Volvo Excavator EC140C L LM Service Repair Manual​
Total Size: 172.55 MB
Language:
English
Brand:
Volvo
Machine Type:
Excavator
EC140C L LM
  • Service Repair Manual
  • Wiring Diagram
  • 5865 Pages
1 Volvo EC140C LM
3 way selector valve, description 1
3 way selector valve, description 2
11 666 140 Multimeter
999 0014 Adapter cable
999 0025 Adapter cable
999 0062 Extension cable
999 3893 Adapter cable
999 3894 Template
8883 0028 Adapter cable
AC compressor belt
Accumulator, replacing
Adjustable boom and cylinder, specifications 1
Adjustable boom cylinder, specifications 1
Adjustable boom cylinder, specifications 2
Adjustable boom cylinder, specifications 3
Air conditioning compressor improvement 1
Air conditioning unit, description 1
Air conditioning unit, description 2
Air conditioning unit, specifications 1
Air conditioning unit, specifications 2
Air distribution, description
Alternator, specifications
Alternator, test
Antenna, replacing
Anti vandal kit
Arm cylinder piping with H-RUPT, 4.6 boom
Arm in operation improvement
Arm parallel conflux changeover valve, disassembly
Arm regenerating valve, disassembly
Attachment shims for clearance adjustment of pin joint
Audio remote controller, description 1
Audio remote controller, description 2
Audio remote controller, specifications 1
Auto Manual pump control switch, specifications 1
Automatic lubrication system, description
Automatic lubrication system, specifications 1
Auxiliary heater
Auxiliary start
Basic check, Engine
Battery condition, check
Battery, specifications 1
Battery, storage
Bearings
Bleeding air
Blower motor
Boom 2 conflux shut-off valve, disassembly
Boom cylinder piping with H-RUPT prot O-L warn
Boom cylinder rod, replacing 1
Boom cylinder rod, replacing 2
Boom cylinder, repacking in machine
Boom holding valve, disassembly and assembly
Boom lifting cylinder, specifications 1
Boom regenerating check valve, disassembly
Boom, description
Boom, installation
Boom, removal
Boom, replacing
Boom, specifications 1
Boost control, description
Booting sequence
Bottom roller, description
Bottom roller, replacing one
Bottom roller, replacing seal
Breather, replacing
Bucket assembly, installation
Bucket assembly, removal
Bucket assembly, replacing
Bucket cylinder rod, replacing
Bucket cylinder, description
Bucket cylinder, installation
Bucket cylinder, removal
Bucket cylinder, repacking in machine
Bucket cylinder, replacing
Bucket cylinder, specifications 1
Bucket drift
Bucket flow control valve, disassembly
Bucket operation 1
Bucket operation 2
Bucket regenerating valve, disassembly
Bucket upper plate
Bushing general, replacing
Cab door latch 1
Cab door latch
Cab door
Cab filter cover sealing
Cab filter, replacing
Cab suspension, description
Cab, prefilter, clean
Cab, prefilter, replace
Cab, weight
Cabin light operation problem
Camshaft, description
CareTrack system, description
CD & MP3 player
CE-marking, EMC-directive
Center passage hose (center passage – motor), replacing
Center passage hose (valve – center passage), replacing
Center passage, description 1
Center passage, description 2
Center passage, disassembly and assembly
Center passage, replacing seal kit
Charge air cooler, description
Charging, description
Check valve, description
Cigar lighter and ashtray change
Circuit breaker, description
Circuit breaker, specification 1
Cleaning prior to repair
Coasting left and right swing
Communication with data buses
Component descriptions
Component designations
Component list, Fuses
Component list, Heating coils
Component list, Lights
Component list, Miscellaneous
Component list, Relays
Component list, Sensors
Component list, Switches
Component locations
Component troubleshooting, checking component
Component troubleshooting, checking subsystem (circuit)
Component troubleshooting, checking wiring harness and input output on ECU
Component troubleshooting, structure, description
Condenser, replacing incl draining and filling 1
Condenser, replacing incl draining and filling 2
Conflux check valve, disassembly
Connecting rod yoke, removal
Connecting rod, description
Connecting special tools
Control levers, description
Control lockout lever switch, specifications 1
Control pattern selector valve, specifications 1
Control system diagram
Control unit, description
Control units changing, precaution
Coolant level, check
Coolant pump improvement
Coolant pump, thermostat, specifications 1
Coolant, change
Coolant, checking anti-freeze resistance 1
Cooling fan clutch, description
Cooling fan clutch
Cooling system, specifications 1
Counterweight, fitting 1
Counterweight, fitting 2
Counterweight, removing 1
Counterweight, specifications 1
Counterweight, specifications 2
Counterweight, specifications 3
Crankshaft, description
CU9901, description and measuring
Current pressure, specifications 1
Cylinder block, description
Cylinder head, description
Cylinder speed
Cylinder, description 1
Cylinder, troubleshooting
D4 – D7 Alternator improvement
Data buses, function
DC–DC converter, description
DC–DC converter, specifications 1
Description, general
Diesel coolant heater (5kw), specifications
Diesel coolant heater, 5KW
Digging unit, maintenance
Dipper arm cylinder rod, replacing
Dipper arm cylinder, removal
Dipper arm cylinder, repacking in machine
Dipper arm cylinder, specifications 1
Dipper arm, description
Dipper arm, installation
Dipper arm, removal
Dipper arm, replacing
Dipper arm, specifications 1
Display unit, content
Door window, replacing
Dozer blade cylinder, specifications 1
Dozer blade, description
Dozer blade, specifications 1
Earth lead to battery, replacing
ECC (MID146) Electronic climate control unit, active measuring conditions
ECC (MID146) Electronic climate control unit, passive measuring conditions
ECC control unit, replacing 1
ECC control unit, replacing 2
ECU, functional check
Electric connector
Electric horn, description
Electric horn, specifications 1
Electric horn
Electrical distribution box 1
Electrical distribution box 2
Electrical distribution box 3
Electrical system, specifications 1
Electronic climate control unit ECC, description 1
Electronic climate control unit ECC, specification 1
Electronic climate control unit ECC, specification 2
Emergency engine speed control switch, specifications 1
Engine - Pump control, specification 1
Engine characteristic curve
Engine control unit E-ECU, specifications 1
Engine heater 120V
Engine heater 240V
Engine hood, replacing
Engine mounting 1
Engine mounting 2
Engine mounting nut
Engine Protection
Engine speed control switch, replacing
Engine speed control switch, specifications 1
Engine starting in the manual mode
Engine system
Engine wire harness, replacing
Engine, identification
Engine, oil level, check
Engine, specifications 1
Engine, tightening torques
Engine, weights 1
Engine, weights
Error codes, build-up
Examples, hydraulic system
Examples, power transmission
Exhaust system, description
Expansion tank
Extra work lamp
Flywheel, weight 1
Flywheel, weight
FOG
FOPS
Frame and track unit, specifications 1
Front idler, replacing one
FU6, description and measuring
Fuel cap improvement
Fuel feed pump, description
Fuel filler pump, description
Fuel filler pump, specifications 1
Fuel filter extra (water separator element), check drain
Fuel filter extra, replacing
Fuel filter housing, replacing
Fuel filter, change
Fuel filters, replacing
Fuel pressure, specifications 1
Fuel pump (Tier 3) manufacturing process improvement 1
Fuel system, tightening torques 1
Fuel system, tightening torques 2
Fuel tank sediment, drain
Fuel tank, description
Fuel tank, specifications 1
Fuse, description
Fuse, specifications 1
Fuse, specifications 2
General, precautions
General, tools
G700B Labour Time Guide Foreword.pdf
Hammer and shear selector and shuttle valve, description
Heater core, replacing
Heating system, description
Hoses and tubes
Hour counter improvement
Hour counter, description
Hour counter, specifications 1
HVAC system 1
HVAC system
Hydraulic circuits, ports
Hydraulic diagram ports, standard
Hydraulic diagram ports, with option components
Hydraulic diagram, schematic
Hydraulic diagram, standard
Hydraulic diagram, with option components
Hydraulic oil cooling system, specifications 1
Hydraulic oil level, check
Hydraulic oil tank, replacing
Hydraulic oil, changing
Hydraulic oil
Hydraulic pressure, check
Hydraulic pump, description
Hydraulic pump, replacing
Hydraulic pump, specifications 1
Hydraulic quickfit, description 1
Hydraulic quickfit, description 2
Hydraulic system
Hydraulic tank air breather
Hydraulic tank, description
Hydraulic tank, specifications 1
Idler wheel and bushing improvement
Idler, assembly
Idler, description 1
Idler, description 2
Idler, disassembly
Idler, measurement of wear
I-ECU, clock and rear view camera
Injector wire harness for D4E D6E D7E
Injector yoke retention bolt loose
Injector, replacing one
Injectors, description
Injectors, specifications 1
Inlet system, description
Instrument ECU change
Instrument ECU Improvement
Instruments and controls, rear instrument panel 1
Instruments and controls, rear instrument panel 2
Instruments and controls, right instrument panel 1
Instruments and controls, right instrument panel 2
Intake actuator, replacing
Intercooler, replacing
Keypad, description 1
Keypad, description 2
Keypad, description 3
Keypad, specification 1
Language 1
Language 2
Line rupture valve (arm), specifications 1
Line rupture valve (boom), specifications 1
Line rupture valve relief pressure, adjustment
Link, description
Logic valve, specifications 1
Lower wiper motor, specifications 1
MA2301-MA2304, description and measuring
MA4216, description and measuring
MA9103, description and measuring 1
MA9104, description and measuring 1
MA9105, description and measuring
MA9106, description and measuring
MA9107, description and measuring 1
MA9109 Quickfit solenoid valve, specifications 1
MA9109 Quickfit solenoid valve, specifications 2
MA9118, description and measuring
MA9166, description and measuring
Machine model
Machine view
Machine weight, specifications
MAIN MENU
Main pump noise and damage
Main pump, proportional reducing valve
Main relief valve, adjustment
Main relief valve, assembly
Main switch, replacing
Measurement conversion tables
Measuring condition
Measuring, general
Menu tree
MID 128 SID 230, description and measuring
MID 140 PID 251, description and measuring
MID 140 PPID 1144, description and measuring
Mode selection, description
New engine oil cooler
New engine oil level sensor
New product 1
New product 2
New product
New software 1
New software for anti-theft and cold starting improvement
New software release 1
New software release 2
New software, V-ECU
New software
Oil analyses
Oil cooler, replacing 1
Oil level gauge, replacing
Oil sampling, sampling points
Operating hour parameter
Overload warning device, description
Pipe and hose (pump - valve), replacing
Piping
Piston cooling
Piston rings, description
Pistons, description
Poor straight travel operation
Pop-up screen
PPID1336, description and measuring
Pre cleaner
Preheating, description
Preheating, specifications 1
Pressure accumulator, specifications 1
Pressure testing
Product plates
Proportional solenoid valve, description 1
Proportional solenoid valve, specifications 1
Proportional solenoid valve, specifications 2
Proportional solenoid valve, specifications 3
Pump double acting for preset, installing new
Pump double acting piping for preset, installing new
Pump gearbox coupling assembly, replacing
Pump regulator, replacing
Pump suction hose and pipe, replacing
Pump, assembly
Pump, disassembly
Pump, installation
Pump, maintenance standard
Pump, tools
Pump, troubleshooting
PWM2601, description and measuring
PWM9101, description and measuring 1
PWM9102, description and measuring
PWM9105, description and measuring 1
PWM9106, description and measuring 1
PWM9129, description and measuring 1
PWM9130, description and measuring
QF piping
Quickfit piping, 2.5m arm
Quickfit piping, 4.6m boom
Quickfit, installation
Quickfit, removal 1
Quickfit, removal
Radiator, replacing
Radio with CD and MP3 player, specifications 1
Radio with CD player
Radio with tape or CD player, descriptions
Radio with tape or CD player, specifications 1
Radio with tape player, description
Radio, installing new
Radio, replacing 1
Radio, replacing 2
Radio, replacing 3
RE2501, description and measuring 1
RE3301, description and measuring 1
Rear view camera
Rear window, replacing
Rear-view mirror, changing
Recoil spring grease valve
Recoil spring package rod
Recommended special tools
Regulator, description
Relay, description
Relay, specifications 1
Relay, specifications 2
Relay, specifications 3
Relay, specifications 4
Remote control valve (dozer blade), specifications 1
Remote control valve (Lever), specifications 1
Remote control valve (pedal), specifications 1
Replacement parts
RM Compaction ABG Time Guide Old 2009-01-26
Foreword
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Compaction Time guide old version 2008-10-27
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Paving Systems ABG Time Guide Old 2009-01-26
Foreword
Screeds
Hydraulics
Structural
Drive system
Electrical
Rotating beacon, description
Rotating beacon, replacing
Rotating beacon, specifications 1
Rotating beacon
Rotator pump, description
Rotator pump, specifications 1
Rotator valve, adjustment 1
Rotator valve, adjustment 2
Rotator valve, specifications 2
Rotator valve, specifications 3
SAE code, conversion for component designation, E-ECU
SAE code, conversion to component designation, ECC
SAE code, conversion to component designation, I–ECU
SAE code, conversion to component designation, V-ECU
SAE J1708 1587 information link, description and measuring
Safety net, installing new
Safety when servicing
SE2202, description and measuring
SE2205, description and measuring
SE2302, description and measuring
SE2501, description and measuring
SE2502, description and measuring
SE2507, description and measuring
SE2508, description and measuring
SE2601, description and measuring
SE9121, description and measuring
SE9123, description and measuring
SE9124, description and measuring
SE9125, description and measuring
SE9126, description and measuring
SE9127, description and measuring
SE9128, description and measuring
SE9129, description and measuring
SE9131, description and measuring
SE9132, description and measuring
SE9138, description and measuring
Seat support, replacing
Seat, replacing
Selection of track shoes
Service methods
Service mode
Service positions
Service
Servo pump, description
Servo pump, parts inspection
Servo pump, replacing
Servo pump, specifications 1
SETUP
SID211, description and measuring
SID232, description and measuring
SID240, description and measuring
SID253, description and measuring
SID254, description and measuring
Side window, replacing
Slew gearbox, description 1
Slew gearbox, lubrication
Slew gearbox, maintenance standard
Slew gearbox, troubleshooting
Slew motor, adjustment
Slew motor, lubrication and air purging
Slew motor, troubleshooting
Slew motor, wear and damage limits for repair
Slew priority valve, disassembly
Slew ring gear, description
Sloap rotation pip
Slop rot pip 4.6 boom with X3
Slop rotation pip on-off
Slop rotation piping on base machine on-off
Solenoid valve, description 1
Solenoid valve, inspection
Solenoid valve, replacing
Solenoid valve, specifications 1
Solenoid valve, specifications 2
Solenoid valve, specifications 3
Speaker, replacing
Special tool catalog 2014-11-17
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Spring package, assembly dimension 1
Spring package, assembly dimension 2
Spring package, assembly dimension 3
Spring package, disassembly
Sprocket improvement
Sprocket, measurement of wear
Sprocket, replacing one
Start lock, description
Start switch, description
Start switch, specifications 1
Starter motor lead to battery, replacing
Starter motor, description
Starter motor, replacing
Starter motor, specifications 1
Starter motor, tests
Starter relay, replacing
Starter switch (engine start switch), replacing
Starter switch, testing 1
Starter switch, testing 2
Starting operation
Superstructure, installing
SW9160, description and measuring
SW9161, description and measuring
Swing bath grease, check
Swing brake, description
Swing gearbox removed, replacing seal
Swing gearbox removed, replacing shaft
Swing gearbox, assembly
Swing gearbox, description 2
Swing gearbox, disassembly
Swing gearbox, replacing
Swing gearbox, specifications 1
Swing motor, assembly
Swing motor, description
Swing motor, disassembly
Swing motor, principle of operation
Swing motor, replacing plate (brake)
Swing motor, specifications 1
Swing ring gear inner seal, replacing 1
Swing ring gear inner seal, replacing 2
Swing ring gear seal 1
Swing ring gear seal 2
Swing ring gear, specifications 1
Swing speed
Swing stop on a slope improvement
Swing unit, replacing
Terminology
Theft protection
Thermostat, checking
Tightening torque, specifications 3
Time Guide Currrent generation 2014-12_12
Time Guide Old generation 2014-12-12
Time Guide Previous generation 2014-12_12
Tool box change
Tools & equipment
Top roller, assembly
Top roller, description
Top roller, disassembly
Top roller, replacing one
Track chain, description 1
Track chain, description 2
Track chain, measurement of wear 1
Track chain, measurement of wear 2
Track chain, wear limit
Track gearbox, assembly
Track gearbox, description 1
Track gearbox, description 2
Track gearbox, description 3
Track gearbox, disassembly
Track gearbox, specifications 1
Track guard, replacing one
Track link, dimension 1
Track link, dimension 2
Track link, dimension 3
Track links, replacing
Track motor, description
Track motor, specifications 1
Track motor, troubleshooting
Track running speed
Track shoe bolts, check
Track shoe, replacing one
Track shoes
Track unit, replacing
Track, adjusting track sag
Travel alarm, description
Travel alarm, replacing
Travel alarm, specifications 1
Travel motor auto travel speed shifting malfunction improvement
Travel motor
Travel Speed
Troubleshooting (5kw)
Troubleshooting 1
Troubleshooting tools
Troubleshooting, diagnosing procedure
Troubleshooting
Turbocharger, description
Undercarriage, description
Undercarriage, tightening torque 1
Undercarriage, tightening torque 2
Undercarriage, tightening torque 3
Upper wiper motor, specifications 1
Valve clearance, check adjust
Valve system specifications 1
Valves, description
VCADS Pro service tool
Vehicle control unit V-ECU, specifications 1
Vehicle control unit V-ECU, specifications 2
Vent actuator, replacing
Vibration damper, description
Warranty inspection 100 hours
Warranty inspection
Washer check valve
Washer fluid level, check
Washer pump improvement 1
Water separator drain valve
Water separator housing, replacing
W-ECU (MID142) Wireless control unit, passive measuring conditions
Windscreen flusher pump, specifications 1
Windscreen wiper, description
Windscreen wiper, replacing switch 1
Windscreen, replacing
Windshield, water and dust entering
Wiper controller, description
Wiper controller, specifications 1
Wireless control unit W-ECU, specification 1
Wireless control unit W-ECU, specification 2
Wiring diagram SCH01
Wiring diagram SCH02
Wiring diagram SCH03
Wiring diagram SCH04
Wiring diagram SCH07
Wiring diagram SCH08
Wiring diagram SCH10
Wiring diagram SCH11
Wiring diagram SCH12 1
Wiring diagram SCH12 2
Wiring diagram SCH13
Wiring diagram SCH14
Wiring diagram SCH15 1
Wiring diagram SCH15 2
Wiring diagram SCH16
Wiring diagram SCH17
Wiring diagram SCH18 1
Wiring diagram SCH18 2
Wiring diagram SCH20
Wiring diagram SCH21
Wiring diagram SCH22
Wiring diagram SCH23
Wiring diagram SCH24 1
Wiring diagram SCH24 2
Wiring diagram
Wiring harnesses
Work lighting, replacing one head lamp assy 1
X1 operating improvement
X1 pip 1p double act
X1 pip, 1-switch 1W
X1 pip, 2-switch 2W
X1 roll switch
X1 stop valve
X1 with 1 pump flow for single act only
X3 control, description
  • Volvo Excavator EC140C L LM Service Repair Manual.txt
