Volvo Excavator EC250E L Service Repair Manual​
Total Size:
220.29 MB
Language:
English
Brand:
Volvo
Machine Type:
Excavator
EC250E L
  • Service Repair Manual
  • Electrical Wiring Diagram
  • Hydraulic Diagram
  • 5909 Pages
1 Volvo EC250E L
EC250E L Description
ACM, IO list
Air breather, description
Air distribution, description
Alternator, test
Attachment quick coupler
Auto Idle
Automatic engine shut-down
Automatic lubrication system, description
Auxiliary heater, description
Auxiliary heater, principles
Auxiliary start
Battery, storage
BB1 Communication bus, description and measuring
BB2 Communication bus, description and measuring
Bearings
Bleeding air
Boom cylinder, description
Boom, description
Boost control, description
Bottom roller, description
Bucket cylinder, description
Cab air pre-cleaner, description
Cab suspension, description
CareTrack W-ECU, description
CareTrack with anti-theft
CCM, IO list1
CCM, IO list2
Center bypass valve, description
Center passage, description
Change capacities
Charging, description
Check valve, description
Cleaning prior to repair
Component designations
Component list, Fuses
Component list, Heating coils
Component list, Lights
Component list, Miscellaneous
Component list, Relays
Component list, Sensors
Component list, Switches
Conditions when checking
Conflux check valve, description
Connectors, overview
Cooling fan control
Counterweight, description
CU9901, description and measuring
Cylinder, description
Cylinder, troubleshooting
DC–DC converter, description
Description, general
Dipper arm, description
Door, replacing
Driver's seat, description
ECM, IO list
ECO mode, description
Engine start
Engine stops
Engine system
Error codes, build-up
Fan motor, description
Fan motor, troubleshooting
Fan pump, description
Function description
Function description1
Fuse, description
FX1006, description and measuring
FX1054, description and measuring
FX1074, description and measuring
FX1079, description and measuring
General purpose machine electronic control unit GPMECU, function description
GPMECU1, IO list
Grading and lifting control, description
Hammer and shear pedal valve (RCV), replacing
Hammer return filter, description
HE2511, description and measuring
HE2512, description and measuring1
HE2512, description and measuring2
HE2513, description and measuring
Heating system, description
HMICU, IO list
Hoses and tubes
Human machine interface control unit HMICU, function description
HVAC system
Hydraulic pump, description
Hydraulic system
IC, IO list
Idler, description
Ignition switch, description and operation
Ignition switch, replacing
Information display, check
Intermittent wiper and washer
Keypad, description
Lead and connector checks
Limp home
Line rupture valve relief pressure, measurement
Link, description
Load check valve - single, description
MA2301-MA2306, description and measuring
MA2517, description and measuring
MA2519, description and measuring
MA2602, description and measuring
MA9125, description and measuring
Machine view
Main control valve, port size and tightening torque
Make up valve, description
MO2505, description and measuring
Mode selection, description
Overload warning
Overview
Power supply CCM, description and measuring
Power supply ECM, description and measuring
Power supply GPMECU 1, description and measuring
Power supply HMICU, description and measuring
Preheating, description
Pressure testing
Product plates
Proportional solenoid valve, description1
Pump, troubleshooting
PWM2602, description and measuring
PWM9129, description and measuring
PWM9141, description and measuring
PWM9142, description and measuring
PWM9143, description and measuring
PWM9145, description and measuring
PWM9146, description and measuring
PWM9156, description and measuring
PWM9157, description and measuring
Quickfit system, operation
Radio with MP3, description
Radio, description
Radio, replacing
RE3102, description and measuring
RE3502, description and measuring
RE3507, description and measuring
RE3508, description and measuring
RE3511, description and measuring
RE3607, description and measuring
RE3608, description and measuring
Regulator, description
Relay, description
Replacement parts
Rotating beacon, replacing
Rotator pump, description
SAE J1939-1 SubNet 1, description and measuring
Safety when servicing
SE2511, description and measuring
SE2512, description and measuring
SE2513, description and measuring
SE2515, description and measuring
SE2516, description and measuring
SE2526, description and measuring
SE2533, description and measuring
SE2543, description and measuring
SE2544, description and measuring
SE2604, description and measuring
SE9121, description and measuring
SE9122, description and measuring
SE9123, description and measuring
SE9124, description and measuring
SE9125, description and measuring
SE9126, description and measuring
SE9127, description and measuring
SE9128, description and measuring
SE9130, description and measuring
SE9131, description and measuring
SE9132, description and measuring
SE9136, description and measuring
SE9141, description and measuring
SE9142, description and measuring
Seat belt
Selection of track shoes
Service methods
Service mode
Service positions
Service
Servo hydraulic block
Servo pump, description
Single pedal stopper position
Slew flow control valve, description
Solenoid valve, description
Solenoid valve, description1
Starter motor, description
Starter switch, testing
Starting operation1
Starting operation2
Stop valve
Superstructure, installing
SW9161, description and measuring
Swing gearbox, description
Swing motor, description
Swing ring gear, description
System voltage
Tech Tool, operations
Tech Tool, operations1
Tech Tool, operations2
Tech Tool, operations3
Tech Tool, operations4
Tech Tool, operations5
Top roller, description
Track chain, description
Track gearbox, description
Track guards
Track motor, description
Travel alarm, replacing
Travel alarm
Travel Speed
Troubleshooting strategy1
Troubleshooting strategy2
Troubleshooting
Troubleshooting1
Undercarriage, description
Voltage converter, replacing
W-ECU, IO list
Welding on the machine
Windscreen wiper, description
Wire harness layout
Wiring diagram1
Wiring diagram2
X1 control, description
X1 Line, description
X1 Pre-set relief valve, description
X1 Pre-set relief valve, disassembly and assembly
X3 control, description
EC250E L Diagrams
Hydraulic diagram, standard
Hydraulic diagram, with option components
Wiring diagram SCH01-1
Wiring diagram SCH01-2
Wiring diagram SCH02-1
Wiring diagram SCH02-2
Wiring diagram SCH03-1
Wiring diagram SCH03-2
Wiring diagram SCH04
Wiring diagram SCH05-1
Wiring diagram SCH05-2
Wiring diagram SCH07-1
Wiring diagram SCH07-2
Wiring diagram SCH08-1
Wiring diagram SCH08-2
Wiring diagram SCH10-1
Wiring diagram SCH10-2
Wiring diagram SCH11-1
Wiring diagram SCH11-2
Wiring diagram SCH12-1
Wiring diagram SCH12-2
Wiring diagram SCH13-1
Wiring diagram SCH13-2
Wiring diagram SCH14-1
Wiring diagram SCH14-2
Wiring diagram SCH15-1
Wiring diagram SCH15-2
Wiring diagram SCH16-1
Wiring diagram SCH16-2
Wiring diagram SCH17-1
Wiring diagram SCH17-2
Wiring diagram SCH18-1
Wiring diagram SCH18-2
Wiring diagram SCH20-1
Wiring diagram SCH20-2
Wiring diagram SCH25-1
Wiring diagram SCH25-2
Wiring diagram SCH26
Wiring diagram SCH29
Wiring diagram SCH30-1
Wiring diagram SCH30-2
EC250E L Installation Instruction
Arm cylinder hose rupture protection piping, installing new
Boom cylinder hose rupture protection piping with over load signal , installing new
FOG (Falling Object Guard), installing new1
FOG (Falling Object Guard), installing new2
Oil leak line boom piping, installing new
Oil leak line on base machine, installing new
Rear view camera, installing new1
Rear view camera, installing new2
Seats with heating, installing new
Travel alarm, installing new
EC250E L Repair
Accumulator, replacing
AdBlue® DEF dosing injector, replacing
AdBlue® DEF mixing tube, replacing
AdBlue® DEF pump unit filter, replacing
AdBlue® DEF pump unit, filter, replacing
AdBlue® DEF pump unit, replacing
AdBlue® DEF tank, breather filter, replacing
AdBlue® DEF tank, replacing
AdBlue® DEF tank, tank armature, replacing
AdBlue® DEF, draining
Air compressor, air filter, cleaning
Air compressor, air filter, replacing
Air compressor, air tank water, draining
Air conditioner main filter, cleaning
Air conditioner main filter, replacing
Antenna, replacing
Arm parallel conflux valve, disassembly and assembly
Arm regenerating valve, disassembly
Backrest, replacing
Battery, checking
Boom cylinder protecting guard, installation
Boom cylinder protecting guard, removal
Boom cylinder, replacing
Boom holding valve, disassembly
Boom, replacing
Bottom roller, replacing one
Bottom roller, replacing seal
Breather, replacing
Bucket cylinder protecting guard, installation
Bucket cylinder protecting guard, removal
Bucket cylinder, replacing
Bucket flow control valve, disassembly
Bucket regenerating valve, disassembly
Cab door, covers, hinges, joints and locks, lubricating
Cab filter, replacing
Cab prefilter, cleaning
Cab prefilter, replacing
CareTrack antenna, replacing
CareTrack backup battery, replacing
CareTrack battery, replacing
CCM, changing non-Programd ECU
CCM, changing pre-Programd ECU
Center passage, assembly
Center passage, disassembly
Center passage, maintenance standard
Center passage, replacing seal kit
Coasting left and right swing
Component locations
Compression test
Compressor, replacing magnetic clutch (compressor removed)
Control valve, replacing
Coolant freezing point, checking
Coolant pump, replacing
Coolant valve, replacing
Coolant, changing1
Counterweight, fitting
Counterweight, removing
Cylinder speed
Diesel oxidation catalyst, replacing
Diesel particulate filter, check and clean
Diesel particulate filter, regenerating
Digging unit, maintenance
Dipper arm, replacing
Door window, replacing
Earth lead to battery, replacing
ECM (Engine control module), replacing non-Programd
ECM (Engine control module), replacing pre-Programd
EGR Actuator, replacing
EGR cooler, replacing
EGR reed valve, replacing
EGR Venturi tube, replacing
Electric pedal control on X1 (on off), replacing
Electric pedal control on X1 (proportional), replacing
Electrical battery disconnect switch, replacing
Engine air cleaner primary filter, replacing
Engine air cleaner secondary filter, replacing
Engine belt condition, checking
Engine belts, replacing
Engine oil pressure sensor, replacing
Engine rotation speed sensor (crank shaft), replacing
Engine temperature sensor, replacing
Engine wire harness, replacing
Engine, installing
E-tools, NET 8940-00300 Swing ring gear guide pin
E-tools, NET 8940-00420 Replace tool for the swing ring gear
Expansion tank, replacing
Fan motor, assembly
Fan motor, disassembly
Fan pump, assembly1
Fan pump, assembly2
Fan pump, disassembly1
Fan pump, disassembly2
Fan pump, parts inspection
Front idler, replacing one
Fuel filter, replacing
Fuel level sender, replacing
Fuel rail, replacing
General, precautions
GPMECU1, changing non-Programd ECU
GPMECU1, changing pre-Programd ECU
Heater core, replacing
High pressure fuel pipes, replacing
HMICU, changing non-Programd ECU
HMICU, changing pre-Programd ECU
Horn, replacing
Hour meter, replacing
Hydraulic oil drain filter, replacing
Hydraulic oil level, checking1
Hydraulic oil level, checking2
Hydraulic oil servo filter, replacing
Hydraulic oil suction strainer, cleaning
Hydraulic oil temperature sensor, replacing
Hydraulic oil, changing
Hydraulic pump, replacing
Hydraulic quickfit, adjustment
Hydraulic return filter on X1 option circuit, replacing
Idler, assembly
Idler, disassembly
Idler, measurement of wear
Injector sleeves, replacing
Injectors, replacing all
Inlet throttle, replacing
Intake actuator, replacing
Intercooler, replacing
Line rupture valve (arm), assembly
Line rupture valve (boom), assembly
Line rupture valve pressure, checking and adjusting
Longitudinal adjustment cable, replacing
Longitudinal suspension cable, replacing
Lubrication, every 50 hours
Machine view, waste handler
Main relief valve, adjustment
Maintenance service, every 10 hours
Maintenance service, first 500 hours
Maintenance service, general
Make up valve, disassembly
MATRIS and Tech Tool, reading
Measuring condition
NET 8940-00190 Travel motor guide pin
Oil cooler fan pump, replacing
Oil cooler line bypass valve (check valve), replacing
Oil cooler, replacing
Oil level gauge, replacing
Oil level sensor, changing
Oil-bath air cleaner reservoir filter insert, cleaning
Oil-bath air cleaner reservoir oil, changing
Oil-bath air cleaner reservoir oil, checking
Power take-off (PTO), replacing
Pre-heating relay, replacing
Pressure relief valve (PRV), replacing
Pump gearbox coupling assembly, replacing
Pump regulator, replacing
Pump, assembly
Pump, disassembly
Pump, installation
Pump, maintenance standard
Pump, tools
Quickfit, replacing1
Quickfit, replacing2
Radiator and hydraulic oil cooler, cleaning
Radiator, replacing
Rear window, replacing
Rear-view mirror, changing
Recoil spring cylinder seal kit, replacing
Rotator pump, assembly
Rotator pump, disassembly
Rotator valve, adjustment
SCR muffler, replacing
SCR system, dosing test
Seat cushion, replacing
Seat heater, checking
Seat support, replacing
Seat, replacing
Servo pump, assembly1
Servo pump, assembly2
Servo pump, disassembly1
Servo pump, disassembly2
Servo pump, parts inspection
Servo pump, replacing
Side window, replacing
Slew flow control valve, disassembly and assembly
Solenoid valve, inspection
Solenoid valve, replacing
Speaker, replacingSpeaker, replacing
Spring package, disassembly
Sprocket, measurement of wear
Sprocket, replacing one
Starter motor, replacing
Starter motor, tests
Superstructure, removing
Swing bath grease, checking
Swing gearbox oil level, checking
Swing gearbox oil, changing
Swing gearbox, assembly
Swing gearbox, disassembly
Swing gearbox, maintenance standard
Swing gearbox, replacing
Swing motor, assembly
Swing motor, disassembly
Swing motor, replacing plate (brake)
Swing ring gear bearing, lubricating
Swing ring gear cover, installation
Swing ring gear cover, removal
Swing ring gear, replacing
Swing speed
Swing unit, replacing
Test running and checking
Thermostat, replacing
Tool box assembly, replacing
Tools & equipment
Top roller, replacing one
Track gearbox (removed), replacing floating seal1
Track gearbox (removed), replacing floating seal2
Track gearbox oil level, checking
Track gearbox oil, changing
Track gearbox, replacing cover
Track guard, replacing one
Track link, dimension
Track links, replacing
Track motor, assembly
Track motor, disassembly
Track motor, replacing
Track running speed
Track shoe bolts, checking
Track shoe, replacing one
Track tension and condition, checking
Track unit, replacing
Track, adjusting track sag
Travel Speed
Turbocharger, replacing
Valve cover, installing
Valve cover, removing
Valves, adjusting1
Vent actuator, replacing
Waste gate, testing
Water separator filter, replacing
W-ECU, replacing, non-Programd
W-ECU, replacing, pre-Programd
Windscreen flusher pump, replacing
Windscreen wiper, replacing switch
Windscreen, replacing
Work lighting, replacing one head lamp assy
X1 Pre-set relief valve, adjusting
EC250E L Safety
Cautions during operation
CE-marking, EMC-directive
Service position 1
EC250E L Service Bulletins
ECU, functional check
Machine model
New product
New product1
New product2
Oil sampling, sampling points
The authorization for new Anti-theft function
W-ECU antenna connector
EC250E L Special Tools, Misc
RM Compaction ABG Time Guide Old
RM Compaction Time guide old version
RM Paving Systems ABG Time Guide Old
Special Tools Recommendations
Time Guide Current generation
EC250E L Specifications
AdBlue® DEF
AdBlue® DEF1
Adjustable boom, specifications
Alternator, specifications
Auxiliary heater, specifications
Boom cylinder, specifications
Boom, specifications
Cab, weight
Center passage, specifications
Control pattern selector valve, specifications
Coolant
Counterweight, specifications
Dipper arm, specifications
Driver's seat, specifications
Electric horn, specifications
Engine limp home switch, specifications
Engine oil
Engine, specification
Engine, tightening torques
Fuel filler pump, specifications
Fuel system, specifications
Fuel
Grease
Hydraulic oil
Ignition switch, specifications
Inlet and exhaust system, specification
Keypad, specification
Machine weight, specifications
Measurement conversion tables
Preheating, specifications
Proportional solenoid valve, specifications
Proportional solenoid valve, specifications1
Radio with MP3, specifications
Relay, specifications
Remote control valve (pedal), specifications1
Rotating beacon, specifications
Rotator pump, specifications
Servo pump, specifications
Solenoid valve for rotator
Solenoid valve, specifications1
Starter motor, specifications
Swing gearbox, specifications
Swing motor, specifications
Swing ring gear, specifications
Tightening torque, specifications1
Tightening torque, specifications2
Tightening torque, specifications3
Tightening torque, specifications4
Tightening torques
Tightening torques1
Tightening torques2
Tightening torques3
Tightening torques4
Track gearbox, specifications
Track motor, specifications
Track shoes
Travel alarm, specifications
Windscreen flusher pump, specifications
X1 Remote control valve (pedal), specifications1
X1 Remote control valve (pedal), specifications2
  • Volvo Excavator EC250E L Service Repair Manual.txt
