Volkswagen Jetta USA 1W2 Workshop Manual 1992-1998
Region: USA
Brand: Volkswagen
Number of Pages: 701 Pages
Type of Manual: Workshop Manual
Model: 1992-1998 Volkswagen Jetta USA 1W2 Automotive
0 3 bar oil pressure switch (4-cylinder engine) [vw a3 cl F22 1]
0 3 bar oil pressure switch (VR6 engine) [vw a3 cl F22 2](1)
4-pin connector for Heated Oxygen Sensor (HO2S) 2 -G108- (4-cylinder engine) [vw a3 cl T4 2]
4-pin connector for Heated Oxygen Sensor (HO2S) 2 -G108- (VR6 engine) [vw a3 cl T4 4]
4-pin connector for Heated Oxygen Sensor (HO2S) 2 -G108- [vw a3 cl T4]
4-pin connector for Heated Oxygen Sensor (HO2S) -G39- (4-cylinder engine) [vw a3 cl T4 1]
4-pin connector for Heated Oxygen Sensor (HO2S) -G39- (VR6 engine) [vw a3 cl T4 3]
19-pin connector for headlight harness [vw a3 cl T19]
21-pin connector for left-rear door harness [vw a3 cl T21]
21-pin connector for right-rear door harness [vw a3 cl T21a]
32-pin connector for left-front door harness [vw a3 cl T32]
32-pin connector for right-front door harness [vw a3 cl T32a]
42-pin connector for engine harness [vw a3 cl T42]
A C cut-out thermal switch (4-cylinder engine) [vw a3 cl F163 1]
A C cut-out thermal switch (VR6 engine) [vw a3 cl F163 2]
A C cut-out thermal switch [vw a3 cl F22]
A C cut-out thermal switch [vw a3 cl F163]
A C pressure switch [vw a3 cl F129]
ABS control module [vw a3 cl J104]
ABS hydraulic pump [vw a3 cl V64]
Airbag control module [vw a3 cl J234]
Alarm horn [vw a3 cl H8]
Alarm system control module [vw a3 cl J284]
Ambient temperature switch [vw a3 cl F38]
Anti-theft Immobilizer Control Module (Cabrio) [vw a3 cl J362]
Back-up light switch (manual transmission 02A) [vw a3 cl F4 2]
Back-up light switch (manual transmission 020) [vw a3 cl F4 1]
Back-up light switch [vw a3 cl F4]
Body Repair Body Collision Repair
Brake fluid level warning switch [vw a3 cl F34]
Brake light switch [vw a3 cl F]
Brake vacuum vent valve switch (cruise control) [vw a3 cl F47]
Central locking system pump and control module (Golf GTI Cabrio) [vw a3 cl V69 1]
Central locking system pump and control module (Jetta) [vw a3 cl V69 2]
Central locking system pump and control module [vw a3 cl V69]
Clutch Pedal Position (CPP) switch [vw a3 cl F194]
Clutch vacuum vent valve switch (cruise control) [vw a3 cl F36]
Connections and plugs on fuse relay panel [vw a3 cl 1 fac 3]
Connector Station [vw a3 cl TV]
Convertible top control module [vw a3 cl J256]
Coolant Fan Control (FC) control module (4-cylinder engine) [vw a3 cl J293 1]
Coolant Fan Control (FC) control module [vw a3 cl J293]
Coolant Fan Control (FC) thermal switch [vw a3 cl F18]
Coolant fan first speed and A C clutch fuse (4-cylinder engine) [vw a3 cl S108 1]
Coolant fan first speed and A C clutch fuse (VR6 engine) [vw a3 cl S108 2]
Coolant fan first speed and A C clutch fuse [vw a3 cl S108]
Coolant fan second and third speed fuse (4-cylinder engine) [vw a3 cl S107 1]
Coolant fan second and third speed fuse (VR6 engine) [vw a3 cl S107 2]
Coolant fan second and third speed fuse [vw a3 cl S107]
Coolant pump [vw a3 cl V50]
Cruise control control module [vw a3 cl J213]
Door contact switch - driver s side [vw a3 cl F2]
Door contact switch - passenger side [vw a3 cl F3]
Driver s heated seat control module [vw a3 cl J131]
Engine Coolant Temperature (ECT) sensor (4-cylinder engine) [vw a3 cl G62 1]
Engine Coolant Temperature (ECT) sensor (VR6 engine) [vw a3 cl G62 2]
Engine Coolant Temperature (ECT) sensor [vw a3 cl G62]
Engine oil temperature sensor [vw a3 cl G8]
Evaporative Emission (EVAP) canister purge regulator valve (4-cylinder engine) [vw a3 cl N80 1]
Evaporative Emission (EVAP) canister purge regulator valve (VR6 engine) [vw a3 cl N80 2]
Evaporative Emission (EVAP) canister purge regulator valve [vw a3 cl N80]
Fresh air blower [vw a3 cl V2]
Fresh air blower series resistance with fuse [vw a3 cl N24]
Fresh air recirculating flap two-way valve [vw a3 cl N63]
Ground connection [vw a3 cl 1 48]
Ground connection Cabrio from 1999 [vw a3 cl 1 1]
Ground connection Cabrio from 1999 [vw a3 cl 1 2]
Ground connection Cabrio from 1999 [vw a3 cl 1 15]
Ground connection Cabrio from 1999 [vw a3 cl 1 18]
Ground connection Cabrio from 1999 [vw a3 cl 1 30]
Ground connection Cabrio from 1999 [vw a3 cl 1 39]
Ground connection Cabrio from 1999 [vw a3 cl 1 43]
Ground connection Cabrio from 1999 [vw a3 cl 1 44]
Ground connection Cabrio from 1999 [vw a3 cl 1 50]
Ground connection Cabrio from 1999 [vw a3 cl 1 51]
Ground connection Cabrio from 1999 left B-pillar [vw a3 cl 1 48 1]
Ground connection Cabrio from 1999 right B-pillar [vw a3 cl 1 48 2]
Hood alarm switch [vw a3 cl F120]
Ignition coil (4-cylinder engine) [vw a3 cl N152 1]
Ignition coil (VR6 engine) [vw a3 cl N152 2]
Ignition coil [vw a3 cl N152]
Ignition coil power output stage [vw a3 cl N157]
Intake Air Temperature (IAT) sensor [vw a3 cl G72]
Knock Sensor (KS) 1 (VR6 engine) [vw a3 cl G61 2]
Knock Sensor (KS) 1 [vw a3 cl G61]
Knock Sensor (KS) 2 [vw a3 cl G66]
Leak detection pump [vw a3 cl V144]
Left front power window control module [vw a3 cl J295]
Left rear door contact switch [vw a3 cl F10]
Left rear power window control module [vw a3 cl J297]
Luggage compartment light switch [vw a3 cl F5]
Luggage compartment release solenoid [vw a3 cl N188]
Manual Transmission
Mass Air Flow (MAF) sensor (4-cylinder engine) [vw a3 cl G70 1]
Mass Air Flow (MAF) sensor (VR6 engine) [vw a3 cl G70 2](1)
Mass Air Flow (MAF) sensor [vw a3 cl G70]
Motronic Engine Control Module (ECM) [vw a3 cl J220]
Multi-function Transmission Range (TR) switch [vw a3 cl F125]
Oil pressure switch (4-cylinder engine) [vw a3 cl F1 1]
Oil pressure switch (VR6 engine) [vw a3 cl F1 2]
Oil pressure switch [vw a3 cl F1]
Passenger s door central locking system switch [vw a3 cl F114]
Passenger s heated seat control module [vw a3 cl J132]
Positive Crankcase Ventilation (PCV) heating element [vw a3 cl N79]
Power sunroof control module [vw a3 cl J245]
Power window circuit breaker [vw a3 cl S43]
Relay locations on fuse relay panel [vw a3 cl 1 fac 1]
Right front power window control module [vw a3 cl J296]
Right rear door contact switch [vw a3 cl F11]
Right rear power window control module [vw a3 cl J298]
Secondary Air Injection (AIR) pump motor [vw a3 cl V101]
Secondary Air Injection (AIR) pump relay (4-cylinder engine) [vw a3 cl J299 1]
Secondary Air Injection (AIR) pump relay (VR6 engine) [vw a3 cl J299 2]
Secondary Air Injection (AIR) pump relay [vw a3 cl J299]
Secondary Air Injection (AIR) solenoid valve [vw a3 cl N112]
Shift lock solenoid (Automatic Transmission) [vw a3 cl N110]
Third speed coolant Fan Control (FC) thermal switch (VR6 engine) [vw a3 cl F165]
Throttle valve control module (4-cylinder engine) [vw a3 cl J338 1]
Throttle valve control module (VR6 engine) [vw a3 cl J338 2]
Throttle valve control module [vw a3 cl J338]
Transmission fluid temperature sensor [vw a3 cl G93]
Trunk lid alarm switch [vw a3 cl F123]
Vehicle Speed Sensor (VSS) [vw a3 cl G68]
Windshield and rear window washer pump [vw a3 cl V59]
