Volvo Excavator EC35C Service Repair Manual
Format: PDFTotal Size: 88.66 MB
Machine Type: Excavator
Model: EC35C
- Service Repair Manual
- Electrical Wiring Diagram
- Hydraulic Diagram
- 5009 Pages
1 Volvo EC35C Excavator
Accumulator, description
Air cleaner, description
Antitheft device, first activation of a new A-ECU
Auto idling device, description
Balancing valve on offset cylinder
Cable harnesses, description1
Cable harnesses, description2
Cable harnesses, description3
Cable harnesses, description4
Cable harnesses, description5
Cable harnesses, description6
Cable harnesses, description7
Cable harnesses, description8
Cables, description
Camshaft, description Figure 1
Cleaning prior to repair
Cold start device, description
Component locations
Control levers, description
Coolant
Counterweight, description
Crankshaft, description Figure 1
Cylinder block, description
Cylinder head, description
DC current measurement
DC voltage measurement
Description, general
Diode check procedure
Engine, description1
Engine, description2
Fuel feed pump, description
Fuel filter water separator, description
Fuel tank, description
Fuel, recommendation
Fuse, description
General notes to be observe when working
Hydraulic control unit, H-ECU, functions check
Infrared Thermometer
Injection pump, description
Injectors, description
Instrument panel, description
Instrument panel, operation
LR pressure relief valve, checking and adjusting
Lubricants, specifications
Main control valve, description1 Figure 1
Main control valve, description2
Measuring components
Oil pump, description1
Oil pump, description2
Pistons, description
Product plate, description
Proportional valve, right left selector
Pump, troubleshooting
Repairing hydraulic system
Resistance measurement
Schematic
Service and maintenance
Servo valve, description
Shuttle valve, swing brake
Six way valve, offset optional equipment Figure 1
Slew motor, break release valve1
Slew motor, break release valve2
Slew motor, description1
Slew motor, description2
Swivel joint, description
Thumb kit, description
Timing gear, description Figure 1
Towing, measures
Track motor, troubleshooting
Transporting and lifting the machine
Travel motor, description
Troubleshooting tips
Undercarriage, description
Valve cover, description and operation
Valve mechanism, description
Vehicle ECU functions, check
Welding on the machine
Hydraulic diagram 1 Figure 1
Hydraulic diagram 1
Hydraulic diagram 2 Figure 1
Hydraulic diagram 2
Hydraulic diagram 3 Figure 1
Hydraulic diagram 3
Hydraulic diagram 4 Figure 1
Hydraulic diagram 4
Hydraulic diagram 5 Figure 1
Hydraulic diagram 5
Hydraulic diagram 6 Figure 1
Hydraulic diagram 6
Hydraulic diagram 7 Figure 1
Hydraulic diagram 7
Hydraulic diagram 8 Figure 1
Hydraulic diagram 8
Hydraulic diagram 9 Figure 1
Hydraulic diagram 9
Hydraulic diagram 10 Figure 1
Hydraulic diagram 11 Figure 1
Hydraulic diagram 12 Figure 1
Hydraulic diagram, complete Figure 1
Hydraulic diagram, control pattern selector valve Figure 1
Hydraulic diagram, swing system Figure 1
Hydraulic diagram, travel Figure 1
Wiring diagram 1-1
Wiring diagram 1-2 Figure 1
Wiring diagram 1-2
Wiring diagram 2-1 Figure 1
Wiring diagram 2-1
Wiring diagram 2-2 Figure 1
Wiring diagram 2-2
Wiring diagram 3-1 Figure 1
Wiring diagram 3-1
Wiring diagram 3-2 Figure 1
Wiring diagram 3-2
Wiring diagram 4-1 Figure 1
Wiring diagram 4-1
Wiring diagram 4-2 Figure 1
Wiring diagram 4-2
Wiring diagram 5-1 Figure 1
Wiring diagram 5-1
Wiring diagram 5-2 Figure 1
Wiring diagram 5-2
Wiring diagram 6-1 Figure 1
Wiring diagram 6-1
Wiring diagram 6-2 Figure 1
Wiring diagram 6-2
Wiring diagram 7-1 Figure 1
Wiring diagram 7-1
Wiring diagram 7-2 Figure 1
Wiring diagram 7-2
Wiring diagram 8-1 Figure 1
Wiring diagram 8-1
Wiring diagram 8-2 Figure 1
Wiring diagram 8-2
Wiring diagram 9-1 Figure 1
Wiring diagram 9-1
Wiring diagram 9-2 Figure 1
Wiring diagram 9-2
Wiring diagram 10-1 Figure 1
Wiring diagram 10-1
Wiring diagram 10-2 Figure 1
Wiring diagram 10-2
Wiring diagram 11-1 Figure 1
Wiring diagram 11-1
Wiring diagram 11-2 Figure 1
Wiring diagram 11-2
Wiring diagram, general
Installation Instruction
2nd auxiliary, optional arm length, installing new
2nd auxiliary, standard arm, installing new
Anti theft device
Double acting quick attachement (1400mm
Double acting quick attachment (1800mm
FOG (Falling Object Guard), installing new1
Hose rupture valve, installing new
Hose rupture valve, installing new1
Manuel Quick Attachment
Protecting screen, installing new
Rotating Beacon
Single acting quick attachment (1400mm
Thumb, quick attachment, installing new
Thumb, standard bucket, installing new
Travel alarm
Working light on boom
X1 Flow adjustment potentiometer, installing new
Air cleaner, installing
Air cleaner, removing
Alternator, installing
Alternator, removing
Automatic idling device, installing
Automatic idling device, removing
Battery condition, check
Battery condition, check1
Boom cylinder, installation
Boom cylinder, removal1
Boom cylinder, removal2
Boom, installation
Boom, removal1
Boom, removal2
Bottom roller, installing
Bottom roller, removing
Bucket cylinder, installation
Bucket cylinder, removal1
Bucket cylinder, removal2
Cab platform, installation1
Cab platform, installation2
Cab platform, removal1
Cab platform, removal2
Cab platform, removal3
Cab, main filter, replacing
Cab, roof panel, installing
Cab, roof panel, removing
Check the static brake torque
Compensator valve, replacing1
Compensator valve, replacing2
Component list Fuses
Component list Relays1
Component list Relays2
Component list Switches
Component list, Heating coils
Component list, Lights
Component list, Sensors1
Component list, Sensors2
Component list, Sounders
Component locations1
Component locations2
Component locations3
Component locations4
Component locations5
Component locations6
Component locations7
Component locations8
Component locations9
Component locations10
Component locations11
Compression test
Control lever, installation
Control lever, removal1
Control lever, removal2
Control levers, maintenance standard
Control levers, repairing
Coolant pump, installing
Coolant pump, removing
Coolant, change
Coolant, level, check
Counterweight, fitting
Counterweight, removing
Crankcase breather system, inspect
Cylinder speed
Deviation when travelling straight ahead
Dipper arm cylinder, removal1
Dipper arm cylinder, removal2
Dipper arm, installation
Dipper arm, removal1
Dipper arm, removal2
Directional valve, dozer blade, disassembling spool and replacing seals1
Directional valve, dozer blade, disassembling spool and replacing seals2
Directional valve, drive, disassembling spool and replacing seals1
Directional valve, drive, disassembling spool and replacing seals2
Directional valve, hydraulically operated, disassembling spool 1
Directional valve, hydraulically operated, disassembling spool2
Dust valve, clean
Engine hood, changing gas spring
Engine, installing
Engine, oil level, check
Fan belt and or alternator belt, checking and adjusting tension1
Flow regulation valve, changing1
Flow regulation valve, changing2
FR pressure control valve, checking and adjusting
Front idler, installing
Front idler, removing
Fuel and fuel return hoses, replace
Fuel filter, change
Fuel injectors, inspect clean and test
Fuel pump, installing
Fuel pump, removing
Fuel tank sediment, drain
Fuel tank, installing
Fuel tank, removing
Gear motor, exploded view
Glow plug, installation
Glow plug, removal
H-ECU (hydraulic), replacing pre-Programd ECU
H-ECU (hydraulic), replacing pre-Programd ECU1
Horn, replacing
Hoses for boom-, dipper-, and bucketcylinder, replace
Hoses on boom for X1, X2, X3, replace
Hydraulic oil cooler, installing
Hydraulic oil cooler, removing
Hydraulic oil level, check
Hydraulic oil tank, changing oil
Hydraulic pressure, check
Hydraulic pump, power control adjusting
Hydraulic pump, suction hose and pressure hose, replace
Idling speed, checking and adjusting
Injection pump, removing
Injection timing, checking
Instrument console, installing
Instrument console, removing
Lamp bulb, replacing
Load check valve, replacing1
Load check valve, replacing2
LS (load sense) pressure, checking1
LS (load sense) pressure, checking2
LS-pressure relief valve, replacing1
LS-pressure relief valve, replacing2
Main Control Valve - Disassembly1
Main Control Valve - Disassembly2
Main control valve, installation1
Main control valve, installation2
Main control valve, removal1
Main control valve, removal2
Main control valve, removal3
Measuring condition
Oil pump, replacing1
Oil pump, replacing2
Operator's seat, installing
Operator's seat, removing
Port relief valve pressure, checking and adjusting1
Port relief valve pressure, checking and adjusting2
Preheating coil, replacing
Pump, installation
Pump, removal
Quick coupler lock mechanism, replace
Radiator, installing
Radiator, removing
Rubber track, installing
Rubber track, removing
Seat belt, replace
Seat retention cable, replacement
Seat safety belt, replacing
Secondary pressure limiting valve, replacing1
Secondary pressure limiting valve, replacing2
Service position 2
Service position 3
Service positions
Servo accumulator, removal1
Servo accumulator, removal2
Servo valve, installation
Servo valve, removal1
Servo valve, removal2
Silencer, installing
Silencer, removing
Slew motor, troubleshooting
Sprocket, installation
Sprocket, removal
Starter motor, installing
Starter motor, removing
Swing motor removed, overhaul
Swing motor, installing1
Swing motor, installing2
Swing motor, removing1
Swing motor, removing2
Swing motor, removing3
Swing motor, replacing counterbalance valve1
Swing motor, replacing counterbalance valve2
Swing motor, replacing counterbalance valve3
Swing speed
Thermostat, replacing
Thumb pivot pin, lubricate
Top roller, installation
Top roller, removal
Track motor, installing
Track motor, removing
Track running speed
Track tension, adjusting
Track tension, checking1
Track tension, checking2
Travel gear, dismantling
Travel motor gearbox, changing oil1
Travel motor gearbox, changing oil2
Travel motor, assembly
Travel motor, exploded view
Travel Speed
Travel valve (pedal), installing
Travel valve (pedal), removing
Values, creeping of hydraulic cylinder
Values, cylinder speed
Values, deviation when travelling straight ahead
Values, slewing speed
Values, track running speed
Values, travel speed
Valve covers, fitting new gasket
Valve covers, fitting new gasket1
V-ECU, replacing
Warranty inspection 100 hours
Water separator, drain
Air conditioning unit
Bonnet latch cracks
Boom offset function, time cycle
Boom welding quality improvement
Cab door vibration (especially with steel track option)
Capilarity leakage at the hose crimpings
Dipper arm welding improvement
Engine hunting
Engine Tier 3 introduction
Fuel cap seal improvement
Fuel level gauge indicator
Fuel tank leakage
Grading
Maintenance of Stored Machines
New cabin plastic roof
New coolant
New dashboard
New engine hood hinges
New hydraulic pump pressure hose
New product
New starter switch
Pilot valve coil
Pivot play tolerance and instruction
Platform cracks
Product improvements
Pump companion
Rotating beacon improvement
Seal between cab and platform
Starter switch change
Top roller, installation torque
Transport of machines equipped with roof on the cab
Travel alarm
X1 function information
Special Tools, Misc
GRD G700B LabourTimeGuide
RM Compaction ABG Time Guide
RM Compaction Time guide
RM Paving Systems ABG Time Guide
Special Tools Recommendations
Time Guide Current generation
Alternator, specifications
Cab, tightening torques
Cab, weight
Control valve, torque value
Cooling system, specification
Counterweight, specifications
Dimensions
Engine, capacities
Engine, specifications1
Engine, specifications2
Engine, tighten torques
Fuel tank, volume
Hydraulic control unit, H-ECU, inputs and outputs
Hydraulic control unit, H-ECU, value list
Hydraulic system, tightening torques
Injectors, specification
Instrument panel, specifications
Lifting capacities
Light bulbs, specification
Preheating, specifications1
Preheating, specifications2
Pump, specifications1
Pump, specifications2
Slew motor, specifications1
Slew motor, specifications2
Slew motor, tightening torques
Starter motor, specification
Track motor, specifications
Track motor, tightening torques
V-ECU, IO list
V-ECU, value list1
V-ECU, value list2
Weight
