Volvo Dump Truck A30D Service Repair Manual
File Size: 169.16 MBFile Format: PDF
Machine Type: Dump Truck
Manual Type: Service Repair Manual, Electrical Wiring Diagram, Hydraulic Diagram
Model: Volvo A30D Dump Truck
Number of Pages: 6165 Pages
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/1 Volvo A30D
2 Volvo A30D
3 Volvo A30D
A–frame
Air conditioning AC, basic principles
Air conditioning unit, operation
Air intake and filter
Appointment and distribution of responsibility
ATC, description
Back up alarm, installing new
Basic checks
Brake booster, overview illustration
By-pass valve (wastegate)1
By-pass valve (wastegate)2
Cab description
Cab, lifting points
Camshaft, description
Checklist, control system, transmission
Component and description
Component position
Compressed air-hydraulic brake system
Compressor, changing
Connectors, overview
Control units, voltage supply
Cooling system, principle illustrations
Crankshaft and vibration damper, description
Cylinder block, description
Cylinder head guides
Cylinder head, description
Cylinder liners and pistons, description
Damping cylinder
Dealers retrofitter´s responsibility
Description Clutch
Description Frame
Description Transmission
Description, retarder
Display unit and keyboard
Display unit, content
Double rocker arm, description
Drive axles, description
Drivetrain, description
Dump lever, description
Electrical distribution box, description1
Electrical distribution box, description2
Engine, identification
Engine, sensor locations
Exhaust brake, description
Exhaust pressure governor (EPG), description1
Exhaust pressure governor (EPG), description2
Fan system, description
Final drive, 1st bogie axle, cut-away view
Final drive, front axle and 2nd bogie axle, cut-away view
Foot brake valve, description
Frame joint, tightening torque
Fuel feed pump, description
Fuel filter, description
Fuel flow, description
Gear F1
Gear F2
Gear F3
Gear F4
Gear F5
Gear F6
Hitch, specifications
Hoist cylinder, description
Hub A25D A30D, cut-away view
Hub end AH56E–AH56G, AH64D–AH64F, cut-away view
Hydraulic and servo systems, description
Hydraulic pump, description
Hydraulics
Information display unit, general
Information, build-up
Injection pump, description
Injectors, description
Instruments and controls, climate control panel
Instruments and controls, main instrument
Intercooler (charge-air cooling), general
Intercooler
Intermediate shaft, cut-away view1
Intermediate shaft, cut-away view2
Introduction Brakes
Key functions
Lifting machine
Load unit frame
Lock-up clutch
Lubrication oil pump and oil cooler, description
Lubrication system, description1
Lubrication system, description2
Lubrication system, valve function
Machine status hardware software
Menu tree
Non-return valve function in steering and dumping valve
Oil and seals AH64D-AH64F
Oil sump, description
Oil trap, description
Other fuses and relays, description
Parking brake, description
Piston cooling system, description
Planetary gear
Power transmission, specifications
Pressure accumulation
Pressure build-up, engine-dependent pumps, description
Pressure build-up, engine-dependent pumps, description1
Pressure check connections, description
Pressure check connections, description1
Propeller shaft
Protection against electromagnetic interference
Recovering and towing
Recovering and towing1
Refrigerant for air conditioning
Refrigerant R134a, vacuum pumping including filling (charging)
Repair instructions
Reverse gear R1
Reverse gear R2
Service
Start electronics
Steering and dumping valve, description1
Steering and dumping valve, description2
Steering cylinder, description1
Steering system, description
Stop electronics
Suspension, description
Theft protection
Torque limiter, description
Tractor unit frame
Transfer gearbox, description
Transmission of power
Transmission, clutches and brakes
Turbocharger, description
Unit injectors, description
Valve mechanism, description
VCADS Pro service tool, general
VCADS Pro tests
VCADS Pro, Calibrating
VCADS Pro, Error codes
VCADS Pro, Programming
VCADS Pro, Test
Warranty inspection
Water separator
Compressed air diagram1
Compressed air diagram2
Compressed air diagram3
Hydraulic diagram PT
Hydraulic diagram, complete1
Hydraulic diagram, complete2
Hydraulic diagram, complete3
Hydraulic diagram, complete4
Steering and dumping valve, overview illustration1
Steering and dumping valve, overview illustration2
Transmission PT1560, cut-away
Wiring diagram A01-1
Wiring diagram A01-2
Wiring diagram A01-3
Wiring diagram A01-4
Wiring diagram A01-5
Wiring diagram A02
Wiring diagram A03-1
Wiring diagram A03-2
Wiring diagram A03-3
Wiring diagram A04-1
Wiring diagram A04-2
Wiring diagram A04-3
Wiring diagram A04-4
Wiring diagram A04-5
Wiring diagram A04-6
Wiring diagram A04-7
Wiring diagram A04-8
Wiring diagram A05-1
Wiring diagram A05-2
Wiring diagram A05-3
Wiring diagram A05-4
Wiring diagram A06-1
Wiring diagram A06-2
Wiring diagram A07-1
Wiring diagram A07-2
Wiring diagram A07-3
Wiring diagram A07-4
Wiring diagram A08-1
Wiring diagram A08-2
Wiring diagram A09-1
Wiring diagram A09-2
Wiring diagram A10-1
Wiring diagram A10-2
Wiring diagram A10-3
Wiring diagram A11-1
Wiring diagram A11-2
Wiring diagram A11-3
Wiring diagram A11-4
Wiring diagram A11-5
Wiring diagram A11-6
Wiring diagram A11-7
Wiring diagram A11-8
Wiring diagram A12-1
Wiring diagram A12-2
Wiring diagram A12-3
Wiring diagram A12-4
Wiring diagram A13
Wiring diagram A14-1
Wiring diagram A14-2
Wiring diagram A14-3
Wiring diagram A14-4
Wiring diagram A15-1
Wiring diagram A15-2
Wiring diagram A15-3
Wiring diagram A16-1
Wiring diagram A16-2
Wiring diagram A17-1
Wiring diagram A17-2
Wiring diagram A18-1
Wiring diagram A18-2
Wiring diagram A18-3
Wiring diagram A18-4
Wiring diagram A18-5
Wiring diagram A19-1
Wiring diagram A19-2
Wiring diagram A19-3
Wiring diagram A19-4
Wiring diagram A19-5
Wiring diagram A20-1
Wiring diagram A20-2
Wiring diagram A20-3
Wiring diagram A21-1
Wiring diagram A21-2
Wiring diagram A21-3
Wiring diagram A22-1
Wiring diagram A22-2
Wiring diagram A22-3
Wiring diagram A22-4
Wiring diagram A23
Wiring diagram A23-1
Wiring diagram A23-2
Wiring diagram A23-3
Wiring diagram A24-1
Wiring diagram A24-2
Wiring diagram A24-3
Wiring diagram A24-4
Wiring diagram A24-5
Wiring diagram A24-6
Wiring diagram A25-1
Wiring diagram A25-2
Wiring diagram A25-3
Wiring diagram A25-4
Wiring diagram A25-5
Wiring diagram A25-6
Wiring diagram A26-1
Wiring diagram A26-2
Wiring diagram A26-3
Wiring diagram A26-4
Wiring diagram A27-1
Wiring diagram A27-2
Wiring diagram A27-3
Wiring diagram A27-4
Wiring diagram A28-1
Wiring diagram A28-2
Wiring diagram A28-3
Wiring diagram A28-4
Wiring diagrams
Installation Instruction
Air Conditioning
Air Conditioning1
Body Heating
Brake shields, installing new
CareTrack
Electrical Hood Opening
Electrical Hood Opening1
Engine Heater 120V
Engine Heater
Engine Heater1
Heat Shield
Oil Bath Air Cleaner
Radio, installing new
Rear View Camera
Rear View Mirror
Rotating Beacon
Tachograph
Tailgate, underhung, installing new1
Towing Hitch
Work Light
Work Light1
4-pin DIN-connectors, remounting
88830051 User Instruction
Air in fuel system, checking
Air suspension operator's seat, adjusting1
Air suspension operator's seat, adjusting2
Alternator, replacing incl function check1
Bogie beam, changing rubber bushing on removed beam
Bogie beam, changing rubber spring, one side (front)
Brake caliper, replacing one
Brake caliper, replacing one1
Brake calliper removed, reconditioning
Brake calliper, replacing one
Brake disc, replacing one
Brake pads, changing
Brake pads, replacing (one wheel, 2d boggie axle)
Brake pads, replacing (one wheel, first boggie axle)
Brake pads, replacing (one wheel, front axle)
Brake pipes and hoses, check
Brake system, basic check
Brake system, bleeding
Cab door, installing door catch
Cab door, removing door catch
Camshaft setting, checking
Camshaft, replacing
CareTrack antenna, replacing
C-ECU, MID178, changing non-Programd ECU
C-ECU, MID178, changing pre-Programd ECU
Centre gear, removing and fitting
Checking and adjusting the longitudinal differential lock
Checking for leaks with inspection light
Combined control by steering wheel, changing
Component position 1, AL3201–31GR1
Component position 2, HE2301–LA3601
Component position 3, LA3602–LC4202
Component position 4, LC4601–MA4207
Component position 5, MA4601–R3502
Component position 6, RC8401–SA4201
Component position 7, SE2202–SE5202
Component position 8, SE5203–SO3901
Component position 9, SW2301–SW3801
Component position 10, SW4201–SW9102
Components, list and positions
Compressed air brake, function check
Compression test,warm engine
Compression test
Compressor, replacing
Connectors C01–DY, position
Connectors EA–F50, position
Connectors HE3601–TAILR, position
Coolant pump removed, reconditioning
Coolant pump, replacing1
Coolant pump, replacing2
Coolant, changing1
Coolant, changing2
Coolant, changing3
Coolant, changing4
Cooling system, flushing
Crankshaft, replacing front oil seal1
Crankshaft, replacing front oil seal2
Cylinder balancing, PC test
Cylinder compression, PC test
Damping cylinder, checking pre-load
Dog-clutch for six-wheel drive (6x6), checking and adjusting
Door lock, replacing
Door window, replacing
Door, replacing
Dropbox, mounting
Dropbox, removing
Dump body alternative, lowering
Dump body alternative, lowering1
Dump body position indicator, adjusting
Dump lever, changing
Dump lever, changing1
Dumping lever, checking pressure
E-1750
E-1763
E-2502
E-2516
E-2519
E-2526
E-ECU, MID 128, changing non-Programd ECU1
E-ECU, MID 128, changing non-Programd ECU2
E-ECU, MID 128, changing non-Programd ECU3
E-ECU, MID 128, changing pre-Programd ECU1
E-ECU, MID 128, changing pre-Programd ECU2
E-ECU, MID 128, changing pre-Programd ECU3
Electric hood pump, changing
Electric hood pump, changing1
Engine and transmission, mounting, version 1
Engine and transmission, mounting, version 2
Engine and transmission, removing, version 1
Engine and transmission, removing, version 2
Engine hood, installing
Engine hood, removing
Engine, basic check
Engine, mounting
Feed pressure, PC test
Feed pump, checking feed pressure1
Feed pump, checking feed pressure2
Feed pump, checking feed pressure3
Final drive, removing and mounting
Final drive, removing and mounting1
Flywheel housing with power take-off (PTO), mounting on engine out of machine
Flywheel housing with power take-off (PTO), removing from engine out of machine
Foot brake valve (pneum), replacing
Frame joint, changing bearing, machine separated (on load unit frame)
Frame joint, separating the machine
Fuel pump, inspection
Fuel system, bleeding air, version 1
Fuel system, bleeding air, version 2
Fuel, coolant and oil leakage, check
Gearshift selector, changing
General instructions for controls, replacing.
General maintenance instructions
Headlights, adjusting
Heat control valve, replacing
Heat control, replacing
Heater core, replacing
Hoist cylinder bearing, changing1
Hoist cylinder bearing, changing2
Hoist cylinder, installation
Hoist cylinder, removal
Hub reduction, installing
Hub reduction, removing
Hydraulic cooling fan control, PC test
Hydraulic pump, checking and adjusting max working pressure
Hydraulic pump, checking and adjusting max. pressure,engine dependent working hydraulic pumps
Hydraulic pump, checking and adjusting stand-by pressure, engine dependent working hydraulic pumps
Hydraulic pump, replacing
Hydraulic pump, replacing1
Hydraulic system, bleeding1
Hydraulic system, bleeding2
Injection pump, installing, and setting injection angle
Injection pump, removing
Injector shut off, manual
Injectors, changing all
Injectors, replacing copper sleeve in machine
Intercooler, replacing
Intermediate shaft and or bearing, changing
Intermediate shaft and or bearing, replacing (in frame joint)
Lever bracket, steering bearing, replacing
Mechanical operator's seat, adjusting
Oil and seals
Oil cooler, replacing
Oil cooler, replacing1
Oil level sensor, changing
Oil sump gasket, changing
Operator's seat, changing air spring
Operator's seat, installing
Operator's seat, removing1
Operator's seat, removing2
Output shaft 6-wheel drive, changing bearing
Overflow valve, checking
Parking brake lever, changing
Parking brake, basic check
Parking brake, replacing brake pads1
Parking brake, replacing brake pads2
Power transmission, basic check1
Power transmission, basic check2
Preheating coil, replacing
Protecting plate, removal
Pump regulator, checking
Radiator, adjusting
Radiator, installing
Radiator, removing
Rear window pane, replacing
Relief Cut-in pressure, adjusting
Relief Cut-in pressure, check
Rubber cushion, replacing
Service brake, brake pads, check
Shift valve, checking
Side window, replacing
Spindle, replacing one side
Spindle, replacing one side1
Stall speed, checking
Starter motor, replacing
Starter motor, replacing1
Steering and dumping valve, removed, reconditioning1
Steering and dumping valve, removed, reconditioning2
Steering cylinder, installing
Steering cylinder, reconditioning on machine
Steering cylinder, removed, reconditioning
Steering cylinder, removing
Steering cylinder, replacing bearings1
Steering cylinder, replacing bearings2
Steering cylinder, replacing bearings3
Steering gear, check.and adj.
Steering gear, replacing
Steering joint, replacing bearings
Steering linkage, checking and adjusting
Steering linkage, checking and adjusting1
Steering linkage, checking and adjusting2
T-ECU, MID 130, changing non-Programd ECU
T-ECU, MID 130, changing pre-Programd ECU
Thermostat, replacing
Thermostat, replacing1
Torque limiting valve, checking and adjusting
Transmission, installing from underneath
Transmission, mounting on engine out of machine, version 1
Transmission, mounting on engine out of machine, version 2
Transmission, removing downward
Transmission, removing from engine out of machine, version 1
Transmission, removing from engine out of machine, version 2
Transverse differential lock axle, checking and adjusting
Troubleshooting tips
Turbocharger, inspection
Turbocharger, replacing
Unit injector, adjusting pretension
Unit injector, replacing
Vacuum pump, connection
Vacuum pump, disconnection
Valves and unit injectors, adjusting – D9A
Valves, adjusting1
Valves, adjusting2
V-ECU, MID 187, changing non-Programd ECU1
V-ECU, MID 187, changing non-Programd ECU2
V-ECU, MID 187, changing pre-Programd ECU1
V-ECU, MID 187, changing pre-Programd ECU2
Warranty inspection 100 hours
Warranty inspection 1000 hours1
Warranty inspection 1000 hours2
Wheel alignment
Windscreen, replacing
CE-marking, EMC-directive
Environment
Rules when handling tyres
Safety when handling accumulators1
Safety when handling accumulators2
Safety when working on pressurized systems
Service position 1
Transporting the machine
AC, time relay
Adaptive gear shifting for machines
Amendment of Service Manual, D10B
A-stay, new rubber bushing
Belt guard, new type
Brake disc, changed minimum thickness
Change of crankshaft seal
Changed software functions in Release1
Changed software functions in Release2
Changed software functions in Release3
Changed software functions in Release4
Changed software functions in Release5
Changed software functions in Release6
Changed software functions in Version
Compressed air drier, service solution
Connector for cooling fan PWM valves
Contronic socket, mounting plate
D9B and D12D Stage 3, valve adjustment, camshaft marking
Door lock
Drainage of engine oil
Drive axles, new hub seal
Engine cable harness D9A, cable rail for injectors
Engine oil requirements
Engine oil, altered time for the first oil change
Engine oil, interval between changes
Engine reconditioning
Fan regulator, PWM2601 and PWM2602
Fan, new type
Flywheel housing, draining hole, drilling
Fuel filter housing with electrical pump, service solution
Headlamp, new light bulb
Hexagon stay, replacing
Hub reduction gear, planet carrier, new design
Hub Seal Leakage AH56 AH64
IL1-IL2 Drop box air leakage on piston, cylinder and sleeve for longitudinal diff
Incorrect Matris information
Intermediate shaft A25D-A30D, new bearings, seals and grease
Intermittent retarder function, PT1563, 1863
KAB Seat, heater range
Lifting tool, new marking
Lifting tool, new type
Lubricant, Biodegradable Hydraulic Fluid
Measuring nipples, new type
New belt tensioners
New brake pipes and brake guards
New Caretrack WECU2
New coolant
New display screen for transmission oil level
New fan installation
New floor panel and floor mat
New fuel filter housing
New fuse FC2, preheating
New gas spring
New haulers, A25D and A30D
New hitch1
New hitch2
New hitch3
New Intercooler Hoses
New keypad
New non-return valve with back-pressure function, MTRV1
New pressure sensors
New rear camera system
New rear LED flasher
New resistor for the alternator's charging circuit
New rubber cloth over the batteries
New seals for steering joint bearings
New sensor for accelerator and retarder pedal
New software version1
New software version2
New software version3
New software version4
New software version5
New software version6
New software version7
New starter switch
New suspension of hydraulic hoses
New tipping spool, valve block
New tool Electrical repair kit, part No. 11666200
New transmission
New transmission1
New transmissions2
New turbocharger for D9A Tier 2 Step II engine
New water trap
New wheel brake disc
New wiper motor
Noise from hoist cylinder when tipping
Noise reduction kit
Oil analyses
Oil jet nozzle eliminated from the D12D and D9B exhaust double rocker arm
Oil sampling, sampling points
Parking brake, new brake pads
Pipe for dipstick for transmission
Product development
PTO, gear shaft assembly update
PTO, o-rings update
Replacement of pivot pin for accelerator pedal and retarder pedal
Replacing damping cylinder
Service and maintenance of batteries
Service kit Overhung Tailgate
Service Manual IL-1, supplement
Service Manual, supplement
Software version
Special tools
Steering cylinder bearing, introduction of grease nipples
Steering joint, vertical joint, introduction of grease nipples
Timing gear casing, leakage
Transmission PowerTronic, new B2 drum
Transmission PowerTronic, new gasket
Transmission PT1663, reinforced bolted joint, converter housing
Transmission, adaptive gear shifting
Transmission, improved retarder
Transmission, inspection form
Tyres, various types
Unstable Self steering
Special Tools, Misc
GRD G700B LabourTimeGuide
Recommended Special Tools
RM Compaction ABG Time Guide
RM Compaction Time guide
RM Paving Systems ABG Time Guide
Time Guide Current generation
AC system, specifications
Alternator, specifications1
Alternator, specifications2
Axles, tightening torques
Brake system, specifications1
Brake system, specifications2
Cabin, specification
Capacities
Cold-start device, specifications
Cooling fan motor, specifications
Cooling system specifications
Drive axles, capacity
Drive shafts, specifications
Dropbox, specifications
Dropbox, weights
Dump lever, specifications
Engine, capacities1
Engine, capacities2
Engine, tightening torques
Engine, weights
Flywheel, tightening torques
Frame, specifications tightening torques
Fuel feed pump, specifications1
Fuel feed pump, specifications2
Hoist cylinder, specifications
Hydraulic pumps, specifications1
Hydraulic pumps, specifications2
Hydraulic system, capacities
Hydraulic transmission, weight
Injection pump, specifications
Injectors, specifications
Intercooler, specifications
Lighting, specifications
Lubrication system, specifications1
Machine dimensions
Oil cooler, tightening torques1
Oil sump, tightening torque
Parking brake, specifications
Product identification plates
Rocker arm shaft, tightening torques1
Service brake, specifications
Starter motor, specification1
Starter motor, specification2
Steering gear, specifications
Steering joint bearing
Thermostat, specifications
Tipping system, specification
Transmission, specifications
Turbocharger, specifications
Tyre equipment and recommended tyre pressures1
Tyre equipment and recommended tyre pressures2
Unit injectors, specifications
Valve mechanism, specifications1
Valve mechanism, specifications2
Weights
Wheel, tightening torque
