Volvo Excavator EC160E L Service Repair Manual
Format: PDFTotal Size: 542.54 MB
Machine Type: Excavator
Model: EC160E L
- Service Repair Manual
- Electrical Wiring Diagram
- Hydraulic Diagram
- 4234 Pages
1.EC160E
Cautions during operation
CE-marking, EMC-directive
General precautions
Preparations for work
3 way selector valve, specifications
AdBlue DEF information
AdBlue DEF
Adjustable boom, specifications
Alternative fuels
Alternator, specifications
Auxiliary heater, specifications
Boom cylinder, specifications
Boom, specifications
Cab, weight
Center passage, specifications
Change capacities
Control pattern selector valve, specifications
Coolant
Cooling fan rpm, specifications
Counterweight, specifications
Dipper arm, specifications
Dozer blade, specifications
Driver's seat, specifications
Electric horn, specifications
Engine limp home switch, specifications
Engine oil
Engine, specifications
Engine, tightening torques
Fuel system, specifications
Fuel
Grease
Hydraulic oil
Ignition switch, specifications
Inlet and exhaust system, specification
Keypad, specification
Line rupture valve (Boom), tightening torque
Machine weight, specifications
Measurement conversion tables
Preheating, specifications
Proportional solenoid valve, specifications 2
Radio with MP3, specifications
Relay, specifications
Remote control valve (dozer blade), specifications
Remote control valve (Lever), tightening torque
Remote control valve (pedal), specifications 2
Rotating beacon, specifications
Rotator pump, specifications
Servo pump, specifications
Solenoid valve for rotator
Solenoid valve, specifications 2
Starter motor, specifications
Swing gearbox, specifications
Swing motor, specifications
Swing ring gear, specifications
Tightening torque, specifications frame
Tightening torques 1
Tightening torques 2
Tightening torques
Track gearbox, specifications
Track motor, specifications
Travel alarm, specifications
Undercarriage, tightening torque 1
Undercarriage, tightening torque 2
Water separator, specifications
Windscreen flusher pump, specifications
X1 electric on off pedal, tightening torque
1.Standart Parts and Service
2.Engine with Mounting and Equipment
3.Electrical System, Warning System, Information System
4.Power Transmission
7.Wheels,Tracks,Tyre,Hub,Drum
8.Cab
9.Hydraulic System ,Digging,Handling,Grading 1
Descriptions and Troubleshooting
ACM, IO list
AdBlue DEF pump unit diagnostics, description
Air distribution, description
Alternator, testing
Automatic engine shut-down
Auxiliary heater, description
Auxiliary heater, principles
Auxiliary start
BA3101, description and measuring 2
BA3101, description and measuring 3
Battery, storage
BB1 Communication bus, description and measuring
BB2 Communication bus, description and measuring
Bearings
Boom cylinder, description
Boom float position, description 2
Boom, description
Boost control, description
Bottom roller, description
Bucket cylinder, description
Cab suspension, description
CareTrack W-ECU, description
CareTrack with anti-theft
CCM, IO list
Center passage, description 2
Charging, description
Check valve, description
Cleaning prior to repair
Conditions when checking
Connectors, overview
Control lever (dozer blade), replacing
Cooling fan clutch, description
Cooling fan control
Counterweight, description
CU9901, description and measuring 2
Cylinder, description
Cylinder, troubleshooting
DC–DC converter, description
Description, general
Dipper arm, description
Door, replacing
Dozer blade, description
Driver's seat, description
ECM (Engine Control Module), IO list
ECO mode, description
Engine stops
Engine system
Engine, reference values
Error codes, build-up
Function description 2
Function description 3
FX1006, description and measuring
FX1054, description and measuring
FX1074, description and measuring
FX1079, description and measuring
General purpose machine electronic control unit GPMECU, function description
GPMECU1, IO list 2
GPMECU1, IO list
Grading and lifting control, description
Hammer and shear pedal valve (RCV), replacing
Hammer return filter, description
HE2501, description and measuring 1
HE2511, description and measuring
HE2512, description and measuring
HE2513, description and measuring
Heating system, description
HMICU, I O list
HMICU, IO list 2
HMICU, IO list
Hoses and tubes
Human machine interface control unit HMICU, function description
HVAC system
Hydraulic components, storing and transporting
Hydraulic pump, description
Hydraulic system
Hydraulic tank, description
IC, IO list
Idler, description
Ignition switch, description and operation
Ignition switch, replacing
Information display, check
Instrument Cluster (IC), description and measuring
Intermittent wiper and washer
Keypad, description
Lead and connector checks
Limp home
Line rupture valve relief pressure, adjustment
Line rupture valve relief pressure, measurement
Link, description
MA2301-MA2304, description and measuring
MA2517, description and measuring
MA2519, description and measuring
MA9109 Quickfit solenoid valve, description 1
MA9125, description and measuring
Main control valve, port size and tightening torque
MO2505, description and measuring
Mode selection, description
Overload warning
Power supply CCM, description and measuring
Power supply ECM, description and measuring
Power supply GPMECU 1, description and measuring 1
Power supply HMICU, description and measuring 2
Power supply W-ECU, description and measuring 2
Power supply, description
Preheating, description
Pressure testing
Product plates
Proportional solenoid valve, description 2
Pump, troubleshooting
PWM2602, description and measuring
PWM9129, description and measuring
PWM9141, description and measuring
PWM9142, description and measuring
PWM9145, description and measuring
PWM9146, description and measuring
PWM9156, description and measuring
PWM9157, description and measuring
Quickfit system, operation
Radio with MP3, description
Radio, replacing
RE2501, description and measuring 2
RE3101, description and measuring 2
RE3102, description and measuring
RE3502, description and measuring
RE3507, description and measuring
RE3508, description and measuring
RE3511, description and measuring
RE3607, description and measuring
Regulator, description
Relay, description 2
Relay, description
Replacement parts
Rotating beacon, replacing
Rotator pump, description
SAE J1939-1 SubNet 1, description and measuring 1
Safety when servicing
SE2303, description and measuring 2
SE2511, description and measuring
SE2512, description and measuring
SE2513, description and measuring
SE2515, description and measuring
SE2516, description and measuring
SE2533, description and measuring
SE2543, description and measuring
SE2544, description and measuring
SE2604, description and measuring
SE9121, description and measuring
SE9122, description and measuring
SE9123, description and measuring
SE9124, description and measuring
SE9125, description and measuring
SE9126, description and measuring
SE9127, description and measuring
SE9128, description and measuring
SE9130, description and measuring
SE9131, description and measuring
SE9132, description and measuring
SE9136, description and measuring
SE9138, description and measuring
SE9141, description and measuring
SE9142, description and measuring 1
SE9401, description and measuring 2
Seat belt
Service methods 2
Service methods
Service mode
Service positions
Servo hydraulic block
Servo pump, description
Single pedal stopper position
Solenoid valve, description 1
Start lock, description
Starter motor, description
Starter switch, testing
Starting operation
Stop valve
Superstructure, installing
Superstructure, removing
SW3803, description and measuring
SW9161, description and measuring 2
Swing gearbox, description
Swing motor, assembly
Swing motor, description
Swing motor, disassembly
Swing ring gear, description
System voltage
Tech Tool, operations 2
Tech Tool, operations 3
Tech Tool, operations 4
Top roller, description
Track chain, description
Track gearbox, description 2
Track guards
Track motor, description
Travel alarm, replacing
Travel alarm
Travel speed, description
Travel Speed
Troubleshooting
Undercarriage, description
Voltage converter, replacing
W-ECU, IO list
Welding on the machine
Windscreen wiper, description
X1 control, description
X1 Line, description
X3 control, description
Component designations
Component list, fuses
Component list, Heating coils
Component list, lights
Component list, Miscellaneous
Component list, motors
Component list, relays
Component list, sensors
Component list, Switches 2
Hydraulic diagram, standard fig 1
Hydraulic diagram, with option components fig1
Hydraulic diagram, with option components fig2
Wire harness layout
Wiring diagram 2
Wiring diagram SCH01
Wiring diagram SCH01-2
Wiring diagram SCH02
Wiring diagram SCH02-2
Wiring diagram SCH03
Wiring diagram SCH03-2
Wiring diagram SCH04
Wiring diagram SCH04-2
Wiring diagram SCH05
Wiring diagram SCH05-2
Wiring diagram SCH05-3
Wiring diagram SCH07
Wiring diagram SCH08
Wiring diagram SCH08-2
Wiring diagram SCH08-3
Wiring diagram SCH10
Wiring diagram SCH11
Wiring diagram SCH12
Wiring diagram SCH12-2
Wiring diagram SCH13
Wiring diagram SCH14
Wiring diagram SCH14-2
Wiring diagram SCH15
Wiring diagram SCH16
Wiring diagram SCH16-2
Wiring diagram SCH17
Wiring diagram SCH18
Wiring diagram SCH20
Wiring diagram SCH20-2
Wiring diagram SCH21
Wiring diagram SCH24
Wiring diagram SCH30
Wiring diagram SCH30-2
Wiring diagram
Installation Instructions
1 pump single acting piping, installing new
2 pump double acting piping, installing new 1
Boom piping with quickfit, installing new
Diesel coolant heater 5 KW, installing new
Oil leak line boom piping, installing new
Quick fit piping on arm, installing new 2
Quick fit piping on Base machine-UQF
Return filter for hammer shear, installing new
Work light extra, installing new
Work light front, installing new
X3 on on dipper arm, installing new
EXC Insp Report
EXC Inspection Instruction
Inspection Program, Arrival Inspection
Inspection Program, Delivery Instructions
Biodiesel fuel for Volvo CE
Boom Hose Rupture Valve plug leakage
Cab door latch
DEF-AdBlue-AUS32 sampling, method
ECU, functional check
Fuel regulator
How to update software when programming fails
Improved pressure sensor installation
Instrument cluster improvement
Machine model
New AdBlue® DEF tank unit (FX1079 AdBlue DEF quality, temperature and level sensor)
New diesel auxiliary heater timer
New fastener assortment
New product 2
New product 3
New product
New software for DPF change interval
New X1 flow control scheme
Oil analyses
Oil sampling, sampling points
Serial number location on machine components
Software versions for E-series
Special tool Manual
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Special Tools
Time Guide Current generation
