Volkswagen ID.4-ID.5 EWD Electric Wiring Diagram 2020
Date: 2020
Type of Document: Electric Wiring Diagram
Model: Volkswagen ID.4-ID.5 EWD
Brand: Volkswagen
001 Electric drive system motor control unit EBJA EBRA
002 Electric drive system for rear axle EBJA
003 High-voltage battery system J9D
004 Pilot line for high-voltage system
005 High-voltage battery charging ES6
006 High-voltage battery charging ES7
007 Thermal management 9M0
008 Thermal management 9M3
009 Auxiliary air heater PTC 7E7
010 High-voltage heater PTC for high-voltage battery system J9D
011 Fuses in engine compartment
012 Fuses in interior
013 Earthing concept in engine compartment
014 Earthing concept in interior
015 Earthing concept in luggage compartment
016 Earthing concept on underbody
017 Radiator fan
018 Brake system
019 Airbag systems 4UF
020 Airbag systems 4UM
021 Door control units driver side L0L
022 Door control units passenger side L0L
023 Door control units driver side L0R
024 Door control units passenger side L0R
025 Anti-theft alarm system 7AL
026 USB charging sockets U9B U9C
027 Sunroof roller blind 3FG
028 Interior lights
029 Trailer coupling 1M6
030 Trailer coupling 1D6
031 Adaptive cruise control 8T8
032 High-voltage battery charging ES5
033 Air conditioning system KC0
034 Air conditioning system KH4 KH7
035 Horn
036 Parking aid PDC 7X2
037 Electromechanical steering
038 Front camera for driver assist systems
039 Reversing camera Rear Assist KA2
040 Overhead view camera KA6
041 Head-up display KS3
042 Entry and start authorisation 4I6 4I7 4I8 4K5 4K6 4K7
043 Interior mirror 4L6
044 Communication GW2
045 Fans for control units
046 Dash panel insert
047 Steering column electronics
048 Multifunction steering wheel
049 Window wash-wipe system
050 Headlights 8IR 8IV
051 Headlights 8IX
052 Tail light clusters 8VG
053 Tail light clusters 8VP
054 Light switch
055 Assist systems 7Y1
056 Communication NZ2 NZ4
057 Engine sound generator
058 Seat heating 4A3
059 Adjustable seat L0L 1R3 3PR 8I6
060 Adjustable seat L0R 1R3 8I6
061 Toll detection system
062 Overhead view camera KA6
063 Windscreen heater 4GW
064 Heated rear window
065 Rear lid remote release
066 Electrically operated rear lid 5I6
067 Bonnet contact switch
068 Special equipment rental vehicle 2F2
069 12 V sockets
070 Multimedia system 7UT
071 Sound system 9VG 9VH
072 Mobile telephone systems 9IJ 9ZV
073 Adaptive chassis control DCC 2I0
074 Data bus diagnostic interface and diagnostic connector
075 Data bus network for powertrain CAN bus
076 Data bus network for infotainment CAN bus
077 Data bus network for high-voltage system CAN bus
078 Data bus network for running gear CAN bus
079 Data bus network for convenience CAN bus
080 Data bus network for driver information system CAN bus
081 Data bus network for ethernet
082 Data bus network for communication CAN bus
083 Data bus network for driver assist systems CAN bus
084 Background lighting UD1 UD2 UD3
085 Adjustable seat 3PT
086 Electric drive system for front axle EBRA
087 High-voltage battery system J9B
801 Fitting locations Earth points 3
802 Fitting locations Fuses 3
803 Fitting locations Relays 3
804 Fitting locations front part of vehicle 3
805 Fitting locations middle part of vehicle 3
806 Fitting locations rear part of vehicle 3
807 Fitting locations vehicle underbody 3
808 Fitting locations special vehicles 2
830 Connector views parts with prefix A to D 3
