Toyota Yaris & Yaris HV 2020-2021 Service and Repair Manual
Model Code:
Region: Europe, Australia
Model: Toyota Yaris, Yaris HV
Date:
Engine: 1KR-FE, M15A-FKS, M15A-FXE, G16E-GTS
Format: HTML
INTRODUCTION
SETUP
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
M15A-FKS (ENGINE CONTROL)
M15A-FXE (ENGINE CONTROL)
G16E-GTS (ENGINE CONTROL)
1KR-FE (ENGINE CONTROL)
HYBRID / BATTERY CONTROL
M15A-FKS (ENGINE MECHANICAL)
M15A-FXE (ENGINE MECHANICAL)
G16E-GTS (ENGINE MECHANICAL)
1KR-FE (ENGINE MECHANICAL)
M15A-FKS (FUEL)
M15A-FXE (FUEL)
G16E-GTS (FUEL)
1KR-FE (FUEL)
M15A-FKS (EMISSION CONTROL)
M15A-FXE (EMISSION CONTROL)
G16E-GTS (EMISSION CONTROL)
1KR-FE (EMISSION CONTROL)
M15A-FKS (INTAKE / EXHAUST)
M15A-FXE (INTAKE / EXHAUST)
G16E-GTS (INTAKE / EXHAUST)
1KR-FE (INTAKE / EXHAUST)
M15A-FKS (COOLING)
M15A-FXE (COOLING)
G16E-GTS (COOLING)
1KR-FE (COOLING)
M15A-FKS (LUBRICATION)
M15A-FXE (LUBRICATION)
G16E-GTS (LUBRICATION)
1KR-FE (LUBRICATION)
M15A-FKS (STARTING)
M15A-FXE (STARTING)
G16E-GTS (STARTING)
1KR-FE (STARTING)
STOP AND START
Drivetrain
P910 (HYBRID TRANSMISSION / TRANSAXLE)
CLUTCH
C551 (MANUAL TRANSMISSION / TRANSAXLE)
EC6E (MANUAL TRANSMISSION / TRANSAXLE)
EA67F (MANUAL TRANSMISSION / TRANSAXLE)
K320 (MULTIDRIVE / CVT)
GF1A (TRANSFER / 4WD / AWD)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE PRESSURE MONITORING
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
TELEMATICS
PARK ASSIST / MONITORING
Power Source / Network
M15A-FKS (BATTERY / CHARGING)
M15A-FXE (BATTERY / CHARGING)
G16E-GTS (BATTERY / CHARGING)
1KR-FE (BATTERY / CHARGING)
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
PRE-COLLISION
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
ACOUSTIC VEHICLE ALERTING SYSTEM
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
M15A-FKS (FUEL)
M15A-FXE (FUEL)
G16E-GTS (FUEL)
1KR-FE (FUEL)
M15A-FKS (COOLING)
M15A-FXE (COOLING)
G16E-GTS (COOLING)
1KR-FE (COOLING)
M15A-FKS (STARTING)
G16E-GTS (STARTING)
1KR-FE (STARTING)
STOP AND START
Drivetrain
CLUTCH
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
TELEMATICS
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS INTRODUCTION
WIRE HARNESS REPAIR GUIDELINES
TERMINAL AND CONNECTOR REPAIR PROCEDURES
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
ADAS / AD
Location & Routing
Engine Compartment
Instrument Panel
Body
Seat
Antenna
Fuse List
Engine Compartment
Instrument Panel
Body
Connector List
Engine Compartment
Instrument Panel
Body
Seat
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
ADAS / AD
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
