-Programd ECU 1
W-ECU, MID142, changing pre-Programd ECU 2
Welding on the machine
Windscreen flusher pump, replacing
Windscreen flusher pump, specifications 1
Windscreen wiper, description
Windscreen wiper, replacing controller
Windscreen wiper, replacing switch
Windscreen, replacing
Windshield guard
Windshield, water and dust entering
Wiper controller, description
Wiper controller, specifications 1
Wireless control unit W-ECU, specification 1
Wiring diagram 1
Wiring diagram 2
Wiring diagram SCH01-1
Wiring diagram SCH01-2
Wiring diagram SCH02-1
Wiring diagram SCH02-2
Wiring diagram SCH02-3
Wiring diagram SCH03-1
Wiring diagram SCH03-2
Wiring diagram SCH03-3
Wiring diagram SCH04-1
Wiring diagram SCH04-2
Wiring diagram SCH05-1
Wiring diagram SCH05-2
Wiring diagram SCH07-1
Wiring diagram SCH07-2
Wiring diagram SCH08-1
Wiring diagram SCH08-2
Wiring diagram SCH08-3
Wiring diagram SCH10-1
Wiring diagram SCH10-2
Wiring diagram SCH11-1
Wiring diagram SCH11-2
Wiring diagram SCH12-1
Wiring diagram SCH12-2
Wiring diagram SCH13-1
Wiring diagram SCH13-2
Wiring diagram SCH14-1
Wiring diagram SCH14-2
Wiring diagram SCH15-1
Wiring diagram SCH15-2
Wiring diagram SCH15-3
Wiring diagram SCH16-1
Wiring diagram SCH16-2
Wiring diagram SCH17-1
Wiring diagram SCH17-2
Wiring diagram SCH18-1
Wiring diagram SCH18-2
Wiring diagram SCH20
Wiring diagram SCH22-1
Wiring diagram SCH22-2
Wiring diagram SCH24-1
Wiring diagram SCH24-2
Wiring diagram SCH24-3
Wiring diagram SCH24-4
Wiring diagram SCH30-1
Wiring diagram SCH30-2
Wiring harnesses 1
Wiring harnesses 2
Work lighting, replacing one head lamp assy
Work lights and extra lights, specifications 1
X1 control, description
X1 Line, description
X1 return filter (optional equipment), change
X1 roll switch for proportional control, installing new
X3 control, description
X3 control, X3 valve proportional, installing new
X3 in basic machine, installing new
  • Volvo Excavator EC480D L Service Repair Manual.txt
