Volvo Excavator EC160B NLC Service Repair Manual
Total Size:
167.68 MB
Language:
English
Brand:
Volvo
Machine Type:
Excavator
EC160B NLC
  • Service Repair Manual
  • Electrical Wiring Diagram
  • Hydraulic Diagram
  • 5517 Pages
1 Volvo EC160B NLC
11 666 140 Multimeter
11 668 006 Extension cable
999 0014 Adapter cable
999 0062 Extension cable
999 3721 Service display unit
999 3893 Adapter cable
999 3894 Template
999 8505 Adapter cable
8920 - 01805 Wire harness checker
8920 - 01806 Wire harness checker
14515484 Multi-pin breaker box
Actuator, air mix door driver
Actuator, foot face driver
Additional counterweight & digging unit
Adjustable boom selector valve
Adjustable boom selector valve1
Air conditioning switch
Air inlet vacuum and temperature switch, description
Alarm, description
Alternator, description (new)
Ambient temperature sensor
Auto manual select switch, description
Auxiliary start
Basic check, Engine
Battery relay, description
Battery, storage
Blower motor
Boom lifting cylinder, troubleshooting
Bottom roller, description
Bucket cylinder, description
Bucket cylinder, troubleshooting
Bucket operation1
Bucket operation2
Center passage, description
Ceramic resistor
Charging, description
Check valve, description
Communication with data buses
Compressor
Condenser
Connecting rod, description
Control system, description
Control units, software functions1
Contronic service display unit, description (I-ECU equipped)
Contronic service display unit, display group 1 general information
Contronic service display unit, display group 1, general information (I-ECU equipped)
Contronic service display unit, display group 2, engine system (I-ECU equipped)
Contronic service display unit, display group 3, electrical system (I-ECU equipped)
Contronic service display unit, display group 4, hydraulic system (I-ECU equipped)
Contronic service display unit, display group 5, program mode (I-ECU equipped)
Contronic service display unit, display group 6, self diagnosis result (I-ECU equipped)1
Contronic service display unit, display group 6, self diagnosis result (I-ECU equipped)2
Contronic service display unit, general
Contronic service display unit, texts and translation summary (I-ECU equipped)
Cooling system, operation
Crankshaft, description
Cylinder head, description
Cylinder, description
Cylinder, description1
Cylinder, troubleshooting1
Cylinder, troubleshooting2
Data buses, function
DC–DC converter, description
Digging unit, description
Dipper arm, description
Dozer blade, description
Dozer blade, hydraulic circuits
Driver's seat, description
Drying filter
Duct temperature sensor
Electric horn, description
Engine block heater, description
Engine characteristic curve
Engine control, operation
Engine oil pressure sensor, description
Engine speed sensor (camshaft), description
Engine speed sensor (crankshaft), description
Engine, description (Deutz D6D EBE2)
Error code information, general (I-ECU equipped)
Error messages on communication and electric system
Error messages on ECUs
Error messages on Engine
Error messages on hydraulic system
Error messages
Evaporator
Examples, hydraulic system
Examples, power transmission
Exhaust system, description
Expansion valve
Foot relief valve (flow sensing valve), description
Fuel Coolant temperature sensor, description
Fuel injection system, description
Fuel level sensor, description
Fuel tank, description
Function of manual air conditioning switch
Heating system, description
Hydraulic diagram, schematic
Hydraulic pump, description
Hydraulic tank, description
Idler, description1
Idler, description2
In-car temperature sensor
Inlet system, description
Instrument panel, description (I-ECU equipped)
Link, description
Logic valve, description
Logic valve, description1
Lower line
Machine display unit (MDU), description
Machine display unit (MDU), display status
Machine display unit (MDU), error code displays
Machine display unit (MDU), status indication
Machine display unit, MDU, functional description
Main line
Manual air conditioning, description
Multimeter
Piston cooling
Pistons, description
Power Take Off (PTO, option), description
Preheating, description
Pump control curves
Pump, troubleshooting
Quickfit system, operation
Radio with tape player, description (new type)
Receiver drier, changing
Refrigerant hoses
Regulator, description
Relay box, description1
Resistance box, description
Return and pump line
Rotator (X3 Line option), hydraulic circuits and principle of operation
Rotator pump, description
Selection of track shoes
Service positions
Servo hydraulic line
Servo hydraulic line1
Servo hydraulic selector valve, description
Servo pump, description
Shuttle valve for hammer and shear - A type
Single pedal stopper position
Slew gearbox, description1
Slew motor, precautions for operation
Slew motor, tools
Slew motor, troubleshooting
Slow blow fuse, description
Software functions, related to electrical system (I-ECU equipped)
Software functions, related to engine
Software functions, related to hydraulic system (I-ECU equipped)
Solenoid valve (2) for hammer and shear 2-pump flow
Solenoid valve, description
Start switch, description
Starter motor, description
Starting operation
Stop valve
Swing gearbox, description1
Swing motor, assembly
Swing motor, description
Swing motor, disassembly
Three point relay
Tool, multi-pin breaker box
Top roller, description1
Top roller, description2
Track chain, description
Track gearbox, description
Track gearbox, principle of operation
Track motor, description
Track motor, operating checks
Track motor, troubleshooting
Travel alarm, description
Troubleshooting (5kw)
Troubleshooting tools
Troubleshooting, diagnosing procedure
Troubleshooting
Undercarriage, description
Valves, description
VCADS Pro service tool
Vehicle control unit V-ECU, function description (I -ECU equipped)
Viscose mount, description
Water temperature sensor
Windscreen wiper, description
Wiper controller, description
Adjustable boom, hydraulic line
Component designations
Electrical circuit, air conditioner heater
Ground connections
Hydraulic circuits, arm in boom raise Figure 1
Hydraulic circuits, arm in conflux Figure 1
Hydraulic circuits, arm out Figure 1
Hydraulic circuits, boom lower Figure 1
Hydraulic circuits, boom raise conflux (internal) Figure 1
Hydraulic circuits, bucket dump Figure 1
Hydraulic circuits, neutral
Hydraulic circuits, ports
Hydraulic circuits, slew (right) Figure 1
Hydraulic circuits, slew priority (slew left arm in) Figure 1
Hydraulic circuits, standard Figure 1
Hydraulic circuits, straight travel (low auto shift) Figure 1
Hydraulic circuits, straight travel arm (straight travel auto shift, arm in) Figure 1
Hydraulic circuits, with option components (Machine serial no. ~ 10805) Figure 1
Hydraulic circuits, with option components (Machine serial no. 10806 ~ ) Figure 1
Positive feed
Wiring diagram SCH01
Wiring diagram SCH01-1 (I-ECU equipped)
Wiring diagram SCH02
Wiring diagram SCH02-1 (I-ECU equipped)1
Wiring diagram SCH02-1 (I-ECU equipped)2
Wiring diagram SCH03
Wiring diagram SCH03-1 (I-ECU equipped)
Wiring diagram SCH04-1 (I-ECU equipped)1
Wiring diagram SCH04-1 (I-ECU equipped)2
Wiring diagram SCH04-2
Wiring diagram SCH05
Wiring diagram SCH05-1 (I-ECU equipped)
Wiring diagram SCH06
Wiring diagram SCH06-1 (I-ECU equipped)
Wiring diagram SCH07
Wiring diagram SCH08
Wiring diagram SCH08-1 (I-ECU equipped)
Wiring diagram SCH09
Wiring diagram SCH09-1 (I-ECU equipped)1
Wiring diagram SCH09-1 (I-ECU equipped)2
Wiring diagram SCH10
Wiring diagram SCH10-1 (I-ECU equipped)1
Wiring diagram SCH10-1 (I-ECU equipped)2
Wiring diagram SCH11
Wiring diagram SCH11-1 (I-ECU equipped)
Wiring diagram SCH12
Wiring diagram SCH12-1 (I-ECU equipped)1
Wiring diagram SCH12-1 (I-ECU equipped)2
Wiring diagram SCH13
Wiring diagram SCH13-1 (I-ECU equipped)1
Wiring diagram SCH13-1 (I-ECU equipped)2
Wiring diagram SCH14
Wiring diagram SCH14-1 (I-ECU equipped)1
Wiring diagram SCH14-1 (I-ECU equipped)2
Wiring diagram SCH15
Wiring diagram SCH15-1 (I-ECU equipped)
Wiring diagram SCH16
Wiring diagram SCH16-1 (I-ECU equipped)
Wiring diagram SCH17
Wiring diagram SCH18
Wiring diagram SCH19
Wiring diagram SCH20
Wiring diagram SCH20-1 (I-ECU equipped)
Wiring diagram SCH21
Wiring diagram SCH21-1 (I-ECU equipped)
Wiring diagram SCH22
Wiring diagram SCH23
Wiring diagram SCH23-1 (I-ECU equipped)
Wiring diagram, Components list and index (I-ECU application)
Wiring diagrams
Installation Instruction
2.3M arm piping with X1
2.6M arm pip W GR manuovre leakfree
2.6m arm piping wiht X3
2.6M arm piping with Q-Fit
2.6M arm piping with X1
2-switch control on X1(on off,2-way)
3.0m arm piping with Q-fit
3.0M arm piping with X1
3.0M arm piping with X3
5.2m Boom piping wiht X3
5.2m boom piping with Q-fit
5.2M boom piping with X1
Anti vandal kit
Arm cyl.hose rupture on 5.2M boom
Block heater, 120V
Block heater, 240V
Boom float position
Brkt for X3 Q Fit H Rupt
CareTrack
Extra pip for Slope Rot on X1
Extra work lamp
Fabirc seat with heating & suspension
FOG
FOPS1
FOPS2
Front rain shield
Front rain shield1
Fuel filler pump - 50Lpm+auto stop
Lower wiper
Net kit - front safety window
Net kit - front safety window1
Oil leak line on 5.2M boom
Oil leak line on base machine
Pedal control on X1(prop 2-way)
Pilot control change
Q-fit piping on base machine
Quick fit S1
Quick fit S6
Radio, installing new
Rotation beacon
Rotation beacon1
Safety net, installing new
Sun shield front, roof, rear
Sunlight protection-roof
Travel alarm, installing new
Travel alarm
With hose rupture protection + over load
X1 modification from 1pump to 2pump
X1 with 2 pump flow
X1 with add retrun filter
X3 piping on base machine
Arm parallel conflux check valve, disassembly
Arm parallel conflux valve, disassembly
Arm regenerating and arm conflux check valve, disassembly and assembly
Attachment bracket, removal
Boom back pressure check valve, disassembly and assembly
Boom holding valve, disassembly
Boom lifting cylinder, disassembly and assembly
Boom lifting cylinder, installation
Boom, installation
Boom, removal
Bottom roller, assembly
Bottom roller, disassembly
Bottom roller, installation
Bottom roller, removal
Bottom roller, replacing seal
Bucket cylinder, disassembly and assembly
Bucket, adjustment of bucket clearance
Center passage, disassembly and assembly
Coasting left and right swing
Connectors
Counterweight, fitting1
Counterweight, fitting2
Counterweight, removing1
Counterweight, removing2
Determining cylinder head gasket
Digging unit, maintenance
Dipper arm cylinder, disassembly and assembly
Dipper arm, installation
Dipper arm, removal
E-ECU, MID 128, changing pre-Programd ECU
Engine mounting
E-tools, NET 8940-00310 Replace tool for the swing ring gear
E-tools, NET 8940-00320 Swing motor guide pin and swing ring gear
Fitting cylinder head
Foot relief valve (flow sensing valve), disassembly
General, precautions
General, tools
Idler, assembly
Idler, disassembly
Idler, installation
Idler, measurement of wear
Idler, removal
Line rupture valve relief pressure, adjustment1
Load check valve, disassembly and assembly1
Load check valve, disassembly and assembly2
Logic valve, disassembly and assembly
Machine view
Main relief valve, adjustment
Measuring condition
NET 8940-00170 Replace tool for the hydraulic tank and fuel tank
NET 8940-00200 Replace tool for the remote control valve joint
NET 8940-00260 Replace tool for the center passage
NET 8940-00290 Track motor guide pin
NET 8940-00400 Replace tool for hydraulic return check valve
Periodic maintenance
Port relief valve pressure, adjustment (when installing or dismantling the line rupture valve)1
Port relief valve pressure, measurement
Port relief valve, adjustment
Port relief valve, disassembly
Pump, assembly
Pump, disassembly
Pump, installation
Pump, maintenance standard
Regulator, disassembly
Regulator, maintenance
Rotator pump, assembly
Rotator pump, disassembly
Rotator valve, adjustment
Seat, replacing
Slew gearbox, assembly
Slew gearbox, disassembly
Slew gearbox, lubrication
Slew gearbox, maintenance standard
Slew gearbox, troubleshooting
Solenoid valve, inspection
Spring package, assembly
Spring package, disassembly
Sprocket, installation
Sprocket, measurement of wear
Sprocket, removal
Straight travel changeover valve, disassembly and assembly
Superstructure, installing
Superstructure, removing
Swing speed
Tool attachment, adjustment
Tools & equipment
Top roller, assembly
Top roller, disassembly
Top roller, installation
Top roller, removal
Top roller, tools for disassembly and assembly
Track chain, installation
Track chain, removal
Track gearbox, assembly
Track gearbox, disassembly
Track gearbox, installation
Track gearbox, removal
Track link, dimension
Track motor, assembly
Track motor, disassembly
Track running speed
Track, adjusting track sag
Travel Speed
Universal quickfit installation
Viscose mount, installation
Viscose mount, removal
Cautions during operation
General precautions
Preparations for work
A1 solenoid valve coil
Air conditioning system
Air conditioning unit1
Arm conflux hose improvement
Arm improvement
Attachment pin improvement
Attachment shims for clearance adjustment of pin joint
Auto belt tensioner improvement
Biodegradable hydraulic oil
Boom and dipper arm improvement
Boom pin improvement
B-series Cab improvements
Bumper improvement
Bushing improvement
Cab door handle improvement
Cab door sliding glass replacement procedure
Cab door striker
Cab roof window waterproofing procedure
Cab weather strip replacement
Cable adjustment of Operator's seat lower slide rail
Cable harness connector, engine
Cable harness for air conditioning system
CD & MP3 player
Check method on engine oil consumption1
Circuit changes of the auxiliary diesel heater
Clamping method improvement of the grease pipes on the dipper arms
Coolant level sensor
Coolant level sensor1
Coolant pump improvement
Coolant pump improvement1
Cylinder liner, specifications
D4 – D7 Alternator improvement
ECU, functional check
Electric connector
Electric horn
Electrical load capacity
Engine coolant temperature
Engine ECU(E-ECU) Change and Conversion kit
Engine oil in the cooling system or coolant in the oil system and external oil or radiator leakage
Engine valve cover gasket improvement
Fan pulley bearing bracket improvement
Fan pulley bearing improvement
Fuel cap improvement
Fuel filler pump service kit
Fuel filter change and relocation
Fuel filter modification instruction
Fuel level sender
Fuel Level
Fuel pump improvement
Fuel tank air breather kit
Fuel tank drain valve
Gas spring
Genuine coolant use
gfsdfgsdfg
Grease nipple commonality
Guidelines of the maximum permissible weight of application tools and load
Handrail improvement
Heat treatment process improvement of the track shoe
High altitude Solution
Hose rupture valve improvement
Hydraulic couplings, description
Hydraulic pipes improvement
Hydraulic pressure, measuring and adjusting
Hydraulic tank air breather
Hydraulic tank air breather1
Idler improvement
Idler wheel and bushing improvement
Improved dipper arm cylinder lock nut
Improved dipper arm cylinder lock nut1
Improved Fuel Level Sender
Improved heater core
Improvement of Main pump hose assembly
Instrument control unit I-ECU, error symptom
Instrument panel improvement
Instrument panel improvement1
Internal leakage
Machine model
Main pump shaft seal leakage
MCV arm holding valve block
MCV logic valve stuck
New air conditioning control switch
New air conditioning control switch1
New bucket spool in main control valve
New cassette radio
New clamp
New Compact Alternator
New Compact Alternator1
New coolant
New drain pipe in the swing drive unit
New fuel filling hoses
New fuel suction cover
New I-ECU introduction
New I-ECU
New label on the fuel sender
New product
New product1
New Radio Antenna
New slew ring gear seal
New software, I-ECU
New software
New starter motor
New track chain
New track guard
New track guard1
New track master pin
New Track roller_lower
New track roller_upper
New track roller_upper1
Oil analyses
Oil pan leakage protection instruction
Oil sampling, sampling points
Plastic shims for Boom Arm pin joints
Poor grading with RCV
Pump seal improvement
Quick coupler for pressure test port leakage
QUICK FIT CHANGES
QUICK FIT CYLINDER CHANGES
Rain visor
Receiver drier pressure switch
Recoil spring improvement
Recoil spring package rod
Repair Instruction for Auto Deceleration Function
Revised method for adjusting valve clearance
Right-hand console box
Solenoid valve for rotator
Solenoid valve improvement
Special wire harness for elevated cabin
Sprocket improvement
Strainer improvement
The checking method of cooling system
Tool box change
Tool box improvement
Track drive unit improvement Floating seal leakage
Track link repair kit
Travel motor relief valve O-ring and Back-up ring
Travel motor
Travel motor1
Travel motor2
Turbocharger checking instruction
Turbocharger
V-ECU Hardware
V-ECU Programming
Water separator improvement
Water separator improvement1
Water separator
Windshield wiper wiping range increase
Wire harness protection cover
X1 Line, hydraulic circuits
X1 stop valve
Special Tools, Misc
Special Tools Recommendations
Time Guide Current generation
2-pump flow selector valve
Air inlet vacuum and temperature switch, specifications
Alternator, specifications (new)
Auto manual select switch, specifications
Battery disconnect switch, specifications
Battery relay, specifications
Boom, specifications
Boost air pressure sensor, specifications
Boost air pressure temperature sensor, specifications
Boost air temperature sensor, specifications
Charged air cooler, specifications
Coolant level sensor, specifications
Counterweight, specifications
Counterweight, tightening torques1
Diesel coolant heater (5kw), specifications
Dipper arm, specifications
Electric horn, specifications
Engine control unit E-ECU, specifications
Engine oil pressure sensor, specifications
Engine speed control switch, specifications
Engine speed sensor (camshaft), specifications
Engine speed sensor (crankshaft), specifications
Engine, specifications
Fuel Coolant temperature sensor, specifications
Fuel level sensor, specifications
Fuel system, specifications
Fuse, specifications1
Fuse, specifications2
Measurement conversion tables
Preheating, specifications
Proportional solenoid valve, specifications
Radio with tape player, specifications (new type)
Regulator, specifications
Relay box, specifications1
Relay box, specifications2
Relay box, specifications3
Resistance box, specifications
Rotator pump, specifications
Safety start relay, specifications
Servo hydraulic selector valve, specifications
Servo pump, specifications
Slew gearbox, specifications
Slew ring gear, specifications
Slow blow fuse, specifications
Start switch, specifications
Starter motor, specifications
Swing motor, specifications
Track gearbox, specifications
Travel alarm, specifications
Vehicle control unit V-ECU, specifications (I-ECU equipped)
  • Volvo Excavator EC160B NLC Service Repair Manual.txt
