Volvo Dump Truck A40E FS Service Repair Manual
File Size: 151.38 MBFile Format: PDF
Machine Type: Dump Truck
Manual Type: Service Repair Manual, Electrical Wiring Diagram, Hydraulic Diagram
Model: Volvo A40E FS Dump Truck
Number of Pages: 3994 Pages
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/Descriptions
1.3 1.4 Setting to zero, saved error codes warnings
1.3-1.4 Saved error codes warnings
Air cleaner, description
Air conditioning AC, basic principles
Air conditioning unit, operation FIG 1
Air intake and filter
Air suspension for operator´s seat, changing
Air suspension operator's seat, adjusting
ATC, description
Axles and brakes
Basic checks
Brake cooling oil system, description
Braking system, description
Cab description
Cab, lifting points
Camshaft, description
Charge-air cooling
Component description BRAKES
Component descriptions
Component position
Connectors, overview
Connectors, position
Control unit, description
Control units, voltage supply
Coolant pump, description
Cooling unit, description 1
Crank mechanism, description
Cylinder block, description
Cylinder head, description
Cylinder liner, description
Damping cylinder
Data bus system
Digital input and output signals
Drawings of E-tools
Drive axles, description
Drivetrain, description
Dump lever, description
Electrical cabling and connectors, checking
Electronic control system, special tool measuring, component
Electronic control system, special tool measuring, E–ECU
Electronic control system, special tool measuring, general
Electronic control system, special tool measuring, I-ECU
Electronic control system, special tool measuring, T-, V- and V2-ECU
Electronic control system, special tool measuring, transmission PT
Engine Protection
Engine, identification
Error causes
Error code and warning levels
Error codes, build-up
Error codes, showing
Error detection
Exhaust pressure governor
Foot brake valve, description
Frame joint, description
Frame, description
Fuel feed pump, description
Fuel flow, description
Full Suspension, description
General vehicle electronics
Hoist cylinder, description
Hydraulic and servo systems, description
Hydraulic pump, description
Hydraulic tank, description
Hydraulics
Infrared Thermometer
Initial display and settings
Instruments and controls, climate control panel
Instruments and controls, control panel
Instruments and controls, main instrument
Intercooler, description
Lifting machine
Load and dump brake, description 1
Load and Dump brake, function check
Machine status hardware software
Maintenance
Measuring, general
Non-return valve function in steering and dumping valve
Oil trap, description
Operating information and service
Parking brake, description
Parking brake, manually releasing
Pistons, description
Pressure build-up, engine-dependent pumps, description 1
Pressure check connections, description 1
Propeller shaft, description
Proportional valve, description
Protecting plate, description
PWM5901, description
Radiator, description
Recovering and towing
Refrigerant for air conditioning
Refrigerant, draining
Relieve pressure
Repair instructions AC
Retarder pedal, description
Retarder, description
SAE J1708 (Information bus)
Service display unit, general
Service display unit, summary
Service position 2
Service
Software versions and ECUs part number, checking
Software versions and ECUs part number, general
Software versions and ECUs part number, list
Steering system, description
Suspension cylinder, description 1
Thermostat, description
Transfer gearbox, description
Transmission, cut-away drawing
Transmission
Turbocharger, description
Unit injectors, description
V2007.3.0, change specification
V2007.4.0, change specification
V2007.5.0, change specification
V2007.6.0, change specification
V2008.1.0, change specification
V2008.3.0 V2008.3.1, change specification
V2008.4.0, change specification
V2009.4.0, change specification
Valve mechanism, description
VCADS Pro service tool, general
VCADS Pro tests
VCADS Pro, Calibrating
VCADS Pro, Error codes
VCADS Pro, Programming
VCADS Pro, Test
Warranty inspection
Wheel brake, function description
Working lights, description
Brake cooling oil system, diagram - 1
Components, list and positions
Compressed air diagram
Compressed air diagram-1
Compressed air diagram-2
Compressed air diagram-2-2
Hydraulic diagram PT
Hydraulic diagram PT-1
Hydraulic diagram PT-1-1
Hydraulic diagram, brake system 2
Hydraulic diagram, brake system 2-2
Hydraulic diagram, brake system 3
Hydraulic diagram, brake system 3-3
Hydraulic diagram, brake system-1
Hydraulic diagram, complete 2 fig 1
Hydraulic diagram, complete 3 fig 1
Hydraulic diagram, complete fig 1
Hydraulic diagram, complete fig 3 fig 1
MS.Internal.Documents
Wiring diagram A01
Wiring diagram A02 1
Wiring diagram A02
Wiring diagram A03 1
Wiring diagram A03
Wiring diagram A04
Wiring diagram A04-1
Wiring diagram A05
Wiring diagram A05-1
Wiring diagram A06
Wiring diagram A07
Wiring diagram A07-1
Wiring diagram A08
Wiring diagram A09
Wiring diagram A09-1
Wiring diagram A10
Wiring diagram A11
Wiring diagram A11-1
Wiring diagram A12
Wiring diagram A13
Wiring diagram A14
Wiring diagram A15
Wiring diagram A16
Wiring diagram A17
Wiring diagram A18
Wiring diagram A18-1
Wiring diagram A18-2
Wiring diagram A18-3
Wiring diagram A19
Wiring diagram A20
Wiring diagram A21
Wiring diagram A21-1
Wiring diagram A21-2
Wiring diagram A22
Wiring diagram A23 1
Wiring diagram A23
Wiring diagram A24
Wiring diagram A25
Wiring diagram A27
Wiring diagram A28
Wiring diagram A31
Wiring diagram A32
Wiring diagram A33
Wiring diagram A33-1
Wiring diagram A34
Wiring diagram A34-1
Wiring diagrams
Installation Instructions
Air cleaner, installing
Back up alarm, installing new
Engine heater, installing new
On board weighing, installing new 1
Radio, installing new
Strobe light, installing new
Voltage converter, installing new
Accumulator bank, installation
Accumulator bank, removal
Accumulator, checking
Accumulator, discarding
Accumulator, installation 1
Accumulator, installation 2
Accumulator, precharge pressure, checking and adjusting 1
Accumulator, removal 1
Accumulator, removal 2
Accumulator, replacing 1
Accumulator, suspension system, discarding
Accumulator, suspension system, overhaul
Adjusting, general
Air drier, drier cartridge, replace
Air in fuel system, checking
Articulated joint, checking clearence
Automatic central lubrication, filter, cleaning replacing
Axle mounts, bolted joints, tourque, check
Battery, charging state, electrolyte level, cables and connections, especially connections at starter motor, check
Brake cooling circulation, function check
Brake cooling oil tank, oil, change 1
Brake cooling oil, level, check
Brake disc, replacing
Brake pipes and hoses, check
Brake system, basic check
Brake system, bleeding
Brake system, pressure oil filter, replace
Cab door, installing door catch
Cab door, removing door catch
Cab, air pre-cleaner filter, clean- change
Cab, asbestos filter, replacing
Cab, main filter, replacing
Cab, prefilter, replace
Camshaft setting, checking
Camshaft, replacing
CareTrack antenna, replacing
Centre gear , removing and fitting
Centre gear, removing and fitting
Checking and adjusting the longitudinal differential lock
Checking for leaks with inspection light
Condenser, clean (with compressed air) (optional equipment)
Cooling fan motor, radiator, checking adjusting high rpm
Cooling fan, return oil filter, replacing
Cooling system, flushing
Cross stay, rubber bushing, replacing 1
Cylinder compression, PC test
Data links, fault tracing with Oscilloscope
Dog clutch 6x6, checking and adjusting
Door lock, replacing
Door window, replacing
Door, replacing
Drive axles, oil, change
Drive axles, transmission, dropbox and frame joint, breather filter, replace
Dropbox, installing
Dropbox, oil, replace
Dropbox, removing
Dump body alternative, lowering 1
Dump lever, changing
Dumping lever, checking pressure
E-ECU, MID 128, changing non-Programd ECU 1
Electric hood pump, changing
Engine and transmission, removing
Engine hood, installing
Engine hood, removing
Engine mounts dropbox mounts propeller shafts, bolted joints and flange mounts, check torques
Engine, air cleaner, cover, clean
Engine, air cleaner, main filter, replace. EON (option) only replace when indicated.
Engine, air cleaner, secondary filter, replace. EON (option) only when indicated
Engine, air pre-cleaner, check clean
Engine, basic check
Fan pump, installation
Fan pump, removing
Feed pressure, PC test
Foot brake valve, replacing
Forced Raisin lowering, Full suspension
Frame joint bearings, clearance, check
Frame joint oil, change
Frame joint oil, check
Frame joint, changing bearing, machine separated (on load unit frame)
Frame joint, measuring and adjusting clearence
Front frame, rear section, cracks, checking
FS-cylinder, rubber bearings, check, after first 4000 hours, then after every 1000 hours.
Fuel pump (valves), inspection
Fuel pump, inspection
Fuel system, extra fuel pre-filter, change
Fuel system, extra fuel pre-filter, drainFuel system, extra fuel pre-filter, drain
Fuel tank, hydraulic oil tank, brake cooling oil tank, breather filter, replace
Fuel tank, sediment, drain. Shorter interval as needed.
Fuel, coolant and oil leakage, check
Headlights, adjusting
Heat control valve, replacing
Heat control, replacing
Heater core, replacing
Hoist cylinder bearing, changing 1
Hoist cylinder, installation
Hoist cylinder, removal
Hub reduction, installing
Hub reduction, removing
Hydraulic cooling fan control, PC test
Hydraulic cylinder bushing, suspension system, replacing 1
Hydraulic cylinder bushing, suspension system, replacing 2
Hydraulic cylinder, suspension system, overhaul
Hydraulic oil tank, oil, replace if system is filled with mineral oil or Volvo Biodegradable hydraulic oil 46. If system is filled with other biologically degradable hydraulic oil, replace every 2000 hour.
Hydraulic oil tank, return oil filter, replace, and magnetic rods, clean
Hydraulic pump, replacing
Hydraulic system, bleeding
Injector shut off, manual
Injector sleeves, replacing
Input shaft seal, replacing
Input shaft, seal, replacing
Intercooler, replacing
Intermediate shaft and or bearing, replacing (in frame joint)
Load and Dump brake, servo pressure, checking
Load body, exhaust heated, check clean grease
Load body, rubber cushions, clearance, check
Manual lowering 1
Manual lowering
Oil cooler, replacing
Oil level sensor, changing
Oil sump gasket, changing
Operator's seat, installing
Operator's seat, removing
Output shaft 6-wheel drive, sealing and bearing, replacing
Overflow valve, checking
Parking brake , replacing brake caliper
Parking brake pads, check
Parking brake, basic check
Position sensor front, replacing
Position sensor rear, replacing
Position sensor, complete replacement
Preheating coil, replacing
Protecting plate, removal
Pump regulator, checking
Pump, installation
Pump, removal
Radiator, adjusting
Radiator, clean (from fan side with compressed air)
Radiator, installing
Radiator, removing
Relief-Cut-in pressure, adjusting
Relief-Cut-in pressure, check
Rotation speed sensor, replacing
Rubber cushion, replacing
Secondary coolant pump, replacing
Service brake, brake disc wear, check
Shift valve, checking
Stall speed, checking
Starter motor, replacing
Steering and dumping valve, removed, reconditioning 1
Steering cylinder bearings, clearance, check
Steering cylinder, installing
Steering cylinder, removing
Steering cylinder, replacing bearings 1
Steering gear, check.and adj.
Steering gear, replacing
Steering joint bearings, first check of steering joint bearings after 6000 hours. Thereafter every 2000 hours.
Suspension cylinder, installation 1
Suspension cylinder, installation 2
Suspension cylinder, removal 1
Suspension cylinder, removal 2
Suspension system, bleeding air
T-ECU, MID 130, changing non-Programd ECU
T-ECU, MID 130, changing pre-Programd ECU
Thermostat, replacing 1
Timing gear case, fitting new gasket in machine
Transmission, installing
Transmission, oil, main oil filter and lubrication oil filter, replace.
Transmission, removing
Transverse differential lock axle, checking and adjusting
Troubleshooting tips hydraulics
Turbocharger, inspection
Turbocharger, replacing
Unit injector, replacing
V2-ECU, MID 249, replacing non-Programd ECU
V2-ECU, MID 249, replacing pre-Programd ECU
Vacuum pump, connection
Vacuum pump, disconnection
Warranty inspection 100 hours
Wear indicator, adjusting
Wheel brake, replacing
Wheel, installing
Wheel, removing
Altered wind shield washer tank installation, improved self bleeding
Automatic transmission lubricants 1
Connection rod self leveling system
Face seal leakage, ARB-H35, H40
Final drive, ARB-H axles
Frame cracks in steering joint-front frame
Ghost codes for E-series Articulated Haulers
Grease-lubricated hitch
Guide pins D12D
Hydraulic connector leakage
IL1-IL2 Drop box air leakage on piston, cylinder and sleeve for longitudinal diff
Improved Operator's seat
KAB Seat, heater range
Locking set screw installation on the double rocker arm
New accelerator and retarder pedal with gold plated terminals
New air horn
New camera cable protection
New Caretrack WECU2
New clamping on coolant pipe
New cross stay, trailer unit
New deflector on companion flange
New engine software V2010.3.0
New front frame and vertical frame link
New fuel filter housing
New full suspension sensor
New gas spring
New haulers, A35E FS and A40E FS
New hoist cylinder
New Intercooler Hoses
New level sensor for full suspension
New needle bearings in planet stage 1
New oil sump and level temp sensor for D12D engine
New O-ring for ARB-H axles
New parking brake valve
New pressure sensors
New pressure switch for AC system
New rear camera system
New rear LED flasher
New rear view monitor
New software V2010.2.2
New software version V2008.4.0
New software version V2009.4.0
New starter switch
New system design to meet revised ISO 15998
New transmission PT2519, Part No. 22418
New wiper motor
Oil analyses
Oil jet nozzle eliminated from the D12D and D9B exhaust double rocker arm
Premature wear on diff lock control piston seal
PT2509, 1563, 1863, reinforced planet kit, stage 1
PT2509, PT1563 and PT1863 new design of spring pins in planet kit stage 2 and 3
PTO, gear shaft assembly update
PTO, o-rings update
Repair instruction, rear section front frame
Restrictor Washer in FS Distribution block
Rubber bearing A-frame
Rubber bearings, cross stay
Service kit Overhung Tailgate
Software and transmission sheets
Transmission PN 22401, incorrect machining for output shaft speed sensor SE4307 and H-L-range sensor SE4215
Transmission software update E-series
Transmission, inspection form
Transmission, new main oil pressure sensor SE4219
Tyres, various types
Volvo Product incidentaccident report & Interview Form
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
AC system, specifications
Accumulator, specification 1
Alternator, specifications
Axles, specifications
Axles, tightening torques
Brake cooling system, specification
Brake system, specifications
Brakes, specifications
Cabin, specification
Capacities
Cold-start device, specifications
Compressed-air system, specifications
Cooling system specifications
Dropbox, capacities
Dropbox, specifications
Dump lever, specifications
Engine, capacities
Flywheel, tightening torques
Front axle rear axle, capacities
Fuel tank, volume
Hitch, specifications
Hoist cylinder, specification
Hydraulic pump brake cooling, specification
Hydraulic system, capacities
Lighting, specifications
Lubricants, specifications
Machine dimensions
Oil sump, tightening torque
Parking brake, specifications
Product identification plates
Protective plate, weight
Rocker arm shaft, tightening torques 1
Starter motor, specification
Steering gear, specifications
Steering linkage, tightening torque
Suspension cylinder specifications
Thermostat, specifications
Tightening torque
Tipping system, specification
Turbocharger, specifications
Unit injectors, specifications
Valve mechanism, double rocker arm
Valve system, specification
Weights
Wheel, tightening torque
Time Guide Current generation
