Volvo Dump Truck A25F Service Repair Manual​
Total Size: 140.08 MB
Language:
English
Brand:
Volvo
Machine Type:
Dump Truck
A25F
1781
  • Service Repair Manual
  • Electrical Wiring Diagram
  • Hydraulic Diagram
1 Volvo A25F
Descriptions
A–frame
Air cleaner, description
Anti-theft device, description
ATC, description
Automatic brake description
Automatic central lubrication
Auxiliary steering backwards, description
Axle suspension, description
Back-up alarm, description
Basic check, transmission
Basic checks
Bogie extension, description
Braking system, description
Cab description
Cab, lifting points
CE-marking, EMC-directive
Charge air cooling system, description
Clutches, brakes and planet stages, description
Component locations
Component position
Connectors, position
Control system, description
Control system
Control unit, description
Control units, voltage supply
Cooling need, overview illustration
Cooling system, principle illustrations
Crank mechanism, description
Cylinder block, description
Cylinder liners and pistons, description
Damping cylinder, description
Data bus system
Delayed stop, description
Diagnostic tools, description
Display, description
Door open, description
Dosage valves, description
Drive axles, description
Drivetrain, description
Dump function, description
Electronic accelerator pedal, description
Engine- and cab heater, description
Engine and transmission overspeed protection, description
Engine hood, description
Engine, description 1
Engine, identification
Engine, sensor locations
Exhaust pressure governor
External activation of central warning, description
Foot brake valve, description
FOPS and ROPS
Frame joint, description
Frame, description
Fuel feed pump, description
Fuel flow, description
Fuel level, description
Gear selector
Gear shifting strategy
Gearshifting, description
General vehicle electronics
Heat exchanger, description
Hoist cylinder, description
Hydraulic pump, description
Inclination, description
Information display unit, summary
Information display, cycle info
Information display, engine
Information display, general
information display, machine information
Information display, service
Inlet and exhaust system, component location 1
Inlet and exhaust system, description 1
Load and dump brake, description
Load unit frame
Lock-up clutch
Lubrication and oil system
Main oil filter
MS.Internal.Documents
Oil level
Oil pump, description
Oil temperature
Oil trap, description
Parameter settings
Preheating description
Pressure build up, steering
Pressure check connections, description
Pressure monitor, description
Propeller shaft, description
PT Transmission
PTO (Power Take Off), description
Pump unit, description
Red extra central warning, description
Retarder pedal, description
Retarder, description
SAE J1708 (Information bus)
Seat belt supervision, description
Sensors and monitors, description
Sensors, description
Service mode, description
Service
Shift valve, description
Start electronics, description
Starter motor, description
Steering system, description twin steer
Stop electronics, description
Supervision data bus communication, description
Suspension cylinder (GHS), description
Suspension, description
System voltage, description
Thermostat, secondary system, description
Torque converter
Tractor unit frame
Transfer gearbox, description
Transmission, description
Turbocharger, description
Unit injectors, description
Vehicle speed, description
Wheel brake, description
Working lights, description
Compressed air diagram
Electrical component list
Hydraulic diagram pic 1
Hydraulic diagram PT
Hydraulic diagram, brake system
Hydraulic diagram, complete pic 1
Hydraulic diagram
Wiring diagram WD201
Wiring diagram WD202
Wiring diagram WD203
Wiring diagram WD204
Wiring diagram WD205
Wiring diagram WD206
Wiring diagram WD207
Wiring diagram WD220
Wiring diagram WD240
Wiring diagram WD241
Wiring diagram WD242
Wiring diagram WD301
Wiring diagram WD302
Wiring diagram WD303
Wiring diagram WD304
Wiring diagram WD305
Wiring diagram WD306
Wiring diagram WD307
Wiring diagram WD308
Wiring diagram WD309
Wiring diagram WD310
Wiring diagram WD311
Wiring diagram WD312
Wiring diagram WD313
Wiring diagram WD314
Wiring diagram WD315
Wiring diagram WD316
Wiring diagram WD318
Wiring diagram WD320
Wiring diagram WD321
Wiring diagram WD322
Wiring diagram WD323
Wiring diagram WD324
Wiring diagram WD325
Wiring diagram WD326
Wiring diagram WD327
Wiring diagram WD328
Wiring diagram WD401
Wiring diagram WD403
Wiring diagram WD501
Wiring diagram WD502
Wiring diagram WD503
Wiring diagram WD504
Wiring diagram WD702
Wiring diagram WD801
Wiring diagram WD802
Wiring diagram WD803
Wiring diagram WD804
Wiring diagram WD805
Wiring diagram WD901
Wiring diagram WD902
Wiring diagram WD903
Wiring diagram WD907
Wiring diagram WD908
Wiring diagram WD909
Wiring diagram WD910
Wiring diagram WD911
Wiring diagram WD912
Wiring diagrams
Accumulator, discarding
Accumulator, replacing
Air pump, oil level, checking
Air pump, oil, changing
Auxiliary heater, replacing
Axles and dropbox, leaks, checking
Battery, charging state, electrolyte level, cables and connections, especially connections at starter motor, check
Bleeding air
Bogie beam, changing rubber bushing on removed beam
Bogie beam, changing rubber spring, one side (front)
Brake caliper, replacing one
Brake calliper removed, reconditioning
Brake calliper, replacing one
Brake disc, replacing one
Brake pads, replacing (one wheel, 2d boggie axle)
Brake pads, replacing (one wheel, first boggie axle)
Brake pads, replacing (one wheel, front axle)
Brake system, basic check
Brake system, bleeding1
Brake system, bleeding2
Cab heating cab ventilation timer, pump, replacing
Cab, main filter, replacing
Cab, prefilter, replace
CareTrack antenna, replacing
Centre gear , removing and fitting
Centre gear, removing and fitting
Checking and adjusting the longitudinal differential lock
Check-measuring electric components
Control system, reconditioning
Control units, changing
Cross stay, installing
Cross stay, installing2
Cross stay, removing
Cross stay, removing1
Cross stay, rubber bushing, replacing
Cross stay, rubber bushing, replacing1
Dog clutch 6x6, checking and adjusting
Door lock, replacing
Door window, replacing
Door, gas spring, replacing
Door, replacing
Dosage valve, checking internal leakage
Dropbox, installing
Dropbox, removing
Dump body alternative, lowering
Dump body angle sensor, calibration
Dump function, checking pressure
Dump lever, changing
E-1763
E-2000
E-2511
E-2519
E-2520
E-2521
E-2524
E-2525
E-2526
E-2527
E-2528
Electric hood pump, changing
Engine hood, installing
Engine hood, removing
Engine mounts and dropbox mounts, checking
Engine, basic check
Evaporator, cleaning
Filling lubricant
Foot brake valve, replacing
Frame extension, bolted joints, torque, check
Frame joint bearing, replacing (machine separated)
Frame joint bearings, clearance, check
Front guard plate, removing
Headlights, adjusting
Heat control valve, replacing
Heat control, replacing
Heater core, replacing
Hitch, installing
Hitch, removing
HMIM, MID 140, changing non-Programd ECU
HMIM, MID 140, changing pre-Programd ECU
Hoist cylinder bearing, changing1
Hoist cylinder bearing, changing2
Hoist cylinder removed, reconditioning1
Hoist cylinder removed, reconditioning2
Hoist cylinder, installation
Hoist cylinder, removal
Hood pump, oil, changing
Hub reduction, installing
Hub reduction, removing
Hydraulic couplings
Hydraulic cylinder bushing, suspension system, replacing
Hydraulic cylinder, suspension system, overhaul
Hydraulic pump, checking and adjusting max working pressure
Hydraulic pump, checking and adjusting max working pressure1
Hydraulic pump, installation
Hydraulic pump, removal
Hydraulic system, bleeding
Intermediate shaft and or bearing, replacing (in frame joint)
Lever bracket, steering bearing, replacing
Load and Dump brake, function check
Load and dump brake, servo accumulator, checking2
Load and Dump brake, servo pressure, checking1
Lubrication points, central lubrication
Maintenance service, every 12000 hours
Maintenance service, first 100 hours
MATRIS and Tech Tool, reading
Operator's seat, air bellows, replacing
Operator's seat, installing
Operator's seat, removing
Operator's seat, shock absorber, replacing
Output shaft 6-wheel drive, sealing and bearing, replacing
Parking brake , replacing brake caliper
Parking brake, adjusting
Parking brake, basic check
Parking brake, manually releasing
Pressure check connections, description1
Pressure release
Propeller shaft, play, checking
Protecting plate, removal
Pump regulator, checking
Pump, installation
Pump, removal
Rear guard plates, removing
Rear window, replacing
Relief Cut-in pressure, adjusting
Relief Cut-in pressure, check
Retarder valve, reconditioning
Retarder valve, replacing
Rotation speed sensor, replacing
Secondary steering, checking
Service points
Shift valve, checking
Side window, rear, replacing
Side window, replacing
Spindle, replacing one side
Spindle, replacing one side1
Starter motor, replacing
Steering and dumping valve, removed, reconditioning
Steering cylinder, installing
Steering cylinder, removing
Steering cylinder, replacing bearings1
Steering cylinder, replacing bearings2
Steering gear, check.and adj.
Steering gear, replacing
Steering joint, replacing bearings
Steering linkage, checking and adjusting
Steering linkage, checking and adjusting1
Steering system, bleeding
Suspension cylinder (GHS), discarding
Suspension cylinder (GHS), function check
Suspension cylinder (GHS), oil changing
Suspension cylinder, installation
Suspension cylinder, removal
System test
Tech Tool, operations
Tech Tool, operations1
Transmission, installing
Transmission, removing
V2-ECU, MID 249, changing non-Programd ECU
V2-ECU, MID 249, changing pre-Programd ECU
Vacuum pump, connection
Vacuum pump, disconnection
VCADS Pro, Operations
VCADS Pro, Operations1
Wheel alignment
Wheel, installing
Wheel, removing
Windscreen wiper front, replacing motor1
Windscreen wiper front, replacing motor2
Windscreen, replacing
Alternator Improvment
Central lubrication
Crank shaft pulley adapter
EATS burner, Ignition cables
EATS functional check
Front LED parking lights
Heater element
Hub Seal Leakage AH56 AH64
Long pressure build-up time in Load & Dump brake
Loose screws on AH Hubs
Main cab cable harness, chafing
New air nipple for the diff lock on load unit
New Articulated Haulers F- and G-series
New Articulated Haulers, A25F and A30F
New ASU part number and new EATS fuel pump
New B5 piston in PT 22416 Transmission
New body angle sensor
New cab heater element
New Caretrack WECU2
New EATS burner
New EATS fuel pump
New E-ECU introduced
New EECU, ACM and ECC software V2012.1.0
New expansion tank
New fuel filter housing
New GHS Cylinder
New hitch
New main cab cable harness
New method for fuel system bleeding
New method for installing injectors
New needle bearings in planet stage 1
New pressure sensors
New rear camera system
New rear LED flasher
New software for VECU V2013.6.1
New software V2011.3.2
New software V2011.6.0
New software V2012.3.0
New software V2012.3.1
New software V2012.5.0
New software V2012.5.1
New software V2013.2.0
New software V2013.2.1
New thrust washers inside planetary step on PT 22416, 22418 and 22419.
New tip lever
New torque converter
New transmission oil pan gasket
New Venturi tube
New wheel brake disc
Noise from hoist cylinder when tipping
Oil analyses
Parking brake switch
Power cable clamping
Preheat cable clamping
Radio band setting
Screws, rubber spring bogie
Semi-automatic regeneration
Service kit Overhung Tailgate
Transmission, inspection form
Tyres, various types
Unstable Self steering
  • Volvo Dump Truck A25F Service Repair Manual.txt
