Volvo Dump Truck A40F FS Service Repair Manual
File Size: 224.24 MB
File Format: PDF
Machine Type: Dump Truck
Manual Type: Service Repair Manual, Wiring Diagram
Model: Volvo A40F FS Dump Truck
Number of Pages: 6471 Pages
1 Descriptions
Air cleaner, description
Anti-theft device, description
Automatic brake description
Automatic central lubrication
Auxiliary steering backwards, description
Axle suspension, description
Back-up alarm, description
Basic check, transmission
Basic checks
Brake cooling system, description
Braking system, description
Cab description
Cab, lifting points
CE-marking, EMC-directive
Charge air cooling system, description
Clutches, brakes and planet stages, description
Component descriptions
Component locations engine
Component position
Connectors, position
Control system, description
Control system
Control unit, description
Control units, voltage supply
Cooling need, overview illustration
Cooling system, principle illustrations
Cooling system
Crank mechanism, description
Cylinder block, description
Cylinder head, description
Cylinder liners and pistons, description
Damping cylinder, description
Data bus system
Delayed stop, description
Description, complete machine
Diagnostic tools, description
Display, description
Door open, description
Dosage valves, description
Drive axles, description
Driver's seat, description
Drivetrain, description
Dump function, description
Electrical cabling and connectors, checking
Electronic accelerator pedal, description
Electronic control system, special tool measuring, component
Electronic control system, special tool measuring, ECU
Electronic control system, special tool measuring, general
Engine- and cab heater, description
Engine and transmission overspeed protection, description
Engine hood, description
Engine, description 1
Engine, identification
Engine, sensor locations
Error causes
Error code and warning levels
Error codes, build-up
Error codes, showing
Error detection
Exhaust pressure governor
External activation of central warning, description
Foot brake valve, description
FOPS and ROPS
Frame joint, description
Frame, description
Fuel feed pump, description
Fuel flow, description
Fuel level, description
Full Suspension, description
Gear selector
Gear shifting strategy
Gearshifting, description
General vehicle electronics
Heat exchanger, description
Hoist cylinder, description
Hydraulic pump flow regulation, description 1
Hydraulic pump, description
Hydraulic tank, description
Inclination, description
Information and warning decals
Information display, cycle info
Information display, engine
Information display, general
information display, machine information
Information display, service
Information display, settings
Infrared Thermometer
Load and dump brake, description
Load unit frame
Load weighing, description
Lock-up clutch
Lubrication and oil system
Machine status hardware software
Main oil filter
Maintenance
Measuring, general
Oil level
Oil pump, description
Oil temperature
Oil trap, description
Parameter settings
Preheating description
Pressure build up, steering
Pressure monitor, description 1
Propeller shaft, description
Protecting plate, description
PT Transmission
PTO (Power Take Off), description
Pump unit, description
Recovering and towing
Red extra central warning, description
SAE J1708 (Information bus)
Seat belt supervision, description
Sensors and monitors, description
Sensors, description
Service mode, description
Service position 2
Service
Shift valve, description
Software versions and ECUs part number, list
Start electronics, description
Starter motor, description
Steering system, description
Stop electronics, description
Supervision data bus communication, description
Suspension cylinder, description
System voltage, description
Thermostat, secondary system, description
Torque converter
Tractor unit frame
Transfer gearbox, description
Transmission, description
Troubleshooting strategy 1
Turbocharger, description
Unit injectors, description
VCADS Pro tests
Vehicle speed, description
Warning screens, general
Wheel brake, description
Working lights, description
Installation Instructions
Automatic central lubrication, installing new
Back up alarm, installing new
Body heating, installing new
Body heating, tube end, installing new
Body height extension, installing new
Decal set, installing new
Electric interface, installing new
Emergency stop, installing new
Engine and cab heater, diesel powered, installing new
Hauler chassis, hydraulic, controlled by lever, installing new
Hauler chassis, hydraulic, controlled by switch, installing new
High Sulphur Fuel Conversion kit, installing new
Lamp retainer, installing new
Load sensing 25 Mpa, installing new
Lube hoses, installing new
Lube kit, tailgate, installing new
No hydraulic function, installing new
On board weighing, installing new
Open center 25 Mpa, installing new
Radio, installing new
Rear view mirrors, adjustable, electric heated, installing new
Strobe light, installing new
Sun blind, installing new
Trailer brake, installing new
Work light extra front, installing new
Work light halogen, installing new
Work light LED, installing new
Accumulator bank, installation
Accumulator bank, removal
Accumulator, discarding
Accumulator, installation 1
Accumulator, precharge pressure, checking and adjusting 1
Accumulator, precharge pressure, checking and adjusting2
Accumulator, removal 1
Accumulator, replacing
Accumulator, suspension system, discarding
Accumulator, suspension system, overhaul
Actuator, variable turbocharger, replacing
Aftertreatment support unit (ASU), replacing
Air drier, drier cartridge, replace
Air in fuel system, checking
Air pump flow, checking
Air pump, oil level, checking
Air pump, oil, changing
Atomization unit, replacing
Automatic central lubrication, filter, cleaning replacing
Auxiliary heater, replacing
Axles and dropbox, leaks, checking
Battery, charging state, electrolyte level, cables and connections, especially connections at starter motor, check
Bleeding air
Brake cooling circulation, function check
Brake cooling oil tank, breather filter, replacing
Brake cooling oil tank, oil, change
Brake cooling oil tank, return oil filter, replace and magnetic rods, clean
Brake cooling oil, level, check
Brake system, basic check
Brake system, bleeding
Brake system, pressure oil filter, replace
Burner, replacing
Cab heating cab ventilation timer, pump, replacing
Cab, asbestos filter, replacing
Cab, main filter, replacing
Cab, prefilter, replace
Camshaft setting, checking
Camshaft, replacing
CareTrack antenna, replacing
Centre gear , removing and fitting 1
Centre gear, removing and fitting 1
Checking and adjusting the longitudinal differential lock
Check-measuring electric components
Compression test 1
Compression test
Condensor, cleaning (with compressed air).
Control system, reconditioning
Control units, changing
Coolant, change
Cooling fan motor, radiator, checking adjusting high rpm
Cooling fan, return oil filter, replacing
Crankshaft, axial clearance, checking
Cross stay, installing bogie susp
Cross stay, removing bogie susp
Cross stay, rubber bushing, replacing bogie susp
Cylinder compression, PC test
Dog clutch 6x6, checking and adjusting
Door lock, replacing
Door window, replacing
Door, gas spring, replacing
Door, replacing
Dosage valve, checking internal leakage
DPF flame sensor, replacing
Drive axles, oil, change
Dropbox, installing
Dropbox, oil, replace
Dropbox, removing
Dump body alternative, lowering 1
Dump body angle sensor, calibration
Dump function, checking pressure
Dump lever, changing
ECC, MID 146, changing non-programmed ECU
ECC, MID 146, changing pre-programmed ECU
EGR cooler, cleaning
EGR cooler, pressure test
EGR cooler, replacing
EGR valve, replacing
EGR venturi tube, cleaning 1
Electric hood pump, changing
Engine- and cab heater, extra fuel tank, breather filter, replacing
Engine- and cab heater, fuel filter, replace
Engine and transmission, removing 1
Engine hood, installing
Engine hood, removing
Engine mounts and dropbox mounts, checking
Engine, air cleaner, main filter, replacing.
Engine, air cleaner, secondary filter, replacing.
Engine, air pre-cleaner, check clean
Engine, basic check
Evaporator, cleaning
Exhaust aftertreatment fuel injector, replacing
Exhaust aftertreatment system fuel flow, checking
Exhaust aftertreatment system, fuel pump, replacing
Fan pump, installation
Fan pump, removing
Feed pressure, PC test
Filling lubricant
Foot brake valve, replacing
Forced Raising lowering, Full suspension 1
Frame joint bearing, replacing (machine separated)
Frame joint bearings, clearance, check
Front guard plate, removing
FS-cylinder, rubber bearings, check, after first 4000 hours, then after every 1000 hours.
Fuel pump, inspection
Fuel system, extra fuel pre-filter, change
Fuel system, extra fuel pre-filter, drain
Fuel tank, axles, gearbox and dropbox, breather filter, replacing
Fuel tank, sediment, drain. Shorter interval as needed.
Headlights, adjusting
Heat control valve, replacing
Heat control, replacing
Heater core, replacing
High pressure air system, pressure, checking
Hitch, installing
Hitch, removing
HMIM, MID 140, changing non-programmed ECU
HMIM, MID 140, changing pre-programmed ECU
Hoist cylinder bearing, changing
Hoist cylinder, installation
Hoist cylinder, removal
Hood pump, oil, changing
Hub reduction, installing
Hub reduction, removing
Hydraulic cooling fan control, PC test
Hydraulic couplings
Hydraulic cylinder bushing, suspension system, replacing
Hydraulic cylinder, suspension system, overhaul
Hydraulic oil tank, breather filter, replacing
Hydraulic oil tank, oil, replace if system is filled with mineral oil or Volvo Biodegradable hydraulic oil 46. If system is filled with other biologically degradable hydraulic oil, replace every 2000 hour.
Hydraulic oil tank, return oil filter, replace, and magnetic rods, clean
Hydraulic oil tank, sediment drain
Hydraulic pump, installing 1
Hydraulic pump, max pressure, checking and adjusting
Hydraulic pump, removing 1
Hydraulic system, bleeding
Ignition cables, change
Injector shut off, manual
Injector sleeves, replacing
Input shaft seal, replacing
Input shaft, seal, replacing 1
Load and Dump brake, function check
Load and dump brake, servo accumulator, checking
Load and Dump brake, servo pressure, checking
Load body position indicator, replacing
Load body, exhaust heated, check clean grease 1
Load body, rubber cushions, clearance, check
Load weighing, calibration
Lubrication oil consumption, checking
Lubrication points, central lubrication
Lubrication pressure rocker arm shaft, check
Lubrication
Maintenance service, every 12000 hours
Manual lowering
MATRIS and Tech Tool, reading
Oil-bath air cleaner's reservoir, cleaning and oil changing.
Oil-bath air cleaner's reservoir, filter insert, cleaning.
Oil-bath air cleaner's reservoir, oil, checking.
Operator's seat, air bellows, replacing
Operator's seat, installing
Operator's seat, removing
Operator's seat, shock absorber, replacing
Output shaft 6-wheel drive, sealing and bearing, replacing
Overflow valve, replacing
Parking brake , replacing brake caliper
Parking brake pads, check
Parking brake, adjusting
Parking brake, basic check
Parking brake, manually releasing 1
Position sensor front, replacing
Position sensor rear, replacing 1
Position sensor, complete replacement
Pressure check connections, description BRAKES
Pressure release brakes
Pressure testing
Propeller shaft, play, checking
Propeller shafts, removing
Protecting plate, removal
Pump regulator, checking
Radiator, adjusting
Radiator, clean (from fan side with compressed air)
Rear guard plates, removing
Rear window, replacing
Relief Cut-in pressure, adjusting
Relief Cut-in pressure, check brakes
Relieve pressure
Restoring of the machine
Rotation speed sensor, replacing 1
Rubber cushion, replacing
Secondary coolant pump, replacing
Secondary steering, checking
Service brake, brake disc wear, check
Service points
Shift valve, checking
Side window, rear, replacing
Side window, replacing
Spark plug, checking
Spark plug, replacing 1
Stall speed, checking
Starter motor, replacing
Steering and tipping valve, installation 1
Steering cylinder bearings, clearance, check
Steering cylinder, installing
Steering cylinder, removing
Steering cylinder, replacing bearings
Steering gear, check.and adj.
Steering gear, replacing
Steering joint bearing, replacing (Hitch removed)
Steering joint bearings, first check of steering joint bearings after 6000 hours. Thereafter every 2000 hours.
Steering joint, replacing bearings
Suspension cylinder, installation 1
Suspension cylinder, removal
Suspension system, bleeding air
System test
Tech Tool, operations 1
Thermostat, replacing
Transmission oil filter, replace
Transmission, changing oil
Transmission, installing
Transmission, removing
Turbocharger, replacing
Unit injector, replacing
V2-ECU, MID 249, changing non-programmed ECU
V2-ECU, MID 249, changing pre-programmed ECU
Vacuum pump, connection
Valves, adjusting 1
VCADS Pro, Operations
Waste gate actuator, replacing
Waste gate, testing
Wear indicator, adjusting
W-ECU, MID142, changing non-programmed ECU
W-ECU, MID142, changing pre-programmed ECU
Wheel alignment
Wheel brake, replacing
Wheel, installing
Wheel, removing
Windscreen, replacing
Checking function
Environment
Rules when handling tyres
Safety when working on pressurized systems
Service position 3
Alternator Improvment
Brake cooling pump
Central lubrication
Clearance in lower steering joint
Connection rod self leveling system
Crank shaft pulley adapter
Diesel powered engine and cab heater, improved diodes DI8703 and DI8704
Front LED parking lights
FS Cylinder
Hydraulic connector leakage
Hydraulic cylinders Full Suspension
Idler gear nut comes off, D13 & D16
Long pressure build-up time in Load & Dump brake
Main cab cable harness, chafing
New Articulated Haulers, A35F and A40F
New cab heater element
New Caretrack WECU2
New D16 Thermostat
New Engine V-ribbed Belts
New fuel filter housing
New full suspension sensor
New main cab cable harness
New method for installing injectors
New needle bearings in planet stage 1
New pressure sensors
New rear camera system
New rear LED flasher
New tip lever
Parking brake switch
Power cable clamping
Premature wear on diff lock control piston seal
Radio band setting
Restrictor Washer in FS Distribution block
Rubber bearing A-frame
Selector fork in final drive, ARB H axles
Service kit Overhung Tailgate
Transmission, inspection form
Tyres, various types
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
AC system, specifications
Accumulator, specification
Alternator, specifications
Axle, specifications
Brake cooling system, specification
Brakes, specifications
Cabin, specification
Compressed-air system, specifications
Coolant
Cooling system, specification
Drive axles, tightening torques
Drive train capacities
Drive train, specification
Dropbox, specifications
Dump lever, specifications
Engine hood, specification
Engine oil
Engine, capacities
Exhaust aftertreatment system, specifications
Exhaust aftertreatment system, tightening torques
Flywheel, tightening torques
Frame joint, tightening torque
Fuel system, specifications
Hitch, specifications
Hoist cylinder, specification
Hydraulic pressure, specifications 1
Hydraulic pump brake cooling, specification
Hydraulic system, capacities
Intercooler, specifications
Lighting, specifications
Oil sump, tightening torque
Parking brake, specifications
Power outlet, specifications
Product identification plates
Secondary steering, specification 1
Starter motor, specification
Steering gear, specifications
Steering linkage, tightening torque
Suspension cylinder specifications
Tightening torque
Tipping system, specification
Turbocharger, specifications
Turbocharger, tightening torques
Voltage converter, specification
Weights
Wheel, tightening torque
Wiring
Compressed air diagram fig 1
Electrical component list
Fuses, description
Hydraulic diagram fig 1
Hydraulic diagram PT fig 1
Hydraulic diagram, brake system fif 1
Hydraulic diagram, brake system1
Hydraulic diagram, complete fig 1
Hydraulic diagram
Hydraulic main diagram fig 1
Wiring diagram WD201
Wiring diagram WD202
Wiring diagram WD203
Wiring diagram WD204
Wiring diagram WD205
Wiring diagram WD206
Wiring diagram WD207
Wiring diagram WD220
Wiring diagram WD240
Wiring diagram WD241
Wiring diagram WD242
Wiring diagram WD301 1
Wiring diagram WD301 2
Wiring diagram WD301 4
Wiring diagram WD302
Wiring diagram WD302-1
Wiring diagram WD303
Wiring diagram WD304 2
Wiring diagram WD304 3
Wiring diagram WD305 2
Wiring diagram WD306 2
Wiring diagram WD306 3
Wiring diagram WD306 4
Wiring diagram WD307
Wiring diagram WD308
Wiring diagram WD309
Wiring diagram WD309-1
Wiring diagram WD310
Wiring diagram WD311
Wiring diagram WD311-1
Wiring diagram WD312
Wiring diagram WD313 2
Wiring diagram WD313 3
Wiring diagram WD314
Wiring diagram WD315
Wiring diagram WD315-1
Wiring diagram WD315-2
Wiring diagram WD316
Wiring diagram WD316-1
Wiring diagram WD316-2
Wiring diagram WD317
Wiring diagram WD318
Wiring diagram WD319
Wiring diagram WD319-1
Wiring diagram WD319-2
Wiring diagram WD320
Wiring diagram WD320-1
Wiring diagram WD321
Wiring diagram WD321-1
Wiring diagram WD322
Wiring diagram WD322-1
Wiring diagram WD323
Wiring diagram WD324
Wiring diagram WD325
Wiring diagram WD326
Wiring diagram WD327
Wiring diagram WD328
Wiring diagram WD401
Wiring diagram WD402
Wiring diagram WD403
Wiring diagram WD403-1
Wiring diagram WD501
Wiring diagram WD502
Wiring diagram WD503
Wiring diagram WD504
Wiring diagram WD701
Wiring diagram WD702
Wiring diagram WD702-1
Wiring diagram WD801
Wiring diagram WD801-2
Wiring diagram WD802
Wiring diagram WD803
Wiring diagram WD804
Wiring diagram WD805
Wiring diagram WD901
Wiring diagram WD902
Wiring diagram WD902-1
Wiring diagram WD902-2
Wiring diagram WD902-3
Wiring diagram WD902-4
Wiring diagram WD903
Wiring diagrams
  • Volvo Dump Truck A40F FS Service Repair Manual.txt
