Volvo Compact Track Loader MCT125C Service and Repair Manual​
Total Size:
91.77 MB
Language:
English
Brand:
Volvo
Machine Type:
MCT125C
  • Service and Repair Manual
  • Hydraulic and Electrical Diagram
Volvo MCT125C Diagrams.pdf (117 Pages)
Component list, fuses1
Component list, fuses2
Component list, lights1
Component list, lights2
Component list, Miscellaneous1
Component list, Miscellaneous2
Component list, motors
Component list, relays1
Component list, relays2
Component list, sensors1
Component list, sensors2
Component list, Solenoid valves1
Component list, Solenoid valves2
Component list, Switches1
Component list, Switches2
Hydraulic diagram 1-1
Hydraulic diagram 1-1 Figure 1
Hydraulic diagram 1-2
Hydraulic diagram 1-2 Figure 1
Hydraulic diagram 1-3
Hydraulic diagram 1-3 Figure 1
Hydraulic diagram 2
Hydraulic diagram 2 Figure 1
Wiring diagram 1-1
Wiring diagram 1-1 Figure 1
Wiring diagram 1-2
Wiring diagram 1-2 Figure 1
Wiring diagram 1-3
Wiring diagram 1-3 Figure 1
Wiring diagram 2-1
Wiring diagram 2-1 Figure 1
Wiring diagram 2-2
Wiring diagram 2-2 Figure 1
Wiring diagram 2-3
Wiring diagram 2-3 Figure 1
Wiring diagram 3-1
Wiring diagram 3-1 Figure 1
Wiring diagram 3-2
Wiring diagram 3-2 Figure 1
Wiring diagram 3-3
Wiring diagram 3-3 Figure 1
Wiring diagram 4-1
Wiring diagram 4-1 Figure 1
Wiring diagram 4-2
Wiring diagram 4-2 Figure 1
Wiring diagram 4-3
Wiring diagram 4-3 Figure 1
Wiring diagram 5-1
Wiring diagram 5-1 Figure 1
Wiring diagram 5-2
Wiring diagram 5-2 Figure 1
Wiring diagram 5-3
Wiring diagram 5-3 Figure 1
Wiring diagram 6-1
Wiring diagram 6-1 Figure 1
Wiring diagram 6-2
Wiring diagram 6-2 Figure 1
Wiring diagram 6-3
Wiring diagram 6-3 Figure 1
Wiring diagram 7-1
Wiring diagram 7-1 Figure 1
Wiring diagram 7-2
Wiring diagram 7-2 Figure 1
Wiring diagram 7-3
Wiring diagram 7-3 Figure 1
Wiring diagram 8-1
Wiring diagram 8-1 Figure 1
Wiring diagram 8-2
Wiring diagram 8-2 Figure 1
Wiring diagram 8-3
Wiring diagram 8-3 Figure 1
Wiring diagram 9-1
Wiring diagram 9-1 Figure 1
Wiring diagram 9-2
Wiring diagram 9-2 Figure 1
Wiring diagram 9-3
Wiring diagram 9-3 Figure 1
Wiring diagram 10-1
Wiring diagram 10-1 Figure 1
Wiring diagram 10-2
Wiring diagram 10-2 Figure 1
Wiring diagram 11-1
Wiring diagram 11-1 Figure 1
Wiring diagram 11-2
Wiring diagram 11-2 Figure 1
Wiring diagram 12
Wiring diagram 12 Figure 1
Wiring diagram 14
Wiring diagram 14 Figure 1
Wiring diagram index
Volvo MCT125C Service and Repair.pdf (4497 Pages)
1 Volvo MCT125C
Description MCT125C
Boom suspension system valve, description
Combination valve, description
Description, complete machine1
Description, complete machine2
Drive motor, description
Electronic throttle control, description
Fault code list
Fault tracing on hydraulic system
Forwards drive, description
Fuels, lubricants and filling capacities (litres)
Fuses and Relays
Fuses
Gear pump, description
High speed, description
Hydraulic contamination
Hydraulic cylinders, precautions during use
Hydraulic service procedures
Lead and connector checks
Left spin turn, description
Load sensing valve block, description
Logic control
Main valve block, description
Multimeter
No drive circuit, description
Operator's platform, lowering
Operator's platform, raising
Positional adapters
Pump engine coupling, description
Push lock fittings
Rapid assembly fittings
Rear demolition guard, description
Relays
Reverse drive, description
Road lights, description
Rubber track, description1
Rubber track, description2
Self level valve, description
Service position 1
Service position 1-1
Service position 2
Throttle control
Transmission motor, description
Valves, checking and adjusting
White noise reverse alarm, description
Work lights, description
Diagrams MCT125C
Component list, Fuses1
Component list, Fuses2
Component list, Lights1
Component list, Lights2
Component list, Relays1
Component list, Relays2
Component list, Sensors1
Component list, Sensors2
Hydraulic diagram 2
Wiring diagram 1-1
Wiring diagram 1-2
Wiring diagram 2-1
Wiring diagram 2-2
Wiring diagram 3-1
Wiring diagram 3-2
Wiring diagram 4-1
Wiring diagram 4-2
Wiring diagram 5-1
Wiring diagram 5-2
Wiring diagram 6-1
Wiring diagram 6-2
Wiring diagram 7-1
Wiring diagram 7-2
Wiring diagram 8-1
Wiring diagram 8-2
Wiring diagram 9-1
Wiring diagram 9-2
Wiring diagram 10-1
Wiring diagram 10-2
Wiring diagram 11-1
Wiring diagram 11-2
Wiring diagram 12
Wiring diagram 14
Installation Instruction MCT125C
Air conditioning kit, installing new1
Air pre-cleaner, installing new
Attachment bracket, installation1
Auxiliary hydraulic option, installing new1
Cab, installing1
Foot throttle control kit, installing new1
Road lights kit, right hand dip, installing new1
Smooth ride system kit, installing new1
Repair MCT125C
Air cleaner dust valve, changing
Air conditioning filters, changing
Alternator removing, inspecting and installing
Alternator, disassembling and assembling
Alternator, installing
Alternator, removing
Auxiliary hydraulic pressure, releasing
Axle hub, installing
Axle hub, removing
Battery isolator
Battery maintenance
Battery, maintenance
Boom suspension system accumulator, charging and discharging
Boom suspension system valve, replacing
Cab door, installing1
Cab door, installing2
Cab door, removing1
Cab door, removing2
Cleaning of the machine
Closed crankcase ventilation filter, cleaning
Combination valve, replacing
Combination valve, replacing1
Control lever, installing
Control lever, removing
Coolant level, checking
Coolant, changing1
Coolant, changing2
Cylinder, disassembling and assembling
Cylinder, sealing
Door handle, replacing1
Door handle, replacing2
Drive chain case oil level, checking
Drive chain case oil, changing
Drive chain, installing
Drive chain, removing
Drive motor, disassembling and assembling
Drive motor, installing
Drive motor, removing
Drive motor, replacing
Drive pulley, replacing
Drive sprocket, installing
Drive sprocket, installing1
Drive sprocket, removing
Drive sprocket, removing1
Engine hour meter, replacing
Engine oil filter, replacing1
Engine oil filter, replacing2
Engine oil level, checking
Engine oil, changing1
Engine oil, changing2
Flushing valve, disassembly and assembly
Front casing, disassembling and assembling
Front end accessory drive (FEAD) belt condition, checking1
Front end accessory drive (FEAD) belt condition, checking2
Front idler wheel, installing
Front idler wheel, installing1
Front idler wheel, removing
Front idler wheel, removing1
Fuel water separator, changing
Fuel water separator, draining1
Fuel water separator, draining2
Gear pump, disassembling and assembling
Gear pump, installing
Gear pump, removing
Gear pump, replacing
Greasing, 50 hours
Greasing, 500 hours1
Greasing, 500 hours2
Greasing, daily1
Greasing, daily2
Guide roller, installing
Guide roller, installing1
Guide roller, removing
Guide roller, removing1
Hydraulic fan motor, replacing
Hydraulic oil level, checking
Hydraulic oil tank, draining1
Hydraulic oil tank, draining2
Hydraulic oil tank, filling1
Hydraulic oil tank, filling2
Hydraulic oil tank, replacing1
Hydraulic oil tank, replacing2
Hydraulic oil, changing1
Hydraulic oil, changing2
Hydraulic pressure, testing
Hydraulic system, bleeding
Jump starting
Load sensing valve block, replacing
Loader arm lift cylinder, radial lift, replacing
Loader arm lift cylinder, vertical lift, replacing
Loader arm lift ram, installing
Loader arm lift ram, removing
Loader arm, installing
Loader arm, removing
Loader arm, replacing
Main valve block, replacing
Main valve, replacing
Maintenance service, every 500 hours1
Maintenance service, every 1000 hours1
Park brake, disassembling and assembling
Positional type hydraulic adapters, fitting
Primary fuel filter, changing
Quickhitch tilt cylinder, radial lift, replacing
Quickhitch tilt cylinder, vertical lift, replacing
Radiator and coolers, cleaning1
Radiator and coolers, cleaning2
Rear casing, disassembling and assembling
Rear door, installing
Rear door, removing
Rear idler wheel, installing
Rear idler wheel, installing1
Rear idler wheel, removing
Rear idler wheel, removing1
Recoil unit, installing
Recoil unit, removing
Return line filter (high flow), replacing
Return line filter, replacing
ROPS FOPS structure, check
Rubber track, inspecting
Rubber track, installing
Rubber track, installing1
Rubber track, removing
Rubber track, removing1
Rubber track, repairing
Self level valve, replacing
Self levelling valve, replacing
Starter motor removing, inspecting and installing
Starter motor, disassembling and assembling
Stop pad, adjusting
Stop pad, adjusting1
Throttle actuator, replacing
Track frame, installing
Track frame, installing1
Track frame, removing
Track frame, removing1
Track tension, checking1
Track tension, checking2
Transmission pump start-up procedure
Transmission pump, adjusting
Transmission pump, adjusting1
Transmission pump, disassembling and assembling
Transmission pump, installing
Transmission pump, removing
Transmission pump, replacing
Two speed spool, disassembling and assembling
Valves, adjusting1
Voltage regulator and brushes, replacing
Wheel hub assembly, disassembling and assembling
Wheel hub assembly, replacing
Window pane, installation
Window pane, installing
Window pane, removal
Window pane, removing
Safety MCT125C
A few simple safety rules
Before operating
Before service, read
Charging batteries
Cleanliness
Environment
Service position
Service Bulletins MCT125C
Alternator terminal labeling and location change
Automatic Belt Tensioner Improvement
Boom drift
Bucket, not level
C Series Line Bore Procedure
Cab door leak
Cab gas strut configuration
Cold Weather Flushing Valve
Drive motor leaks
ECU trouble shooting
EGR fault code diagnostics procedures
Engine Compartment Inspection1
Engine Compartment Inspection2
Engine Fuel Filter Change
Engine oil pressure test
High pressure fuel pipe bracket installation (mechanical injection)
Hydraulic pipes improvement
Improved Cab Door Sealing
Improved ignition switch
Improved lap bar
Improved top glass skylight seal
Inspection form for engine failure or suspected failure
Intermittent or complete loss of throttle response
Large Platform Pre-cleaner Kit
Large Platform Rear Door Grill Kit
Large platform Tier 4 Stage IIIB loader and transmission setup
Left Hand Armrest Rotation
Loader Arm Shimming
Manual Flushing Valve Procedure Instructions
New generation of skidsteer and compact track loaders
New Skid Steer Loader models
Oil change procedure
Optional precleaner available
Poor window adhesive
Precautionary engine oil pressure cranking test
Rapid Assembly Hoses
Software Distribution Procedure
Top Window Leak
Water Temperature Sensor Failure
Window cracks and or breaks
Special Tools, Misc MCT125C
G700B Labour Time Guide Foreword.pdf
Foreword, Labour Time Guide
The standard times are issued for the purpose of:
The following is not included in the listed times:
Recommendations special tools
RM Compaction ABG Time Guide Old
Foreword
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Compaction Time guide old version
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Paving Systems ABG Time Guide Old
Foreword
Screeds
Hydraulics
Structural
Drive system
Electrical
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Specifications MCT125C
Alternator, specifications
Battery, specification
Boom suspension system (BSS) valve block, specifications1
Charge pump, specifications
Charge pump, specifications1
Charge pump, specifications2
Engine, specification1
Engine, specification2
Fuel, specifications
Gear pump, specifications
Hydraulic connections, tightening torques1
Hydraulic connections, tightening torques2
Load sensing valve block, specifications
Loader pump, specifications
Loader pump, specifications1
Loader pump, specifications2
Main valve, specifications
Main valve, specifications1
Quick release couplings
Radio, specifications
Radio, specifications1
Radio, specifications2
Self level valve, specifications
Self levelling valve, specifications1
Servo cut off manifold, specifications
Servo cut off manifold, specifications1
Servo cut off manifold, specifications2
Starter motor, specifications
Thread locking compound, application specifications1
Thread locking compound, application specifications2
Tightening torque, specifications1
Tightening torque, specifications2
Transmission pump, specifications1
Transmission pump, specifications2
  • Volvo Compact Track Loader MCT125C Service and Repair Manual.txt
