Volvo Dump Truck A40G Service Repair Manual
File Size: 234.51 MBFile Format: PDF
Machine Type: Dump Truck
Manual Type: Service Repair Manual, Electrical Wiring Diagram, Hydraulic Diagram
Model: Volvo A40G Dump Truck
Number of Pages: 6119 Pages
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/A40G Intro
Descriptions
ACM, IO list
A–frame
Anti-theft device, description
ATC, description
Automatic brake description
Automatic central lubrication
Auxiliary steering backwards, description
Axle suspension, description
Back-up alarm, description
Basic check, transmission
Basic checks
Bleed pump, user instructions
Brake cooling oil tank, description
Brake cooling system, description
Braking system, description
Cab description
Cab heat ventilation timer, description
Cab, lifting points
CE-marking, EMC-directive
Charge air cooling system, description
Clutches, brakes and planet stages, description
Complete machine, descriptions
Component descriptions
Component position
Compression brake, description
Connectors, position
Control system, description
Control system
Control unit, description
Control units, voltage supply
Cooling fan, description
Cooling system
Cylinder block, description
Damping cylinder, description
Data bus system
Delayed stop, description
Diagnostic tools, description
Display, description
Door open, description
Dosage valves, description
Drive axles, description
Driver's seat, description
Drivetrain, description
Dump function, description
E-2016
ECM, IO list
Electrical cabling and connectors, checking
Electronic accelerator pedal, description
Electronic control system, special tool measuring, component 1
Electronic control system, special tool measuring, ECU
Electronic control system, special tool measuring, general
Engine- and cab heater, description
Engine and transmission overspeed protection, description
Engine hood, description
Engine, sensor locations
Entrance lighting, description
Error code and warning levels
Error codes, build-up
Error codes, showing
Error detection
External activation of central warning, description
Foot brake valve, description
FOPS and ROPS
Frame joint, description
Frame, description
Fuel level, description
Gear selector
Gear shifting strategy
General vehicle electronics
Heat exchanger, description
Hoist cylinder, description
Hydraulic pump, description
Hydraulic system component location
Hydraulic tank, description
Inclination, description
Information display unit, summary
Information display, cycle info
Information display, engine
Information display, general
information display, machine information
Information display, service
Information display, settings
Infrared Thermometer
Leak detector 951 1207, new model
Load and dump brake, description
Load unit frame
Load weighing, description
Lock-up clutch
Lubrication and oil system
Main oil filter
Maintenance rear axle
Measuring, general
Oil level
Oil pump, description
Oil temperature
Parameter settings
Preheating description
Pressure build up, steering
Pressure check connections, description
Pressure monitor, description
Pressure monitor, description1
Product plates
Propeller shaft, description
PT Transmission
PTO (Power Take Off), description
Pump unit, description
Red extra central warning, description
Retarder, description
SAE J1708 (Information bus)
Safety when handling AdBlue DEF
Seat belt supervision, description
Sensors and monitors, description
Sensors, description
Service mode, description
Service
Shift valve, description
Speed limitation, description
Start electronics, description
Starter motor, description
Steering system, description
Stop electronics, description
Supervision data bus communication, description
Suspension, description
System voltage, description
Tailgate, wire, description
Tech Tool, operations 1
Thermostat, secondary system, description
Torque converter
Tractor unit frame
Transfer gearbox, description
Transmission, description
Vehicle speed, description
Warning screens, general
Wheel brake, description
Working lights, description
1 Wiring diagrams
Brake cooling oil system, diagram
Compressed air diagram
Electrical component list
Hydraulic diagram PT
Hydraulic diagram, brake system
Hydraulic diagram, complete 1
Hydraulic diagram, complete 2
Hydraulic diagram, complete 3
Wiring diagram WD201
Wiring diagram WD202
Wiring diagram WD203
Wiring diagram WD204
Wiring diagram WD205
Wiring diagram WD206
Wiring diagram WD207
Wiring diagram WD208
Wiring diagram WD240
Wiring diagram WD241
Wiring diagram WD242
Wiring diagram WD243
Wiring diagram WD244
Wiring diagram WD301
Wiring diagram WD302
Wiring diagram WD303
Wiring diagram WD304
Wiring diagram WD305
Wiring diagram WD306
Wiring diagram WD307
Wiring diagram WD308
Wiring diagram WD309
Wiring diagram WD310
Wiring diagram WD311
Wiring diagram WD312
Wiring diagram WD313
Wiring diagram WD314
Wiring diagram WD315
Wiring diagram WD316
Wiring diagram WD317
Wiring diagram WD318
Wiring diagram WD319
Wiring diagram WD320
Wiring diagram WD321
Wiring diagram WD322
Wiring diagram WD323
Wiring diagram WD324
Wiring diagram WD325
Wiring diagram WD327
Wiring diagram WD328
Wiring diagram WD329
Wiring diagram WD330
Wiring diagram WD401
Wiring diagram WD402
Wiring diagram WD403
Wiring diagram WD501
Wiring diagram WD502
Wiring diagram WD503
Wiring diagram WD504
Wiring diagram WD801
Wiring diagram WD802
Wiring diagram WD803
Wiring diagram WD804
Wiring diagram WD805
Wiring diagram WD901
Wiring diagram WD902
Wiring diagram WD903
Wiring diagram WD904
Wiring diagram WD905
Installation Instructions
Air cleaner, heavy duty, EON, installing new
Body heating, installing new
Decal set, installing new
Frame extension, installing
Hauler chassis, hydraulic, controlled by lever, installing new
Hauler chassis, hydraulic, controlled by switch, installing new
Radio, installing new
Strobe light, installing new 1
Towing winch
88830227-88830228 User instruction
Accumulator, discarding
Accumulator, replacing
Actuator, variable turbocharger, replacing
AdBlue® DEF tank, breather filter, replacing
AdBlue®DEF hoses, replacing
AdBlue®DEF nozzle, replacing
AdBlue®DEF pump unit, components, replacing
AdBlue®DEF pump unit, replacing
AdBlue®DEF quality, checking
AdBlue®DEF tank, tank armature, replacing
AdBlue®DEF, draining
Aftertreatment fuel dosing unit, replacing
Aftertreatment fuel nozzle, replacing
Air drier cartridge, replacing
Air in fuel system, checking
Alternative exit, checking
Automatic central lubrication filter, replacing
Axle breather filters, replacing
Axle support, trailer unit
Basic service
Bleeding air
Bogie beam, changing rubber bushing on removed beam
Bogie beam, changing rubber spring, one side (front)
Brake cooling circulation, function check
Brake cooling oil level, checking
Brake cooling oil tank breather filter, replacing
Brake cooling oil, changing
Brake cooling tank return oil filter and magnetic rods, cleaning and replacing
Brake disc, replacing
Brake system pressure oil filter, replacing
Brake system, basic check
Brake system, bleeding
Cab asbestos filter, replacing
Cab heating cab ventilation timer, pump, replacing
Cab main filter, replacing
Cab prefilter, replacing
Camshaft setting, checking
Camshaft, replacing
CareTrack antenna, replacing
Centre gear , removing and fitting
Centre gear, removing and fitting 1
Component position 1
Component position 2
Component position 3
Component position 4
Component position 5
Component position 6
Component position 7
Component position 8
Component position 9
Component position 10
Component position 11
Component position 12
Component position 13
Component position 14
Component position 15
Compressed air system, component location
Compression test
Compressor operator’s seat, replacing
Control units, changing
Coolant freezing point, checking
Cooling fan motor, radiator, checking high rpm
Crankshaft, axial clearance, checking
Cross stay, installing
Cross stay, removing
Cross stay, rubber bushing, replacing
Diesel particulate filter, check and clean
Door lock, replacing
Door window, replacing
Door, gas spring, replacing
Door, replacing
Dosage valve, checking internal leakage
Draining Filling pump, user instructions
Drive axle oil, changing
Drive axles leakage, checking
Drive belts, checking
Dropbox and front axle, breather filter, replacing
Dropbox leakage, checking
Dropbox oil, changing
Dropbox rubber bushing, replacing
Dropbox, installing
Dropbox, removing
Dump body alternative, lowering 1
Dump body angle sensor, calibration
Dump function, checking pressure
Dump lever, changing
E1763, Drain hose
E-2005
E-2517
E-2519
E-2525
E-2526
E-2529
E-2534
EATS cooling fan, replacing 1
EATS Heat protection, checking
EGR cooler, cleaning
EGR cooler, pressure test
EGR cooler, replacing
EGR valve, replacing
EGR venturi tube, cleaning
Electric hood pump, changing
Engine air cleaner primary filter, replacing
Engine air cleaner secondary filter, replacing
Engine and cab heater fuel filter, replacing
Engine and dropbox mounts, checking
Engine and transmission, removing
Engine Gateway, MID 165, replacing non-Programd ECU
Engine gateway, MID 165, replacing pre-Programd ECU
Engine hood, installing
Engine hood, removing
Engine, basic check
Evaporator, cleaning
Exhaust aftertreatment system fuel flow, checking
Exhaust heated load body, checking, cleaning and greasing
Extra fuel prefilter, replacing
Filling lubricant
Fire suppression system, checking
Flasher lamp front glass or bulb, replacing
Flasher lamp sidelight glass or bulb, replacing
Foot brake valve, replacing
Frame extension bolted joints torque, checking
Frame extension, removing
Frame joint bearing, replacing (machine separated)
Frame joint bearings clearance, checking
Fuel filters, replacing
Fuel pump, inspection
Fuel system extra fuel pre- filter, draining
Fuel tank sediment, draining
Headlight, complete, changing (high beam 1 pc.) incl. setting
Headlight, complete, changing (low beam 1 pc.) incl. setting adjustment
Headlights, adjusting
Heat control valve, replacing
Heat control, replacing
Heater core, replacing
High pressure air system, pressure, checking
Hitch, installing
Hitch, removing
HMIM, MID 140, changing non-Programd ECU
HMIM, MID 140, changing pre-Programd ECU
Hoist cylinder bearing, changing
Hoist cylinder, installation
Hoist cylinder, removal
Hood pump, oil, changing
Hub reduction, installing
Hub reduction, removing
Hydraulic couplings
Hydraulic oil level, checking
Hydraulic oil, changing
Hydraulic pump, installation
Hydraulic pump, installing
Hydraulic pump, removal
Hydraulic pump, removing
Hydraulic system, bleeding
Hydraulic tank return oil filter and magnetic rod, cleaning and replacing
Hydraulic tank sediment, draining
Injector sleeves, replacing 1
Input shaft seal, replacing
Input shaft, seal, replacing 1
Lamp bulb, replacing
Load and Dump brake, function check 1
Load and Dump brake, servo pressure, checking
Load body position indicator, replacing
Load body rubber cushions clearance, checking
Load cell, replacing
Load weighing cable to load cell, checking
Load weighing, calibration
Lubrication points, central lubrication
Lubrication pressure rocker arm shaft, check
Lubrication, every 250 hours
Lubrication, every 500 hours
Lubrication, every 1000 hours
Lubrication, every 2000 hours
Maintenance service, every 10 hours
Maintenance service, every 12000 hours
Maintenance service, first 100 hours
MS.Internal.Documents
Operator's seat, air bellows, replacing
Operator's seat, installing KAB
Operator's seat, removing 1
Operator's seat, shock absorber, replacing
Output shaft 6-wheel drive, sealing and bearing, replacing
Output shaft, bearing and seal, replacing
Overflow valve, replacing
Parking brake function, checking
Parking brake pads, checking
Parking brake, adjusting
Parking brake, basic check
Parking brake, manually releasing 1
Pressure check connections, description 1
Pressure release 1
Pressure release
Pressure testing
Propeller shaft movement, checking
Propeller shafts, removing
Protecting plate, removal
Pump regulator, checking
Radiator, adjusting
Radiator, cleaning
Rear window, replacing
Refrigerant, draining
Relief Cut-in pressure, adjusting 1
Relief Cut-in pressure, check 1
Restoring from serviceposition
Restoring of the machine
Rotation speed sensor, replacing
Rubber connection, suction line, replacing
Rubber cushion, replacing
SCR system, dosing test
Secondary coolant pump, replacing
Secondary steering, checking
Service brake disc wear, checking
Service points
Service position 1
Shift valve, checking
Side window, rear, replacing
Side window, replacing
Stall speed, checking
Starter motor, replacing
Steering and dumping valve, removed, reconditioning
Steering cylinder bearings clearance, checking
Steering cylinder, installing
Steering cylinder, removing
Steering cylinder, replacing bearings
Steering gear, check.and adj.
Steering gear, replacing
Steering joint bearing, checking
Steering joint bearing, replacing (Hitch removed)
Steering joint, replacing bearings
System test
Tail lamp, replacing
Tech Tool, operations braKES
Tech Tool, operations suspension
Transmission breather filter, replacing
Transmission oil filter, replacing
Transmission oil pressure, checking
Transmission oil, changing
Transmission, installing
Transmission, removing
Turbocharger, inspection
Turbocharger, replacing
Tyre wear and air pressure, checking
Unit injector, replacing
V2-ECU, MID 249, changing non-Programd ECU
V2-ECU, MID 249, changing pre-Programd ECU
Vacuum pump, connection
Vacuum pump, disconnection
Valves, adjusting 1
Venturi tube, checking
Wear indicator, adjusting
Wheel alignment
Wheel, installing
Wheel, removing
Windscreen, replacing
Checking function
Environment
Recovering and towing
Rules when handling tyres
Safety when working on pressurized systems
Service position 1
Transporting the machine
Brake cooling pump
New Articulated Haulers F- and G-series
New inlet pipe for air compressor
New tip lever
TechTool 2 communication
Transmission, inspection form
Tyres, various types
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Special Tool Recomendation
AC system, specifications
Accumulator, specification
AdBlue®DEF
Alternator, specifications
Brake cooling system, capacities
Brake cooling system, specification
Brake system (with air-controlled parking brake)
Brake system (with hydraulically controlled parking brake)
Cabin, specification
Compressed-air system, specifications 1
Coolant
Cooling fan, specification
Cooling system, specification
Drive axles, tightening torques
Drive shafts, specifications
Drive train capacities
Drive train, specification
Dropbox, specifications
Dump lever, specifications
Engine hood, specification
Engine, capacities
Engine, specification
Fire Suppression System, tightening torques
Flywheel, tightening torques
Frame extension, specification
Frame joint, tightening torque
Frame, weight
Fuel system, specifications
Grease
Hitch, specifications
Hoist cylinder, specification
Hydraulic pressure, specifications 1
Hydraulic pumps, specifications 1
Hydraulic system, capacities
Inlet and exhaust system, specification
Lighting, specifications
Load carrier, specifications
Parking brake, specifications
Parking brake, tightening torque
Power outlet, specifications
Protective plate, weight
Pump unit, specification
Starter motor, specification
Steering gear, specifications
Steering linkage, tightening torque
Tailgate, specifications
Tightening torque
Tipping system, specification
Voltage converter, specification
Weights
Wheel, tightening torque
Time guide current generation
